Ice Age Model
Ice Age Model
« on October 28th, 2011, 12:51 PM »Last edited on November 17th, 2014, 08:54 PM by Matt Watts
This model in its physical form, and character was  made with great care to include all know probability in its most simple of form.
The establishment of the most probable of all the inputs i include for this simple model.
Greetings all.
I have been working on this theory over the last two years.
A warning this is a very unconventional theory, it only came to light recently, and is related to my special study's.
This will include research I have done in order to make global climate change theory possible to every reader.
I have determined a need to account for the recent flurry of questions about ice ages, and Global warming.
The information I will include will have as many Facts as possible for this very simple Ice age theory.
Background information, define ice age.
A change in climate were the northern pole, southern pole, or both begin to experience a build up of ice sheet, or snow cap for an unidentified period of time.
This can relate to mini Ice age definition as well.  The best I can do is relate this to observation.
'The "wiki"- definition An ice age or, more precisely, glacial age, is a generic geological period of long-term reduction in the temperature of the Earth's surface and atmosphere, resulting in the presence or expansion of continental ice sheets, polar ice sheets, and alpine glaciers.'
The wiki definition is also speculative. It considered an ice age as a long term scenario. I simply excluded that premise.
The basics . Q: When we describe a system effected by change, how do you determine, and go about explaining these changes in a scientific manner?
Include, and determine the state of changes occurring in the system leading to a functional physical working model.
My question was used to determine these factors.
The methodology, I had used the axiom assuming all is true.  I picked it apart piece by piece, what is left are these observations, and determinable effects.
I had tested for a high degree of accuracy.
All statements used for explaining changes by categorizing the fundamental laws of nature.
Change was determined by cause, and effect including only what is not assumed, but instead what is widely known.
Factor that are less widely known are also included, and gives answers to questions current models lack.
by use of axiom assuming all statements are true, and then by testing it for truth.
by using well known principles, explaining a cause for a given effect.
by keeping it very simple, including self evident or well known principles.
by explaining other less known causes for a given effect.
Try to see this for what I show. I have a carpenters level. It has a bubble of air in the center. The level is used to show what side is up, and what side is down. The air bubble in the center shows equilibrium.
How can I use this in my model that this is so in the case of our planet? How will this predict when a possible ice age will occur?
let earths axis be the level plane, and if I stretched my level from north to south pole the bubble is in perfect equilibrium.. This be the implication, the earth has an up and down.
Obviously Earth is not in perfect equilibrium, when it comes to cold air finding its place among the cold air in our planet system.
We may then state the planet is not in perfect balance, and the bubble resides over the southern pole, rather then the equator. Do you agree?
I will add to this, but if you see were I am going then, ask a question, ponder the thought..
How will that bubble then in fact shift from equilibrium? Not as hard as you may make it, but by a change in earth axial position. This would cause the bubble to shift.. do you agree?
We have a northern hemisphere, and a southern. If the coldest hemisphere be the southern, than because of Antarctica having a lower temperature then the north pole. This remains true.
Now I wish to cause all the cold air in the south to flow to the north. How can that be? A simple explanation.
A move in axis will prove a shift in bubble, and therefore equilibrium is now in the process of shift, and change.  The observable factor, and start of the age. Prediction is important.
I have determined the Northern side now in a process of cold air shift. That shift will eventually find its equilibrium with the coldest air once again above the northern pole.
There are many circumstances that can be related to an ice age, long term, or short term.
One of these circumstances has to do with the earths temperature in relation to the evaporation rate of the oceans world wide.
More evaporation, more water vapor in the atmosphere, and not in the oceans. Predictions that self verify are important.
How can cloud cover effect the globe in relation to temperature rains, snow, oceanic currents, and airflow circulation in the system?
In the same manner volcanic gasses may block out the sun. In the same manner if a deep impact was to occur here on earth, by causing the solar rays to be reflected.
This could lead to a progressive ice age, as time passes world temperatures will fall at a faster rate, more so after the blocking of solar radiation.
Other factors included are also determined, and  agree with current knowledge.
Such as gasses from volcanoes. this may block out the suns energy over time. I include the most understood factors, well known today by modern science.
Dust from either volcanoes, meteorite impacts, and the deforestation of the planet. To much air born material in the system.
Perhaps even a dust bowl world wide. leading to a colder climate due to less solar warmth reaching the earths surface.
Solar fluctuations, may lead to a cooling, or warming of earths surface. Both can lead to an ice age. I can  agree with that.
Location of equilibrium, or a change in Earth Axial position can lead to a warming, and cooling in one hemisphere over the other.
Non equilibrium. The teeter totter perspective. Similar is the function of a see-saw.
Factors included seem to answer all of the possible circumstances related to ice age periods.
Premiss.
By a change in Axial position, or equilibrium of Earth system in relationship to said  galactic plain. I can reflect this change in several ways.
1. By a change in location, and, or position of a body in relation to said plain. A body such as the Earth may experience diverse effects. Including magnetic anomaly, including a change in air flow direction, or temperature within the  given system. assuming it has an atmosphere.
2. A change in Earth axis position, to whatever degree may have diverse effects on the inner system, or atmosphere of said body.
This In relation to its present equilibrium, and its magnetic alignments to the stars.. The rotation of the given body, or its angular momentum can make predictable statements. Self verified today.
3. Ice age By volcanic emissions alone, or in conjunction with a change in equilibrium of a system. In relation to its orbit, axial position, and speed of rotation. May also lead to an ice age. Extremely non intuitive.
4 A large meteor impact may lead to an ice age, by the blocking of solar rays reaching the Earths surface.
All statements are true statements.. Yes or no? I have determined this is accurate.
How many of these effects mentioned have taken place today, and when did the first ideas develop?
1. For the axial shift, and bubble, yes there was 2 separate events in the last 2 years. the axis has shifted a total of 7 inches.
2. more then 30 volcanoes have erupted, and continue to erupt in the last 18 months.
fact. If you want to see the numbers of how much dust and ash have been sent hurling into the atmosphere. (quantity of gaseous material).
3. Water vapor level of our atmosphere is quickly increasing. Storms with high wind speed reflect these relations in the given way.  A change in angular momentum, and velocity of rotation.
I will also post the numbers. water vapor, or steam is the number one volcanic gas expelled by volcanoes. Include estimated gaseous material over time.
4. There has not been a deep impact on earth by meteorite in a long time. This observation of cause for an ice age today is therefore is excluded from any cause as of today. No deep impact.
I only need to show you with pictures how the air in the system, has made a change in direction in the last 18 months. I show air flow from the southern hemisphere is moving to the northern.
The proper term is arctic, tropical, continental flow. Crossing boundary lines.
5. Solar fluctuation, again this is present in this model. Solar energy is a given, and may decrease, or increase over time.. We now are in the 24 solar cycle, and it has produced  heating fluctuation on Earth also.
The sun has also produced many solar flare extremes during this event. 24th solar cycle started in 2010. All info can be found on the net about the problems of solar cycle 24. I can provide much more data. Make your own determinations on these conditions. Solar energy, angular momentum, volcanic eruptions, meteor impact, increase in gaseous materials , and dust in the system, axial shift, Etc..
Oceans reflect the immediate changes, and therefore determined a leveling off period is also is progressive.
All these effects  are ongoing, and observable.
The self verified Factor: solar anomalous, volcanic eruption on a large scale, tilt in axial position, Earth magnetic field anomalous, a change in direction of air circulation, and oceanic tides moving to the north.
The model is simple, and works very well for prediction. Excluding all global warming BS  mainstream claims.
According to this model are we closing in on an ice age?
Has all causing factors been reflected upon enough to make a determination? If we stick to known causes only. It definitely closely agrees.
Ice age cause,  simple verifying model.
See the movies I have made. Immediate determinations based on observation of the globe over time. The first movie was just after the Great chili quake. After the axis has shifted 3 inches.
Pleas pause this movie at 31 seconds, do you see what I do?  Intuitive of scientific  validating factors. The intimidate change is a constant in determining a cause.  There is a massive drip, or a drip of cold air moving toward the equator.  Looks like a change in equilibrium in the Earth system. This is the bubble I have reflected. Some may say this is a wobble, some may say indeterminable. Further  scientific observation does not  agree with the given notion..
Sincerely free ...
Longer version, more weather pictures.
https://www.youtube.com/watch?v=O55ft7i6AK4#
:huh:
Please add some input, as to what you may think is not included in this very simple model, thank you.
RE: Ice Age Model
« Reply #1, on October 29th, 2011, 05:26 AM »Last edited on November 17th, 2014, 03:20 AM by Matt Watts
https://www.youtube.com/watch?v=vNfClJMnQxM#
Top rated 5 star effects.
https://www.youtube.com/watch?v=gB3hlTb794s#
Some factual data to support my claim. very non intuitive.
OCT 29 : Chile, Hudson volcano - Clouds of steam and smoke have risen up to 5km into the air
OCT 28 : Chile, Hudson volcano stirs up, Chile evacuates residents
OCT 27 : Indonesia, Mt. Lokon - Mt.Lokon erupted again, now spewing incandescent materials up to a height of 1,200 meters (3,930 feet)
OCT 27 : Chile, Hudson volcano - Chilean volcano awakens, red Alert declared at Mount Hudson in southern Chile
OCT 26 : Indonesia, Mt.Lokon volcano - Mount Lokon Volcano Erupts In Central Indonesia, No Injuries Reported
OCT 25 : Underwater volcano spews exotic lava
OCT 25 : New volcano in El Hierro
OCT 25 : Bolivia, more Uturuncu volcano news:  Inflating With Astonishing Speed / Is she about to blow? Scientists investigate riddle of rapidly inflating volcano
OCT 24 : New magma intrusion into El Hierro volcano
OCT 24 : Turkey, Nemrut volcano - Turkey fears volcano eruption
OCT 24 : Etna volcano eruption forces airport closure
OCT 22 : El Hierro volcano - The tremor signal grows again while increasing the shaking
OCT 20 : Hawai, Mauna Kea volcano - Earthquake swarm
OCT 19 : Bolivia, Rapidly Inflating Volcano Creates Growing Mystery
OCT 18 : Iceland, Katla volcano - Seismic tremors
OCT 17 : Chile, Puyehue volcano - Argentina, Uruguay halt flights due to volcanic ash
OCT 16 : Russia, Shiveluch in violent eruption
OCT 16 : El Hierro volcano - Giant bubbles visible from the coast
OCT 15 : El Hierro, green area + a small plume
OCT 15 : Magma incandescent and explosion hazard impede access La Restinga EL HIERRO
OCT 14 : El Hierro eruption aerial, showing the green spot
OCT 13 : sharp tremor drop in El Hierro
OCT 13 : The magma is close to La Restinga EL HIERRO
OCT 12 : People of El Hierro can spot the “supposed” eruption areas (green colored sea areas) from a viewpoint above La Restinga
OCT 12 : Canary Islands, El Hierro volcano - La Restinga , A Ghost town as the only people left behind are the Scientists
OCT 12 : Canary Islands, El Hierro volcano - latest updates
OCT 12 : Chile - NASA satellite imagery shows that the eruption of Puyehue Corón-Caulle Volcano is continuing after more than 4 months of activity.
OCT 12 : Canary Islands: Town flees volcano threat
OCT 11 : Canary Islands, El Hierro volcano - Spanish Town Evacuated Because of Volcano Threat
OCT 11 : Icelandic Volcano Dust Hits Swiss Airline in the Country
OCT 11 : Indonesia, Anak Krakatau volcano - High seismic activity, increase of Volcanic quakes
OCT 11 : Usa, Cleveland volcano - If the lava dome continues to grow in the summit crater, the possibility of an explosive event increases
OCT 10 : Hawaii, Kilauea volcano - Lava flow resumes to southeast and northeast
OCT 10 : The port of La Restinga, very close to yesterday´s eruption zone, has now been called on a RED ALERT and evacuation is ongoing.
OCT 10 : El Hierro update - Eruption is growing in size
OCT 10 : Subsea Volcanic Eruption Underway Near El Hierro (The Canary Islands)
OCT 10 : Indonesia,  Six volcanoes on high alert, but no evacuations for now
OCT 10 : Submarine Eruption Underway South of El Hierro
OCT 9 : Volcanic activity in Sunda Strait continues picking up: Indonesia
OCT 8 : Lava Builds in Alaska Volcano, May Threaten Planes
OCT 8 : Iceland, Hamarinn volcano - Tremor pulses in Hamarinn volcano (most likely)
OCT 7 : Reykjanes Ridge Earthquakes Coincide With Rise In Seismic Activity At Katla Volcano
OCT 7 : Canary islands, El Hierro volcano - Nearly 9,000 seismic movements on the island since July 17 + rising ball of lava
OCT 6 : Iceland, 4.8M eq struck Katla volcano
OCT 5 : Indonesia, Warning status for Anak Krakatau
OCT 5 : Iceland, Intense swarm of earthquakes in Katla volcano
OCT 5 : Alaskas Cleveland Volcano Closer to Erupting
OCT 4 : New Zealand, alert level at Ruapehu remains at 1, despite the temperature of the crater lake rising towards conditions typical for an eruption.
OCT 4 : Tourists, fishers Warned to Stay Clear of Anak Krakatau Volcano
OCT 3 : Magma on the move in El Hierro, Canary Islands
OCT 3 : Hawaii, Kilauea volcano - Lava flows vigorously advancing east of Pu`u `O`o; gas emissions elevated.
OCT 3 : Explosive eruptions at Sakurajima volcano, Japan :
OCT 3 : Indonesia, Anak Krakatau - New eruption
OCT 2 : Indonesia: Anak Krakatau Raised To Highest Alert Status- Quakes Are Now Continuous, Warn Officials
 SEP 30 : Costa Rica's Rincon de la Vieja Volcano Awakens
SEP 29  : Eruption on Nabro volcano continues / Evidence of ongoing activity (satellite pictures)
SEP 29 : National Geological Institute (IGN-Spain) graphic shows the massive surge of energy release at El Hierro
SEP 29 : The Canary Islands government radio alert to all operators of the impending El Hierro volcanic eruption on the island 12 kilometers!
SEP 29 : Italy, Etna volcano - 15th eruption of Mt.Etna
SEP 28 : Canary islands, El Hierro volcano - Evacuation of smallest Canary Island begins after earthquake 'swarm' sparks fears of volcanic eruption / Risk of landslides
SEP 27 : Iceland, Hamarinn volcano tremor signal
SEP 27 : Japan, Sakurajima volcano - Daily eruptions continues
SEP 26 : Japan, Sakurajima volcano - Shock wave move the clouds around the peak of the volcano.. followed by a moderate lava flow/ejection.
