Ice Age Model
Re: Ice Age Model
« Reply #175, on July 31st, 2014, 04:54 AM »Last edited on July 31st, 2014, 05:29 AM
test file. no one can see it unless logged in?
thanks Matt i see it, its Green... O:-)
simply predictable. INCOMING STORM CLOUD: Yesterday, July 30th, a dark magnetic filament on the sun erupted and hurled part of itself into space. The Solar and Heliospheric Observatory tracked a bright CME moving away from the blast site at 700 km/s:
Although the CME is not coming straight for Earth, it does have an Earth-directed component. Computer models suggest it will deliver a glancing blow to Earth's magnetic field on August 2nd. NOAA forecasters estimate a 30% chance of polar geomagnetic storms when the storm cloud arrives.
Re: Ice Age Model
« Reply #176, on August 1st, 2014, 06:59 PM »Last edited on August 1st, 2014, 07:04 PM
Quote from freethisone on May 28th, 2014, 06:08 PM
who made the discovery? nasa? and Tony.. ppppp please.
Earth-Size Planet Found In The 'Habitable Zone' of Another Star
April 17, 2014: Using NASA's Kepler Space Telescope, astronomers have discovered the first Earth-size planet orbiting in the "habitable zone" of another star. The planet, named "Kepler-186f" orbits an M dwarf, or red dwarf, a class of stars that makes up 70 percent of the stars in the Milky Way galaxy. The discovery of Kepler-186f confirms that planets the size of Earth exist in the habitable zone of stars other than our sun.
The "habitable zone" is defined as the range of distances from a star where liquid water might pool on the surface of an orbiting planet. While planets have previously been found in the habitable zone, the previous finds are all at least 40 percent larger in size than Earth and understanding their makeup is challenging. Kepler-186f is more reminiscent of Earth.
splash
The artist's concept depicts Kepler-186f , the first validated Earth-size planet to orbit a distant star in the habitable zone.  More
Kepler-186f orbits its parent M dwarf star once every 130-days and receives one-third the energy that Earth gets from the sun, placing it nearer the outer edge of the habitable zone. On the surface of Kepler-186f, the brightness of its star at high noon is only as bright as our sun appears to us about an hour before sunset.
Auroras Underfoot (signup)
"M dwarfs are the most numerous stars," said Elisa Quintana, research scientist at the SETI Institute at NASA's Ames Research Center in Moffett Field, Calif., and lead author of the paper published today in the journal Science. "The first signs of other life in the galaxy may well come from planets orbiting an M dwarf."
However, "being in the habitable zone does not mean we know this planet is habitable," cautions Thomas Barclay, a research scientist at the Bay Area Environmental Research Institute at Ames, and co-author of the paper. "The temperature on the planet is strongly dependent on what kind of atmosphere the planet has. Kepler-186f can be thought of as an Earth-cousin rather than an Earth-twin. It has many properties that resemble Earth."
Kepler-186f resides in the Kepler-186 system, about 500 light-years from Earth in the constellation Cygnus. The system is also home to four companion planets: Kepler-186b, Kepler-186c, Kepler-186d, and Kepler-186e, whiz around their sun every four, seven, 13, and 22 days, respectively, making them too hot for life as we know it. These four inner planets all measure less than 1.5 times the size of Earth.
splash
The diagram compares the planets of our inner solar system to Kepler-186, a five-planet star system about 500 light-years from Earth in the constellation Cygnus.  More
Although the size of Kepler-186f is known, its mass and composition are not. Previous research, however, suggests that a planet the size of Kepler-186f is likely to be rocky.
"The discovery of Kepler-186f is a significant step toward finding worlds like our planet Earth," said Paul Hertz, NASA's Astrophysics Division director at the agency's headquarters in Washington.
The next steps in the search for distant life include looking for true Earth-twins -- Earth-size planets orbiting within the habitable zone of a sun-like star -- and measuring the their chemical compositions. The Kepler Space Telescope, which simultaneously and continuously measured the brightness of more than 150,000 stars, is NASA's first mission capable of detecting Earth-size planets around stars like our sun.
Looking ahead, Hertz said, "future NASA missions, like the Transiting Exoplanet Survey Satellite and the James Webb Space Telescope, will discover the nearest rocky exoplanets and determine their composition and atmospheric conditions, continuing humankind's quest to find truly Earth-like worlds."
Credits:
Production editor: Dr. Tony Phillips | Credit: Science@NASA
Re: Ice Age Model
« Reply #177, on August 2nd, 2014, 02:01 PM »Last edited on August 2nd, 2014, 02:07 PM
Quote from freethisone on July 16th, 2014, 05:46 PM
Link to discovery planet freethisone...
a large to great t moderate quake 6.8 or higher should be expected in a short time. perhaps up to 7 days. the earth magnetic field annomoly continues for a time delta T.
volcanic eruption, and storms, hails and snow in diverse places occured right as expected due to angular momentum changes on earth deformable body. large explosive volcanic eruptions expected in a given time. pehaps we will see a large eruption this week.
http://www.seti.org/seti_kepler_62
Has Kepler Found Ideal SETI-target Planets?
For Immediate Release Friday April 19, 2013 11 am PST
Kepler 62An artistic view of the system seen from Kepler-62f. The host star is slightly redder than our sun. The smaller exoplanets Kepler-62b (1.3 times Earth’s radius) & Kepler-62c (0.5 times Earth’s radius) are close to the star. Kepler-62d (2 times Earth’s radius) is significantly bigger and closer, Kepler-62e (1.6 times Earth’s radius) & Kepler-62f (1.4 times Earth’s radius) are relatively close to each other and both are sustaining water and rocky surface as suggested by the clouds' color, water, atmosphere and rocks Credit: Danielle Futselaar/SETI Institute (Click for full size image)
Mountain View: NASA's Kepler mission has discovered a new planetary system that is home to five small planets around a slightly smaller star than our Sun. Two of them are super-Earth planets, most likely made of rock or ice mixed with rock, which are located in the habitable zone of their host star. This discovery is providing a target for the SETI search, since if life has thrived on these worlds and reached a point where civilization has developed complex technology, it may be detectable.
When the NASA Kepler mission was launched on March 9, 2007, the Delta II rocket was carrying the hope of a large community of scientists who dedicate their work to studying extra-solar planets, planets in orbit around other stars. The Kepler mission's main scientific objective is exploration of the structure and diversity of planetary systems. It accomplishes this goal by staring almost constantly at a large field composed of about 150,000 stars to detect small dips in brightness due to the transits of a planet.
Kepler has already been a successful NASA mission with the discovery of 2,740 planet candidates with estimated sizes from Mercury to larger than Jupiter. A fifth of these planet candidates are also called "super-Earths", a new class of planets, without analog in our solar system, with a radius between 1.25 to 2 times the radius of our planet.
Today, in a scientific article published in Science magazine and through a NASA press conference, the Kepler team announced the discovery of a multiple planet system, composed of 5 Earth-sized and super-Earth planets orbiting a K-type star.
The detection of these planets was indirect since Kepler astronomers observed the attenuation of the host star's brightness due to the passage of a planet in the line of sight, and not the planets themselves. The authenticity of this multiple planet system was confirmed by a statistical analysis based on previous detections of multiple planets by Kepler.
“By estimating the rate of false-positives due the remote possibility of additional planet-hosting stars in the photometric aperture we have strong confidence that we have discovered two genuine transiting super-Earth planets in the habitable zone  of their host star.  Such calculations are only possible because of the thousands of additional transiting extrasolar planets that Kepler has discovered” said Jason Rowe, Research Scientist at the Carl Sagan Center of the SETI Institute and co-author of the work
The outermost planet, named Kepler-62f (radius about 1.4 times Earth’s radius and a period of 267 Earth days) is located in the habitable zone of the star, a region around the star where a rocky planet with an atmosphere similar to Earth could host liquid water on its surface. The team expanded the definition of the Habitable Zone by taking into account the evolution of the brightness of the host star. Their calculations suggest that Kepler-62e (radius about 1.6 times Earth’s radius and a period of 122 Earth days) was also in the habitable zone so that liquid water could have existed on its surface, too.
Similar to Venus and Mars that are believed to have lost their surface water 1 billion years and 3.8 billion years ago respectively, before our sun was more luminous, the host star's habitable zone was broader in the past. The Kepler team's calculations suggest that Kepler-62e (radius about 1.6 times Earth’s radius and a period of 122 Earth days) is also in the habitable zone so that liquid water could exist on its surface, too.
“These discoveries move us farther down the road to discovering planets similar to Earth. While we don’t know if Kepler-62e and f are rocky or whether they have liquid water pooling on their surfaces, their existence shows that the incidence of small worlds in the habitable zone of sun-like stars is high. Thus we can look forward to the discovery and detailed characterization of Earth’s cousins in the years and decades to come by future missions and telescopes.“ said Jon Jenkins Senior Scientist at the Carl Sagan Center of the SETI Institute and also co-author of the work.
