If we add enough we might be able to remove the capacitors added to the coils... see where I'm going?
Ask for a little help with this tonight before bed....that's what I do. See how you wake.
The caps are used for energy storage from the coils.
Now you're back to where I was in my mind before you kept throwing in the capacitors. Don't read into that I'm saying I'm right....I liked your ideas but your doubting yourself.
@ Haxar
I take that back Ive not seen the circuit with the capacitors so I,m assuming...sorry
Yes see now, the whole short circuit will change impedance because of the caps. there's quite a bit of maths to do there.
still think we shouldn't worry about capacitance as I believe it would be a help. wonder how matt we see it.
Those plans, is it Joe's. source has his address but did he endorse that plan anyone know?
the machine there is not very big and sort of goes against what he said.
the speed of the charges is proportional to the value of electric current;"
http://amasci.com/miscon/speed.html
and potential (voltage) moves at the speed of light.. (so its said)
as of now, i agree, but i wanted to really push the WHY NOT... :) ~Russ
If you keep the internal capacitance low, you will limit the speed in which things happen. Ten RPM might not be what you're looking for, but possibly be all you are going to get.
If Newman is correct, the voltage acts as a catalyst to manifest out the magnetic field in such a way to have a coherent polarity. That's really all you need. The tricks Newman uses to get the proper alignment should be applicable whether done slowly or quick. If those are my two choices, I'd take quick and do those same tricks more often.
What size wire is on that MOT you think? ~Russ
