That L.M.D. / T.E.M. illustration is going to be helpful. You're on it.
haxar
« Reply #1200, on March 18th, 2017, 01:27 PM »
In electrical circuits, parasitic capacitance, or stray capacitance is an unavoidable and usually unwanted capacitance that exists between the parts of an electronic component or circuit simply because of their proximity to each other.
I'm also curious how unintended L.M.D. parasitics are filtered in modern electronics.
When I mess around with my slayer exciter, I have a couple of capacitive touch lamps in my house that go crazy. Even the smallest signal generated on the other side of the house is picked up by these devices. Drives my wife crazy. :-P
Make a note of this: Stan referred to the tube sets as wave guides, not electrodes. There is a reason for this and it should be apparent to everyone by now. The two tubes setup a dielectric pressure differential; all the water between them is being stressed equally, which is why the bubbles don't form on the metal, the tubes are not electrodes.
Physics. to raise (an atom, molecule, etc.) to an excited state.
any of the energy levels of a physical system, especially an atom, molecule, etc., that has higher energy than the lowest energy level.
We need the VIC to produce Longitudinal Magneto Dielectric waves, i.e. "Cold Electricity". These waves should have polarity nodes spaced exactly to match the gap in the resonant cavity.
If this is the case you need a wavelength of 1MHz to match the gap?
... and the conductors are merely a wave quide.
Actually, according to Eric Dollard, they are dielectric reflectors. When positioned properly, yes they would function as wave guides.
Dielectricity lives between conductors, which is why a transformer (spools of conductive wire on a bobbin) is a far more complex device than most people realize. The more adjacent turns you have, the more volume you have to house dielectricy. If we could all get away from the terms "capacitors" & "inductors" and think about the medium we are working with, these device structures would begin to make a lot more sense. I highly recommend everyone watch this video several times and take notes. Get your head wrapped around what he is saying or relaying from the true masters of their time.
It's going to be up there yes Webmug. These waves move at Pi/2 * C, but how they actually form what appears to be standing waves is outside my comprehension at the moment. The Tesla Hairpin or Stout Bars experiment shows us fairly distant nodes. Taking this design and modifying it to look like Stan's VIC will probably give us the node spacing we are after. First we need a method to measure, then an apparatus to measure and lastly begin changing variables to shorten the node length down to the gap size. I'm working on a PLL controlled, capacitive discharge driven coil system at the moment in hopes I can see and relate to everyone what I think is going on here. I'm really hoping to discover this process is fairly simple and straightforward in principal even if the implementation is more difficult than I thought. Once we all know what to do, then we can each work on a method of how to do it. If this takes us back to how Stan did it, so be it, that's actually the best answer. The goal here is in the title:
It is through disturbance of this oscillatory equilibrium, by means of resonant impulses, that Keely alters the relations of the vibratory impulses which constitute matter. This he does by striking the same chord in three octaves, representing the third, sixth, and ninth of the scale.
Forces are held in a dynamic state of equilibrium, a neutral state, until disturbed by an excitation or stimulation.
Experiment shows that molecular dissociation does not take place until the molecule attains an oscillation approaching, if not fully reaching two-thirds of its diameter.
Keely used the word Intensify and was his intended word for amplify. He intensified vibrations but amplified oscillations. Amplifying a vibration in the zero or neutral state.
I'll take the time to chime in here. You are correct Matt, it does not move. And neither does it move around the Vic once tuned correctly. Using a compass setting above the Vic will help one tune the Vic. This is the method I use myself.
this is the "electron bounce phenomenon"
look for it in Stans work. if you guys forgot...
also for your viewing pleasure:
https://www.youtube.com/watch?v=AvCZG5ccPsk
The electron bounce phenomenon (current restriction) uses the magnetic field???
~webmug
also this can be that way that stan was trying to explain the "electron bounce phenomenon"
In my opinion Meyers vic has nothing to do with Impulses from a sparkgap...no sparkgap is used. A compass moves due the spark creating magnetic field...
If a compass doesnt move above the vic, then there is no moving magnetic field so there is no current!
So how is the voltage created using no magnetic field since electric field has two components, magnetic and electrostatic?
~webmug
My feeling about the VIC is that it does produce LMD waves. These waves have very short nodes equivalent to the spacing of the WFC tubes, or exciter array. This is unlike the regular Tesla hairpin circuit where the nodes are spaced much further apart. This is theory now on my part, but keep it in mind. I could be correct, I could be full of crap. I don't think we know for sure one way or another as yet.
So I've been thinking more about the VIC while it is actually in operation. The LMD waves create standing nodes due to the way the chokes are configured. I said "waves" plural. There are two of them exiting each choke and passing through the opposing wave via the exciter array. This is the process that makes the actual nodes: two waves slightly out of phase, so they don't cancel by way of superposition. This is part of the story, but there's more to it.
These two waves now re-enter the opposing choke after passing through the exciter array. This is the point where they recombine back with magnetic component isolated in the VIC core. This combining action is what keeps the core in oscillation. The dielectric component of the previously hybrid electrical energy is restored and another cycle begins. My theory as to why this can happen deals with the propagation speed of the dielectric component versus the magnetic component. Dielectricity can shoot out the choke, go all the way through the exciter array and come back into the opposing choke at nearly the same speed as the magnetic component changes within the core. It happens so fast the VIC doesn't even react to the fact the dielectric component has left at all. The system just cycles along as though it were a typical oscillating circuit. This may actually be what happens within an LC circuit, but no one has really ever looked at it that way.
Now to be technically correct with Dollard's description of dielectricity, the energy in the LMD wave doesn't actually pass through the wires. It's actually in between the wires, remember he refers to conductors as dielectric reflectors. So the LMD wave shoots out towards to the exciter array and a portion of it bounces back in exactly the opposite path as it took to get there. This gets a little tough to wrap my head around, but we have to think of dielectricity as preferring a path of insulation, not conduction. So the WFC actually reflects or causes a bounce of the LMD wave. Looking at it this way, the nodes appear due to the wave arriving and departing from the exciter array. Given this viewpoint, I would suspect if we placed a fluorescent tube between the two wires going to the exciter array, we might actually be able to see the standing wave nodes appear and if they have the proper spacing, likely the WFC will be producing gas.
The above consideration raises the question: What happens when the exciter array is empty? My suspicion is there is no bounce. And with no bounce, there would be no standing wave nodes either. Purely speculation, but certainly something we can verify in due time.
i was trying to express the type of electricity that is with in the VIC...
T.E.M. VS L.M.D
I be leave we must be dealing with L.D.M
go read that section again. where Stan talks about electron bounce phenomenon. if you understand L.D.M first. then tell me I'm crazy?
or tell me you agree. i would love for you to do so. let me know!!