Both Goldilocks planets’ masses remain unknown since they are too small to produce detectable gravitational effects on the host star and between themselves. However, considering a lower upper limit for their mass and the age of the star, estimated to be 7 billion years, the team suggests that both planets are solid and either made of a dry rocky material, like Earth, or a large body of water surrounding a core of iron and rock (a water world).
Kepler discoveries are an amazing opportunity to focus the search for technosignatures conducted at the Center for SETI Research led by Gerry Harp. Kepler provides the detection of exoworlds that could host water on their surfaces and potentially life. Unfortunately, the planets of the Kepler-62 system are too distant (1200 light-years from Earth) to be fully characterized, and no direct measurement of their atmospheric composition is possible with current technologies.
"Since December of 2011, the SonATA program to search for extraterrestrial intelligence with the Allen Telescope Array has been focusing on the Kepler exoplanet candidates and especially those planets expected to be within the "Habitable Zone" of their stars. Our surveys improve on previous, generally narrowband SETI by covering the radio frequency range where Earth's atmosphere is most transparent, including many frequencies never before observed. We expect to complete a meaningful survey of these stars in less than 1 year -- be sure to check back soon." says Gerry Harp, Director of the Center for SETI Research.
FURTHER INFORMATION
SETI Institute
The mission of the SETI Institute is to explore, understand and explain the origin, nature and prevalence of life in the universe. The SETI Institute is a private, nonprofit organization dedicated to scientific research, education and public outreach. Founded in November 1984, the SETI Institute began operations on February 1, 1985. Today it employs over 120 scientists, educators and support staff. Research at the Institute is anchored by three centers. Dr. Gerry Harp is Director of the Center for SETI Research (Dr. Jill Tarter continues as Bernard M. Oliver Chair for SETI). Dr. David Morrison is the Director for the Carl Sagan Center for the Study of Life in the Universe. Edna DeVore leads our Center for Education and Public Outreach.for Education and Public Outreach. SETI Institute website:http://www.seti.org
Jon Jenkins is a senior researcher at the Carl Sagan Center of the SETI Institute and leader of the Kepler Analysis team located at NASA Ames
Jason Rowe is a research scientist at the Carl Sagan Center of the SETI Institute and part of the Kepler Science Office located at the NASA-Ames Research Center.
Gerry Harp is the Director of the Center for SETI Researchhttp://www.seti.org/sites/default/files/Kepler-62-def-540px.jpg
side by side. you be the judge.
the con artist view? or the actual images? you choose what u want to know and understand.. O:-) O:-)
major magnetic influence. tourque times delta T. the new comet is a fake! look at the edges. its to sharp. there for it is a manipulated.image.  its temple one heartly 2. comet this remains the most likely to occur.  earthquake, and explosive eruption expected in as a effect of external forces. these 30 days ahead. will be well examined. :cool: :cool:  the leader for ice age model. and astronomy. this space science is a cake walk when you have known objects running about.  look  for  the twins to emerge as the spark gap is triggered O:-). a 7.0 or higher would be a reasonable probability according to ice age model. 5 days or less.
Re: Ice Age Model
« Reply #178, on August 2nd, 2014, 07:10 PM »
Quote from freethisone on August 2nd, 2014, 02:01 PM
im  saving this for the archives.
 results from the hottest highest solar event in history. they say we are at a low for this month but fail in every way to understand this is a high for the year, the month prior, and the month there after. volcanic eruption is on deck.
ocks Federated States of Micronesia region
Xray J
Offer Upgrade
User ID: 61085424
 United States
08/02/2014 08:58 PM
Report Abusive Post
Report Copyright Violation
BREAKING: DOUBLE 7.2M Earthquake rocks Federated States of Micronesia region
7.2
2014-08-03 00:22:03 UTC
10.0 km deep
[link to earthquake.usgs.gov]
tsunami buoy link
[link to www.ndbc.noaa.gov]
Sunday August 3 2014, 00:21:59 UTC Federated States of Micronesia region 7.2 10.0 USGS Feed
Sunday August 3 2014, 00:22:03 UTC Federated States of Micronesia region 7.2 10.0 USGS Feed
4 seconds apart same quake???
"It is easier to fool people than to convince them they have been fooled." - Mark Twain
Anonymous Coward
User ID: 43485535
 United States
08/02/2014 09:01 PM
Report Abusive Post
Re: BREAKING: DOUBLE 7.2M Earthquake rocks Federated States of Micronesia region
Sunday August 3 2014, 00:21:59 UTC   37 minutes ago   Federated States of Micronesia region    7.2   10.0   USGS Feed   Detail
there are 2 7.2 showing , was it two earthquake or just a duplicate?
Dont see a tsunami warning ..
Xray J (OP)
User ID: 61085424
 United States
08/02/2014 09:02 PM
Report Abusive Post
 Quoting: Anonymous Coward 43485535
there is a buoy in event mode.
Xray J (OP)
User ID: 61085424
 United States
08/02/2014 09:05 PM
Report Abusive Post
7.2
10.0 km deep
6.6
13.3 km deep
upgrade or down grade???
Xray J (OP)
User ID: 61085424
 United States
08/02/2014 09:14 PM
Report Abusive Post
im not sure either looks like 2 7.2m that were 4 seconds apart!
biggen
User ID: 60633763
 United States
08/02/2014 09:19 PM
Report Abusive Post
bump for saturday nite booty bump. shake dat ass gurrrr....
Anonymous Coward
User ID: 44600189
 United States
08/02/2014 09:32 PM
Report Abusive Post
In the name of Allah, the Beneficent, the Merciful.
99:1 When the earth is shaken with her shaking,
99:2 And the earth brings forth her burdens,
99:3 And man says: What has befallen her?
99:4 On that day she will tell her news,
99:5 As if thy Lord had revealed to her.
99:6 On that day men will come forth in sundry bodies that they may be shown their works.
99:7 So he who does an atom’s weight of good will see it.
99:8 And he who does an atom’s weight of evil will see it.
Anonymous Coward
User ID: 38730593
 Canada
08/02/2014 09:32 PM
Report Abusive Post
big magmatic movement rather than seismic??
4 seconds ante possible
Anonymous Coward
User ID: 60711427
 United States
08/02/2014 09:33 PM
Report Abusive Post
Downed to a 6.6
TheTruthMonger
Guitard
User ID: 44102723
 United States
08/02/2014 09:33 PM
Report Abusive Post
From here Poo escalates.
"And it really didn't have to stop...it just kept on going."
Anonymous Coward
User ID: 41441070
 United States
08/02/2014 09:34 PM
Report Abusive Post
Double eq
500k ppl w/out water
Ebola lands in USA.
what else you got for us tonight?banana2
Anonymous Coward
User ID: 13379262
 United States
08/02/2014 09:34 PM
Report Abusive Post
 Quoting: Anonymous Coward 44600189
Pull my finger.
PoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostreamPoostream
Anonymous Coward
User ID: 38730593
 Canada
08/02/2014 09:48 PM
Report Abusive Post
not good
[link to www.sciencemediacentre.co.nz]
Anonymous Coward
User ID: 39691594
 United States
08/02/2014 09:52 PM
Report Abusive Post
M6.6 - Federated States of Micronesia region
PAGER - GREENShakeMap - IVDYFI? - ITsunami Warning Center
Earthquake location 0.854°N, 146.125°E
Return to the EQ List/Map/Search
kml iconGoogle Earth KML
SummaryLocation and Magnitude contributed by: USGS National Earthquake Information CenterGeneral
100 km
50 mi
Powered by Leaflet
0.854°N, 146.125°E
Depth: 13.3km (8.3mi)
Event Time
2014-08-03 10:22:03 UTC+10:00 at epicenter
2014-08-02 20:22:03 UTC-04:00 system time
Location
0.854°N 146.125°E depth=13.3km (8.3mi)
Nearby Cities
342km (213mi) NNW of Lorengau, Papua New Guinea
561km (349mi) NNE of Wewak, Papua New Guinea
643km (400mi) NW of Kavieng, Papua New Guinea
663km (412mi) NE of Vanimo, Papua New Guinea
1144km (711mi) N of Port Moresby, Papua New Guinea
Magnitude
6.6
Event Time
2014-08-02 14:22:03 HST
Location
Nearby Cities
TSUNAMI BULLETIN NUMBER 001
PACIFIC TSUNAMI WARNING CENTER/NOAA/NWS
ISSUED AT 0030Z 03 AUG 2014
THIS BULLETIN APPLIES TO AREAS WITHIN AND BORDERING THE PACIFIC
OCEAN AND ADJACENT SEAS...EXCEPT ALASKA...BRITISH COLUMBIA...