SEP 26 : Canary Islands, El Hierro volcano - On alert for a possible volcanic eruption
SEP 24 : Costa Rica, Poas Volcano - Incandescence of the lava dome
SEP 23 : Philippines, 7 quakes rock Taal Volcano :
SEP 23 : Tonga, Very strong shallow earthquake near Niuafo’ou volcano :
SEP 23 : Canary Islands, Government raises alert level on El Hierro volcano to yellow :
SEP 23 : Iceland, Skagafjörður volcanic zone - Seismic activity
SEP 23 : Iceland, Earthquakes in Katla volcano, strong sulphur smell in Múlakvísl river
SEP 23 : Hawaii, Kilauea volcano - lava level in the summit eruptive vent briefly rose a few meters overnight
SEP 23 : Usa, Cleveland Volcano in Alaska Shows Signs of Eruption :
SEP 22 : Indonesia, Lewotobi (Laki-laki) volcano - Because of increased activity alert level raised to level 2
SEP 22 : Indonesia, Alert level raised for the mudflow spewing from an underground volcano in Sidoarjo after nearby dikes nearly failed.
SEP 21 : Lethal super volcano ready for eruption
SEP 21 : Hawaii, Kilauea volcano - New lava breakout at Pu’u O’o flows towards Royal Gardens
SEP 21 : Iceland,  New earthquake swarm in Katla volcano
SEP 21 : Usa, Cleveland volcano - Volcano on Alaska's remote Aleutians oozes lava
SEP 21 : Indonesia, Mt. Marapi - W.Sumatra volcano continues to expel smoke, dust
SEP 20 : Mt. Tambora fear mounts....
SEP 19 : Italy, Etna volcano - 14th paroxysm of SE crater in progress
SEP 19  : Russia, Karymsky (Kamchatka) volcano spews ash again
SEP 19 : Indonesia, Mt.Tambora - History’s deadliest volcano comes back to life in Indonesia, sparking panic among villagers
SEP 18 : Japan, Sakurajima volcano - Eruption with heavy static discharge lightning
SEP 18 : Usa, Cleveland volcano - Continued growth of the lava dome
SEP 18 : Usa, Long valley caldera - Twenty-seven earthquakes in the past week
SEP 17 : Seismic activity, Long valley caldera
SEP 17 : Seismic activity, Campi Flegrei
SEP 16 : Seismic activity, Yellowstone caldera
SEP 16 : Iceland, Krýsuvík volcano - Land and water levels rise
SEP 16 : Usa, Cleveland volcano - Two months of low-level eruptions could signal bigger problem to come
SEP 15 : Volcanic eruptions drape Kagoshima in ash
SEP 15 : Indonesia, Semeru volcano - 3-4 eruptions per day
SEP 15 : Iceland, Katla volcano - More new tremor spikes in Katla volcano
SEP 14 : Russia, Kamchatka Volcano - Powerful volcanic explosions
SEP 14 : Hawaii, Kilauea volcano - Lava lake level rising as inflation progressed
SEP 13 : Russia's Shiveluch volcano erupts, spews 10-km ash column
SEP 13 : Russia, Satellite Images Highlight The Growth Of Russia’s Kizimen Volcano
SEP 12 : Seismic tremors at Colombian volcanoes
SEP 12 : Indonesia, Mt.Tambora - Three areas were emptied of community activities both wood seekers and tourists.
SEP 12 : Iceland, Earthquake swarm in Öræfajökull volcano sparks interest
SEP 12 : Philippines, Bulusan Volcano - Seismic activity and white steam was observed
SEP 12 : Seismic activity, Philippines, Taal volcano
SEP 11 : Indonesia, Mt.Tambora - Evacuation Plans Prepped as Mount Tambora Alert Level Is Raised
SEP 10 : Iceland, Katla volcano - Two earthquake swarms during the night.
SEP 9 : Indonesia - Papandayan Activity Continues to Increase
SEP 9 : New eruption at Mount Etna sends lava down slopes, ash cloud
SEP 9 : Indonesia - Mount Tambora alert status raised to Level 3
SEP 9 : Seismic activity, misc.
SEP 9 : More harmonic tremors in Katla volcano
SEP 8 : Iceland, Katla volcano - Iceland’s Civil Protection Department has increased its monitoring of Katla, following increased seismic activity in the surrounding area
SEP 7 : Iceland, Katla volcano - Magma on the move in Katla volcano / Increased geothermal heat and seismic activity might indicate an upcoming eruption
SEP 7 : Alaska, Cleveland volcano - Remote Alaska volcano might erupt soon, experts say
SEP 7 : Hawaii, Kilauea volcano - The summit lava lake rose slightly overnight at Pu`u `O`o crater sep 6 Iceland goes on alert as volcano Katla nears eruption
SEP 6 : Mount Duokono North Halmahera erupted belching volcanic ash as high as 800 meters
SEP 6 : Indonesia’s Mount Lokon erupts four times on Tuesday
SEP 6 : Remote Alaska volcano resumes dome building, AVO raised the Aviation Color Code at Cleveland to ORANGE
SEP 6 : Earthquake swarm in Krýsuvík volcano, Iceland
SEP 6 : Strong harmonic tremor pulse starting in Katla volcano
SEP 6 : Seismic activity; Campi Flegrei caldera, W.Naples/Italy
SEP 6 : Increased seismicity at Iceland's Katla has finally begun to show up in the mainstream media : Iceland volcano sees surge in seismic activity
SEP 6 : Katla seismic activity continues - Growing harmonic tremor spike in Katla volcano
SEP 5 : Seismic activity - Magnitude 6.6 eq struck N.W.of Toba supervolcano caldera
SEP 5 : Earthquake swarm deep on the Reykjanes Ridge
SEP 5 : More Seismic Activity by Katla Volcano than Usual
SEP 4 : New harmonic tremors spikes in Katla volcano
SEP 3 : Indonesia - Increased activity at 22 volcanoes, alert raised
SEP 3 : Another earthquake swarm in Katla volcano, 3rd swarm in 6 days
SEP 3 : Inflation starts in Katla volcano
SEP 3 : Indonesia, Ranakah volcano (Flores, Indonesia) - because of increased seismicity alert status raised
SEP 3 : Japan - This year's 600th explosive eruption was observed Saturday at Mt. Sakurajima
SEP 2 - Quake-hit Iceland volcano Katla shows strengthening signs of eruption
SEP 2 : Indonesia - Mt.Tambora volcano in Indonesia has been raised to level 2 alert
Latest Earthquakes Magnitude 5.0 and Greater in the World - Last 7 days
Versión en Español
Magnitude 5 and greater earthquakes located by the USGS and contributing networks in the last week (168 hours). Magnitudes 6 and above are in red. (Some early events may be obscured by later ones on the maps.)
The most recent earthquakes are at the top of the list. Times are in Coordinated Universal Time (UTC). Click on the word "map" to see a ten-degree tall map displaying the earthquake. Click on an event's "DATE" to get a detailed report.
DISCLAIMER
Update time = Mon Nov 7 10:01:31 UTC 2011
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    5.0     2011/11/07 09:43:20      7.854      125.087    86.2     MINDANAO, PHILIPPINES
MAP    5.2     2011/11/07 04:44:38      -3.709      149.705    34.8     BISMARCK SEA
MAP    5.1     2011/11/07 04:01:40      -3.633      149.674    35.0     BISMARCK SEA
MAP    5.1     2011/11/07 01:46:36      45.938      149.136    158.4     KURIL ISLANDS
MAP    5.1     2011/11/07 01:43:39      -3.556      149.599    35.0     BISMARCK SEA
MAP    5.2     2011/11/06 10:41:03      54.206     -162.624    30.4     ALASKA PENINSULA
MAP    5.3     2011/11/06 08:08:14      54.108     -162.504    24.9     ALASKA PENINSULA
MAP    5.1     2011/11/06 07:34:16     -23.149     -175.382    17.2     TONGA REGION
MAP    5.3     2011/11/06 04:41:57      -6.057      106.349    160.1     JAVA, INDONESIA
MAP    5.6     2011/11/06 03:53:11      35.537      -96.747    5.0     OKLAHOMA
MAP    5.0     2011/11/06 00:46:28      -8.334      128.030    34.8     TIMOR SEA
MAP    5.1     2011/11/05 16:49:38     -28.828     -176.955    50.7     KERMADEC ISLANDS REGION
MAP    5.7     2011/11/05 07:13:57     -23.529      -70.400    27.3     ANTOFAGASTA, CHILE
MAP    5.8     2011/11/05 01:49:20     -18.293      168.309    39.5     VANUATU
MAP    5.2     2011/11/04 21:31:35      -7.194      103.791    35.0     SOUTHWEST OF SUMATRA, INDONESIA
MAP    5.8     2011/11/04 15:43:45     -15.183      167.366    145.8     VANUATU
MAP    5.1     2011/11/04 14:59:54      -8.889      115.740    98.3     BALI REGION, INDONESIA
MAP    5.0     2011/11/04 02:59:19      36.041      141.148    35.0     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    5.0     2011/11/03 15:47:34      55.551      163.987    21.9     OFF THE EAST COAST OF KAMCHATKA, RUSSIA
MAP    5.2     2011/11/03 11:40:11     -24.176      -69.902    91.2     ANTOFAGASTA, CHILE
MAP    5.1     2011/11/03 10:34:29      35.784      139.983    70.4     NEAR THE SOUTH COAST OF HONSHU, JAPAN
MAP    5.4     2011/11/02 19:01:34      9.654      -84.788    39.6     COSTA RICA
MAP    6.2     2011/11/02 14:59:26     -55.303     -128.795    1.1     PACIFIC-ANTARCTIC RIDGE
MAP    5.0     2011/11/02 06:33:29      -0.039      123.413    130.8     SULAWESI, INDONESIA
MAP    5.3     2011/11/01 23:21:20      -7.116      129.120    178.6     KEPULAUAN BABAR, INDONESIA
MAP    5.0     2011/11/01 22:29:40      19.683     -109.266    9.9     REVILLA GIGEDO ISLANDS REGION
MAP    5.1     2011/11/01 17:58:34     -23.902      -69.173    79.2     ANTOFAGASTA, CHILE
MAP    5.1     2011/11/01 17:18:05      34.513      104.105    17.0     GANSU, CHINA
MAP    5.0     2011/11/01 16:21:26      35.939      141.637    21.1     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    6.3     2011/11/01 12:32:00      19.891     -109.216    5.0     REVILLA GIGEDO ISLANDS REGION
MAP    5.5     2011/11/01 01:03:53      -0.004      123.370    140.4     SULAWESI, INDONESIA
MAP    5.4     2011/11/01 00:21:28      43.633      82.383    27.9     NORTHERN XINJIANG, CHINA
MAP    5.5     2011/10/31 21:58:17      32.559      105.324    16.1     SICHUAN-GANSU BORDER REGION, CHINA
News
    2011 Seismo-volcanic Swarm on Hierro, Canary Islands
    8/23/11 - Magnitude-5.8 Earthquake Strikes National Capital Area
    05/09/2011-Distant Earthquakes Can Trigger Deep Slow Fault Slip
    04/28/11 - Preparing for the Great ShakeOut Drill: Handbook Offers Vital Earthquake History and Preparedness Information to Central U.S. Residents
    04/15/2011 - Closing Thoughts: New Madrid Earthquake Bicentennial Remains Central Topic at Memphis Conference
    03/28/2011-No Evidence for Large Triggered Earthquakes Across the Globe
    USGS Updates Magnitude of Japan's 2011 Tohoku Earthquake to 9.0
    02/18/2011-Nearly 60 Small to Moderate Earthquakes Strike Arkansas and Are Widely Felt
    01/11/11 - Haiti Dominates Earthquake Fatalities in 2010
Earthquakes
    Magnitude 5.6 OKLAHOMA November 06, 2011
    Magnitude 4.7 OKLAHOMA November 05, 2011
    Magnitude 6.3 REVILLA GIGEDO ISLANDS REGION November 01, 2011
    Magnitude 6.9 NEAR THE COAST OF CENTRAL PERU October 28, 2011
    Magnitude 7.1 EASTERN TURKEY October 23, 2011
    Magnitude 7.4 KERMADEC ISLANDS REGION October 21, 2011
    Magnitude 4.8 SOUTHERN TEXAS October 20, 2011
    Magnitude 6.5 EASTERN NEW GUINEA REG, PAPUA NEW GUINEA October 14, 2011
    Magnitude 5.3 OFF THE COAST OF OREGON October 13, 2011
    Magnitude 6.1 SOUTH OF THE KERMADEC ISLANDS October 07, 2011
    Magnitude 5.8 GUATEMALA September 19, 2011
    Magnitude 6.9 INDIA-NEPAL BORDER REGION September 18, 2011
    Magnitude 6.7 NEAR THE EAST COAST OF HONSHU, JAPAN September 16, 2011
    Magnitude 7.3 FIJI REGION September 15, 2011
    Magnitude 6.4 VANCOUVER ISLAND, CANADA REGION September 09, 2011
    Magnitude 6.6 NORTHERN SUMATRA, INDONESIA September 05, 2011
    Magnitude 7.0 VANUATU September 03, 2011
    Magnitude 6.7 SANTIAGO DEL ESTERO, ARGENTINA September 02, 2011
    Magnitude 6.8 FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA September 02, 2011
    Magnitude 6.8 BANDA SEA August 30, 2011
    Magnitude 6.8 NORTHERN PERU August 24, 2011
    Magnitude 5.8 VIRGINIA August 23, 2011
    Magnitude 5.3 COLORADO August 23, 2011
    Magnitude 4.6 COLORADO August 22, 2011
    Magnitude 7.0 VANUATU August 20, 2011
    Magnitude 7.1 VANUATU August 20, 2011
    Magnitude 6.3 NEAR THE EAST COAST OF HONSHU, JAPAN August 19, 2011
    Magnitude 6.8 NEAR NORTH COAST OF NEW GUINEA, P.N.G. July 31, 2011
    Magnitude 6.7 SOUTH OF THE FIJI ISLANDS July 29, 2011
    Magnitude 6.1 KYRGYZSTAN July 19, 2011
    Magnitude 7.0 OFF THE EAST COAST OF HONSHU, JAPAN July 10, 2011
    Magnitude 7.6 KERMADEC ISLANDS REGION July 06, 2011
    Magnitude 7.2 FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA June 24, 2011
    Magnitude 6.0 SOUTH ISLAND OF NEW ZEALAND June 13, 2011
    Magnitude 5.8 WESTERN TURKEY May 19, 2011
    Magnitude 5.1 SPAIN May 11, 2011
    Magnitude 6.8 LOYALTY ISLANDS May 10, 2011
    Magnitude 6.9 SOLOMON ISLANDS April 23, 2011
    Magnitude 7.1 EASTERN HONSHU, JAPAN April 11, 2011
    Magnitude 7.1 NEAR THE EAST COAST OF HONSHU, JAPAN April 07, 2011
    Magnitude 6.5 VERACRUZ, MEXICO April 07, 2011
    Magnitude 6.7 SOUTH OF JAVA, INDONESIA April 03, 2011
    Magnitude 6.9 MYANMAR March 24, 2011
    Magnitude 6.6 OFF THE EAST COAST OF HONSHU, JAPAN March 22, 2011
    Magnitude 6.3 VANUATU March 17, 2011
    Magnitude 9.0 NEAR THE EAST COAST OF HONSHU, JAPAN March 11, 2011
    Magnitude 5.5 MYANMAR-CHINA BORDER REGION March 10, 2011
    Magnitude 6.5 NEW BRITAIN REGION, PAPUA NEW GUINEA March 09, 2011
    Magnitude 7.3 NEAR THE EAST COAST OF HONSHU, JAPAN March 09, 2011
    Magnitude 6.6 SOLOMON ISLANDS March 07, 2011
    Magnitude 6.5 SOUTH SANDWICH ISLANDS REGION March 06, 2011
    Magnitude 4.7 ARKANSAS February 28, 2011
    Magnitude 6.1 SOUTH ISLAND OF NEW ZEALAND February 21, 2011
    Magnitude 4.1 ARKANSAS February 18, 2011
    Magnitude 6.6 OFFSHORE MAULE, CHILE February 14, 2011
    Magnitude 6.8 OFFSHORE BIO-BIO, CHILE February 11, 2011
    Magnitude 6.5 CELEBES SEA February 10, 2011
    Magnitude 7.2 SOUTHWESTERN PAKISTAN January 18, 2011
    Magnitude 7.0 LOYALTY ISLANDS January 13, 2011
    Magnitude 6.6 VANUATU January 09, 2011
    Magnitude 4.1 NORTHERN CALIFORNIA January 08, 2011
    Magnitude 7.1 ARAUCANIA, CHILE January 02, 2011
    Magnitude 7.0 SANTIAGO DEL ESTERO, ARGENTINA January 01, 2011
Saturday 10th December 2011
Kilauea Volcano, Hawaii
A lava flow has reached the old Royal Gardens subdivision and is burning forest in a kipuka. Lava is also advancing across the coastal plain towards the ocean. At the summit of Kilauea volcano there is a lava lake in a vent 75 m below the floor of Halemaumau crater. On the east rift zone lava periodically appears in Pu'u O'o crater.
