Cold Electricity how to
Re: Cold Electricity how to
« Reply #275, on February 21st, 2015, 12:46 PM »
Quote from Breakzeitgeist on February 21st, 2015, 11:19 AM
That video is to me varification of Tetryonics and if Your ready all the info needed for electrogravitics which is covered in tetryonics
as a challenge to this forum i offer u a chance to make a prediction of the mars skull pyramid. it will stand to reason its location on mars is no coincidence,
what u have is the key piece of information.is  its lat, and long. located in at least 3 frames of the actual location of the pyramid. what is on earth in this position?
i think there must be a correlation on mars and earth. if u do it then you have your proof.
https://www.youtube.com/watch?v=z3Zc5dQ5ye4#
Tetryonics
« Reply #277, on March 4th, 2015, 02:36 PM »Last edited on March 4th, 2015, 02:38 PM
The Richard C. Hoagland thing is pretty cool verification of a greater Tetrahedral principle at work, applied to the macro level, but the video completely fails to recognize a correspondent application at the micro level ( unless I just happened to miss that ). So if Cydonia on Mars is pointing us to the inscribed Tetrahedral geometry, then I find this to be a verification but in a slightly different way than I would expect. Interesting correlations, and much to consider moving forward. I find it hard to believe that the Richard Hoagland video was presented in 1992 with research going back into the 70's. It almost feels like the human mind is wired in some way as to not recognize the Equilateral Triangular nature of energy in our universe...
I guess we have a new meaning to "as above so below",  or "what goes up must come down"...
I suppose the principle of correspondence works to some degree because everything is comprised of these Triangular relations, and when you realize that the Golden Ratio and Phi relations are inherent within the geometry of energy, and the photonic geometry itself, well...things start coming into focus.
http://tetryonictheory.com/the-golden-number
The Atom of Matter is comprised of a Tetryon/Tetrahedral Topology. All the energy content of a single Tetryon is contained in the 4 faces, and there is absolutely no energy inside that topology. The 3D volume of enclosed space creates a region of null energy density-pressure and this is the quantum gravity so many are searching for.
These Tetrahedral Matter Topologies are Lorentz invariant, in that once the Matter Topology has formed, it contains a specific mass. Motion of the Electron, for instance, does NOT increase the mass in the charged fascia of the Matter topology. Rather it's the secondary KEM field ( which ONLY applies to Matter in Motion ) that is responsible for the relativistic increase we observe when Matter is put to motion.
Einstein's Error of Perception
http://screencast.com/t/xx2E8xH7
"Today we have a situation where, the theory does not explain the facts; the facts explain the theory.
Whatever the standing of the relativity theory as a whole may be, if and when it conflicts with a physical fact it is, to that extent, wrong. No scientist can deny this if he faces the issue squarely. But to acknowledge such errors would involve conceding that there are serious deficiencies in the conventional structure of theory, and this, the scientific community is currently unwilling to do." - Tetryonics
"The argument amounts to nothing more than the convenient supposition that something which has not been observed does not exist. It predicates that we know everything."  - Fred Hoyle
"We all began to see that the nineteenth century physicists had taken themselves a little too seriously, that we had not come quite as near sounding the depths of the universe, even in the matter of fundamental physical principles, as we thought we had." -- Millikan
"The equilateral geometry itself gives rise to the physical properties of charge, electrical permittivity, magnetic permeability and the rigid physical relationships between inertial mass-energy and moment in physical systems at the quantum level. Tetryonics is the ONLY theory capable of firstly distinguishing between 2D mass-energies and 3D Matter and, in turn accurately defining all physical aspects of any 1KG mass of Matter, irrespective of its isotopic composition and physical state." - Tetryonics
Reality is what everyone is keen to know about. No one wants to be deceived; all are eager for trustworthy information, if it be forthcoming, about both the material and the spiritual worlds, which together seem to constitute the Universe." -- Sir Oliver Lodge
Breakzeitgeist
« Reply #279, on March 5th, 2015, 11:40 AM »
Ok everyone time to shake off the dust and get busy we all got work to do.
« Reply #280, on March 5th, 2015, 12:25 PM »
I thought for sure we wandered down this road already.  If you put glass between the plates, the glass becomes the capacitor's dielectric instead of the water.  Is there something else we are missing?
« Reply #281, on March 5th, 2015, 03:03 PM »
Quote from Matt Watts on March 5th, 2015, 12:25 PM
Doctor TT brown states the effects are greater with more dielectric material.    Try adding fine mica powder to water, if it is solubal you may be able to increase the dilectric of water?
searching for information on increasing the dielectric of water.i found this first so here it is..