WASHINGTON...OREGON AND CALIFORNIA.
... TSUNAMI INFORMATION BULLETIN ...
THIS BULLETIN IS FOR INFORMATION ONLY.
THIS BULLETIN IS ISSUED AS ADVICE TO GOVERNMENT AGENCIES.  ONLY
NATIONAL AND LOCAL GOVERNMENT AGENCIES HAVE THE AUTHORITY TO MAKE
DECISIONS REGARDING THE OFFICIAL STATE OF ALERT IN THEIR AREA AND
ANY ACTIONS TO BE TAKEN IN RESPONSE.
AN EARTHQUAKE HAS OCCURRED WITH THESE PRELIMINARY PARAMETERS
 ORIGIN TIME -  0022Z 03 AUG 2014
 COORDINATES -   0.9 NORTH  146.2 EAST
 DEPTH       -   10 KM
 LOCATION    -  FEDERATED STATES OF MICRONESIA REGION
 MAGNITUDE   -  7.2
EVALUATION
 NO DESTRUCTIVE WIDESPREAD TSUNAMI THREAT EXISTS BASED ON
 HISTORICAL EARTHQUAKE AND TSUNAMI DATA.
 HOWEVER - EARTHQUAKES OF THIS SIZE SOMETIMES GENERATE LOCAL
 TSUNAMIS THAT CAN BE DESTRUCTIVE ALONG COASTS LOCATED WITHIN
 A HUNDRED KILOMETERS OF THE EARTHQUAKE EPICENTER. AUTHORITIES
 IN THE REGION OF THE EPICENTER SHOULD BE AWARE OF THIS
 POSSIBILITY AND TAKE APPROPRIATE ACTION.
THIS WILL BE THE ONLY BULLETIN ISSUED FOR THIS EVENT UNLESS
ADDITIONAL INFORMATION BECOMES AVAILABLE.
THE JAPAN METEOROLOGICAL AGENCY MAY ALSO ISSUE TSUNAMI MESSAGES
FOR THIS EVENT TO COUNTRIES IN THE NORTHWEST PACIFIC AND SOUTH
CHINA SEA REGION.  IN CASE OF CONFLICTING INFORMATION... THE
MORE CONSERVATIVE INFORMATION SHOULD BE USED FOR SAFETY.
THE U.S. NATIONAL TSUNAMI WARNING CENTER WILL ISSUE PRODUCTS
FOR ALASKA...BRITISH COLUMBIA...WASHINGTON...OREGON...CALIFORNIA.
USGS: How large does an earthquake have to be to cause a tsunami?
Magnitudes below 6.5
Earthquakes of this magnitude are very unlikely to trigger a tsunami.
Magnitudes between 6.5 and 7.5
Earthquakes of this size do not usually produce destructive tsunamis. However, small sea level changes may be observed in the vicinity of the epicenter. Tsunamis capable of producing damage or casualties are rare in this magnitude range but have occurred due to secondary effects such as landslides or submarine slumps.
Magnitudes between 7.6 and 7.8
Earthquakes of this size may produce destructive tsunamis especially near the epicenter; at greater distances small sea level changes may be observed. Tsunamis capable of producing damage at great distances are rare in the magnitude range.
Magnitude 7.9 and greater
Destructive local tsunamis are possible near the epicenter, and significant sea level changes and damage may occur in a broader region.
Note that with a magnitude 9.0 earthquake, the probability of an aftershock with a magnitude exceeding 7.5 is not negligible. To date, the largest aftershock recorded has been magnitude 7.1 that did not produce a damaging tsunami.
survay said. 7.0 plus earthquake..
link to god
http://www.godlikeproductions.com/forum1/message2609673/pg1 :@ :sleepy:
Re: Ice Age Model
« Reply #179, on August 3rd, 2014, 02:16 PM »Last edited on August 4th, 2014, 01:05 AM
torque times delta T has become very long.  dragged by the heels of the chariot. plume waving. :P a single explosive eruption. 1.5 km high.
phase one.
Kuchinoerabu-Jima volcano (Ryukyu Islands, Japan): new eruption and pyroclastic flow
Pyroclastic flow from Kuchinoerabu-Jima yesterday
 A new eruption occurred yesterday at the volcano at 1245  local time. It consisted of a single powerful explosion from the Shin-Dake crater. An ash plume rose to approx 1.5 km height, and a pyroclastic flow was generated.
The eruption lasted about 10 minutes and much of the erupted mass collapsed into an impressive pyroclastic flow (hot avalanche of fragmented lava and gasses).
There are no reports of victims or damage. Japanese volcanologists raised the alert level to 3 and closed access to the summit area.
Re: Ice Age Model
« Reply #180, on August 5th, 2014, 03:59 AM »Last edited on August 5th, 2014, 04:02 AM
I want to make a comment on this quote from space weather? Really! As space weather NASA, and the USGS plunges deeper into there pile of crap.
Oh yea we just happened to plunge into a comets tail left over from a few years ago.. Wrong we are in a stream caused by known objects . keplerr 186. kepler 186 f temple one and heartley 2 comets. for starters do a search for real shooting star with a tail.
Magnetic anomaly continues torque times delta T is increasing. We follow the torque. Simple as that.  Next time around it wont be so unbelievable. Why? These effects are nearing a break point with catastrophic consequences.Atlantic ocean will be a lava pit and cracked like an egg before its all over. mexico strain is great, battle La follows. usa volcanoes erupt.
a full week away of full on debri? please that is over a week of continual bombardment. never seen before :dodgy:
PERSEID METEOR SHOWER: Meteor activity is increasing as Earth plunges deeper into the debris stream of Comet Swift-Tuttle, source of the annual Perseid meteor shower. On the night of Aug 3-4, NASA cameras recorded more than a dozen Perseid fireballs over the USA. Counts are high even though the shower's peak is still more than a week away. To see for yourself, get away from city lights and look up during the dark hours before sunrise. You can also hear the Perseids o
Re: Ice Age Model
« Reply #181, on August 7th, 2014, 02:07 AM »Last edited on August 7th, 2014, 02:25 AM
  a blue glow. confirmation ice age model has a cause and effect chain that exeeds golbal warmers. and has proven itself able to document, and predict accurate model for ice age.  please comment of your concerns. ty.
ozone
ok people look at this, of course i had already said this is the case with ozone production at an extreem. this means it is ionizing radiation, and in part solar, and fulashima type radiations. ozone production.
i had said to monitor this case, no one has the meens. its a cry and a shame that people are so easy fooled. :(
Acute radiation syndrome
  (Redirected from Radiation poisoning)
Radiation poisoning and radiation sickness redirect here. This page is about the short-term systemic health effects of a large dose. For other uses of these terms, see Radiation poisoning (disambiguation).
Classification and external resources
A Japanese girl presenting the effects of radiation sickness.
ICD-10   T66
ICD-9   990
MedlinePlus   000026
eMedicine   article/834015
MeSH   D011832
Acute radiation syndrome (ARS), also known as radiation poisoning, radiation sickness or radiation toxicity, is a collection of health effects which present within 24 hours of exposure to high amounts of ionizing radiation. The radiation causes cellular degradation due to damage to DNA and other key molecular structures within the cells in various tissues; this destruction, particularly as it affects ability of cells to divide normally, in turn causes the symptoms. The symptoms can begin within one or two hours and may last for several months.[1][2] The terms refer to acute medical problems rather than ones that develop after a prolonged period.[3][4][5]
The onset and type of symptoms depends on the radiation exposure. Relatively smaller doses result in gastrointestinal effects such as nausea and vomiting and symptoms related to falling blood counts such as infection and bleeding. Relatively larger doses can result in neurological effects and rapid death. Treatment of acute radiation syndrome is generally supportive with blood transfusions and antibiotics, with some more exotic treatments such as bone marrow transfusions being required in extreme cases.[1]
Similar symptoms may appear months to years after exposure as chronic radiation syndrome when the dose rate is too low to cause the acute form.[6] Radiation exposure can also increase the probability of developing some other diseases, mainly different types of cancers. These diseases are sometimes referred to as radiation sickness, but they are never included in the term acute radiation syndrome.
Ebola virus disease (EVD) or Ebola hemorrhagic fever (EHF) is the human disease caused by the Ebola virus. Symptoms typically start two days to three weeks after contracting the virus, with a fever, sore throat, muscle pains, and headaches. Typically nausea, vomiting, and diarrhea follow, along with decreased functioning of the liver and kidneys. At this point, some people begin to have
bleeding problems.[1]
My goal : By taking certain considerations, and factors into account paving the way for new viable study dealing with past, present, and future crisis of the environment. With the flurry of data entering the debate, certain real factors may have been ignored, or misunderstood in recent years, leading to false, or misleading outcomes. The reader is stuck in the middle of this debate, asking more questions than having answers provided.
