Cold Electricity how to
Breakzeitgeist
Re: Cold Electricity how to
« Reply #225, on August 28th, 2014, 12:36 PM »
My apoligies guys been worrking round the clock and have wonderful news. im making a video to help illistrate my thoughts. The answers are coming. so stan did get use tesla tech. I beleave i know the answers to why no one has produced a working EPG. promise all most mysteries will soon be unlocked ounce and for all. My advice though wojld be to start learning about static electricity. Teslas teleforce....its not a death beam lol like has been thought. its an epg and its disguised as a weapon that can end all war just depends on how you take what tesla says. he knew what he was doing. read vandegraphs book and start building holtz. van...whimhurst..ect the static is wherer its at.also i would like everyone to have a look inside your home fire alarm. its got a goody in side do youre research on what that radioactive. substance
Breakzeitgeist
« Reply #226, on August 28th, 2014, 12:41 PM »
Is and what it dose and also keep in mind a simple static machine can put out 100reds of thousannds of volts at micro amps.....stan said voltage was a STATIC condition:-)anyways thtat will get u started....
« Reply #227, on August 28th, 2014, 12:57 PM »
Looking foreward to your results from Tesla's research Breakzeitgeist.
Breakzeitgeist
« Reply #228, on August 28th, 2014, 01:14 PM »
So i.  think the epg is wound with iron wirecopper coating on outside or mig wire....think about PMH
Breakzeitgeist
« Reply #229, on August 28th, 2014, 01:23 PM »
Have another look at stans epg and look at the wire were u can see whats benieth the coating
« Reply #230, on August 28th, 2014, 02:10 PM »
I would have to agree based on Steven Mark's TPU.
heatlocke
« Reply #233, on December 3rd, 2014, 10:38 AM »
Gerald needs to join our forum if he is not a member already.
Breakzeitgeist
« Reply #234, on December 7th, 2014, 03:31 AM »
I am in contact with Gerald and will be pointing him in our direction as you can see from his work he is adding to the understanding of the cold side of things
Breakzeitgeist
« Reply #235, on December 7th, 2014, 03:34 AM »
Thank you Matt for this what's amazing 3 others pointed me in his direction the same day
Enrg4life
« Reply #236, on December 7th, 2014, 06:26 AM »
There are some good points made in this video, however I know that an induction clamp on amp meter readings are affected greatly when subject to high frequency such as produced in two way radios. I am a master electrician in industry and I found this out because I wear a two way radio and when taking amp readings on motors I have keyed the radio to talk to other people and have seen the amp meter readings jump 10 fold while the micro phone is keyed. This is a simple test for those who have a clamp on amp meter and a two way radio.
    I'm thinking the high frequency being generated in this video experiment is generating the noise and giving the inaccurate readings on the clamp on amp meter. He has some good things going on here though just wanted other people to be aware of the clamp on amp meters and radio frequencies
Breakzeitgeist
« Reply #237, on December 7th, 2014, 06:06 PM »
Yea but what about the output lighting those loads and most important the temp. The idea of cold and hot radiation is something worth looking into and how about the in and out on the power supply from the mains. I'm duplicating his work and will report my findings
Breakzeitgeist
« Reply #238, on December 7th, 2014, 06:18 PM »
The set up is so easy why not give it a try I'm building a set up on the lathe to control distance of the spark gap. Also note how the energy is balanced enough to run trough that circuitry and we'll he is not hiding anything. I don't know but I want to see for my self it's the only way...lol I'm so tempted to go pull the part off my front loader right now
Enrg4life
« Reply #239, on December 7th, 2014, 06:50 PM »
I agree it it definatly worth trying. The voltage, temp, and frequency readings should be good. If you use an induction clamp on meter to check the amp draw, try running the wire longer so you can get the amp reading 8 to 10 feet away the generator and the high voltage transformer that should be far enough to get an accurate reading with being in the high frequency  zone that that rig is generating. Looking forward to hear what your results are. Thanks
Breakzeitgeist
« Reply #240, on December 7th, 2014, 07:17 PM »
My teacher say
K-EL ABRAHAM shared: Radiant EM waves of 2d mass-energy momenta are the foundation of Force, interaction-at-a-distance and fields of conscious thought.... Modern physics relies too heavily on modelling the motion of 3D
K-EL ABRAHAM
Shared publicly  -  Yesterday 6:09 PM
Modern physics relies too heavily on modelling the motion of 3D Matter at the expense of true understanding of the role of 2d mass in the Cosmos..