Water is the most abundant compound on the surface of the Earth, and can be considered to be the most important molecule in living systems. Water plays a variety of cellular functions, being the solvent of most biological molecules, a substrate and product of enzymatic catalysis, an important component of macromolecules, and more. Because of importance of water in life, many physical and chemical treatments were invented to improve the quality of drinking water. Among them, the treatment with electromagnetic field is a well-known, but much debatable physical method. Although electromagnetic field has been utilized for treating water for 80 years, many reports on beneficial biological effect of electromagnetic field-treated water were either anecdotal or less convincing. To explore if there is any physical base for understanding possible biological effects of electromagnetic field-treated water, dielectric relaxation spectra of deionized water treated with an extremely low frequency electromagnetic (ELFEM) field were measured and compared with that of untreated water.
It was surprisingly found that the dielectric constant of the ELFEM field-treated water was 3.7% higher than the control over the frequency range of 1-10 GHz, which indicates a higher molecular polarization occurs in the ELFEM field-treated water. Electrostatic and thermodynamic analysis shows that proteins or other biomacromolecules would have more reduced free energy when they are hydrated in high dielectric constant water. Since free energy is of crucial importance for stability of proteins, protein folding and its conformational change, as well as catalytic activity of enzymes, the free energy reduction of the biomacromolecules hydrated with higher dielectric constant water may be responsible for many possible biological effects of electromagnetic field treated water.
« Reply #282, on March 5th, 2015, 03:18 PM »
I don't think anyone should call things the "key" to anything until that system is in full operation using the "key".
I.E. A Stan Meyer cell fully powers a car down the road.
Breakzeitgeist
« Reply #283, on March 5th, 2015, 03:26 PM »
Well I'm almost done with the replication and I insulated a few cells with different things. Test do our nest and forget the rest. It could very well be but we have to do the work to know for sure.
Breakzeitgeist
« Reply #285, on May 19th, 2015, 07:46 PM »
gravity is a convergent force and in the weeks to come I'm going to be explaining some things I have come to understand about nature and the universe. Seems we are still living in flat land with x,y,z coordinates systems and parallel and perpendicular views. Notions of up down left right are flat land perspectives. There's only in, out, and around. So I'm just going to try to share my experience with you all and introduce my new teachers to anyone who might be reading this. It all holds a promise to shine new light on the integrity of our 100% efficient eternal regenerative universe. ....thanks
Breakzeitgeist
« Reply #287, on November 18th, 2016, 09:28 PM »
Wow I been reading all day trying to catch up on what you all been doing. I got locked up police came and knocked down my door my lab was looted I lost so much everything basically went up in smoke but I'm humbled by the experience and now with so little to work with i have had to learn how to do more with less. I'm back now I really don't want to medle to much in the details. It is tragic but I'm leaving it we're  it is now in the past. I'm present and accounted for and ready to get back to work. No fate but what we make
« Reply #288, on November 18th, 2016, 10:37 PM »
Quote from Breakzeitgeist on November 18th, 2016, 09:28 PM
welcome back,
wow, that's really a mess, i was talking to a friend who seen some of your videos today, i hope there is no hard feelings between us and i'm really glad to see you back.
he was asking about that patent by Tesla that had the water cells in it.
do you remember any info on that?
I'm glad to see you humble about what happen, that is a real mess, i thought that was not happening to much any more but i guess it still dose.
blessings your way!!!
Diadon
« Reply #289, on November 18th, 2016, 11:09 PM »
I was wondering why I hadn't seen a video from you in a while. That is a most unfortunate turn of events and I hope its all sorted out. Look forward to see what you are working on and glad to see you back and manifesting your destiny in a way that makes you happy. Much love brother from another mother.
-Diadon
Breakzeitgeist
« Reply #290, on November 19th, 2016, 04:02 AM »
Russ that drawing your refering to was not fuel cells at all but rather a drawing or a circuit useful for wireless experments Tesla used it in his studio had the wire running all the way round his laboratory but it got mixed in with water fuel tech lol
Breakzeitgeist
« Reply #291, on November 19th, 2016, 04:14 AM »
Dos anyone here have a computer desktop,laptop, dinosaurs welcome that they will sell or trade. It will be a while if ever before I get mine back.
« Reply #292, on November 19th, 2016, 05:05 PM »
Oh that makes sense. Lol.
Well here's to better future.
 :thumbsup:
haxar
« Reply #293, on November 19th, 2016, 05:31 PM »
Police, or policy enforcers, are known to stomp on your rights. Just don't say anything and do not give consent, especially to search and seizure. Your guaranteed 4th amendment right was violated, if you're in U.S. jurisdiction.