Thursday 8th December 2011
Sundoro Volcano, Indonesia
Sundoro volcano in central Java was raised to level 2 alert on 6th December 2011 after an increase in seismicity. The temperature of fumaroles at the summit increased from 75 deg C on 26th November to 95 deg C on 2nd December. On 2nd December a plume from the summit rose several tens of metres above the rim of the crater. The number of volcanic earthquakes were measured as 3 in October, 13 in November and 20 between 1-4 December. A 2 km exclusion zone has been placed around the volcano. The last eruption of Sundoro volcano occurred in 1971.
More on Sundoro volcano...
Volcanoes of Indonesia...
Monday 5th December 2011
Gamalama Volcano, Indonesia
Gamalama volcano in Indonesia erupted at 11 pm local time on 4th December 2011. The eruption deposited ash over the Ternate. On 4th December 47 shallow volcanic earthquakes were recorded at the volcano compared to 1 shallow earthquake on 3rd December.
More on Gamalama volcano...
Sunday 4th December 2011
A lava flow is advancing towards the old Royal Gardens subdivision at Kilauea volcano in Hawaii. The flow is moving alongside a kipuka and has started forest fires. The lava is moving west of the February 2010 flow and is close to the last inhabited house in the subdivision.
definition assume respiratory conditions are increasing.
For me, I have noticed the atmosphere is producing copious amounts of ozone, several less well know causes can be accounted for.
Lets face it, the nuclear disaster in japan is a main contributor. Radioactive material drifting around the entire world.
What does radio active mean? It means it is releasing energy.
The interaction in our atmosphere, causes a response.
water vapor in the form of cloud cover gets heated, heat causes it to evaporate quickly, leading to less cloud cover were the heating is very high.
Perhaps the drought in Texas is related to that, the radiation transforms the atmosphere leading to a huge spike in low level ozone, you may not like this answer, but it is scientifically sound.
Other causes an increase in natural gas, and methane bubbling up from pockets under ground that have reached the surface. an earth quake, or drilling in search of fuel may release the trapped pockets of gas.
This gets even more dangerous, as it is also exposed to solar rays, and even the radiation coming from nuclear plants that fail, nuclear testing, under ground testing etc.
This is not per-say the (only factors) to respiratory problems on a global scale, but is becoming evident, a main contributor. Independent study, and sampling of the air you breathe and the drinking water being consumed
Is necessary for determining cause. The amount of tolerances a body can handle is determined not by the individual, but by the quantity a species can safely tolerate.
If the quantity of these very dangerous by products find its way hovering above your home, you can be sure the clean breathable oxygen is reduced. It may even lead to brain damage, or permanent damage to the respiratory system.
My own researches verify that.
Sincerely
If we go back to 2010, 6,7 or greater quakes are increasing in frequency.
If we go back to 2009 we have a somewhat stable environment.
When dealing with 2010, prediction was very intuitive, and there was found to be a cause.
In 2011, predictions may be determined on a time sensitive base if we look at 2010.
Earthquakes are generally not time sensitive. random quakes are a result of stress on plates that are in motion, assuming the earth is in a stable condition.
In 2011 the earth is quickly becoming destabilized, and an outcome for future predictions based on the time frame given for 2010 will lead to a higher degree of accuracy.
The progression of the destabilizing crustal shifts for 2011 will clearly show an increase of frequency, and more powerful quakes, leading to the next great earthquake expected within the next 4 months. closer to the end of march is my prediction, although it may be sooner December 2011 to February 2012.
January 2011 will have a high probability for 7.0 to 8.0 earthquakes.
If you had thought earthquake prediction is unlikely, then by looking at a graph of 2010, you may prove with accuracy time sensitive relations for 2011, and also 2012.
People claiming to be able to use astronomical charts in the past found it most difficult.
Volcanic eruptions are no different for 2011, and 2012 many will be erupting by mid January, and continue for a few months there after. You may find a chart for 2010, and determine these eruptions most accurately for the next 2 to 3 years. It is time to be prepared.
The progression will accelerate more so after destabilization. So yea, its not looking good.
I hope your concern may lead to a better understanding of the process of torque induced precession.
It has been found to be a progression of axial shift. Over a 3 to 5 year period starting in early months of 2010.
The magician does not tell his secrets, but in this case science does. I am a scientist, not a magician.
Get technical, and yes science does, you must provide data within the parameters, or scope determined to be highly unlikely to occur.
The greater the magnitude of prediction, the less likely it is to occur. Stated you must go back to a somewhat stable platform 2009. When dealing with averages, the greater the imputable input factors, the greater the average relation over time. We don't average here.This is clearly time sensitive.
 I have set the bar much higher. you must go back to the year 2008-2009 and make your input data entirely.
Do the same for the entire year of 2010 to the current date. Compare, see if a time sensitive progression has occurred as of Feb 27, 2010.
Then you must determine how an earthquake is related as a time sensitive factor, comparing the 4 years of total data.
To be on the safe side, 2 years before progression, 2 years of progression. Now you plot on two charts, each with 2 years of average data, and compare. The chart will tell the story all by itself. the chart must follow the time sensitive information provided. Meaning each month, and each quake plotted on the chart 6.0 or greater corresponds, or in relation with the date it had occurred.
By doing so, the data will reflect to a much higher degree of accuracy.
 7.3     2011/12/14 05:04:57      -7.507      146.791    115.1     EASTERN NEW GUINEA REG, PAPUA NEW GUINEA
Tuesday 13th December 2011
Marapi Volcano, Indonesia
Marapi volcano in Sumatra, Indonesia has been raised to level 2 alert (out of a maximum 4). On 12th December there were 43 volcanic earthquakes measured at the volcano. A 1.5 radius exclusion zone has been placed around the volcano.
RE: Ice Age Model
« Reply #2, on November 29th, 2011, 09:47 AM »Last edited on November 29th, 2011, 10:26 AM by freethisone
Observation leading to determining factors.
"Terminology of definitions, context : wiki
"In traditional logic, an axiom or postulate is a proposition that is not proven or demonstrated but considered either to be self-evident or to define and delimit the realm of analysis. In other words, an axiom is a logical statement that is assumed to be true. Therefore, its truth is taken for granted, and serves as a starting point for deducing and inferring other (theory dependent) truths.
basic, foundational proposition or assumption that cannot be deduced from any other proposition, or assumption.
to be the cause of; bring about. A person, or thing that acts, happens, or exists in such a way that some specific thing happens as a result; the producer of an effect:
Science has been looking for evidence that explain what chain of events, or factors play a major role in predicting cataclysmic events in the past, present, and future.
Making past assumptions leads to debate, a major problem for modern theoretical advancements, and the difficulty researchers have addressing these issues.
My goal : By taking certain considerations, and factors into account paving the way for new viable study dealing with past, present, and future crisis of the environment. With the flurry of data entering the debate, certain real factors may have been ignored, or misunderstood in recent years, leading to false, or misleading outcomes. The reader is stuck in the middle of this debate, asking more questions than having answers provided.
In light of the moon, Bruce Lee said, "don't focus on the finger, or you will miss all that heavenly glory." he also said when he strikes a target that "It strikes all by itself"
I have chosen the date Jan 29, 2010 to begin this study. Why? Because it was then certain information had come to light relating to the events that follow. I bring your attention to the first wolf moon in 20 years. smiling at Bruce. The event may have not been all that memorable to the reader, but it was for me. What occurred shortly thereafter was something incredible indeed. After turning my attention away from the moon I observed the sun in its relation out of curiosity for the event. I had discovered the sun was in a process of change, that change was the beginning of a new solar cycle. (solar cycle 24) A process that will be the most memorable event for the rest of my life. After I had observed this process for the next 5 to 7 days I had confirmed that a new solar cycle had begun. shortly after it was also confirmed by leading scientists of the day.
The next observation lead me to focus on the effects this change could have on the planet earth, and that is just what i did. I now had 3 factors to keep a close eye on. Each new factor was leading to other factors with a higher, and higher degree of probable outcomes. (cause, and effect chain.)
1. The sun. solar rotational periods.  In comparison, determinable factors help predict earth quake, and eruptions.
2. The moon. lunar periods of change. Time frame relations observable factors.
3. The planet earth, and all the effects relate to these changes. Predicted out comes.
The first real results came as a series of powerful earthquakes. Unaware at the time of the historical implications of the Jan 17, 2010 Haiti earthquake,
occurring just prior to the start of solar cycle 24. I had considered all may have been by coincidence, and my attention was now on the The Vernal Equinox. A time when the Sun reaches the balancing point in its path through the tropical zodiac, when the length of the day is equal to the length of the night.
Astronomy charts confirm, leading to the beginning of the new astrological year. (The new age also, 25000 years perhaps) The dawning of the age of Aquarius.
It was my belief at the time Feb 16, 2010 marked Equinox, sweet 16. I also confirmed it had occurred in a specific location on the planet looking at astronomical charts.
If you like a good mystery like I do, check out the coral castle By Edward Leedskalnin.
My focus is on the stars, I had observed something special. Jupiter aligns with mars, and the moon enters the seventh house. looking from the northern hemisphere to the west. One pill will make you grow, one pill will make you small. (feeding your head) I had expanded my mind. Smile.
These are the true observations I had made.
I scrabbled for more information in astronomy, solar cycles, lunar cycles, Earth cycles, and precession. I found what I was looking for, unknowing what would lead to the next change, and cause of events that would follow. I had found MIT lectures By X-ray Astronomer Walter Lewin, and proceeded to watch them all, over the next several months. 801, 802, and 803 lectures, as a refresher to my major.
11 days later, Feb 27, 2010 Great quake of chili happened. I thought could this have any relation to this special time, and are these effects directly related? Focusing now on Earth weather patterns, cloud cover, and the circulation within our atmosphere. I observed closely, and intently for the last couple of years. What had occurred next was another astonishing effect, seemingly there was a hick-up in the direction of circulation within the system.
Storms had spawned quickly after the Great quake, and I was like, another coincidence? I started questioning my motives to find a solution to these effects. What would be revealed to me over the course of the next year could not be caused by the sun alone. Prior to this i began predicting powerful earthquakes accurately, and immediately began to understand the true meaning of climatology. storms would spawn, cyclones, tornadoes, and even hail in diverse places on earth. Another coincidence i said? questioning my sanity, my mind suddenly ruptured into a volcano of information from my observations. I made several conclusions, and these conclusions were short lived, until I discovered the induction factor.
Induction you may say? Yes, at this point several volcanoes began to erupt within a short period of time, and had to understand this better for my own research purposes, and knowledge. I found part of the answer. Induction, something was causing the Earths core to expand I said. On the next new moon, another eruption had occurred, and for a period of time, about 3 months the eruptions had stopped. This is very odd, I was convinced science could explain these immediate effects, and by 2011 I had used all the information I had gained, and applied it with present day predictions. Looking always for a cause, and effect, I had discovered a short time period of about 13 days before a major event, and they did occur as expected.
This was in relation to earthquakes, so i made it my goal to prove there was no way this is a coincidence. I would set as a minimum magnitude that could not be only by chance. 6.4 was the norm for these time variable events, and then i demonstrated to many of my friends who are extremely skeptical with ease. I raised the bar once again, I had set the limits of reportable magnitude to at least 7.0. with The same outcome. I even had the March 11 2011 quake predicted to 24 hours. That is strange indeed.
Prior to the March 11 2011 quake, I was looking for variables, I was also expecting the first results relating to strong quakes by February 16 2010, although it may have been subtle, or a overlooked effect at 6.4 , taking place in the same region in Japan. This as a signal of effects I had thought, a pair of events would signal the predicted outcomes following part one.
4. Induction factor related to expansion periods during the time frame proposed, 2 years. this can be extended 2 more years taken what was learned.
5. Angular momentum, or earth rotational speed that is under change. Relative to the circulation of air flow, includes immediate relation, determining factor. Strong storms, and all related effects in the systems are still under observation.
6. Oceanic tidal surges, and there specific location to the rotational center of mass of the given body. accompanied by marine life loosing the ability to navigate by instinct.
Even other magnetic variations in the system, causing airplanes to miss runways wile trying to land, and crash. leading to the recalibration of airport automatic safe guards that use the earths magnetic field.
Concluding with the continued effects, time lines, and progressive events.
All of these factors were found to be related to cause, these are the major determining predictable factors that validate this model wile at the same time excluding less known causes such as an increase of co2 levels in the system, the continued reduction of Antarctic ozone levels, or the depletion of the rain forests. even by excluding all man made flora carbons of the last 100 years.
A genuine gravitational lensing effect, and an increase in uv bursts, magnetic flux, or pressure. A cassimir effect. Coronal mass ejections, solar flairs, and solar winds interacting with the earths ionosphere.
leading to spectacular Auroras. verify  ozone production, and the rarefaction of our atmosphere.
The twist is in the traits of the species. The doors that are enshrouded, are now open. The sleepy mouse comes out to play. We open our eyes, no need to be told analogy.
The magician does not reveal his secrets, but in this case science does.
Research, and advancements if requested.
Every thing in nature, everything included in a system has a generating effect on another system.
You might say mainstream global warming scientist look at a completely empty system, with no regard for all the facts, only including there axioms that blame The human race for any changes in that system.
