Seen the videos!not much of a proof he shows just one jar and one bubbler.To stick a hose in the engine and put people behind the wheel is not a proof,why does not pull the hose out to see the engine stops...One more thing i saw a methane gas tank behind,from what i know the gpl gas sistem conects trough the air inlet of the engine,not trough the fuel inlet.What about the hho management...?what happens with his jar when the car is iddling if the jar produces lets say 30 lpm how do you control that flow?Stan has 2big boxes full with electronics and this guy shows a little jar and a hose.Even with resonance that he is talking about you need more tubes/cells to prodece enough gas to even idle a car....Untill i don't see some electronics i think is a froud and looking to get his people out of the poverty and to get noticet on media....
if you go to president and talk to him "here is success new energy".you must plan carefully??if you lie then you will arrest!!!!
picture i attached,it is inner tube of car tire. wfc--->inner tube-->water flash back arrestor or wfc-->water flash back arrestor--->inner tube
thanks
geenee
i saw that video too.what is this? a hho filled car tire tube?for what?storage?
i thinks " low cost storage!!!- -* ".
i already tested VIC's Meyer with 230VAC-rms 50hz of my country(Thailand).my set up is 2 little plates of SS, distill water, 1 diode(1000v50a) 2 choke(from primary of MOT), cfl bulb 13w in series with secondary choke to see amps draw.
result is
1.VIC restrict amps flow 100% because stable dc cannot pass water capacitor.first - cfl light up and second - became dark.mean like charge capacitor when full with stop amps flow.
2.have a bubble in middle plates.this is distill water!!!!!!!i'm very happy this.i never make bubble by distill water.
that proof my opinion.RL low pass filter to make stable DC(straight line DC).stable dc cannot pass distill water.but this test use 50hz frequency of home power.i think resonant will improve gas and more voltage will good.
thanks
geenee
Cool Geenne, but you made no measurements: Volts and current.
I'm not entirely sure, that distilled water begins to ionize and begin to conduct current, especially with high voltage. I did tests with distilled water, because from the beginning I wanted to replicate Meyer, and he used any water.
Now I'm destroying a flyback a monitor (as they have tripler and this hinders), to enjoy the trafo lift.
i thinks too with you,if make more bubbles between plates, it will conduct current because air's dielectric strength lower than water. from this, Meyer upgrade WFC add duty circle on PLL.to wait water come back again.but in the test didn't have more bubbles and low voltage(230/2 Vrms).if electric pass water but cannot pass air.
1.this is my setup pictures.
2.when turn on power light up.
3.after a little time(0.5s) light drop and gone(see bulb on first pic).
4.1ohm10w resister to measure amps draw.
5.volt=0.05v amps=0.05 amps=50 milliamperes.
6.a little bubble from distilled water(distilled water for battery).if you distill water by yourself, it will be best purest water.
updated
-i tested to measure voltage across cell is 62 VDC. i thinks if voltage of wfc up to 20000v it will be excited.
-reason for use bulb to test be cause i fear short circuit if distilled water conduct electric(but now i known 100% is not conduct stable dc).next step i remove bulb and result is more bubble, amps draw about 80mA.!!!!!! let's test by yourself ,will be excited.!!! choke of Meyer is any choke(Air core,Ferrite core,iron core).all choke act like RL filter like RC low pass filter.to make stable dc low swing range PEAK TO PEAK DC.
thanks
geenee
