I have a question though it might not make sense physically? Every other rod instead of inside and outside of each?
soulfluence
Re: Stans VIC finally reverse engineered and ready to build.
« Reply #200, on April 23rd, 2018, 01:11 AM »
I know I'm new here, but capacitance is resonance in this case is it not???
The reason why I say that is because a standing wave is what is being used to induce current along with a gate, back and forth back and forth.
To have a standing wave, you need a long enough wire, such as a delay line or transmission line. Transmission lines on poles traversing T.E.M. waves at 50/60Hz does not produce standing waves.
To date we can say well over 200 People have made the method work as described using Voltage to split water and avoid Amps .
:rofl2:Quote from securesupplies on April 24th, 2018, 02:09 PM To date we can say well over 200 People have made the method work as described using Voltage to split water and avoid Amps .
And Russ hasn't yet? Hmmm... Doesn't compute.
I do understand that the process works, my question was referring to the amount of hydrogen produced vs. faraday-type direct electrolysis. This is my main concern. If a baseline has been established to get more hydrogen using Stan's method with less energy than regular electrolysis by at least 10%, the rest is just fine tuning different things like you stated.
Exactly, has anyone proved 10% more hydrogen than brute-force electrolysis? Actually, how about 20%? That sounds more comfortable.
Yes, Cycle, I was just going to mention this. One of the catalysts is something like nano ---- aluminum. I saw it demonstrated by just dropping it in water . When it made contact with water the water almost looked like it was boiling. That technology is said to be being used by the Army.