Radioactive material, and the inability to contain it is there fault not mine. They have destroyed vast quantity of land mass, leaving it uninhabitable for generations, leaving piles of spent fuel rods in land fills, leaving that material in a delicate system such as earth enters the atmosphere, ground water, and destroys all life.
Every change leads to other changes. Simple these changes are accumulative, and the main cause of change in the system is not co2.
That is all I have to say about that. You may wonder why most people call global warming BS. Politics include what there feeble minds allow them to.
Scientists may have a theory fine, but it needs structure, and not simple assertion.
You know what I am saying, not the scientists fault they are only there to cover up what is implied by these changes.
http://science.nasa....ep_harvestmoon/
http://dundalk.patch...-rising-tonight
http://www.examiner....ight-january-29
http://news.national...moon-2010-mars/
http://science.nasa....6mar_supermoon/
http://www.youtube.c...h?v=r1yalg_Apdw
RE: Ice Age Model
« Reply #3, on November 29th, 2011, 03:43 PM »Last edited on December 1st, 2011, 08:54 AM by freethisone
"Extra research section. :Axial position is following the torque. Angular momentum takes over. Its simply torque times delta T."
Author notes, and topics open for your review.
Greetings all, I have outlined key factors, that separate this model from main stream science. I would like to validate any responses to this topic.
When dealing with terminology, it was stated many factors mainstream claimed may have been overlooked, ignored, assumed, and misleading, or out right lies..
It was said facts stated in this model do not fit in with current understanding on the subject. Have the virtues of science been ignored, along with the process, and steps necessary for functionality of a working model been distorted over the years?
This is open for more  available verifiable data.
The major relations dealing with cause, and effect have been determined, and demonstrated. This followed by answering the questions that make valid relations, rather then assumptions science can not account for.
In a manner of speaking, global warmers delimit the realm of analysis.
They  have lost there way, by not following self evident principles, and observation.
Also by deliberately misleading the public, and by hiding real data that is used to determine these changes. Scoundrel.
Please see movie, review.
https://www.youtube.com/watch?v=QhpTU2kN5Ew
Everything is relative to the observer's point of reference in time and space.
See Euclidean plane reference. Once it has been described in this language, it is actually a simple matter to extend its concept to arbitrary dimensions. It has an Axis of rotation.
In one way the Earth is considered a closed system, in another it is open. refer to auroras, it is a result of an external force. A CME does cause induction of that energy into the ionosphere, that energy can indeed reach the surface as electric charge. I said it was closed, because I was relating to the atmosphere, assuming it did not leak into outer-space, but in reality it can. I include both perspectives
Wiki
Why are density and seismic velocity inversely proportional to one another? Very non-intuitive.
Propagation through denser material. P wave. It is when the wave reaches a more liquified medium, that the propagating wave is dampened.
( secondary waves S wave: Damping effect). In the first case you may have trust type quake, because the energy has someplace to go. This is a more sever Earth quake.
"Seismic wave Wiki
:The S-wave moves as a shear or transverse wave, so motion is perpendicular to the direction of wave propagation: S-waves are like waves in a rope, as opposed to waves moving
"through a slinky, the P-wave. The wave moves through elastic media, and the main restoring force comes from shear effects. These waves do not diverge, and they obey the continuity equation for incompressible media: Posted Image Posted Image Posted Image The shadow zone of a P-wave. S-waves don't penetrate the outer core, so they're shadowed everywhere more than 104° away from the epicenter (from USGS) Its name, S for secondary, comes from the fact that it is the second direct arrival on an earthquake seismogram, after the compressional primary wave, or P-wave, because S-waves travel slower in rock. Unlike the P-wave, the S-wave cannot travel through the molten outer core "
"In continuum mechanics, stress is a measure of the internal forces acting within a deformable body. Quantitatively, it is a measure of the average force per unit area of a surface within the body on which internal forces act. These internal forces are a reaction to external forces applied on the body. Because the loaded deformable body is assumed to behave as a continuum, these internal forces are distributed continuously within the volume of the material body, and result in deformation of the body's shape. Beyond certain limits of material strength, this can lead to a permanent shape change or structural failure.
However, models of continuum mechanics which explicitly express force as a variable generally fail to merge and describe deformation of matter and solid bodies, because the attributes of matter and solids are three dimensional. Classical models of continuum mechanics assume an average force and fail to properly incorporate "geometrical factors", which are important to describe stress distribution and accumulation of energy during the continuum.
The dimension of stress is that of pressure, and therefore the SI unit for stress is the pascal (symbol Pa), which is equivalent to one newton (force) per square meter (unit area), that is N/m2. In Imperial units, stress is measured in pound-force per square inch, which is abbreviated as psi."
"A stress energy tensor T^{mu,nu} is not the only thing that curves space-time. There is another curvature driving function Q^{mu,nu}. My friend Mzulu"said this is so.  I think he is correct.
In the same manner Earth reacts to the external torques as stresses.  It is net force Inducing.
Peace, love, and understanding all.. :huh:
RE: Ice Age Model
« Reply #4, on November 30th, 2011, 08:33 PM »Last edited on December 3rd, 2011, 08:25 PM by freethisone
The writing on the wall has changed.
Ice age 3 d -model described. Yes Doctor?  The precession is continuity torquing. It continues to follow the slipping top analogy.
Its simply spinning. Its simply stunning, its simply continues to rotate I will exaggerate your observations. Its simply up to you to observe.
As it rotates earthquakes become time variable according to rotational speed.  The axis it i pointing, it following the spinning top.. its simply slipping. its simply a stunning effect. There is a pressure of fluid within the core.  Its simply splitting, its Humphrey Dummpie. Its described ,and self verifying. Its simply continues.
Its bursting, of a water balloon. Its simply to soon.,  Its simply predictable. Its following its secondary oscillation. Beating like a drum. The wave is in front. Its simply like a pointy boat or arrow. Its simply caused by this star. There is, simply no way around.  The time frame was predictable. Its simply solar rotation. Its simply lunar precession. @3 days of solar rotation, and according to speed it will split like a cord. Ripping the seams. Its
It was simply well known. Its simply a des-cry. An utter dis-( By grace). I am simply sorry.  It simply was well known to be true. lighting up like a tree on Christ mass day. Its spilling  on two sides. The start of the  predictable out come is time variable. It also follow along the net force inducing. Its also bouncing and skipping along. simply bending space. What is relativity?
 Its simply, Cause and effect..   :angel:
As the earth spheroid preforms like an egg.
observe:https://www.youtube.com/watch?v=N5tESZ-zzp8&feature=channel_video_title
Peace, and Love all, understanding.  :heart::heart::heart::heart:
RE: Ice Age Model
« Reply #5, on November 30th, 2011, 09:56 PM »Last edited on November 17th, 2014, 03:22 AM by Matt Watts
Observe with care.  Bouncing skipping, beating like a drum. Its relative.
Peace all   :heart::heart:
:dodgy:
https://www.youtube.com/watch?v=XblMlYWNoG8#
 play a nice loving song, Or mute the volume. Given torque momentum, and direction of propagation. secondary euclidean geometry Remember it our Jo.b... Take care.
:heart::sleepy::heart:
sincerely free. Take care people.
RE: Ice Age Model
« Reply #7, on December 4th, 2011, 11:45 AM »Last edited on December 4th, 2011, 10:16 PM by freethisone
Dynamic Gyroscopic Precession. High performance. high definition effect. 3-4 average % stars. include lunar periods. solar rotation. delay of given generating charge  see casimir effect. charge configuration. Lectures provided.etc..
https://www.youtube.com/watch?v=-kJpW4_0Ta4
add surround sound. play song Candy-o by the cars. 5.o version: For given effect.:blush::s:blush:
https://www.youtube.com/watch?v=sS0oy1QRIl8&feature=channel_video_title
:cool::cool::cool:
RE: Ice Age Model
« Reply #8, on December 18th, 2011, 01:31 PM »Last edited on December 31st, 2011, 09:59 PM by freethisone
Fountains of Methane 1,000 m Across Erupt From Arctic Ice
    Posted by Weston Ginther on December 18, 2011 at 5:44pm
'Fountains' of methane 1,000m across erupt from Arctic ice - a greenhouse gas 30 times more potent than carbon dioxide
The Russian research vessel Academician Lavrentiev conducted a survey of 10,000 square miles of sea off the coast of eastern Siberia.
They made a terrifying discovery - huge plumes of methane bubbles rising to the surface from the seabed.
'We found more than 100 fountains, some more than a kilometre across,' said Dr Igor Semiletov, 'These are methane fields on a scale not seen before. The emissions went directly into the atmosphere
http://www.dailymail.co.uk/sciencetech/article-2073686/Fountains-methane-1-000m-erupt-Arctic-ice--greenhouse-gas-30-times-potent-carbon-dioxide.html#ixzz1guBpMFDA
    6.6     2011/12/27 15:21:56      51.858      95.825    6.9     SOUTHWESTERN SIBERIA, RUSSIA
confirmig information.:s
     This event has been reviewed by a seismologist.
Magnitude   7.0
Date-Time
    Sunday, January 01, 2012 at 05:27:54 UTC
    Sunday, January 01, 2012 at 02:27:54 PM at epicenter
Location   31.416°N, 138.155°E
Depth   348.5 km (216.6 miles)
Region   IZU ISLANDS, JAPAN REGION
Distances   242 km (150 miles) SW of Hachijo-jima, Izu Islands, Japan
365 km (226 miles) S of Hamamatsu, Honshu, Japan
393 km (244 miles) S of Shizuoka, Honshu, Japan
495 km (307 miles) SSW of TOKYO, Japan
RE: Ice Age Model
« Reply #9, on January 19th, 2012, 06:02 PM »
Quote from freethisone on December 18th, 2011, 01:31 PM
Magnitude   7.0
Date-Time
https://www.youtube.com/watch?v=-kYILVMBunc&feature=channel_video_title:rolleyes::P:huh::)
In summery, we can now solve for continuum. As Maxwell.The dimension of stress is that of pressure, and therefore the SI unit for stress is the pascal (symbol Pa), which is equivalent to one newton (force) per square meter (unit area), that is N/m2. In Imperial units, stress is measured in pound-force per square inch, which is abbreviated as psi."
 Immediate determinations based on observation of the globe over time.  After the axis has shifted 3 inches Feb 27-2010, and again 4 more on march 11-2011
If someone has already done the math , or needs a solution of pointing axis, together with violent jerks  from axial shift during the time eastern 3pm time usa.
Furthermore We have all points of subduction zones. we also  Se the earths magnetic field attracted to the secondary systems magnetic field, and charge in the ISCM. Earth will experience increased rotation speed, pointing of Earth  axial is away, or to the northern  direction pointing. According to pictures rated in the video provided. from the  in the form of magnetic suspension. The position earth axial is pointing during a 6 hour period. The Movie provides a three demolition view. Also verifying the angle of momentum shows vector rotation, and angular momentum. The influence of net charge and the determine lens effect and cassimire effect reactions. Volcanic eruption time variable is  predictable , And are now confirming the increase of volcanic eruption expected for the month of January through march 2012. The 3-D models current configuration together with the integration of images.Pictures of ongoing storms earthquakes other given effects, and telling mathematical solution.. Dynamic pressure. Can be solved together with predictable outcome in the near future. Subduction zones and country's in dire need for assistance.
 I will edit the movie with everything needed to make accurate prediction.
 of net charge.  Update later.:huh::huh::huh:
.:heart::heart::heart::angel::angel::angel:
RE: Ice Age Model
« Reply #10, on January 19th, 2012, 06:09 PM »Last edited on February 15th, 2012, 12:45 PM by freethisone
Its simply continues. continuum dynamic rotation.
Summery conclusions.
Ice age cause, simple verifying model. Immediate determinations based on observation of the globe over time.  After the axis has shifted 3 inches.
Feb 27-2010, and again 4 more on march 11-2011 scientific validating factors. The immediate change is used as a main determining factor, or the  cause for  immediate changes in weather, volcanic activity, and earthquake relations over the last 2 to 3 years.
 subduction zones due to torque.  clearly  the earths magnetic field is attracted to the secondary systems magnetic field interaction with all the planets in our solar system. Earth Has experienced increases, and decreases of rotation speed.
The secondary system  will reach its closes point,  and a  great Quake is therefore predicted, expected. Possibly by March 23 2012.
Earths orbit crosses the horizontal plain according to the position, and alignments of charges, or  the magnetic field lines of that secondary system in relation to  local space, and earths current position of yearly orbit.. We must be closing in very quickly now. Today is feb 15 2012.
 The influence of net charge, and the determined lens effect, or  Red shift  cassimire effect influences Earths reaction to inductive forces causing eruptions.
April to may we should see this increase in activity once again, according to time sensitive data over the last 2 to 3 years.
Volcanic eruption time variable is  predictable, confirming the increase of volcanic eruption expected for the month of January through march 2012. Not excluding April, and May 2012.
The 3-D model has Pictures of ongoing storms earthquakes, and other given effects determined to be a direct relation to the increasing energy inductive forces.
 everything needed to make accurate prediction , calculate  net charge, Observe gravitational  lensing, or poynitng energy was included. A self generated system of mass. The inductive charge and movement through local space.
Increasing pressure, Velocity, and changes of direction of Earths inner fluid.
 gaseous material releasing vast quantity of dangerous materials for all life.
 The Precession can now be solved as caused by an external torque, rather than caused by lunar or solar cycles alone. Verifiable reactions according to Einstein are confirmed. Astronomers such as Galileo Galilee
 See Maxwell poem of continuum mechanics on my chalk board.
Thank God, and God blessing to All. Peace.
:blush::blush::dodgy:
Pause movie at 10 min 20 seconds. What is claimed to be a fireball, was also claimed to be comet love joy.  see the picture below and compare.
RE: Ice Age Model
« Reply #11, on March 4th, 2012, 01:01 PM »Last edited on March 7th, 2012, 09:26 AM by freethisone
February 2012 Venus Jupiter, and moon..
Precursor evidence for predictable binary relation. cassimire forces, poynting energy, other factor, solar x ray flux graph one, two, and three. Some of the research used as observations of solar energy, and magnetic field alignment are included.
 CCD BACKEOUT magnetic poles flip on the sun, and are in a process of change.  Great quake prediction , annual great event. highest probability for such event is getting closer, evidence, data, and research point to this relation. Cause- and - effect.   This would validate this relation  3-d model. But more can be learned through Astronomy.