You might say mainstream global warming scientist look at a completely empty system, with no regard for all the facts, only including there axioms that blame The human race for any changes in that system.
Radioactive material, and the inability to contain it is there fault not mine. They have destroyed vast quantity of land mass, leaving it uninhabitable for generations, leaving piles of spent fuel rods in land fills, leaving that material in a delicate system such as earth enters the atmosphere, ground water, and destroys all life.
Every change leads to other changes. Simple these changes are accumulative, and the main cause of change in the system is not co2.When dealing with terminology, it was stated many factors mainstream claimed may have been overlooked, ignored, assumed, and misleading, or out right lies..
It was said facts stated in this model do not fit in with current understanding on the subject. Have the virtues of science been ignored, along with the process, and steps necessary for functionality of a working model been distorted over the years?
Everything is relative to the observer's point of reference in time and space.
See Euclidean plane reference. Once it has been described in this language, it is actually a simple matter to extend its concept to arbitrary dimensions. It has an Axis of rotation.
In one way the Earth is considered a closed system, in another it is open. Refer to auroras, it is a result of an external force. A CAME does cause induction of that energy into the ionosphere, that energy can indeed reach the surface as electric charge. I said it was closed, because I was relating to the atmosphere, assuming it did not leak into outer-space, but in reality it can. I include both perspectives
"Extra research section. :Axial position is following the torque. Angular momentum takes over. Its simply torque times delta T."
Author notes, and topics open for your review.
Greetings all, I have outlined key factors, that separate this model from main stream science. I would like to validate any responses to this topic.
4. Induction factor related to expansion periods during the time frame proposed, 2 years. This can be extended 2 more years taken what was learned.
5. Angular momentum, or earth rotational speed that is under change. Relative to the circulation of air flow, includes immediate relation, determining factor. Strong storms, and all related effects in the systems are still under observation.
6. Oceanic tidal surges, and there specific location to the rotational center of mass of the given body. Accompanied by marine life loosing the ability to navigate by instinct.
Even other magnetic variations in the system, causing airplanes to miss runways wile trying to land, and crash. Leading to the recalibration of airport automatic safe guards that use the earths magnetic field.
Concluding with the continued effects, time lines, and progressive events.
All of these factors were found to be related to cause, these are the major determining predictable factors that validate this model wile at the same time excluding less known causes such as an increase of coo levels in the system, the continued reduction of Antarctic ozone levels, or the depletion of the rain forests. Even by excluding all man made flora carbons of the last 100 years.
A genuine gravitational lensing effect, and an increase in uv bursts, magnetic flux, or pressure. A Cassini effect. Coronal mass ejections, solar flairs, and solar winds interacting with the earths ionosphere.
Leading to spectacular Auroras. Verify  ozone production, and the rarefaction of our atmosphere.
The twist is in the traits of the species. The doors that are enshrouded, are now open. The sleepy mouse comes out to play. We open our eyes, no need to be told analogy.
The magician does not reveal his secrets, but in this case science does.
Re: Ice Age Model
« Reply #182, on August 9th, 2014, 09:09 PM »Last edited on August 9th, 2014, 09:18 PM
Quote from freethisone on July 21st, 2014, 01:43 PM
this is very confirming. im sorry i have made the unpredictable predictable. sad face main stream?  are u tired of being dumb down? has ice age mmodel not predicted acuratly. lets just wait for the volcanic explosive eruption and put a exlamation on ice age model..
answers questions current models lack. welcome to planet freethisone. the two Italians discovered it first. up your nose Toney.. kepler  186F they claimed to have taken a year or two too have confirmed there claims. but i did it 4 years ago, and ice age model validates my claim. others also. and made very accurate predictablity.. you must be  interested by now?
a volcanic eruption was also assumed and we will wait on this explosive eruption to follow..  this 6.8 was just what i was looking for. you must know by now my curve is also accurate. it was above 7.0.. on this day made confimation for accurate earthquake prediction. 7/21/2014
  Latest Earthquake News and Real-Time Earthquake Alerts:
STRONG EARTHQUAKE:  A strong earthquake hits Fiji Region  with a moment magnitude of Mw 6.8  at a depth of 610 km (deep-focus earthquake,5h and 37m ago)  View Location
Today: 6.9 magnitude earthquake in South Of Fiji Islands
Yesterday: 6.2 magnitude earthquake near Nemuro, Hokkaido, Japan
http://earthquaketrack.com/quakes/2014-07-21-14-54-41-utc-6-9-616
Imagery ©2014 NASA, TerraMetrics
Terms of Use
Map
Satellite
about 6 hours ago
UTC time: Monday, July 21, 2014 14:54 PM
Your time: Monday, July 21 2014 10:54 AM
Magnitude Type: mww
USGS page: M 6.9 - 94km NNE of Ndoi Island, Fiji
USGS status: Reviewed by a seismologist
Reports from the public: 0 people
be aware these are at least class 2 eruptions. this on the back end, and still tourqing, another 7.0 or higher would be a reasonable assumption. but a dumb down 6.5 is most like the data will reflect. on the fifth day, on the 15th of this month i will test a blind in the dark prediction for a quake..the next 7 day ice age model  should have be able to  continue to predict cause and effect chain.
 at least one ore two quakes. 6.5 or higher 7 days or less.just as a blind test.  will such a quake really happen? we will see. on the fifth day.
as a result of front and back time lines. this 2nd eruption was on the 19 th day, with the mirror eruption of class 1 or 2   that marks the inductions lag time.causing  explosive eruption in the given frame..eruO:-)
2nd explosive eruption, :dodgy:
August 2014 – ITALY – Stromboli volcano lava eruption: The lava effusion continues at decreasing, but still considerable rate. When seen yesterday evening, only one channel, 5-10 m wide was still entering the sea at 10 m wide front, while there had been up to 7 branches reaching the shore in the area west of or partially covering the 2007 lava delta. Small explosions were occurring at the sea entry. Several lava branches were still weakly active on the upper Sciara, causing many incandescent rock falls.
It appears that a part of the NE flank of the NE crater has collapsed and that the new effusive vent is located at its northern base, at approx. 700 m elevation. Thus, being lower than the summit vents, it is able to effectively drain the upper part of the volcano’s plumbing system, which explains why no explosions were observed at the summit craters. –Volcano Discovery
Ecuador’s volcano spews lava: The 5,023-meter (16,575-foot) volcano Tungurahua, in Central Ecuador, spewed lava and incandescent rocks from its crater in its latest activity on Thursday. Tungurahua has been shooting plumes of ash into the sky to a distance of upto three kilometers (1.8 miles) since the beginning of the week. Civil defense officials have issued an “orange warning,” – involving voluntary evacuation – to villagers living near Tungurahua’s flanks. The Tungurahua volcano has been active since 1999. In 2006, it spewed large clouds of ash down its slopes, killing four people and leaving two missing. –
first explosive eruption
 Reply #163 18 days ago »
Volcano Explodes in Indonesia
June 1st, 2014 at 12:27 am by Bill Steffen under Bill's Blog, News, Weather
Volcano Sangiang wikipedia  Volcanoes Indonesia  There has been a significant volcanic eruption in Indonesia.  Mt. Sangeang Api (see map – click to enlarge) erupted several times Friday and Saturday, sending smoke and ash tens of thousands of feet into the air.  Here’s a satellite view of the eruption.   Cool pics. here of the smoke/ash cloud expanding out.  Dozens of flights were cancelled because of the ash cloud.  There have been some gigantic volcanic explosions in the past in Indonesia, including Tambora in 1815 (1816 was the Year Without a Summer) and Krakatoa in 1883.  A major eruption can put enough ash into the upper atmosphere to cool the Earth.  A relatively short (6 mo.) and small bump downward in global temperature occurred after the Pinetubo eruption in the Philippines in 1991.  While the mainland U.S. is relatively quiet when it comes to volcano eruptions (anyone remember Mt. St. Helens – May 18, 1980?), there is certainly the potential for an eventual major eruption.  At some point the “supervolcano” beneath Yellowstone N.P. in Wyoming will erupt.   Michigan is a state that is relatively free from natural catastrophe.  Yeah, we get winter, an occasional severe storm or rare tornado…but we don’t get strong earthquakes, volcanoes, hurricanes or (in S. Lower Michigan) significant wildfires.  For many years I told people that the biggest disaster in Michigan was the Detroit Lions.   In 2008-09 that line really worked!
http://blogs.woodtv.com/2014/06/01/volcano-explodes-in-indonesia/
explosive eruption was a first response to magnetic and gravitational effects. Induction.as a guied line,and is a first in a cause and effect chain. perhaps the interaction may still lead to a second great quake or 7.4 and above. up to 40 days observation. look for volcanic events this 3 to 6 month period we get hot. aand during tourque times delta T 2015 we will have our temple one heartly 2 comet. these object are of high mass and density. they are sun skipping stone. i had theorized these object oragin in the mira star system . Is perhaps a remnant of a companion star.
