The Gas Processor GMS Board Replication
« Reply #25, on October 23rd, 2019, 03:54 AM »Last edited on October 23rd, 2019, 03:57 AM
  Stanley A Meyer EGR Exhaust  Gate Ratio Card
GERBER ATTACHED
Re: The Gas Processor GMS Board Replication
« Reply #26, on October 28th, 2019, 11:43 AM »Last edited on October 29th, 2019, 05:19 AM
Stanley A Meyer Air / Exhaust Gate Tuning board k20 summing card
GERBER
« Reply #28, on June 9th, 2020, 05:42 AM »Last edited on January 2nd, 2021, 09:14 PM
Analog Voltage Board ( duaghter board ) to supply extra power to accelerate tps card and digital control means board
Gerber
BOM
Pictures
Made it a bit nicer to fit
a Pin female 30 pin pcb slot card adaptor
Done
Daniel
« Reply #29, on June 9th, 2020, 06:47 AM »Last edited on January 2nd, 2021, 09:13 PM
analog bom
1   R1   1K   AXIAL-0.4   3               PeterMartin
2   R2   47K   AXIAL-0.4   4
3   R3   100K   AXIAL-0.4   4
4   R4   220K   AXIAL-0.4   1
5   C1   10UF 35V   AXIAL   2
6   IC1   UA741CA   DIP-8   1
7   Q1   MPSA20   TO92 CBE   1
8   Q2   2N3095   TO92 CBE   1
9   Q3   2N3096   TO92 CBE   1
10   Card edge connector row 30 Pin 3.96mm pitch 805 slot solder PCB 2x15 socket
« Reply #31, on June 10th, 2020, 06:10 AM »Last edited on June 11th, 2020, 12:32 AM
Digital Control Means
gerber and bom
( updated again 6/11 /2020
Vic MATRIX cIRCUIT K11  gms sET
Enjoy
( added ic sockets and header pints male female and  ribbon out to light sensitive diodes
1   R1   22K   AXIAL-0.4   1
2   R2   10K   TRIMMER   1
2   R3   10K   AXIAL-0.4   1
3   R4   100K   AXIAL-0.4   1
5   C1   2.2UF   AXIAL   1
6   C2   8NF   CERAMIC   1
7   C3   10K400   10K400   1
8   IC1   SN74LS122   DIP-14   2
9   IC2   LCD PICKUP CIRCUIT K7   DIP-16   2
10   IC3   DM74150N   DIP-24_600MIL   2
11   IC4   SN7404N   DIP-14   2
12   IC5   SN7408N   DIP-14   1
13   IC6   CD4001CN   DIP-14   1
14   IC7   SN74193N   DIP-16   2
15   BNC CONNECTOR         1
16   TOGGLE SWITCH         2
17   100K POT         1
18   25K POT         1
19   50K POT         1
20   MALE HEADER PINS            https://www.amazon.com/2-54mm-Breakaway-Connector-Arduino-Prototype/dp/B085MFHVSH/ref=sr_1_4?dchild=1&keywords=female+ARDUINO+header+pins&qid=1591793880&sr=8-4
21   FEMALE HEADER PINS            https://www.amazon.com/2-54mm-Breakaway-Connector-Arduino-Prototype/dp/B085MFHVSH/ref=sr_1_4?dchild=1&keywords=female+ARDUINO+header+pins&qid=1591793880&sr=8-4
22   ICS1   DIP-14 IC SOCKET      5
23   ICS2   DIP-16 IC SOCKET      5
24   ICS3   DIP-24_600MIL SOCKET      2
25   MALE HEADER RIBBON CABLE            https://www.wiringo.com/ribbon-cables.html
« Reply #32, on June 11th, 2020, 12:30 AM »
Stanley A Meyer k2 Variable Pulse Frequency Generator GMS Vix MAtrix
Vic Matrix Set Circuit k2
Gerber
Bom
Enjoy
« Reply #38, on June 16th, 2020, 10:33 AM »Last edited on June 16th, 2020, 10:39 AM
going to suggest we  try to make some  adapter boards and post them
so we can use modern tps pedal or sensor into k11 digital control means,
amd we can delete k7
it is so we migrate training alittle easier as well as fast integration with modern standard.
 of coarse infuture we also update k11 but for now we want  k11 able to connect to modern standerd tps
signal from parts on pedal or throttle and or on a splice on ecu tps signal or 2 nd pin out
all attemps to make adaptor board welcome  to post
« Reply #49, on August 4th, 2020, 09:26 PM »Last edited on August 4th, 2020, 09:29 PM
Early Days
VIC Matrix  Adjusting the power side and safety card at this moment
Not even a version yet just a foundation step
This one is a HIL matrix  so traces are connector as jumpers on board
there is a draft update in works i post so people suggest things as we assemble