Tetryonics makes clear the role of each and their interplay in bringing about and explaining the physics of the Universe....
Read more
2014-12-06
10 photos
K-EL ABRAHAM's photos
Breakzeitgeist
« Reply #241, on December 7th, 2014, 07:20 PM »
If you don't know Kevin's work you should check it out.....it's really incredible
« Reply #243, on December 8th, 2014, 12:54 AM »
Quote from Breakzeitgeist on December 7th, 2014, 07:17 PM
My teacher say...
He is probably correct, but I'll give you something you can use straight away.
Hot/cold electricity has something to do with impedance.  Typical hot electricity seems to manifest itself when you have a low impedance source driving a high impedance load.  This is the kind of juice that will bite you hard if you touch it.  Cold electricity seems to manifest when you have the opposite.  If you have a high impedance source driving a load impedance load (like Gerard's setup), you can touch it and it just tingles.  I think because the load absorbs the majority of the electricity (amperage).
Voltage simply gives you an indication of the pressure differential.  It's the amperage that is the real energy mover.  That is the electricity.  When you have a high voltage condition, it is telling you there is a lot of amperage that is at point A and wants to go to point B, but it can't, the impedance is too high, too much restriction to get there.  Hence why some inductors are referred to as chokes, they choke off the passage way for amperage to flow.
Basic stuff I know, but if you keep it in the front of your mind when experimenting, things tend to make a lot more sense.
Breakzeitgeist
« Reply #246, on December 11th, 2014, 11:27 PM »
Ok guys this is interesting I'm about to upload a video of my replication. Well I'm waiting on the bulbs like Gerald has. Take notice of what he is using. He also points out in his other videos how we all are getting robbed by our current energy providers. His set up uses all the things you will find on the grid before it gets switched when fed trough the pole transformer and arrives at our junction box. You can use a clamp meter to see how many amps is being pulled and you can clamp the return line and see most of what comes in is going back out and we'll it's all a bit suspicious. My investigation continues. Now has anyone here ever took a pole transformer apart? Also the moter he is using can be found in just a
Bout any kind of water pump I'm driving mine with a small 12 v battery from my drill and it performs well took me 5 min to put together. I think we should all try to focus on this and repeat the results and see what all we can do with this. Fun and interesting
« Reply #247, on December 12th, 2014, 08:56 AM »
Dustin,
I'd like for you to look at something if you would.  This video has been marked as a hoax by some, but I'm not there yet.  I have looked at every single frame of this video and cannot find anything that clearly tells me to discount it.
https://www.youtube.com/watch?v=amHKKlnUVSw#ws
Something to look at very closely, the measurements taken on the ground wire.  At first he has his clamp meter on DC and it only shows 0.77 amps, but when he switches to AC the meter reads 7+ amps when the system is loaded and 5+ amps when just running idle.  What I'm getting at is this M/G is pumping electricity right out of the ground, just like Gerard said is possible.  The bigger and better the ground, the more juice it can pull beyond covering its own losses.  Somehow this system is able to recycle those "free electrons" and get them into usable electricity.
Anyway, just look at it and take the stance that it is for real.  See if you get any ideas we can work with.
Thanks much,
M@
Breakzeitgeist
« Reply #248, on December 12th, 2014, 09:33 AM »
I'm on it everyone needs to start looking at this. What do we all really know about the power before it transforms into house power. Go buy yourself a high pressure sodium bulb and start researching it the person or persons who developed it for world wide use is not known and the plot keeps thickining.
Breakzeitgeist
« Reply #249, on December 12th, 2014, 09:56 AM »
It's real anyone out there can do this you need battery and dc moter and a.c. moter what's more interesting is when the high pressure sodium bulb comes in to it with spark gap. I'm trying to get the video done but this is right and I'm starting to wonder about the nuke power stations and all that boiling water and what about walen I still think he was telling truth. Hell what if the power plants are there to absorb the excess power and the byproduct is....lol ok time to get back to work. Just saying though is it even plasible. For now this set up is working but there's a lot to think about and it would kind of make since of things that I can't make since of yet....anyways have fun