Re: Ice Age Model
« Reply #183, on August 10th, 2014, 02:10 PM »Last edited on August 10th, 2014, 02:33 PM
Quote from freethisone on August 9th, 2014, 09:09 PM
day one southern, and northern hemisphere large , and very significant quakes..
Latest magnitude 4.5+ earthquakes
M 5.0, 74km ENE of Santa Rosalia, Mexico 27.6476 -111.6223
Sunday, August 10, 2014 18:46:17 UTC
Sunday, August 10, 2014 11:46:17 at epicenter
Depth: 10.00 km (6.21 mi)
M 5.0, 118km SE of Atka, Alaska 51.5206 -172.8623
Sunday, August 10, 2014 18:27:41 UTC
Sunday, August 10, 2014 06:27:41 at epicenter
Depth: 27.42 km (17.04 mi)
M 4.5, 7km NE of Nahrin, Afghanistan 36.1075 69.1977
Sunday, August 10, 2014 15:16:43 UTC
Sunday, August 10, 2014 19:46:43 at epicenter
Depth: 14.27 km (8.87 mi)
M 4.5, 254km NNE of Ndoi Island, Fiji -18.4179 -178.1296
Sunday, August 10, 2014 14:35:06 UTC
Sunday, August 10, 2014 02:35:06 at epicenter
Depth: 562.02 km (349.22 mi)
M 5.6, 117km ESE of Pondaguitan, Philippines 5.853 127.1141
Sunday, August 10, 2014 13:33:23 UTC
Sunday, August 10, 2014 21:33:23 at epicenter
Depth: 98.64 km (61.29 mi)
M 5.0, Central Mid-Atlantic Ridge 0.829 -26.1336
Sunday, August 10, 2014 12:12:25 UTC
Sunday, August 10, 2014 10:12:25 at epicenter
http://earthquakestoday.info/
1 Day, Magnitude 2.5+ Worldwide
32 earthquakes - Download
Updated: 2014-08-10 17:13:26 UTC-04:00
Showing event times using Local System Time (UTC-04:00)
5.0
2014-08-10 14:46:17 UTC-04:0010.0 km
2.8
64km SSW of Redoubt Volcano, Alaska
2014-08-10 14:38:21 UTC-04:00100.0 km
5.0
 :huh:the date is important.
Magnitude 6.0 quake strikes of coast of Japan
Reuters
August 3, 2014 12:29 AM
today Strong magnitude 6.0 quake hits off northern Japan
AFP | Aug 10, 2014, 09.55 AM IST
READ MORE Tokyo|Pacific Ocean|Natural Disaster|Japan
RELATED
India-Japan effortJapanese PM Abe keen to have Modi over in TokyoAn eatery in Tokyo that offers 'balding discount'Moscow voted worst city for tourists, Tokyo is best: PollJapan expresses 'grave concern' about Thailand situation
TOKYO: A 6.0 magnitude earthquake struck off northern Japan on Sunday, the US Geological Survey said, but Japanese authorities did not issue a tsunami warning and there were no immediate reports of damage.
The quake struck at 12.43pm (0343 GMT) in the Pacific Ocean off Japan's northern Aomori prefecture at a depth of 37 kilometres (23 miles), the US agency said.
Aomori prefecture is some 600 kilometres northeast of Tokyo. Japan's islands are situated at the conjuncture of several tectonic plates and experience a number of relatively violent quakes every year.
But, thanks to strict building codes, even powerful quakes that might wreak havoc in other countries frequently pass without causing much damage.
In May, a strong 6.0 magnitude earthquake shook buildings in the Japanese capital Tokyo, injuring 17 people. :@
Read or leave comments
Stromboli volcano
stratovolcano 926 m
 Eolian Islands, Italy, 38.79°N / 15.21°E
Stromboli webcams / live data
Stromboli volcano videos
Stromboli volcano eruptions:
 Persistant (near-constant) activity since at least 2-3000 years. Lava flow eruption from Dec. 2002-July 2003, and in March 2007.
Typical eruption style:
Small explosive (strombolian) eruptions, typically every 20-30 mins. Intermittently, ca. every 2-20 years, minor effusive eruptions (lava flows); on average 2-5 times per year larger explosions.
Last earthquakes nearby Lava flow and explosions in Jan 2013Tours to Stromboli and other volcanoes in Italy...
Stromboli volcano update: Continuing lava flows
Saturday Aug 09, 2014 10:47 AM | BY: T
Stromboli's lava flows yesterday night
Several lava branches were still weakly active on the upper Sciara, causing many incandescent rockfalls.
It appears that a part of the NE flank of the NE crater has collapsed and that the new effusive vent is located at its northern base, at approx. 700 m elevation. Thus, being lower than the summit vents, it is able to effectively drain the upper part of the volcano's plumbing system, which explains why no explosions were observed at the summit craters.
Re: Ice Age Model
« Reply #184, on August 12th, 2014, 11:41 AM »Last edited on August 12th, 2014, 11:47 AM
radio flux remains skewed, m, class flare are observe, solar or coronal filiment continue to be a threat.
the sun report before you hear it from them/ 8-12-14
yes the next 23 days will continue to have the possibility of earth directed cme.  cme is high, and so is solar irridation.
sun spots crackling and m and x clas flares will be expected. look for volcanic eruptions to increase over the next  5 months.,
 look for the cracking of the egg shell earth. its getting to the point the strain will cause plate movement on a large scale. Mexico, up to Baja california is on watch..Usa volcanic eruption can be expected in a short time. up to 2 years. tidal surges are on watch alert level. and ionizing radiation continues to destroy all life. pacific ocean almost dead now 2 more years of this, and so will we.
earthquake level increase to 7.0 and 6.0 during the same period.
a battle la may be nearer then you think.. lung damage to people becomes evident. in a short time.
peace luv.. O:-)
Re: Ice Age Model
« Reply #185, on August 12th, 2014, 05:54 PM »Last edited on August 12th, 2014, 05:56 PM
Quote from freethisone on August 12th, 2014, 11:41 AM
... and ionizing radiation continues to destroy all life. pacific ocean almost dead now 2 more years of this, and so will we.
Ought to be interesting seeing people try to get themselves out of this scrape.
Sharpen your pen for the final chapter.  Make it count because it's all you have left.
https://www.youtube.com/watch?v=fsFpm4yAoMQ#
Re: Ice Age Model
« Reply #186, on August 13th, 2014, 02:24 AM »
I totally agree to Carlin.
The interesting thing is that nobody cares ... no replies, no attention, no changes in mindset ...
interesting species being sucked down the sink now ;-)
homo sapiens sapiens??? can´t be ...
home freakius curiosus would be a tighter fit ...
Re: Ice Age Model
« Reply #187, on August 13th, 2014, 03:01 AM »
Quote from Matt Watts on August 12th, 2014, 05:54 PM
Those with open eyes have started to find their sanctuary some time ago now. the others will wait until the highways are blocked by all the other bystanders ... they will cry and beg and shout "how could we know ..."
they could have known ...
Re: Ice Age Model
« Reply #188, on August 13th, 2014, 04:12 AM »Last edited on August 13th, 2014, 04:19 AM
test people, buy gas mask or resperator ware it to test for ozone and ionizing radiation in your area.  after 15 min of use take off the mask and breath trough the nose.. can you smell it? or is your nose messed up already from 2 years of exposure? allergies? please..have a wet or runny nose, well then this is the case, and its not rag weeds..
i can show you how to make a detector for under 50 bucks. picks up ozone,  ions, and saturates the gap until continual discharge is seen. be sure energy is coming in, when levels are high the gap is caused to be more conductive due to the rare air.,, and a warning will sound. a continual discharge that crosses a larger spark gap without the need for adjustments.. O:-) but is fully adjustable. by screw type gap settings.   cheers.. :sleepy:
Re: Ice Age Model
« Reply #189, on August 13th, 2014, 02:29 PM »
Matt, Nav, Gunther, Russ, none have posted as to my model at all. :( :huh: every post has to do with something other then ice age model.
are you even sure you are allowed to express your conserns here? ice age model has set a standard far above any other theory.
guys i want your feed back to date and tell me what you learned from this model?  does it continue to asstonish main streem global warmers. yes ! :P
they are speechless and only wish to delete all the information to date, sad face people.
i want you to tell me that to your amazed at ice age model, because it  delivered  a cause and effect chain that main stream excludes., and could only dream to reach the pinacal of there fields.
ice age model works its magic on every aspect of nature. a cycle of external precession, and the effects  predicted.
