OK, and thx Russ for the video.
Couldn't find the liveshow on your utube channel dow.
I know your a volunteer etc. and your only doing what ye can, but i thought there where more here who have a popper device and when it gets quiet around here or when someone like Jabowery has a testworthy idea to maybe find a breakthrough...it itches me to howler at the blue sky.
:)In the vid you also say you have to do a lot of preps for the Global BEM. I understand that it will be nice to concur with other people in this field. But further on it is also like preaching for the converted. If info from BEM would go mainstream etc. then it would be really something...not to piss on the parade, but just to relativice any too nice dreamed off outcome from it. (or spend too much time on preps for it) But already some new help and contacts can be worth it all.
To your feedback question:
I think you need to make some pilots-check-list when experimenting.
And yes, safety from the EM should be first.
(almost) Every test should have the input/output graph
Note which capacitors you use per test
Note the electrode spacing
Note the gassort
Note the amount of voltage and current and durations
Etcetera, just note every variable and with the outcomming data we get to draw some lines in the sand. Doesn't matter at what efficiency.
Test the triple spark and test the addition of Boron, those seem to me the most urgent tests.
Doing the Boron before BEM you would have some news for them, even if it doesn't deliver its something to get answered in means of a possible reaction.
And to Jabowery i want to point out the following video of Bob Rohner and a duration test in which he talks and shows some residue, blue (and white when perfect?) in colour.
