Sonnet. On the drawing I have "the magnet needs to extend past the coil"
This is what your saying
Also its noted that the drawing is not that way.
But. There both still repelling. Or to look at it differently. There holding each other by repelling. Lol I understand.
What your seeing as a naturalising effect.
We both agree there.So inadvertently you're stating no obvious work being done? if so we agree....it adds nothing.
Now all this is well down the problem list but can have a bearing on getting the most from the motors torque. so don't let it sway you.
One reply says if only he spoke in the language of academics they might look at it. Weak considering in the case of cold fusion full accredited academics were speaking in their language and they got the similar treatment.
Talisman
I guess the most relevant question is... if you had a working device right in front of you and someone said I don't believe it works would you care what they believe?. Well no that is absurd because you know as a fact it does work and their beliefs are completely irrelevant. Why so many seem to be so concerned with what others think of them and their beliefs seems a little superficial in my opinion. If we can make this a reality then that is reality and they will have to deal with it no matter what they believe. Reality is reality is it not?.
as i do... open, free, and non considered of others thoughts of negativity... press forward for what you believe in. just try not to leave others at the bottom of the mountain.... for if you do. all will be lost...
