haha russ would have loved to see your delivery mans face when that parcel moved on its own....lol
in fact, I'm making this a teaching lesion. i want EVERYONE to make a list of the things that are extremely important in this video that is not so evident in everything else you have seen... make that list, post it here, and we will find even more interesting clues...
other wise this is a pretty std newman motor replica.
items that are there include the commutator with segmented contacts, magnets inside the coil driving the commutator via pullies...this is a good note because the ratio of the pullies could be increasing the contact segment fire,blank,short frequency...is this why less mass is used than I would expect in the coil????
What you think guys?
sonnet
« Reply #627, on December 9th, 2017, 03:24 AM »Last edited on December 9th, 2017, 03:37 AM
In saying that, the coil is big enough to power it's self, it just can't deliver the torque required for useful work. Imho.
Hence work - output must use the spin to achieve full use of the Newman motor...electrical gain is secondary to the spin.
Others seeking purely electrical energy will loose a valid property of the quadratic field relationships.
Imho
Imho
My entire doc I posted was telling you why those extra terminials are... He even said it in the video. ;)
TUNING!!
Same reasion why I'm having the extra wire on the outside of the one I'm making.
Small coil? Its still quite big considering and if tuned correctly to get max output then I think yes its big enugh.
Rotor
Yes one could change the ratio, but then would need to do it in multiples. switch polarity...
Just. Making. The rotor bigger might be eazer.
Right. In my. Testing I will try to confirm with or with out magnet. To see if it really effects output. I think it will also.
TUNING!!
Rotor
in fact, I'm making this a teaching lesion. i want EVERYONE to make a list of the things that are extremely important in this video that is not so evident in everything else you have seen... make that list, post it here, and we will find even more interesting clues....
1) ... the rest of it is tuning basically, in a load ...
2) He said that he has 713 volts and 0.05 amps which is 35.65 Watt and he confirms that so, if the coil is in series (i mean one big coil) then the ohms will be around 14 260 Ohms (give or take based on the speed).
3) Meter is running negative (this is a big confirmation that someone else achieve the Newman effect as well and it proves that Newman was not lying.
4) The commutator looks to be in 60% fire 40% blank configuration (give or take), at least what it is look like from above (it is shiny and not, shiny and not and so on ...)
5) Batteries are recharged and not consumed and he even achieve this with low speed, amazing.
6) 5 inductors is there, or else 5 coils is in there, now this is where it gets confusing so, for me there are two options,
A) Eather he has 5 coils in parallel with total resistance of 14 260 Ohms (as above) or
B) he has 5 coils with 14 260 Ohms on each (give or take), the first coil can be connected to the commutator (motor), next three of them are connected start to end and the last one is on the load.
But to be honest, i have no idea if B is a nonsense ...
7) could someone explain why the load is not blinkink at the same rate ? because it is blinking more and then almost none and again ...
it is at 5:27.
Three stage device, what is that mean, and he compared it to the storms. It is at 8:42
I have been out for few days so, i will need some time to read back few pages on this topic.
Well, that's all from me, have fun :)
after getting my magnifying glass out most of those connections were not in use.....as far as I can see. But I'll take it you can see they are...that was my question.
So why has this Witts not got this in production and spreading the word. looks like its been 8 years plus....can anyone give us a quick over view...or am i asking obvious questions?
« Reply #632, on December 9th, 2017, 04:33 PM »
Sir Timothy Thrapp (head hauncho at WITTS) is purely pay to play. You give your life and money over to his church and he might allow you to see and play with some of his sequestered technology. He has his own game plan and based on what I can tell, TPTB haven't really messed with him as long as he stays in his own sandbox. Whatever floats your boat right?
take the video for what it is...
we know what to do already... it was just yes ANOTHER confirmation, that's 4 now... that we know of.
« Reply #634, on December 9th, 2017, 10:31 PM »
onepower
« Reply #635, on December 9th, 2017, 10:48 PM »
Like minds seek like minds and in nature opposites do not attract they try to negate there opposite conditions to find balance in unity.
Thank you matt. I did ask the question last night and woke knowing I'm on the right path, But it did make me think....why has witts taken their path.
Good thought also overpower. That's where I come in with the premise you have to believe, when you ask questions of others you are believing that they will help. And from that your get a sign. Regards.
Are you counting Bruce DePalma? Seems he was corresponding with Joseph Newman--pretty sure they both were on the same page.
why?
Becuse its a diffrent physical makeup. That's all...
« Reply #638, on December 10th, 2017, 08:00 AM »Last edited on December 10th, 2017, 08:13 AM
Of course none of this is true here on earth. Here on this rock we must obey. Those conceived in special wombs say so--first they persuade and then if needed use force to convince. Sure wish Valiant Thor would have came and talked with me instead of the monkeys at the Pentagon. No matter. I won't make the same mistake twice.
Yes. This is part of the plan...
Magneton
« Reply #640, on December 12th, 2017, 06:27 PM »
After a rough start I got my first 10000 turns wound, only 225000 turns to go LOL
wow... that's one sore thumb :)
I'm glad you got it started though!
well that's interesting... where did his inspiration come from...
https://www.youtube.com/watch?v=Hd2rdiVKwL4
hummm... nano second switching...
dont get lost on this one... the reason i posted it was to show you where the inspiration come from....
Back to Newman directly on this thread...
Tavote
« Reply #645, on December 12th, 2017, 11:53 PM »
Magneton
« Reply #646, on December 13th, 2017, 05:09 AM »
Awesome, in a few days (or weeks) you will have it done :)
the key is, don't quit until then...
talisman
« Reply #648, on December 13th, 2017, 03:45 PM »
The video with Babcock raises a number of points.
The technology is a planned build device.
He says they understand the underlying mechanisms to engineer the concepts.
The various concepts have a theoretical potential. That would be the efficiency rating.
The device is being commercialized. In this form factor it is applied in the space and volume
that will permit it. With an understanding of the theory other devices can be engineered to a
competitive standard of efficiency. The highest ratio would be the best but competitive advantage
can be factored in as risk.
The experiential background in industry gave insight. The motivator is not conventional norm
but in the profitability of a viable alternative. Otherwise I would be still typing on a typewriter.