Below i included the solar process of change in solar rays, as they extend in all directions before confirming a pole change on the sun, and the relation to earths  magnetic poles, and orbital trajectory as we near the spring equinox. march 2012.
weather anomaly due to increased Earth rotational  velocity together with  decreases and, or axial change.  ( External torque  precession of equinox continues). vs net force , or torque interacting with Earths angular momentum with relation to the binary system magnetic field and position. continuity, and  net force inducing , induction, increases  in solar mass, and energy..
the information on solar flairs below, are in close accord with the 2 previous years of data obtained.  20 days perhaps before the second solar outbreak is recorded, and reported.
take care people.:blush:
millerwilson
cord covers
« Reply #12, on March 6th, 2012, 08:54 AM »
I have great interest in these type of topics.........Its really fantastic.Thank you very much for this.
cord covers
RE: Ice Age Model
« Reply #13, on March 20th, 2012, 11:46 AM »Last edited on March 26th, 2012, 11:46 AM by freethisone
Quote from freethisone on March 4th, 2012, 01:01 PM
The solar flairs  charts below, are in close accord with the 2 previous years of data obtained.  20 days perhaps before the second solar outbreak is recorded, and reported.
Hmmmm>:dodgy::dodgy:
My update for second solar outbreak as expected according to the 2 previous years. I will add the charts as they are reported over the next several days.
MAP    7.6     2012/03/20 18:02:49      16.662      -98.188    17.5     OAXACA, MEXICO
MAP    6.2     2012/03/20 17:56:19      -3.830      140.220    66.9     PAPUA, INDONESIA
MAP   6.6 2012/03/21 22:15:06      -6.244      145.959    105.9     NEW GUINEA, PAPUA NEW GUINEA
MAP    7.1     2012/03/25 22:37:07     -35.183      -71.792    34.8     MAULE, CHILE
MAP    6.0     2012/03/26 18:12:54      10.198     -104.030    9.9     NORTHERN EAST PACIFIC RISE
(Central Chile Rocked By 7.2 Earthquake by The Associated Press March 25, 2012)
(A magnitude-7.1 earthquake struck central Chile Sunday night, the strongest and longest that many people said they had felt since a huge quake devastated the area two years ago. Some people were injured by falling ceiling material, but there were no reports of major damage or deaths due to quake-related accidents.
The quake struck at 7:30 p.m. about 16 miles north-northwest of Talca, a city of more than 200,000 people where residents said the shaking lasted about a minute.)
Solar flares. or x ray flux. for the first time since i have been monitoring no data for the 22 of march. the first M class flare was today march 23 2012.
At this point in the time frame. iT should be expected .( great earthquake) further tilt in axis. The data should mirror the  previous 2 years obtained. ( two solar out break, two weather outbreaks world wide.)  Tornadoes cyclones high wind etc... :( volcanic eruption.
RE: Ice Age Model
« Reply #14, on April 11th, 2012, 08:29 AM »Last edited on May 4th, 2012, 05:38 PM by freethisone
Quote from freethisone on March 20th, 2012, 11:46 AM
the report
FIFTEEN million people of the northwestern Sumatran coastal strip and nearby islands slept nervously, if at all, last night after their region was shaken by two massive magnitude-8+ earthquakes that triggered tsunami warnings for the entire Indian Ocean rim.
Magnitude-8+ quakes are counted as "great earthquakes" and, based on US Geological Survey data, they are expected to occur anywhere on Earth just once a year. Sumatrans experienced two in 125 minutes yesterday, along with a series of aftershocks of magnitude-5 to magnitude-6 in between and after.
The first quake, at 3.38pm local time (6.38pm AEST), registered 8.6 on the Richter scale, with an epicentre 434km southwest of Aceh province's capital, Banda Aceh.
One of the 10 largest-magnitude earthquakes ever measured, off a coast repeatedly and devastatingly smashed by tsunami waves, the shock sparked fears of a repeat of the magnitude-9.1 quake and tsunami of Boxing Day 2004 that killed 230,000 people around the Indian Ocean, 170,000 of them in Aceh province. Initial local alert warnings were issued for waves exceeding 6m.
Rec Coverage 28 Day pass
Start of sidebar. Skip to end of sidebar.
Recommended Coverage
quake
Tsunami 'less likely' this time
Earthquake in Indonesia
End of sidebar. Return to start of sidebar.
The US Pacific Tsunami Warning Centre issued a tsunami watch for Indonesia, India, Sri Lanka, Australia, Burma, Thailand, Maldives, Britain, Malaysia, Reunion, Seychelles, Pakistan, Somalia, Oman, Madagascar, Iran, United Arab Emirates, Yemen, Comores, Bangladesh, Tanzania, Mozambique, Kenya, Crozet Islands, Kerguelen Islands, South Africa and Singapore.
The magnitude-8.6 tremor was felt as far afield as Thailand and southern India. According to the Joint Australian Tsunami Warning Centre, however, there was no tsunami threat to Australia.
Having suffered the brunt of the 2004 disaster, the populations of Aceh, North and West Sumatra's coastal strip, and the provincial and offshore islands, scrambled immediately for higher ground. There were some reports of panic and hospital evacuations from Padang and Medan.
Power supplies shut down automatically in Banda Aceh and surrounding districts and telephone communications with the coast were disrupted, but almost miraculously there appeared to be no substantial damage or injuries from the initial quake.
The tsunami wave - when it came to the coast about an hour later - registered a peak of 1.06m at Meulaboh on the southern Aceh coast.
The nature of the tremor - a strike-slip quake, where the rupture between the blocks of earth is almost vertical and the two pieces of the earth's crust slide past each other horizontally - greatly reduced the likelihood of a tsunami.
The devastating waves are usually caused by the vertical displacement of a tectonic plate, but can also be caused by underwater landslides.
About 90 minutes after the first shock, President Bambang Susilo Yudhoyono said during a nationally televised press conference, "there is no tsunami threat, although we are on alert".
Another 2 1/2 hours later, the Pacific Tsunami Warning Centre removed the alert for both 8+ quakes.
Parluatan Siregar, police chief of Simeulue, an island last battered by tsunami in October 2010, told Detik.com, an online news service, that "some buildings are cracked".
There were no initial reports of deaths or injuries although emergency services teams were sent immediately from Jakarta.
Then, at 4.43pm, as people were returning to their homes and workplaces breathless but unscathed, a magnitude-8.2 quake struck, its epicentre 618km south-southwest of Banda Aceh.
A second wave of tusnami alarms was sounded.
Equally remarkably, there were no initial reports of significant damage injury, although coastal communities again battened down against the risk of a big tsunami.
The Indian National Centre for Ocean Information Service issued a red high-level warning for the Andaman and Nicobar Islands, and also put out lower alerts for the coasts of Andhra Pradesh and Tamil Nadu states in the southeast of the country.
Thailand's disaster centre on Wednesday put provinces along the Andaman coastline on watch for a possible tsunami. It advised people in the area, which was battered by the 2004 tsunami, to move to higher places and stay as far away as possible from the sea.
Smith Dhamasoroja, of the Thai National Disaster Warning Foundation, predicted that the earthquake was of such a magnitude that it would create a tsunami that would "definitely" reach Thailand.
Flights to Phuket were diverted to other airports as passengers and staff were evacuated to higher ground. In Sri Lanka tremors were felt across the country, including western and southern provinces following the earthquake.
A Sri Lankan government official said disaster management authorities had advised people in coastal communities, particularly in previously tsunami-struck areas such as Batticaloa and Trincomalee in the country's northeast, to move away from the coast although he stressed at this stage it was still only advice.
Indonesia is on the so-called Ring of Fire, an arc of fault lines circling the Pacific Basin that is prone to frequent earthquakes and volcanic eruptions. Last year, a magnitude-9 quake caused a tsunami and nuclear disaster in Japan, killing 19,000 people.
Additional reporting: Telly Nathalia, Nicolas Perpitch, Amanda Hodge
Update time = Wed Apr 11 15:15:28 UTC 2012
MAP    6.9     2012/04/12 07:15:49      28.790     -113.142    10.3     GULF OF CALIFORNIA
MAP    6.2     2012/04/12 07:06:01      28.841     -113.072    10.1     GULF OF CALIFORNIA
MAP    6.5     2012/04/11 22:55:11      18.272     -102.732    20.0     MICHOACAN, MEXICO
MAP    5.3     2012/04/11 14:54:29      1.336      91.841    11.9     NORTH INDIAN OCEAN
MAP    5.3     2012/04/11 14:34:19      1.504      90.894    14.4     NORTH INDIAN OCEAN
MAP    5.0     2012/04/11 14:26:27      2.287      92.385    9.4     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.0     2012/04/11 14:18:45      2.569      92.296    10.3     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.2     2012/04/11 14:08:41      1.147      92.158    9.6     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.5     2012/04/11 13:58:07      1.493      90.889    13.7     NORTH INDIAN OCEAN
MAP    5.3     2012/04/11 13:42:41      2.199      93.623    10.7     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.0     2012/04/11 13:19:37      2.296      90.342    17.5     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.1     2012/04/11 12:37:48      2.528      92.602    10.0     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.1     2012/04/11 12:21:58      3.136      92.775    9.9     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.1     2012/04/11 12:10:53      1.385      92.639    10.4     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.7     2012/04/11 11:53:37      2.929      89.534    14.9     NORTH INDIAN OCEAN
MAP    5.3     2012/04/11 11:52:29      0.989      91.942    14.9     NORTH INDIAN OCEAN
MAP    5.4     2012/04/11 11:34:02      0.743      92.865    15.5     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.4     2012/04/11 11:29:00     -56.847      -27.966    259.0     SOUTH SANDWICH ISLANDS REGION
MAP    8.2     2012/04/11 10:43:09      0.773      92.452    16.4     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.4     2012/04/11 10:36:55      1.072      91.943    15.5     NORTH INDIAN OCEAN
MAP    5.4     2012/04/11 10:21:16      2.833      92.476    14.8     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.1     2012/04/11 10:08:30      2.646      90.084    16.1     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.3     2012/04/11 10:01:20      2.499      90.365    20.0     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.3     2012/04/11 09:51:42      2.510      90.316    20.0     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    6.0     2012/04/11 09:27:57      1.281      91.731    9.8     NORTH INDIAN OCEAN
MAP    5.5     2012/04/11 09:00:13      51.518     -176.312    56.5     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    8.6     2012/04/11 08:38:37      2.311      93.063    22.9     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    5.3     2012/04/11 07:41:46      -6.227      130.158    132.2     BANDA SEA
MAP    5.1     2012/04/11 05:44:42     -16.900      -14.406    10.5     SOUTHERN MID-ATLANTIC RIDGE
MAP    5.2     2012/04/11 04:53:26     -16.822      -14.440    9.7     SOUTHERN MID-ATLANTIC RIDGE
MAP    5.8     2012/04/10 05:09:09      -1.148      -13.968    9.9     NORTH OF ASCENSION ISLAND
MAP    5.4     2012/04/08 21:43:32      24.094      122.303    25.5     TAIWAN REGION
MAP    5.0     2012/04/07 20:37:52      1.034      -28.110    10.0     CENTRAL MID-ATLANTIC RIDGE
MAP    5.2     2012/04/07 20:09:40      -6.067      130.687    76.4     BANDA SEA
MAP    5.8     2012/04/07 11:58:08      -6.785      149.549    39.6     NEW BRITAIN REGION, PAPUA NEW GUINEA
MAP    5.5     2012/04/06 19:24:13      -3.376      100.453    5.5     KEPULAUAN MENTAWAI REGION, INDONESIA
MAP    6.2     2012/04/06 16:15:56      -4.534      153.497    85.4     NEW IRELAND REGION, PAPUA NEW GUINEA
MAP    5.5     2012/04/04 20:27:29      -4.030      152.091    16.7     NEW BRITAIN REGION, PAPUA NEW GUINEA:s
New Activity/Unrest
BATU TARA Komba Island (Indonesia) 7.792°S, 123.579°E; summit elev. 748 m
Based on analyses of satellite imagery, the Darwin VAAC reported that during 25-26 April ash plumes from Batu Tara rose to an altitude of 2.4 km (8,000 ft) a.s.l. and drifted 37 km W and SW. During 30 April-1 May ash plumes again rose to an altitude of 2.4 km (8,000 ft) a.s.l. then drifted 37-55 km NW.
Geologic Summary. The small isolated island of Batu Tara in the Flores Sea about 50 km north of Lembata (formerly Lomblen) Island contains a scarp on the eastern side similar to the Sciara del Fuoco of Italy's Stromboli volcano. Vegetation covers the flanks of Batu Tara to within 50 m of the 748-m-high summit. Batu Tara lies north of the main volcanic arc and is noted for its potassic leucite-bearing basanitic and tephritic rocks. The first historical eruption from Batu Tara, during 1847-52, produced explosions and a lava flow.
Map
Source: Darwin Volcanic Ash Advisory Centre (VAAC)
Batu Tara Information from the Global Volcanism Program
CLEVELAND Chuginadak Island 52.825°N, 169.944°W; summit elev. 1730 m
AVO reported that elevated surface temperatures were detected over Cleveland in satellite imagery during 25-29 April and possibly on 30 April. Observations showed that a small lava dome, 25 m across, had recently been emplaced.
Geologic Summary. Symmetrical Mount Cleveland stratovolcano is situated at the western end of the uninhabited dumbbell-shaped Chuginadak Island in the east-central Aleutians. The 1,730-m-high stratovolcano is the highest of the Islands of Four Mountains group and is one of the most active in the Aleutians. Numerous large lava flows descend its flanks. It is possible that some 18th to 19th century eruptions attributed to Carlisle (a volcano located across the Carlisle Pass Strait to the NW) should be ascribed to Cleveland. In 1944 Cleveland produced the only known fatality from an Aleutian eruption. Recent eruptions from Mt. Cleveland have been characterized by short-lived explosive ash emissions, at times accompanied by lava fountaining and lava flows down the flanks.
Map
Source: Alaska Volcano Observatory (AVO)
Cleveland Information from the Global Volcanism Program
IOTO [IWO-JIMA] Volcano Islands (Japan) 24.754°N, 141.290°E; summit elev. 161 m
According to a JMA report on 2 May, an eruption at Ioto (Iwo-jima) caused water discoloration to the NE. A new fumarole was also confirmed.
Geologic Summary. Ioto (also known as Iwo-jima) in the central Volcano Islands portion of the Izu-Marianas arc lies within a 9-km-wide submarine caldera. Ioto, Iwo-jima, and Io-jima are among many transliterations of the name, which means "Sulfur Island;" the volcano is also known as Ogasawara Io-jima to distinguish it from several other "Sulfur Island" volcanoes in Japan. The triangular, low-elevation, 8-km-long island narrows toward its SW tip and has produced trachyandesitic and trachytic rocks that are more alkalic than those of other Izu-Marianas arc volcanoes. The island has undergone dramatic uplift for at least the past 700 years accompanying resurgent doming of the caldera. A shoreline landed upon by Captain Cook's surveying crew in 1779 is now 40 m above sea level. The Moto-yama plateau on the NE half of the island consists of submarine tuffs overlain by coral deposits and forms the island's high point. Many fumaroles are oriented along a NE-SW zone cutting through Moto-yama. Numerous historical phreatic eruptions, many from vents on the west and NW sides of the island, have accompanied the remarkable uplift.