The results speak for them self, but the forum has nothing to say. no questions... :dodgy:
Re: Ice Age Model
« Reply #190, on August 14th, 2014, 02:31 AM »
I have not gone into detail of your ice age model. you are the expert for that. but I agree to increasing solar activities and major changes in vulcanic activities.
to my opinion nature starts to strike back to our ignorant species ...
not getting replies to one´s own subjects is an experience you and me share. take a look at the number of active members and dormant members ...
it´s always 2% ... not more ...
Re: Ice Age Model
« Reply #191, on August 14th, 2014, 03:25 AM »Last edited on August 14th, 2014, 03:30 AM
Quote from Gunther Rattay on August 14th, 2014, 02:31 AM
thanks for your honesty. the real information i on page one. but every quake predicted are scattered around as verified data.
i have advanced my theory for ice age and i conclude. It is true we have external forces, induction, and red shift.
I refine this situation of ex-po star K.
what had happened was the entire air mass above ant-artica is moving to the north. ant-artic tropical, continental flow.is my term. and it is the proper term.
but we first get huge ice melts in the north. this because the sun is now shining on the entire area for a much longer period of time for a day.Time zones blended.
but because ant artica get less solar radiation as a result. the storms, and flooding will continue in the north. a longer period of time is assumed before temps reach a freezing point in the north, and the ice caps grow at a very fast rate. long run 5 to 10 years..?
each summer flood waters from snow run off will be a concern. in the long run temps will fall at a faster rate in the north.,after temps fall even further in the south. every year that follows.
i say the southern pole will build up faster, and the northern pole will now have the severe weather as a result. this is confirmed. europe zone is flooded a 4 year process was observed..
 think about it. the south pole gets much colder, over time the north pole will sustain a freezing temp  to support the newly formed ice caps, and continual rains.
A 10- 100 year process. should be observed, and recorded,
 O:-)  thanks again for the post on topic..
Re: Ice Age Model
« Reply #192, on August 18th, 2014, 02:11 PM »
 250 injured after strong earthquake hits Iran near border with Iraq - CNN
Aljazeera.com
CNN
(CNN) -- A powerful earthquake struck early Monday in western Iran, injuring at least 250 people in a region near the border with Iraq. Local authorities said they fear the quake may have caused widespread destruction in rural areas. The 6.2-magnitude ...
Iran rocked by 6.3 magnitude earthquakeAljazeera.com
Iran Earthquake 2014: Strong Temblor Hits Western City, Injuring DozensHuffington Post
Western Iran hit by earthquake of magnitude 6.3 - USGSReuters UK
KGNS.tv -AccuWeather.com
all 242 news articles »
on the 8th day. we have a dumb down 6.3  hundreds of aftershocks..
as we see super storms will now spawn as a result of angular momentum change.
the sun glows like a candle, all the ions point to its discharge, crossing the spark gap trigger. volcanic eruption these days and weeks ahead. spectacular effects as a result of torque. these storms are no stranger but as a result we have a band of brothers moving in and across the pacific. the gulf is very warm at this point. high winds as a result, and storms marching across the USA up into and across the Atlantic.
farmers should protect there crops. flood waters, and tidal flooding would also be a result of angular momentum changes. November this year the Earth will now break like an egg, and continue sliding to the east, volcanic eruption on a large scale to follow. air become clearly toxic, as it continues to ionize due to solar  intensity., and radiations producing ozone high levels.
Re: Ice Age Model
« Reply #193, on August 18th, 2014, 07:00 PM »
Worldwide Volcano News and Updates:
latest (Aug 2014) | Jul 2014 | Jun 2014 | archive
Monday, Aug 18, 2014
Stromboli volcano (Eolian Islands, Italy): increased lava flow activity
Lava flow on Stromboli this evening (INGV Sciara del Fuoco webcam)
Corresponding thermal image
 The eruption continues with no significant change, but lava effusion seems to have increased. Several secondary active branches formed on the upper part of the new lava flow field and are visible on webcam images. More about Stromboli volcano
Volcanoes Today, 18 Aug 2014: Bárdarbunga
Bárdarbunga volcano (Iceland): continuing earthquake swarm & inflation, orange alert
Earthquakes under Bárdabunga volcano during the past days
 An eruption of the subglacial volcano seems more and more likely to be imminent. Rapid inflation suggests magma intrusion at shallow depth. Orange alert has been declared today by the Iceland Met Office (IMO).  ...more
 [read all] More about Bárdarbunga volcano
Sunday, Aug 17, 2014
Volcanic activity worldwide 17 Aug 2014: Bárdarbunga, Mayon, Stromboli, Etna
The active lava flow on Stromboli's upper Sciara del Fuoco (INGV thermal webcam)
Current tremor signal (ECPNZ station, INGV Catania)
Stromboli (Eolian Islands, Italy): No significant changes have occurred during the past days. The lava flow continues to be active from the vent at the base of the NE cone, but the effusion rate is slowly decreasing overall.  ...more
 [read all]
to top
Stromboli volcano (Eolian Islands, Italy) activity update
 No significant changes have occurred during the past days. The lava flow continues to be active from the vent at the base of the NE cone, but the effusion rate is slowly decreasing overall. More about Stromboli volcano
Mayon volcano (Philippines): new lava dome in summit crater
A small lava dome is present at the top of the volcano. During a field survey on 12 August, PHIVOLCS scientists observed a new lava dome, approx. 30-50 m high. It is not known when exactly the dome had grown, but it seems likely that it was relatively recently.  ...more
 [read all] More about Mayon volcano
Bárdarbunga volcano (Iceland): earthquake swarm, possible subglacial eruption
Earthquakes under Bárdabunga volcano (Icelandic Met Office)
Harmonic tremor (Dyngjuháls SIL station, IMO)
 An intense earthquake swarm started yesterday under Bárðarbunga volcano, located under the northwestern part of the Vatnajökull ice cap. It is continuing at the moment and accompanied by elevated harmonic tremor.  ...more
Friday, Aug 15, 2014
Volcanic activity worldwide 15 Aug 2014: Kilauea
Kilauea (Hawai'i): The June 27 flow remains active on Kilaueas East Rift Zone, and has advanced further into the forest over the past week. The flow front is 8.5km (5.3mi) NE of the vent on Puʻu ʻŌʻō. The flow's continued brisk advance rate is likely related, in part, to its continued confinement by local topography. In this USGS photo, the narrow flow front was within one of the many linear depressions (grabens) on the East Rift Zone.  ...more
 [read all]
to top
Thursday, Aug 14, 2014
Volcanic activity worldwide 14 Aug 2014: Etna, Ijen, Slamet, Sabancaya, Bagana, Shishaldin, Stromboli, Soputan
Stromboli (Eolian Islands, Italy): A set of videos showing the new lava flow, the sea entry and explosive interaction with the sea water is available at our Stromboli August 2014 video page.  ...more
 [read all]
Kelut volcano (East Java, Indonesia): alert level lowered
Due to visual and instrumental monitoring results as well as level of potential hazards the Alert Level for Kelut was lowered to 1 (on a scale of 1-4) on 12 August. Residents and visitors were advised to not approach the crater rim, crater floor, or the rivers that disgorge from Kelut.
More about Kelud volcano
poweful eruptions have been predicted. it gets hot enough to start to wonder is it safe???.
Re: Ice Age Model
« Reply #194, on August 20th, 2014, 02:18 PM »
you heard it first from the autour. Cheers. :blush:
https://theextinctionprotocol.wordpress.com/ hot of the press ionizing radiation. and flooding. with eruption on a large scale.
Erupting volcano off the coast of Japan could cause tsunami
Posted on August 20, 2014 by The Extinction Protocol
August 2014 – JAPAN – An erupting volcanic island that is expanding off Japan could trigger a tsunami if its freshly-formed lava slopes collapse into the sea, scientists say. The small, but growing, island appeared last year and quickly engulfed the already-existing island of Nishinoshima, around 1000 kilometers south of Tokyo. It now covers 1.26 square kilometers. The island’s craters are currently spewing out 200,000 cubic meters of lava every day – enough to fill 80 Olympic swimming pools – which is accumulating in its east, scientists said. “If lava continues to mount on the eastern area, part of the island’s slopes could collapse and cause a tsunami,” warned Fukashi Maeno, assistant professor of the Earthquake Research Institute at the University of Tokyo. He said a rockfall of 12 million cubic meters of lava would generate a one metre tsunami that could travel faster than a bullet train, hitting the island of Chichijima – 130kms away – in around 18 minutes, he said. Chichijima, home to about 2000 people, is the largest island in the Ogasawara archipelago, a wild and remote chain that is administratively part of Tokyo.
