Awesome, thanks for sharing, JP :D
« Reply #175, on November 28th, 2012, 01:18 PM »
Hy JP,
ok I understand.
So you think the alternator does have the same effect as the VIC? There must be some parallels I think to create the "effect" we are all searching for....
This black box only regulates the excitation http://en.wikipedia.org/wiki/Excitation_%28magnetic%29
Normally this must be a real good DC Source, not a rectified sine.
it regulates the electrical output power of the alternator.
The rectified sine make a pulsing signal from 0 to xx (depending on the variac). A pulsing signal tends to result to very high voltage peaks on the alternators output, but only in ideling without any load on the output.
But watch out, the adjusted voltage on the variac should not be too high, because the little coil (armature winding) for excitation normaly does have very low resistance values--> so the amps would grow up very high and can burn the coil.
The alternators advantage is, that it can be considered as heavy duty variac with three phases.
Amsy
Remember, to even begin the induction must match the capacitance.
I think my huge capacitor needs a big inductor, thus the alternator is acting as an inductor and restricting the amp flow and creating the pulse frequency.
If amps go down voltage goes up.
No one ever saw Stan run the big demo cell without the alternator.
He made his VIC's for the small resonant cavities and injectors.
They are very small and have the big 5 coil VIC inductors.
I'm looking at this thread for some ideas.
http://www.ionizationx.com/index.php?topic=1201.0
I hope we don't burn up my Variac....that would suck...
Cheers,
JP
Badger,Quote from Badger on November 13th, 2012, 10:19 AM I was planning on going the route of the Arduino PulseGen, but now I'm reconsidering. Bussi, that would be great if you could post some more info on the pulse generator you're using, I think I would like to give that a try. Wish they would email me back... I'm not even sure if they will to ship to US or not. Like you say, we need more experimenters posting data and results!
here you are
http://open-source-energy.org/?tid=469&pid=9806#pid9806
I have just finished my 2 very first videos at youtube. More to come ...
Hy JP,Quote from MeyerandMe on November 29th, 2012, 03:49 PM Remember, to even begin the induction must match the capacitance.
Cheers,
JP
thanks for your answer!
Did Meyer mentioned this to you about the matching of capacitance and inductance? Especially to which frequency? Of the alternator (rpms)? Of the excitation(120Hz)? :huh:
That is right with the current and voltage relaionship. So if you can put the current down the voltage will rise automatically!
I hope this helps.
It is all I have about how to get started.
This is what Tad Johnson used to make his first working circuit years ago.
I haven't heard from Tad in 10 years.
Cheers,
JP
So basically Tad Johnson here knows how to build a fully functioning Stanley MeyerQuote from MeyerandMe on November 30th, 2012, 01:25 PM I hope this helps.
Cheers,
JP
water fuel cell then?
Have you tried contacting him lately?
If you do manage to get in contact with him tell him that he's more than welcome
to the forum :D
''The MM74C132 has a smith trigger function
so you only need one resistor from output to
input and a capacitor from the same input to
the ground for making a good oscillator.''
the circuit is incomplete you have to feed the input somehow not just unite the output with input with a resistor,he says that he changes the freq,,,how? from what?
any electronics guy corect me if i am wrong..
Cheers,
JP
to the forum :D
Btw, I found a document detailing what Tad here had done to get his WFC up and running and it sure looks like it's working the way you describe how it should be
working JP, so for now I'll use this as a base for trying to replicate the good work.
Many thanks for the Tad Johnson/Ted Zettergren lead, much appreciated.
I made a small PDF of pages 28 & 29 of the document, which basically details what
Tad uses in his WFC.
Good info and find everyone,:D this looks like we can take it to the bank and to say the least , there are things we will not understand, that Stan and others proved worked, we just need to find it and have an open mind to new things. I have no doubt once we do find out the secret, we will say, oh that's how it works. Keep up the good work guy's, awesome.:cool::D:PQuote from Lynx on November 30th, 2012, 02:05 PM So basically Tad Johnson here knows how to build a fully functioning Stanley MeyerQuote from MeyerandMe on November 30th, 2012, 01:25 PM I hope this helps.
Cheers,
JP
to the forum :D
found it,but diffrent ic.4093 which does the same thing ,is the simplesc osc i ever seen,and you can make a gate within the same cip...very nice....Quote from adys15 on November 30th, 2012, 02:49 PM ''The MM74C132 has a smith trigger function
Jp, maybe you can ask your EE about that. I think it is the only way to put voltage on the WFC without flowing of amps, because the WFC nearly is an dead short condition because of the low resistance of natural water.
That is what has me so baffled is the WFC appears to be a dead short with any voltage over 2.0. Also, it makes it very difficult to find the capacitance. But supposedly with a properly designed cell, you can push in AC around 42.8kHz and everything changes. Then all of the sudden, voltages of 1200 are quite possible and the cell begins producing gas. But the question remains, for a particular cell at some temperature, do you need 42.81257 kHz where 42.81319 kHz no longer works? What kind of frequency tolerance is needed? I've never heard anyone explain that. This one factor alone bothers me because even with a perfect cell and VIC, you'll never see resonance because you will likely skip right over the exact frequency needed to make it work. Does anyone understand Stan's PLL circuit well enough to at least find the frequency lock range and step size it is capable of? Maybe this would give us a clue.Quote from Amsy on December 1st, 2012, 01:15 AM Jp, maybe you can ask your EE about that. I think it is the only way to put voltage on the WFC without flowing of amps, because the WFC nearly is an dead short condition because of the low resistance of natural water.