Map
Source: Japanese Meteorological Agency (JMA)
Ioto [Iwo-jima] Information from the Global Volcanism Program
LOKON-EMPUNG Sulawesi 1.358°N, 124.792°E; summit elev. 1580 m
According to the Darwin VAAC, ash plumes from Lokon-Empung, that rose to an altitude of 3.7 km (12,000 ft) a.s.l. and drifted 75 km N, were detected in satellite imagery and reported by ground-based observers.
Geologic Summary. The twin volcanoes Lokon and Empung, rising about 800 m above the plain of Tondano, are among the most active volcanoes of Sulawesi. Lokon, the higher of the two peaks (whose summits are only 2.2 km apart) has a flat, craterless top. The morphologically younger Empung volcano has a 400-m-wide, 150-m-deep crater that erupted last in the 18th century, but all subsequent eruptions have originated from Tompaluan, a 150 x 250 m wide double crater situated in the saddle between the two peaks. Historical eruptions have primarily produced small-to-moderate ash plumes that have occasionally damaged croplands and houses, but lava-dome growth and pyroclastic flows have also occurred.
Map
Source: Center of Volcanology and Geological Hazard Mitigation (CVGHM)
Lokon-Empung Information from the Global Volcanism Program
POPOCATEPETL México 19.023°N, 98.622°W; summit elev. 5426 m
CENAPRED reported that gas-and-steam plumes, occasionally containing ash, rose from Popocatépetl during 25-29 April. Gas-and-ash plumes rose 1.5 km above the crater on 25 and 27 April. On 28 April incandescent fragments ejected from the crater landed on E flank as far as 1 km. The next day steam-and-gas plume rose from the crater. On 1 May gas-and-steam plumes, that occasionally contained low amounts of ash, and rose 1 km above the crater. The Alert Level remained at Yellow Phase Three.
Geologic Summary. Popocatépetl, whose name is the Aztec word for smoking mountain, towers to 5,426 m 70 km SE of Mexico City and is North America's second-highest volcano. Frequent historical eruptions have been recorded since the beginning of the Spanish colonial era. A small eruption on 21 December 1994 ended five decades of quiescence. Since 1996 small lava domes have incrementally been constructed within the summit crater and destroyed by explosive eruptions. Intermittent small-to-moderate gas-and-ash eruptions have continued, occasionally producing ashfall in neighboring towns and villages.
March 29
New Activity/Unrest
Map
Map
Map
Map
RE: Ice Age Model
« Reply #15, on June 1st, 2012, 02:45 PM »Last edited on August 13th, 2012, 09:50 AM by freethisone
Volcano News - John Seach
June 2012
john
Monitoring worldwide volcanic activity
12 years on the internet - 2000-2012
Reports are posted in Eastern Australian Time (UT +10 hr).
Archived Volcano News
Wednesday 6th June 2012
Manam Volcano, Papua New Guinea
Activity has increased at Manam volcano in Papua New Guinea. Explosions have been heard on the mainland 15 km away, and a skyglow was visible at night.
More on Manam volcano...
Volcanoes of Papua New Guinea...
Tuesday 29th May 2012
Soputan Volcano, Indonesia
The alert status at Soputan volcano, Indonesia was increased from level 2 (waspada) to level 3 (siaga) on 28th May 2012. Seismic activity has increased significantly over the past 4 days with avalanche earthquakes averaging 60 per day. Potential hazards at the volcano include lava dome phreatic explosion, pyroclastic flows, and ashfall. A 6 km exclusion zone has been placed around the volcano.
More on Soputan volcano...
Friday 25th May 2012
Popocatepetl Volcano, Mexico
Activity at Popocatepetl volcano, Mexico remains high. On 24th May 2012 emissions reached a height of 800 m above the crater. Periods of harmonic tremor have been accompanied by ejection of incandescent fragments of lava 500 m down the flanks of the volcano. The alert status remains at level 3. This means the lava dome remains active and continued explosive eruptions are possible.
More on Popocatepetl volcano...
Volcanoes of Mexico...
The level of the summit lava lake has dropped at Kilauea volcano, Hawaii. This has coincided with deflation of the volcano. Twelve earthquakes were recorded at the volcano over the past day. The overall seismicity at the volcano remains low. Lava flows continue on the pali and coastal plain along the east rift zone. Lava flows move towards the ocean, but there is no lava ocen entry at present. A fissure eruption which occurred on the east rift zone on September 21, 2011 drained the lava lake in Pu'u O'o crater. The subsequent lava flow moved through the abandoned Royal Gardens subdivision, destroying the remaining house in the area.
More on Kilauea volcano...
Volcanoes of Hawaii...
Ijen Volcano, Indonesia
The alert status at Ijen volcano, Indonesia was decreased from level 3 (siaga) to level 2 (waspada) on 13th May 2012. Volcanic tremor decreased from the beginning of April until 13th May 2012. A 1 km exclusion zone remains around the crater lake. It is recommended that tourists and miners about the crater.
More on Ijen volcano...
Sirung Volcano, Indonesia
A small ash eruption occurred at Sirung volcano Indonesia on 8th May 2012. The eruption lasted for 3 hours and was accompanied by a burst of sound and incandescent material ejected 10m above the crater. Ashfall occurred 3.5 km north of the volcano to a depth of 4mm. The smell of sulphur detected 3km north of the crater. On 12th May 2012 the alert status at Sirung volcano was raised from level 2 (waspada) to level 3 (siaga). A 2.5 km exclusion zone has been planed around the volcano.
More on Sirung volcano...
Fuego Volcano, Guatemala
Activity continues at Fuego volcano, Guatemala. On 23rd May 2012 there were explosions and ash columns rising 700 m above the crater. At night glowing avalanches occurred, and were accompanied by rumbling explosions and shockwaves. Lava flows have almost disappeared.
More on Fuego volcano...
Volcanoes of Guatemala...
Santa Maria Volcano, Guatemala
Activity continues at Santa Maria volcano, Guatemala. On 23rd May 2012 explosions and ash emissions reached a height of 800 m above the crater.
More on Santa Maria volcano...
Thursday 3rd May 2012
Lokon Volcano, Indonesia
An eruption occurred at Lokon volcano on 1st May 2012. The eruption occurred at 11:55 am, local time and was accompanied by ashfall over a radius of 2.5 km from Tompaluan crater.
More on Lokon volcano...
Quick Links
    Breaking News
    World Volcanoes
    Adventure Travel
    Film and Television
    Photos
    Volcanology
    Live Cams
    Contact
This model would be useless if it could not predict, or back up the scientific principles with real data in the form of quakes, and volcanic eruption. Because it predicts these as time variable I get the results as expected.
I have to Update this due to the recent earthquake that struck Italy last week. will continue.
This is a progression of activity. This has progressed in the opposite direction of earths rotation. continuity torquing.  These earthquakes progressing west from California, ending in California.  I suspect this is the case.
I have 1 question to leave hanging. has the lunar precession completed in 28 month? starting in February 2010?  needs validation...
Italy should see continued activity over a 6 to 18 month period. I must however summarize California as the last building block of the puzzle. Mountain building.
Last in the chain of Earthquakes, starting in the Hatti region, and continuing west to Japan, and Siberia. the progression there was very quick in my opinion. Observations of 3 to 7 months time frame.
I am expecting King tides for July august, and September. quake activity in October through  February. and Another great quake for 2013. perhaps up to 40 days late.. At the end of May, beginning June 2013 Great quake four.   If not up to 40 days earlier then the FEB 27, 2010 chili quake. Even Jan 12 to Feb 27 2013 this Great quake could occur.. Ring the bell two times.  This would mark the astronomical event as fact for validation purposes.
 December, and January 7.0 or  greater quakes. and the solar outburst once starting in February. Edd Lee on Sweet 16 may be significant. marking the half way point perhaps.
There is much more information learned  that has not been posted, or mentions.
The Mid  Atlantic ridge to feel some quakes. alaska will also, and Alaskan volcanoes may blow. central usa fault comes next. All at once perhaps Baja, cali northern Cali, and chili. from east to west.
 The activity of quakes if that was to occur will be more damaging after the fact, as the entire region would be building up..
The Sahara mountains formed in this manner?
Thanks guys. If you have any questions to the current information give a shout.:angel::angel:
May volcanic information.
New Activity/Unrest
FUEGO Guatemala 14.473°N, 90.880°W; summit elev. 3763 m
INSIVUMEH reported that on 6 June lahars descended Fuego's El Jute (SE), Las Lajas (SE), Ceniza (SSW), Santa Teresa (S), and Taniluyá (SW) drainages, and destroyed roads in Yepocapa (8 km WNW). During 6-7 June explosions produced ash plumes that rose 200-500 m above the crater and drifted N, and 12 km S and SW. Lava flows on the SE flank were about 800-900 m long in the Las Lajas drainage, 600 m long in the El Jute drainage, and 250 m long on the SW flank, and produced blocks that rolled and reached vegetated areas. The explosions were accompanied by rumbling sounds and shock waves that were detected in areas 10 km away, including Panimaché and Morelia (~8 km SW).
During 10-11 June an ash plume rose 1.5 km above the crater and drifted 15 km W and NW. Ashfall was reported in Panimaché I and II, Sangre de Cristo (8 km WSW), Yepocápa, and other villages nearby. Lava flows traveled 1.6 km down Taniluyá drainage, 1 km down the Ceniza drainage, and 1.5 km down Las Lajas. Pyroclastic flows descended Las Lajas. During 11-12 June explosions generated ash plumes that rose 300 m above the crater and drifted W. Lava flows traveled 300 m down the Taniluyá drainage. Incandescence rose 100 m.
Geologic Summary. Volcán Fuego, one of Central America's most active volcanoes, is one of three large stratovolcanoes overlooking Guatemala's former capital, Antigua. The scarp of an older edifice, Meseta, lies between 3,763-m-high Fuego and its twin volcano to the N, Acatenango. Construction of Meseta volcano continued until the late Pleistocene or early Holocene, after which growth of the modern Fuego volcano continued the southward migration of volcanism that began at Acatenango. Frequent vigorous historical eruptions have been recorded at Fuego since the onset of the Spanish era in 1524, and have produced major ashfalls, along with occasional pyroclastic flows and lava flows. The last major explosive eruption from Fuego took place in 1974, producing spectacular pyroclastic flows visible from Antigua.
Map
Source: Instituto Nacional de Sismologia, Vulcanologia, Meteorologia, e Hidrologia (INSIVUMEH)
Fuego Information from the Global Volcanism Program
GALERAS Colombia 1.22°N, 77.37°W; summit elev. 4276 m
On 5 June INGEOMINAS reported that seismicity at Galeras increased since the previous week and indicated continuing ash and gas emissions. Ash originated from an area N and W of the cone within the main crater and was emitted in a pulsating manner. Ash was deposited on the NW flanks. Ash emissions were especially frequent on 2 and 5 June, with plumes rising 1 km above the crater. The Alert Level remained at III (Yellow; "changes in the behavior of volcanic activity").
Geologic Summary. Galeras, a stratovolcano with a large breached caldera located immediately W of the city of Pasto, is one of Colombia's most frequently active volcanoes. The dominantly andesitic Galeras volcanic complex has been active for more than 1 million years, and two major caldera collapse eruptions took place during the late Pleistocene. Longterm extensive hydrothermal alteration has affected the volcano. This has contributed to large-scale edifice collapse that has occurred on at least three occasions, producing debris avalanches that swept to the W and left a large horseshoe-shaped caldera inside which the modern cone has been constructed. Major explosive eruptions since the mid Holocene have produced widespread tephra deposits and pyroclastic flows that swept all but the southern flanks. A central cone slightly lower than the caldera rim has been the site of numerous small-to-moderate historical eruptions since the time of the Spanish conquistadors.
Map
Source: Instituto Colombiano de Geología y Minería (INGEOMINAS)
Galeras Information from the Global Volcanism Program
NEVADO DEL RUIZ Colombia 4.895°N, 75.322°W; summit elev. 5321 m
According to INGEOMINAS, the Observatorio Vulcanológico and Sismológico de Manizales reported that a satellite image of Nevado del Ruiz acquired on 6 June showed an ash plume rising from the crater and drifting NW, and ash deposits on the N, NW, W and SW flanks. Based on analysis of satellite imagery and information from INGEOMINAS, the Washington VAAC reported that gas plumes possibly containing some ash drifted 75-110 km W, WNW, and N during 7 and 9-10 June. Ash plumes drifted almost 30 km SE on 8 June. INGEOMINAS reported that on 11 June seismic signals indicated continuing ash emissions. The Alert Level remained at II (Orange; "eruption likely within days or weeks").
Geologic Summary. Nevado del Ruiz is a broad, glacier-covered volcano in central Colombia that covers >200 sq km. Three major edifices, composed of andesitic and dacitic lavas and andesitic pyroclastics, have been constructed since the beginning of the Pleistocene. The modern cone consists of a broad cluster of lava domes built within the summit caldera of an older Ruiz volcano. The 1-km-wide, 240-m-deep Arenas crater occupies the summit. Steep headwalls of massive landslides cut the flanks of Nevado del Ruiz. Melting of its summit icecap during historical eruptions, which date back to the 16th century, has resulted in devastating lahars, including one in 1985 that was South America's deadliest eruption.
Map
Sources: Instituto Colombiano de Geología y Minería (INGEOMINAS), Washington Volcanic Ash Advisory Center (VAAC)
Nevado del Ruiz Information from the Global Volcanism Program
POAS Costa Rica 10.20°N, 84.233°W; summit elev. 2708 m
OVSICORI-UNA reported that phreatic eruptions at Poás occurred on 6, 15, 20 and 26 May. The eruption on 15 May was preceded by about 6 hours of very-low amplitude harmonic tremor. Administrators of the Poás Volcano National Park witnessed the eruption and reported that sediment, water, rock fragments, and plumes were ejected 500 m above the lake surface. The level of the lake dropped ~0.9 m between 8 and 29 May.
Geologic Summary. The broad, well-vegetated edifice of Poás, one of the most active volcanoes of Costa Rica, contains three craters along a N-S line. The frequently visited multi-hued summit crater lakes of the basaltic-to-dacitic volcano, which is one of Costa Rica's most prominent natural landmarks, are easily accessible by vehicle from the nearby capital city of San José. A N-S-trending fissure cutting the 2,708-m-high complex stratovolcano extends to the lower northern flank, where it has produced the Congo stratovolcano and several lake-filled maars. The southernmost of the two summit crater lakes, Botos, is cold and clear and last erupted about 7,500 years ago. The more prominent geothermally heated northern lake, Laguna Caliente, is one of the world's most acidic natural lakes, with a pH of near zero. It has been the site of frequent phreatic and phreatomagmatic eruptions since the first historical eruption was reported in 1828. Poás eruptions often include geyser-like ejection of crater-lake water.
Map
Source: Observatorio Vulcanologico y Sismologico de Costa Rica-Universidad Nacional (OVSICORI-UNA)
Poás Information from the Global Volcanism Program
Ongoing Activity
BAGANA Bougainville 6.140°S, 155.195°E; summit elev. 1750 m
Based on analyses of satellite imagery, the Darwin VAAC reported that on 10 June ash plumes from Bagana rose to an altitude of 2.4 km (8,000 ft) a.s.l. and drifted 45-130 km SW.