“The ideal way to monitor and avoid a natural disaster is to set up a new tsunami and earthquake detection system near the island, but it’s impossible for anyone to land on the island in the current situation,” Maeno added. An official from the Japan Meteorological Agency, which monitors earthquakes and tsunamis, said the agency is watching for any signs of anything untoward. “We studied the simulation this morning, and we are thinking of consulting with earthquake prediction experts … about the probability of this actually happening, and what kind of measures we would be able to take,” he said. Japan’s northeast was ravaged by a huge tsunami in March 2011, when a massive undersea earthquake sent a wall of water barreling into the northeast coast, killing more than 18,000 people and wrecking whole towns. -3News
contribution Irene
Posted in Avalanche, Civilizations unraveling, Earth Changes, Earth Watch, Earth's core dynamics, High-risk potential hazard zone, Landslide & geological deformation, Lava flow, Magma Plume activity, New land rises from sea, Potential Earthchange hotspot, Prophecies referenced, Signs of Magnetic Field weakening, Strange high tides & freak waves, Time - Event Acceleration, Volcanic Eruption, Volcano unrest, Volcano Watch    | Leave a comment
32 killed, 9 missing in flooding and landslides, as heavy rains lash Hiroshima
August 2014 – ASAHIKAWA, Japan — At least 32 people were killed and nine more were still missing in the western Japanese city of Hiroshima on Wednesday after heavy rain caused flash floods and landslides that buried victims alive as they slept in their homes, the police said. Hundreds of soldiers have been sent to the scene to dig for survivors. Prime Minister Shinzo Abe, who had been on summer vacation, cut short a game of golf to rush back to Tokyo to lead the response to the disaster, government officials said. While deadly landslides are common in this densely populated, mountainous nation, death tolls rarely reach this high. According to the police, the dead included two young boys, brothers aged 2 and 11, who were both buried when a wall of mud engulfed their home in a neighborhood that sits at the foot of a steep mountainside. A firefighter also died while engaged in rescue operations, the police said. The landslides took place around 3:30 a.m. local time, after rainfall of up to four inches per hour was recorded by the national weather agency. Many of the victims appeared to be asleep when entire hillsides, heavy with the weight of rainwater, suddenly gave way.
Japanese news reports quoted one survivor as saying that he had heard the frantic screams of the buried boys’ mother and had rushed to find their house covered in mud. He said he dug with his bare hands until he found the younger boy, but he could not free him because of furniture and other debris, according to Kyodo, a Japanese news agency. The boy was dug out two hours later by rescuers, who were unable to revive him, the agency said. Video footage taken by helicopter showed thick layers of mud and, in some places, raging torrents of muddy water flowing through what had been neighborhoods of tightly spaced homes. Many of the wooden houses had been shattered into broken planks and piles of colorful roof tiles. –NY Times
Re: Ice Age Model
« Reply #195, on August 21st, 2014, 03:28 PM »
This is the case, X class solar flare..
X class back end.
reflected as Mhttp://www.swpc.noaa.gov/rt_plots/Xray.gif
MYSTERY IN THE OZONE LAYER: More than 27 years after the Montreal Protocol regulated chemicals that destroy ozone, a damaging compound named carbon tetrachloride (CCl4) is still surprisingly abundant in the ozone layer. "We are not supposed to be seeing this at all," says NASA atmospheric scientist Qing Liang. Countries around the world report zero emissions of CCl4, yet the amount actually in the ozone layer corresponds to 39 kilotons per year. Where is the compound coming from? Some of the possibilities are discussed in a NASA press release.
WEAK IMPACT? MAGNIFICENT AURORAS: Visually, the CME that struck Earth's magnetic field on August 19th was dim and unimpressive. The auroras it produced were magnificent. "For the first time in my life, I saw the Northern Lights," says Tadas Janušonis who sends this photo from Vabalninkas, Lithuania:
ionizing radiation by known causes.
The Proof is in the pudding, ice age model continues to lead the way for solar observation, and cause and effect chain associated with tourque times delta T O:-)
Re: Ice Age Model
« Reply #196, on August 22nd, 2014, 04:18 PM »
more explosive eruptions.  Friday, Aug 22, 2014
Volcanoes Today, 22 Aug 2014: Ubinas volcano, Fuego
Fuego volcano (Guatemala) activity update
Explosive activity has been relatively high recently. Individual eruptions have been producing ash plumes that rose to up to 1 km and incandescent material was seen rising 150-200 m above the crater.
Shock waves often accompany the stronger explosions. There is no lava flow currently.
Ubinas volcano (Peru): sudden strong explosion
Powerful vulcanian explosion at Ubinas yesterday
 After a being relatively since the end of July, a powerful explosion occurred suddenly at the volcano yesterday afternoon at 15:36 local time.
The explosion ejected blocks to up to 2 km distance and produced an ash plume that rose to approx. 7-8 km altitude.
The eruption was likely a vulcanian-type event, i.e. caused by the sudden release of pressure as viscous (sticky) and gas-rich magma had accumulated beneath a solid plug in the vent. It shows that the eruptive phase at the volcano continues and is capable of producing extremely dangerous explosions
Re: Ice Age Model
« Reply #197, on August 23rd, 2014, 02:29 AM »Last edited on August 23rd, 2014, 02:37 AM
Quote from freethisone on August 18th, 2014, 02:11 PM
Tropical Storm Cristobal to Form, Impact US Eastern Beaches
Kristina Pydynowski
By Kristina Pydynowski, Senior Meteorologist
August 23, 2014; 3:15 AM
Aljazeera.com
CNN
http://www.weather.com/news/science/environment/powerful-photos-climate-change-global-warming-20140820
32 Powerful Photos of the World Feeling the Impact of external net force precession.
http://www.weather.com/news/weather-hurricanes/tropical-threat-caribbean-gulf-mexico-20140820
go to this yellow stone cam  http://www.nps.gov/features/yell/webcam/oldFaithfulStreaming.html
it is true volcanic activity has risen in a 4 year period.
East Pacific Hurricane & Tropical Storm Center
Hurricane Karina is a Category 1 Hurricane located at 16.7 N, -134.4 W with maximum sustained winds of 80 mph, gusting to 100 mph more >
Tropical Storm Lowell is located at 23.4 N, -126 W with maximum sustained winds of 45 mph, gusting to 60 mph more >
Hurricane Marie is a Category 1 Hurricane located at 14 N, -105.7 W with maximum sustained winds of 75 mph, gusting to 90 mph more >
 O:-)
8/23/2014 5:56:05 AM
A developing area of low pressure just to the north of Hispaniola continues to develop more convection and a spin, meaning this will likely become our next system in the Atlantic Ocean. The system is pulling off to the northwest of Hispaniola currently, after bringing some heavy rain and gusts to near tropical storm force. Winds as of early Friday evening were sustained near tropical storm force, but there is no well defined center for the system, meaning this is still not a tropical depression or storm yet.
This system will push northwest over the day Saturday and bring some heavier rainfall to the southern Bahamas already during the day. With this system moving more northwest, the shear on the storm is looking to decrease, meaning there is a better chance for development later Saturday into Saturday night. By this time, this may be the third named storm of the Atlantic tropical season. The name of this storm would be Cristobal. The exact track of the storm is still uncertain, but it is possible this may track near Florida before curving back over the Atlantic as it pushes off to the northeast. Any possible affects to the United States are not expected until later Sunday into Monday at the earliest.
The main affect from this system now are higher surf around the Caribbean and some heavier rainfall over the Dominican Republic. This is likely to bring some stronger wind gusts to the southern Bahamas as early as Saturday night, with some heavier rain and rough surf. This system will have its best chance to develop near the Bahamas, and if development is slow it may stay below hurricane strength. No matter the strength of the storm, residents of South Florida need to watch the progress of the system.
It is quiet across the rest of the Atlantic basin and tropical development is not expected over the next couple of days.
By AccuWeather.com Meteorologist Alan Reppert
Re: Ice Age Model
« Reply #198, on August 23rd, 2014, 09:02 PM »Last edited on August 23rd, 2014, 11:25 PM
Ubinas volcano (Peru): sudden strong explosionhttp://www.nps.gov/features/yell/webcam/oldFaithfulStreaming.html
Friday Aug 22, 2014 12:35 PM | BY: T
The eruption was likely a vulcanian-type event, i.e. caused by the sudden release of pressure as viscous (sticky) and gas-rich magma had accumulated beneath a solid plug in the vent. It shows that the eruptive phase at the volcano continues and is capable of producing extremely dangerous explosions. Sunday, Aug 24, 2014
Volcanoes Today, 24 Aug 2014: Bárdarbunga volcano
Bárdarbunga volcano update: Uncertainty about eruption, magnitude 5.3 earthquake
Tremor has dropped again. A magnitude 5.3 earthquake occurred shortly after midnight at 10 km depth.
There are no clear signs telling whether eruptive activity is still (or had all all been) going on.
IMO writes "Presently there are no signs of ongoing volcanic activity. The aviation color code for the Bárðarbunga volcano remains red as an imminent eruption can not be excluded."
