Hi @All,
I'm waking up this thread, since it's in a kind of hibernation mode :D
RULE: Stan Meyer (EPP) Electrical Polarization Process
http://open-source-energy.org/?tid=188&pid=5948#pid5948
2-6:Principles of Electrodynamics
Principles of Electrodynamics (polarization)
Vibrational Contributions to Molecular Dipole Polarizabilities
"When a molecule is placed in an electric field it exhibits molecular polarization, a property which, in principle, has three components: orientation polarization, electronic polarization and vibrational polarization. (book concerned with the last component)"
http://www.nist.gov/data/PDFfiles/jpcrd199.pdf
Chapter I:Atoms, Molecules And Clusters in Electric Fields
"This article is limited to static phenomena, and does not describe time-dependent or dynamic polarization."
Electric dipole moment
Too bad, I think SM has a form of Dynamic Polarization!!!!
Did someone noticed the total capacitance C1 (L1 Cp and Cwfc) has different capacitance C2 (L2 Cp and Cwfc). Choke L1 connected to POS exciter and choke L2 to NEG exciter?
Because there is a ROD and TUBE, two exciters of different dimensions.
"The tunable L2 coil"
This current restricting only works if C's are equal compensated and the two L's are the same. So there is the same resonance frequency for both chokes (highest static pulsating potential at lowest current). According to Meyer voltage then takes over.
Best regards,
Webmug
I know some of us have experienced isolate the electrodes without success, why? why not work with any dielectric? because water has a high "K" = 78 and any insulator has a "K" = + / - 3. We need a 'K' => 1500 (twenty to thirty times higher than water).
Maybe "BaTiO3".