Geologic Summary. Bagana volcano, occupying a remote portion of central Bougainville Island, is one of Melanesia's youngest and most active volcanoes. Bagana is a massive symmetrical lava cone largely constructed by an accumulation of viscous andesitic lava flows. The entire lava cone could have been constructed in about 300 years at its present rate of lava production. Eruptive activity at Bagana is characterized by non-explosive effusion of viscous lava that maintains a small lava dome in the summit crater, although explosive activity occasionally producing pyroclastic flows also occurs. Lava flows form dramatic, freshly preserved tongue-shaped lobes up to 50-m-thick with prominent levees that descend the volcano's flanks on all sides.
Map
Volcanoes of Indonesia...
Kilauea Volcano, Hawaii
Sunday 12th August 2012
Eruption from Unknown Undersea volcano, South Pacific
A large amount of pumice has been observed floating in the South Pacific ocean 85 nautical miles west-south-west of Raoul Island. The pumice raft was first observed by an aircraft pilot on 1st August 2012. The pumice covered 25,000 square km. Crew on board the ship HMNZS Canterbury observed the pumice on 9th August. The source of the pumice has not been determined.
More on Kermadec Islands volcanoes...
Thursday 9th August 2012
White Island Volcano, New Zealand
A tuff cone has started to build over the eruption site at White Island volcano. The eruption on 6th August 2012 was the first in 11 years. Small amounts of ash are being emitted from the active vent. Visitors to the island are at risk from further eruptions. The alert status remains at level 2 (on a scale of 0-5).
More on White Island volcano...
Volcanoes of New Zealand...
Wednesday 8th August 2012
A small eruption occurred at White Island volcano at 04:55 am on 6th August 2012. The eruption occurred at the crater lake and was preceded by strong volcanic tremor on 4-5 August. The crater lake had gradually emptied during 2011 and 2012, and the water level rose rapidly 3-5 m on 27-28 July 2012. The alert status at the volcano has been raised to level 2.
Tuesday 7th August 2012
Tongariro Volcano, New Zealand
Tongariro volcano erupted at 11:30 pm on 6th August 2012. The eruption occurred at Te Mari crater and lasted a few minutes and was followed by earthquakes over the next half hour. Activity subsided the following morning. Ketetahi Hut was destroyed by volcanic boulders 1 metre in diameter. The hut is located 1.5 km from the eruption. There were no hikers in the hut at the time of the eruption. All four national park huts around Mt Tongariro have been closed for safety reasons. No one was injured in the eruption. The alert status at Tongariro volcano has been raised to level 2.
More on Tongariro volcano...
Monday 30th July 2012
The alert status at Ijen volcano, Indonesia was increased from level 2 (waspada) to level 3 (siaga) to on 24th July 2012. A 1.5 km exclusion zone has been placed around the crater lake. It is recommended that tourists and miners avoid entering the crater.
Friday 20th July 2012
Beginning on 13th July 2012 small earthquakes were recorded under Tongariro volcano. The earthquakes were small (less than magnitude 2.5). The seismic activity was located in a cluster between Emerald crater and Te Mari crater at a depth of 2-7 km. More than 20 earthquakes were recorded between 13th-20th July 2012. This compares to a background rate of 2 per year. On 20th July 2012 the alert level at the volcano was raised from 0 to 1.
Wednesday 18th July 2012
A new period of activity has begun at Fuego volcano, Guatemala. A 150 m long lava flow has appeared in the direction of Taniluyá ravine. The lava flow was accompanied by incandescent avalanches. Weak explosions in the crater sent ash emissions 600 m high, and drifting 10 km south and southwest.
Tuesday 17th July 2012
Merapi Volcano, Indonesia
A small emission of ash occurred at Merapi volcano, Indonesia on 15th July 2012. The small eruption was not followed by other signs of unrest and the alert status remained unchanged. The eruption was caused by a small collapse of the lava dome which remains unstable after the 2010-11 eruptions. Ash emission reached a height of 1 km above the crater, and ashfall occurred at Jurang Jero and Srumbung. Climbers are advised to stay away from the summit.
More on Merapi volcano...
Thursday 28th June 2012
Eruptions are occurring at two locations at Kilauea volcano in Hawaii. On the east rift zone lava has descended the pali and is moving along the coastal plain. A summit lava lake is located at Halemaumau crater in a 160 m wide vent.
The alert status at Ijen volcano, Indonesia was decreased from level 3 (siaga) to level 2 (waspada) on 13th May 2012. Volcanic tremor decreased from the beginning of April until 13th May 2012. A 1 km exclusion zone remains around the crater lake. It is recommended that tourists and miners avoid the crater.
RE: Ice Age Model
« Reply #16, on July 1st, 2012, 03:20 PM »Last edited on July 11th, 2012, 07:54 PM by freethisone
Quote from freethisone on November 30th, 2011, 08:33 PM
This as an update to the scientific principles of mass, or charge the direction of that force. gravity.
I had reviewed this information over the last few days, and i was very interested. Walter lewin had described the direction of increasing potential, and also the gravitational force place on that charge.
Go over the material a few times. this is the formula for calculating the gravitational flux or electric field.  In this lecture something became apparent to me
Astronomy of binary systems of stars or planets, .how to relate the real work to reality? How do we separate what is fantastic in its Glory?
If i have charge  sun, and charge little sun, and i let the little partner star go; It will  try to find equilibrium. it will move to the lower potential.
I ask how can this be?   I suppose that the velocity of little sun does not remain constant and is speeding up. We get to a point were little sun needs to exert a strong force on big sun, a increasing potential. So i had said the sun is also increasing in potential energy, but the force is clearly pushing little sun away.
If it be that the sun is at its farthest point from earth as we have known it, it is in fact one million miles farther than it used to be...  How can a force little sun exert a pressure strong enough to move the sun 1 million miles out of its way so it may then change direction, and we get a gravitational force in the opposite direction that is decreasing.
this is to help me understand the formula better, and to also include that both potential energy on little sun, and sun are increasing. I really have to push...
https://www.youtube.com/watch?v=bwDaSf6WuRU:cool:
:dodgy:https://www.youtube.com/watch?v=G5CSr7nRdvw
https://www.youtube.com/watch?v=VKxB_KR7Iss
I will also add a few drawings..
peace all..
RE: Ice Age Model
« Reply #17, on July 10th, 2012, 08:57 AM »Last edited on August 13th, 2012, 09:52 AM by freethisone
   confirming all data. Alaska region, Mexico, Caribbean, virgin islands, and more...  The areas stated will begin to feel a greater strain, and movement in a short time..
Tuesday, Jul. 10, 2012
   What's up in space
Listen to radar echoes from satellites and meteors, live on listener-supported Space Weather Radio.
Spaceweather Radio is on the air
AURORAS OVER THE SOUTH POLE: On July 10th, observers are reporting butterfly-shaped auroras directly over the South Pole. The shape of the southern auroral oval often leaves the South Pole in a "doughnut hole" of poor visibility, but today is an exception. [aurora gallery]
NORTHERN LIGHTS: For the second day in a row, Earth's polar magnetic field is unsettled and glowing with auroras. Paul Zizka sends this picture from Banff National Park in Alberta, Canada:
"Yet another sleepless night at Lake Minnewanka--and it was worth it," says Zizka. "The aurora danced on and off for hours. Most of the time it was barely visible to the naked eye, but now and then Mother Nature would put on a show that was hard to miss. The displays ranged from a very interesting, long-lasting pink streak directly overhead to wild green curls and purple pillars to the north and east."
The source of the display was not an explosion on the sun, but rather a fluctuation in the interplanetary magnetic field (IMF). On July 9th, the IMF near Earth tipped south, opening a crack in our planet's magnetosphere. Solar wind poured in and ignited the lights.
   Update time = Wed Jul 25 21:27:47 UTC 2012
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    2.5     2012/07/25 20:24:07      18.120      -65.723    3.0     PUERTO RICO REGION
MAP    4.7     2012/07/25 20:00:18      36.383      142.442    43.7     OFF THE EAST COAST OF HONSHU, JAPAN
MAP    5.0     2012/07/25 19:01:37     -19.398      167.770    38.1     VANUATU REGION
MAP    2.5     2012/07/25 18:08:40      48.469     -114.445    10.1     WESTERN MONTANA
MAP    4.9     2012/07/25 17:20:12      30.988      130.363    142.0     KYUSHU, JAPAN
MAP    4.0     2012/07/25 14:51:39      58.977     -139.730    25.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.7     2012/07/25 14:51:15      36.091      69.239    22.7     HINDU KUSH REGION, AFGHANISTAN
MAP    4.6     2012/07/25 13:44:18      -7.712      127.026    232.1     KEPULAUAN BARAT DAYA, INDONESIA
MAP    4.8     2012/07/25 13:27:53      5.532      126.458    136.3     MINDANAO, PHILIPPINES
MAP    6.5     2012/07/25 11:20:28      -9.721      159.730    22.9     SOLOMON ISLANDS
MAP    4.6     2012/07/25 11:09:36     -20.141     -177.695    487.4     FIJI REGION
MAP    3.7     2012/07/25 10:18:42      33.964     -118.407    10.8     GREATER LOS ANGELES AREA, CALIFORNIA
MAP    4.5     2012/07/25 10:09:53      5.600      127.070    114.5     PHILIPPINE ISLANDS REGION
MAP    4.7     2012/07/25 08:39:36      11.709      125.494    69.0     SAMAR, PHILIPPINES
MAP    3.0     2012/07/25 08:23:20      44.484     -114.519    10.3     SOUTHERN IDAHO
MAP    4.9     2012/07/25 06:13:04      1.941      89.704    10.0     NORTH INDIAN OCEAN
MAP    4.6     2012/07/25 06:01:15     -28.043      -66.574    167.1     CATAMARCA, ARGENTINA
MAP    3.0     2012/07/25 04:07:18      38.838     -122.786    2.4     NORTHERN CALIFORNIA
MAP    2.6     2012/07/25 02:45:19      60.858     -149.425    19.9     KENAI PENINSULA, ALASKA
MAP    2.7     2012/07/25 02:34:18      51.079      179.135    15.7     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    6.4     2012/07/25 00:27:45      2.657      96.126    22.0     SIMEULUE, INDONESIA
MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    5.1     2012/07/10 18:09:43     -23.407     -179.805    535.1     SOUTH OF THE FIJI ISLANDS
MAP    2.5     2012/07/10 16:36:17      51.501     -176.967    55.4     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.7     2012/07/10 15:39:41      32.289     -115.298    0.0     BAJA CALIFORNIA, MEXICO
MAP    3.6     2012/07/10 14:56:24      64.484     -146.865    6.2     CENTRAL ALASKA
MAP    2.6     2012/07/10 14:11:17      32.193     -115.309    0.1     BAJA CALIFORNIA, MEXICO
MAP    3.0     2012/07/10 14:09:15      19.068      -64.067    57.0     VIRGIN ISLANDS REGION
MAP    3.1     2012/07/10 12:37:40      32.181     -115.308    0.4     BAJA CALIFORNIA, MEXICO
MAP    2.9     2012/07/10 11:30:07      51.546      178.252    71.1     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.6     2012/07/10 10:46:39     -16.670      167.158    41.3     VANUATU
MAP    4.7     2012/07/10 10:43:52     -59.568      -26.241    15.6     SOUTH SANDWICH ISLANDS REGION
MAP    5.2     2012/07/10 10:27:00      -1.663      134.186    31.7     NEAR THE NORTH COAST OF PAPUA, INDONESIA
MAP    3.4     2012/07/10 09:38:17      62.184     -149.420    40.8     CENTRAL ALASKA
MAP    4.5     2012/07/10 09:05:18     -21.464     -179.172    572.4     FIJI REGION
MAP    4.3     2012/07/10 04:06:54      63.437     -149.407    104.3     CENTRAL ALASKA
MAP    4.8     2012/07/10 03:48:58      36.751      138.150    18.2     EASTERN HONSHU, JAPAN
MAP    3.2     2012/07/10 03:36:08      19.322      -67.442    59.0     PUERTO RICO REGION
MAP    5.1     2012/07/10 02:28:13     -25.224     -176.291    18.1     SOUTH OF THE FIJI ISLANDS
MAP    2.5     2012/07/10 01:16:31      63.938     -151.656    0.1     CENTRAL ALASKA
MAP    4.5     2012/07/10 00:32:29      32.350      141.673    43.6     IZU ISLANDS, JAPAN REGION
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    2.5     2012/07/09 23:31:29      32.186     -115.278    12.6     BAJA CALIFORNIA, MEXICO
MAP    2.9     2012/07/09 23:23:53      60.837     -152.306    101.4     SOUTHERN ALASKA
MAP    2.8     2012/07/09 22:17:30      18.846      -67.666    10.0     PUERTO RICO REGION
MAP    4.4     2012/07/09 21:01:34      -7.560      127.563    163.1     KEPULAUAN BARAT DAYA, INDONESIA
MAP    2.8     2012/07/09 20:40:21      39.310     -119.988    7.4     NEVADA
MAP    2.5     2012/07/09 19:42:33      53.405     -164.722    25.6     UNIMAK ISLAND REGION, ALASKA
MAP    5.5     2012/07/09 19:25:09      29.389      130.177    49.5     RYUKYU ISLANDS, JAPAN
MAP    2.6     2012/07/09 17:30:53      34.029     -117.552    4.7     GREATER LOS ANGELES AREA, CALIFORNIA
MAP    4.8     2012/07/09 15:40:21      0.806      -29.095    10.0     CENTRAL MID-ATLANTIC RIDGE