Aljazeera.com
CNN
A 6.6 to boot. magnetic field is now frozen, magnetic re allignment..
6.6 earthquake in Chile, U.S. Geological Survey says
The Associated Press 9:08 p.m. EDT August 23, 2014
AFP 532672741
(Photo: Martin Bernetti, AFP/Getty Images)
 183
CONNECT
 67
TWEET
 2
LINKEDIN
 2
COMMENT
EMAIL
MORE
SANTIAGO, Chile — A 6.4-magnitude earthquake rocked the region around Valparaiso, Chile on Saturday, the U.S. Geological Survey reported.
No injuries or serious damage from the strong quake that occurred at 7:23 p.m. ET were reported, but electricity and telephone service was interrupted in some areas.
The seismological service initially reported the initial quake's magnitude as 6.6, but later downgraded it to 6.4.
Earthquakes in the range of 6.1 to 6.9 happen about 100 times a year, according to the Department of Geological Engineering and Sciences at Michigan Technological University. But they can cause a lot of damage in populated areas and can be felt hundreds of miles from the epicenter.
<!--iframe-->
The seismological service said a preliminary report showed the quake was centered about 11 miles west-northwest of a community called Hacienda La Calera, about 67 miles northwest of the capital of Santiago. It had a depth of about 19 miles.
The largest recorded earthquake was the Great Chilean Earthquake of May 22, 1960, which had a magnitude of 9.5. Each whole-number increase on the Richter scale represents a tenfold increase in an earthquake's strength.
Copyright 2014 The Associated Press. All rights reserved. This material may not be published, broadcast, rewritten or redistributed.
 :dodgy:
Eastern Pacific   tab   tab   Atlantic   tab
tab
Active Storms    |    Marine Forecasts
2-Day Graphical Tropical Weather Outlook     |    5-Day Graphical Tropical Weather Outlook
Atlantic - Caribbean Sea - Gulf of Mexico
Tropical Weather Outlook (en Español*)
800 PM EDT SAT AUG 23 2014   Tropical Weather Discussion
805 PM EDT SAT AUG 23 2014
TC Type ImageTropical Depression FOUR  RSS Feed icon   Satellite | Buoys | NDFD | Storm Archive
...DEPRESSION MOVING NORTHWESTWARD NEAR THE SOUTHEASTERN BAHAMAS....
11:00 PM AST Sat Aug 23
Moving: NW at 9 mph
Min pressure: 1005 mb
Max sustained: 35 mph
Public
Advisory
#2
1100 PM AST    Aviso
Publico
not
available    Forecast
Advisory
#2
0300 UTC    Forecast
Discussion
#2
1100 PM AST    Wind Speed
Probabilities
#2
0300 UTC
 Hurricane Wind Speed Probability
Hurricane Wind
Speed Probability
 50-knot Wind Speed Probability
50-knot Wind
Speed Probability
 34-knot Wind Speed Probability
Trop Storm Wind
Speed Probability
 Wind History
Wind
History
 Google Maps API Warnings and Track Forecast Cone
Warnings/Cone
Interactive Map
 Warnings and 5-Day Cone
Warnings/Cone
Static Images
 Surface Wind Field
Warnings and
Surface Wind
 Mariner's 1-2-3 Rule
Mariner's
1-2-3 Rule
*Spanish translations courtesy of the NWS San Juan Weather Forecast Office.
Information about experimental Spanish Tropical Cyclone Forecast Discussions can be found here.
Eastern Pacific (East of 140°W)
500 PM PDT SAT AUG 23 2014   Tropical Weather Discussion
0405 UTC SUN AUG 24 2014
TC Type ImageHurricane KARINA  RSS Feed icon   Satellite | Buoys | NDFD | Storm Archive
...HURRICANE KARINA BEGINS TO WEAKEN...
8:00 PM PDT Sat Aug 23
Moving: NE at 8 mph
Min pressure: 988 mb
Max sustained: 75 mph
Public
Advisory
#45
800 PM PDT    Forecast
Advisory
#45
0300 UTC    Forecast
Discussion
#45
800 PM PDT    Wind Speed
Probabilities
#45
0300 UTC
Hurricane Wind
Speed Probability
50-knot Wind
Speed Probability
Trop Storm Wind
Speed Probability
 Wind History
Wind
History
Warnings/Cone
Interactive Map
Warnings/Cone
Static Images
 Surface Wind Field
Warnings and
Surface Wind
Mariner's
1-2-3 Rule
TC Type ImagePost-Tropical Cyclone LOWELL  RSS Feed icon   Satellite | Buoys | NDFD | Storm Archive
...LOWELL DEGENERATES TO A REMNANT LOW...
Moving: NW at 8 mph
Min pressure: 1002 mb
Public
Advisory
#25
800 PM PDT    Forecast
Advisory
#25
0300 UTC    Forecast
Discussion
#25
Probabilities
#25
0300 UTC
Hurricane Wind
Speed Probability
50-knot Wind
Speed Probability
Trop Storm Wind
Speed Probability
 Wind History
Wind
History
Warnings/Cone
Interactive Map
Warnings/Cone
Static Images
 Surface Wind Field
Warnings and
Surface Wind
Mariner's
1-2-3 Rule
TC Type ImageHurricane MARIE  RSS Feed icon   Satellite | Buoys | NDFD | Storm Archive
...MARIE GAINING STRENGTH... ...LARGE SWELLS AND HAZARDOUS SURF CONDITIONS AFFECTING THE COAST OF MEXICO...
Moving: WNW at 14 mph
Min pressure: 971 mb
Max sustained: 105 mph
Public
Advisory
#9
800 PM PDT    Forecast
Advisory
#9
0300 UTC    Forecast
Discussion
#9
Probabilities
#9
0300 UTC
Hurricane Wind
Speed Probability
50-knot Wind
Speed Probability
Trop Storm Wind
Speed Probability
 Wind History
Wind
History
Warnings/Cone
Interactive Map
Warnings/Cone
Static Images
 Surface Wind Field
Warnings and
Surface Wind
Mariner's
1-2-3 Rule
http://www.nhc.noaa.gov/?epac
this is my band of brothers update
off line.. interesting timing. http://iswa.ccmc.gsfc.nasa.gov/IswaSystemWebApp/StreamByDataIdServlet?allDataId=674969997
Re: Ice Age Model
« Reply #199, on August 24th, 2014, 03:59 PM »Last edited on August 24th, 2014, 04:06 PM
well boys and girls. it looks like the influence of object M has been great. even to the point of all data being lied about. earthquakes, nasa, you name it..
mark your calenders on this day 08 ,23,1014. the spare gap was triggered. and we have explosive X class flares. It is very clear this is the case.
the M is for M class star The M class flare is for bull sheet..
see for yourself, X class flare with CME of billions of tons of material. directed at Earth.  were are a  direct hit.
 Now you have This..
Much bigger then a 6.0 reported at 6.4 with skew it was a 6.7 quake to boot. who said external forces dont have predictable effects?
6.0-magnitude earthquake hits San Francisco Bay area, injuring at least 120, three critical, and starting six fires
The epicenter of the tremor was about six miles southwest of Napa, California's wine country, where dozens were hospitalized Sunday.
THE ASSOCIATED PRESS Published: Sunday, August 24, 2014, 7:22 AM
When is the best time to see auroras? Where is the best place to go? And how do you photograph them? These questions and more are answered in a new book, Northern Lights - a Guide, by Pal Brekke & Fredrik Broms.
MINOR STORM WARNING: A CME is heading for Earth. The relatively slow-moving storm cloud left the sun on Aug. 22nd and looks like it will take 4 days to cross the sun-Earth divide. NOAA forecasters estimate a 15% chance of polar geomagetic storms on Aug. 26th when the CME arrives. Aurora alerts: text, voice
"M" FOR MAGNIFICENT: In the vocabulary of space weather, an "M-flare" is a medium-sized explosion. Today's M5.6-class eruption, however, was magnificent. NASA's Solar Dynamics Observatory recorded the blast:
An explosion in the magnetic canopy of emerging sunspot AR2151 hurled a dense and twised plume of plasma into space. The Solar and Heliospheric Observatory (SOHO) recorded a bright coronal mass ejection emerging from the blast site: movie. If this CME were to ht Earth, the likely result would be strong geomagnetic storms. However, because of the sunspot's location near the sun's eastern horizon, Earth was not in the line of fire.
Nevertheless, the flare did produce some Earth effects. A pulse of extreme UV radiation partially ionized our planet's upper atmosphere. This "Sudden Ionospheric Disturbance" (SID) altered the normal propagation of VLF (very low frequency) radio transmissions over the the dayside of Earth, an effect recorded at the Polarlightcenter in Lofoten, Norway: data.
http://www.weather.com/news/san-francisco-california-area-earthquake-20140824
http://www.spaceweather.com/?applecreek.com/weather.html