I suspect the tolerances of the electronics Stan had just couldn't keep the cell tuned and is why he switched his focus to the water spark plug. But today, we do have those kind of electronics; relatively cheap too. We just need to know what specs are needed. With all digital electronics we should be able to do away with LC tank circuits and drive the cell direct to the nearest Hertz or tenth of a Hertz if necessary. We can scan and lock simply by monitoring cell voltage or even gas production (via LED/opto sensors) if necessary. It's my opinion that if coils and chokes are necessary, something else is going on and simple resonant high voltage is not all there is to it. I mean, how hard would it be to connect an ultrasonic high voltage amplifier to a precision signal generator? If that's all it takes, wouldn't lots of people cracked water by now?
Too much pretzel logic. Someone surely understands how this thing works and can explain it. With that knowledge, then we can pick out the most cost effective and straightforward way to energize a WFC and have it work, repeatably.
If you wire a VIC bifilar so that positive and negative paths are bifilar connected there is a stray capacitance between positive and negative path. that way the serial LC switches to a parallel LC circuit :-). and it mutates into a pulse forming network (PFN).
there should be some way to simulate that behaviour but up to now I didn´t get Spice so simulate anything that can be observed in an experiment with VIC and WFC :-(
How about trying to build it in real life and see how it acts on an oscilloscope?Quote from bussi04 on December 2nd, 2012, 03:33 AM If you wire a VIC bifilar so that positive and negative paths are bifilar connected there is a stray capacitance between positive and negative path. that way the serial LC switches to a parallel LC circuit :-). and it mutates into a pulse forming network (PFN).
If what Meyer discovered isn't in any textbook then I seriously doubt that it's
in a computer software. :cool:
JP, I made a PDF of the images you posted on the Ionization forum, but I couldn't upload it there for some reason, maybe it was
too a big an attachment?
I'll upload it here instead.
Well ok, good.Quote from Lynx on December 2nd, 2012, 02:23 PM JP, I made a PDF of the images you posted on the Ionization forum, but I couldn't upload it there for some reason, maybe it was
I actually posted the articles in this or in Stephen Meyer thread link in my first post in this thread.
Nice to have them as one file but you should tell folks what they are.
One is a four page paper presented by Gary Johnson, IEEE called Electrically Induced Explosions in Water.
The second is a paper about Tesla, Moray, and Bearden.
My EE said that to him this is the most important information as to repeating Stan's work.
Cheers,
JP
Ok, let's answer that with numbers.Quote from gpssonar on November 27th, 2012, 05:27 PM That is a great looking piece of work. As far as the slots for tunning, those slot are there not realy for tunning, they are cut to match the surface area of the inner tube. Alot of people think they are there for sound or ringing. Each choke has to have the same Cap. and Res. when hook to the cell, in order for it to be the same you have to match the surface area of the inner and outer tubes.
Hope this helps everyone,
gpssonar
We can calculate the inner and outer surface areas here:
http://www.onlineconversion.com/object_surfacearea_tube.htm
My tube dimensions are .5 in inner tube O.D. and .625 in. outer tube I.D for matching surfaces.
The tube's matching surface areas are about 17.5 inches.
The actual length is 18 inches.
The small tube r is .1875.
The small tube R is .250
Length 18
That Small tube OD surface area is 28.27 sq/in.
My large tube OD is .75 in.
The large tube ID is .625 in.
For the calculator the small r is .3125
The large R is .375.
Length 18 in.
The Large tube inner surface area is 35.34 sq/in.
So 35.34 - 28.27 = 7.07 sq/in. is the difference
Does it look like there is 7.07 sq/in removed from Stan's outer tubes?
Also we don't know how long Stan's tubes were exactly.
I do think Stan had .5 and .625 in matching surfaces.
There are 18 slots.
Each slot is let's say a generous, 1.5 inches by .1875.
1.5 times .1875 = .280 sq/in.
.280 times 18 = 5.04 sq.in.
7.07 - generous 5.04 = 2.03 sq/in difference in matching surface area.
The calculation seems too far off.
Meyer's slots may only be 1.25 long and .100 wide.
This yields.
1.25 times .100 = .125 sq/in. times 18 = 2.25 sq/in.
7.07 - 2.25 = 4.82
That leaves quite a bit to remove to match surfaces.
Somebody check my math.
It doesn't look good to me that the matching surface area is an issue at this point.
If we did this for total surface area rather than matching surfaces this would be an even larger difference so...
If and when, or not, we get some serious gas we can balance 1 set tube this way and see if it improves output. I don't think it's needed. Stan never said anything about it to me but that doesn't mean it won't help. I think it is more about the shape of the electrical fields between whatever surfaces you are using. I can maybe make a test with one tube much longer than another when we have gases.
Cheers,
JP
