This is my proposal to test a new "VIC" and realize the phenomenon of placing high voltage without current in the cell.
Following the circuit diagram, you will notice a minimal difference with the patent Meyer, however changes the whole outcome:
At first glance, the circuit is open (or no circuit) because there is no loop in the transformer secondary cell and this alone, so let's see, when the voltage is positive at the top of the transformer with respect to ground, the diode conducts through the choke to the anode of the cell (there is a minimum charge, since water is mass) and when reversing the voltage transformer, passes through the other choke drive to the cathode of the cell. So we have high positive (the anode) and negative (the cathode), although not at the same time, so without current. (photo attached)
All have already seen, Leds and / or neons being driven this way, in the experiments of "Electron tief" where radio frequency is used and a dipole.
I believe we can take advantage flybacks without tripler (adjusted to about 2 or 3 kV.) And for the chokes, other two flybacks (mounted on a single core). In primary, a variable frequency generator, a driver FET, and a power adjustable voltage / current. And media monitoring circuit (probes, oscilloscope etc).
This is the Set-Up.
Hugs.