MAP    2.7     2012/07/09 13:56:02      48.593     -124.858    31.3     VANCOUVER ISLAND, CANADA REGION
MAP    5.6     2012/07/09 13:55:01      35.623      28.925    56.5     EASTERN MEDITERRANEAN SEA
MAP    2.6     2012/07/09 13:30:42      61.741     -149.416    18.2     SOUTHERN ALASKA
MAP    4.5     2012/07/09 12:56:39     -33.082      -68.277    157.7     MENDOZA, ARGENTINA
MAP    3.1     2012/07/09 12:34:20      59.790     -153.888    138.5     SOUTHERN ALASKA
MAP    5.4     2012/07/09 12:25:46      -0.191      122.769    86.9     SULAWESI, INDONESIA
MAP    5.0     2012/07/09 10:39:01      17.145      146.106    125.8     ALAMAGAN REG., NORTHERN MARIANA ISLANDS
MAP    4.3     2012/07/09 09:50:41      7.304      -73.135    41.4     NORTHERN COLOMBIA
MAP    4.6     2012/07/09 08:30:19      42.039      142.975    86.8     HOKKAIDO, JAPAN REGION
MAP    3.1     2012/07/09 08:17:00      18.827      -64.927    77.0     VIRGIN ISLANDS REGION
MAP    4.8     2012/07/09 07:20:54      49.185      147.294    545.8     SEA OF OKHOTSK
MAP    2.7     2012/07/09 06:49:39      18.955      -65.264    17.0     PUERTO RICO REGION
MAP    4.5     2012/07/09 06:29:24     -14.277      167.268    184.5     VANUATU
MAP    4.5     2012/07/09 01:44:27     -35.213      -72.069    49.7     MAULE, CHILE
MAP    4.5     2012/07/09 01:34:50      46.493      149.148    119.4     KURIL ISLANDS
MAP    3.8     2012/07/09 00:01:18      38.819     -122.796    3.9     NORTHERN CALIFORNIA
MAP    2.7     2012/07/09 00:00:45      38.820     -122.800    3.9     NORTHERN CALIFORNIA
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.6     2012/07/08 22:39:08      -6.565      155.023    98.7     BOUGAINVILLE REGION, PAPUA NEW GUINEA
MAP    4.3     2012/07/08 21:11:20      46.867      152.816    73.2     KURIL ISLANDS
MAP    2.6     2012/07/08 18:56:36      36.823     -121.555    3.5     CENTRAL CALIFORNIA
MAP    2.5     2012/07/08 18:07:56      36.821     -121.548    3.8     CENTRAL CALIFORNIA
MAP    3.4     2012/07/08 17:02:16      51.885      176.326    67.1     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.7     2012/07/08 16:58:28      45.465      151.259    49.4     KURIL ISLANDS
MAP    2.5     2012/07/08 16:21:50      19.198     -155.359    49.7     ISLAND OF HAWAII, HAWAII
MAP    5.2     2012/07/08 14:41:24     -56.386      -24.058    14.8     SOUTH SANDWICH ISLANDS REGION
MAP    3.3     2012/07/08 13:16:31      19.274      -65.168    63.0     PUERTO RICO REGION
MAP    4.8     2012/07/08 13:08:38      45.383      151.391    43.9     KURIL ISLANDS
MAP    3.2     2012/07/08 12:29:39      51.148      179.732    10.3     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.4     2012/07/08 12:05:49      39.480     -123.804    8.1     OFFSHORE NORTHERN CALIFORNIA
MAP    4.9     2012/07/08 11:47:22      45.884      150.813    35.6     KURIL ISLANDS
MAP    5.8     2012/07/08 11:33:03      45.495      151.354    17.1     KURIL ISLANDS
MAP    4.4     2012/07/08 11:13:38      52.032      -60.822    18.0     LABRADOR, NEWFOUNDLAND AND LAB., CANADA
MAP    3.3     2012/07/08 10:50:03      33.961     -116.132    6.9     SOUTHERN CALIFORNIA
MAP    2.5     2012/07/08 09:11:49      35.541      -96.000    4.9     OKLAHOMA
MAP    4.4     2012/07/08 07:06:51      -9.863      119.100    74.5     SUMBA REGION, INDONESIA
MAP    3.3     2012/07/08 06:56:24      54.415     -161.382    0.8     ALASKA PENINSULA
MAP    3.1     2012/07/08 06:32:48      20.070     -155.394    11.2     HAWAII REGION, HAWAII
MAP    3.1     2012/07/08 05:48:44      18.953      -64.920    10.0     VIRGIN ISLANDS REGION
MAP    2.5     2012/07/08 05:32:13      52.882     -168.287    24.3     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.8     2012/07/08 04:16:41      19.378      120.899    37.6     BABUYAN ISLANDS REGION, PHILIPPINES
MAP    2.6     2012/07/08 02:42:47      54.078     -163.746    46.9     UNIMAK ISLAND REGION, ALASKA
MAP    2.9     2012/07/08 01:48:37      19.039      -67.672    25.0     PUERTO RICO REGION
MAP    3.3     2012/07/08 01:04:00      18.064      -68.572    124.0     DOMINICAN REPUBLIC REGION
MAP    3.1     2012/07/08 00:44:35      18.245      -68.016    69.0     MONA PASSAGE, DOMINICAN REPUBLIC
MAP    4.7     2012/07/08 00:11:16     -30.410     -176.898    35.1     KERMADEC ISLANDS REGION
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.7     2012/07/07 23:48:21     -33.418     -179.679    80.9     SOUTH OF THE KERMADEC ISLANDS
MAP    4.4     2012/07/07 23:42:44      33.744      136.058    415.8     NEAR S. COAST OF WESTERN HONSHU, JAPAN
MAP    3.0     2012/07/07 23:42:02      58.912     -154.613    122.4     ALASKA PENINSULA
MAP    4.7     2012/07/07 23:31:46     -55.715      -27.421    35.1     SOUTH SANDWICH ISLANDS REGION
MAP    5.0     2012/07/07 22:49:21     -17.042      66.934    10.0     MAURITIUS - REUNION REGION
MAP    2.8     2012/07/07 22:18:06      52.108     -173.444    25.8     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    3.3     2012/07/07 22:06:13      33.866     -119.310    0.1     CHANNEL ISLANDS REGION, CALIFORNIA
MAP    4.6     2012/07/07 20:37:04      45.166      151.645    29.0     KURIL ISLANDS
MAP    5.1     2012/07/07 20:32:38      18.236      -71.134    25.9     DOMINICAN REPUBLIC
MAP    4.0     2012/07/07 17:58:20     -44.515      167.748    6.5     SOUTH ISLAND OF NEW ZEALAND
MAP    3.1     2012/07/07 15:08:08      19.300     -155.214    10.1     ISLAND OF HAWAII, HAWAII
MAP    3.2     2012/07/07 14:59:11      19.205      -64.891    7.0     VIRGIN ISLANDS REGION
MAP    3.0     2012/07/07 14:48:33      19.301     -155.216    9.5     ISLAND OF HAWAII, HAWAII
MAP    2.7     2012/07/07 14:40:37      37.117     -121.524    7.0     NORTHERN CALIFORNIA
MAP    3.0     2012/07/07 14:38:04      37.266     -119.355    28.8     CENTRAL CALIFORNIA
MAP    2.6     2012/07/07 14:32:40      18.379      -66.341    67.0     PUERTO RICO
MAP    4.9     2012/07/07 14:26:03      -3.646      100.843    35.7     KEPULAUAN MENTAWAI REGION, INDONESIA
MAP    4.9     2012/07/07 13:38:20      9.752      126.018    66.8     MINDANAO, PHILIPPINES
MAP    4.3     2012/07/07 12:59:11      41.282      20.931    13.1     MACEDONIA
MAP    4.8     2012/07/07 10:52:14     -32.505      -71.731    23.2     OFFSHORE VALPARAISO, CHILE
MAP    2.7     2012/07/07 10:13:07      37.919     -119.349    12.0     CENTRAL CALIFORNIA
MAP    3.3     2012/07/07 09:49:09      32.170     -115.224    12.9     BAJA CALIFORNIA, MEXICO
MAP    3.4     2012/07/07 09:30:47      51.513      176.519    31.8     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    2.7     2012/07/07 09:24:58      62.295     -151.550    7.5     CENTRAL ALASKA
MAP    2.9     2012/07/07 09:02:20      63.706     -149.270    112.2     CENTRAL ALASKA
MAP    5.4     2012/07/07 08:11:37     -56.239      -27.443    97.0     SOUTH SANDWICH ISLANDS REGION
MAP    4.1     2012/07/07 07:51:23      36.378      26.866    147.5     DODECANESE ISLANDS, GREECE
MAP    3.1     2012/07/07 07:15:53      19.060      -66.811    7.0     PUERTO RICO REGION
MAP    2.6     2012/07/07 07:14:11      59.791     -152.893    128.1     SOUTHERN ALASKA
MAP    3.4     2012/07/07 07:09:39      17.959      -68.467    80.0     DOMINICAN REPUBLIC REGION
MAP    2.9     2012/07/07 06:21:39      18.604      -66.613    75.0     PUERTO RICO REGION
MAP    2.8     2012/07/07 05:20:12      68.059     -157.799    8.4     NORTHERN ALASKA
MAP    2.7     2012/07/07 04:57:23      19.013      -65.486    54.0     PUERTO RICO REGION
MAP    4.8     2012/07/07 04:34:59      -6.303      104.071    47.6     SUNDA STRAIT, INDONESIA
MAP    2.7     2012/07/07 03:43:44      18.384      -66.279    64.0     PUERTO RICO
MAP    3.1     2012/07/07 03:40:08      18.703      -64.250    43.0     VIRGIN ISLANDS REGION
MAP    5.6     2012/07/07 03:35:29      -4.675      153.275    37.7     NEW IRELAND REGION, PAPUA NEW GUINEA
MAP    2.5     2012/07/07 01:58:50      19.469     -156.049    36.9     HAWAII REGION, HAWAII
MAP    4.7     2012/07/07 01:20:40      47.028      149.515    39.8     NORTHWEST OF THE KURIL ISLANDS
MAP    5.2     2012/07/07 00:56:30      45.487      151.266    42.3     KURIL ISLANDS
MAP    5.0     2012/07/07 00:50:26     -39.083      175.701    88.5     NORTH ISLAND OF NEW ZEALAND
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.5     2012/07/06 22:48:01      45.669      26.587    109.3     ROMANIA
MAP    2.6     2012/07/06 19:45:04      36.333     -120.909    9.9     CENTRAL CALIFORNIA
MAP    2.7     2012/07/06 19:44:11      32.187     -115.257    10.0     BAJA CALIFORNIA, MEXICO
MAP    2.5     2012/07/06 18:45:24      36.333     -120.910    9.2     CENTRAL CALIFORNIA
MAP    4.6     2012/07/06 17:50:29      43.639     -127.433    10.2     OFF THE COAST OF OREGON
MAP    4.9     2012/07/06 17:50:14     -10.453      161.447    88.6     SOLOMON ISLANDS
MAP    2.5     2012/07/06 13:06:38      61.278     -150.596    60.6     SOUTHERN ALASKA
MAP    2.5     2012/07/06 10:46:43      17.583      -67.696    16.0     PUERTO RICO REGION
MAP    2.6     2012/07/06 08:30:49      35.539      -96.791    5.0     OKLAHOMA
MAP    2.7     2012/07/06 08:26:56      32.420      -97.272    5.0     NORTHERN TEXAS
MAP    2.9     2012/07/06 06:48:40      18.080      -67.169    11.0     PUERTO RICO
MAP    5.0     2012/07/06 06:16:47     -42.618      -73.418    13.1     GOLFO DE CORCOVADO, LOS LAGOS, CHILE
MAP    3.1     2012/07/06 03:33:09      18.194      -64.986    120.0     VIRGIN ISLANDS REGION
MAP    4.8     2012/07/06 03:29:30     -43.578      172.380    10.1     SOUTH ISLAND OF NEW ZEALAND
MAP    4.7     2012/07/06 02:52:25     -17.579     -178.457    587.2     FIJI REGION
MAP    3.6     2012/07/06 02:48:46      52.022      174.744    95.2     NEAR ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    6.3     2012/07/06 02:28:23     -14.664      167.357    162.7     VANUATU
MAP    4.4     2012/07/06 01:22:04      61.677     -151.274    84.8     SOUTHERN ALASKA
MAP    4.9     2012/07/06 00:40:37     -14.607     -177.863    10.2     FIJI REGION
MAP    3.3     2012/07/06 00:36:04      18.860      -68.695    152.0     DOMINICAN REPUBLIC
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    3.3     2012/07/05 23:47:42      54.798     -160.436    27.5     ALASKA PENINSULA
MAP    4.7     2012/07/05 23:04:31      29.326      130.419    39.9     RYUKYU ISLANDS, JAPAN
MAP    2.6     2012/07/05 19:18:38      18.797      -67.263    15.0     PUERTO RICO REGION
MAP    2.6     2012/07/05 18:42:55      34.302     -116.841    7.3     SOUTHERN CALIFORNIA
MAP    3.5     2012/07/05 18:18:09      34.304     -116.841    7.3     SOUTHERN CALIFORNIA
MAP    2.7     2012/07/05 15:39:42      17.873      -66.183    4.0     PUERTO RICO REGION
MAP    2.9     2012/07/05 12:28:19      56.357     -152.211    12.1     KODIAK ISLAND REGION, ALASKA
MAP    2.9     2012/07/05 11:21:51      48.653     -123.129    14.3     SAN JUAN ISLANDS REGION, WASHINGTON
MAP    3.3     2012/07/05 11:11:07      59.687     -150.061    18.5     KENAI PENINSULA, ALASKA
MAP    5.1     2012/07/05 09:46:22      32.274      141.645    33.4     IZU ISLANDS, JAPAN REGION
MAP    3.2     2012/07/05 09:10:41      19.191      -65.188    15.0     PUERTO RICO REGION
MAP    5.4     2012/07/05 08:14:19      5.130      126.599    61.7     MINDANAO, PHILIPPINES
MAP    4.0     2012/07/05 05:53:00     -34.494      -72.638    39.2     OFFSHORE LIBERTADOR O'HIGGINS, CHILE
MAP    2.6     2012/07/05 05:38:27      51.655     -167.678    25.6     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    3.2     2012/07/05 04:07:11      19.205      -66.388    8.0     PUERTO RICO REGION
MAP    2.9     2012/07/05 03:44:22      18.180      -67.373    15.0     MONA PASSAGE, PUERTO RICO
MAP    2.5     2012/07/05 03:40:35      37.856     -122.246    9.0     SAN FRANCISCO BAY AREA, CALIFORNIA
MAP    4.5     2012/07/05 03:09:18      49.476      155.174    74.0     KURIL ISLANDS
MAP    2.5     2012/07/05 02:27:38      51.529     -179.912    77.5     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.7     2012/07/05 01:13:03      36.945     -121.441    2.6     CENTRAL CALIFORNIA
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.8     2012/07/04 23:46:35      35.008      26.698    35.4     CRETE, GREECE
MAP    4.5     2012/07/04 23:39:19      -6.562      105.861    97.9     SUNDA STRAIT, INDONESIA
MAP    3.1     2012/07/04 23:18:18      52.729     -161.663    36.6     SOUTH OF ALASKA
MAP    4.6     2012/07/04 22:57:16     -37.444      -73.881    11.4     OFFSHORE BIO-BIO, CHILE
MAP    2.7     2012/07/04 22:33:21      51.465     -177.366    26.6     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.9     2012/07/04 22:18:33      51.029     -179.768    14.3     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    4.2     2012/07/04 22:13:51      51.202     -179.681    52.3     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    5.1     2012/07/04 21:29:26      18.197      -62.958    88.4     ANGUILLA REGION, LEEWARD ISLANDS
MAP    4.6     2012/07/04 16:16:18      47.782      154.456    43.8     KURIL ISLANDS
MAP    2.9     2012/07/04 15:20:09      44.620     -111.193    12.7     WESTERN MONTANA
MAP    5.1     2012/07/04 14:36:34     -30.774     -178.160    35.5     KERMADEC ISLANDS, NEW ZEALAND
MAP    2.6     2012/07/04 14:30:49      53.039     -164.521    16.9     UNIMAK ISLAND REGION, ALASKA
MAP    4.6     2012/07/04 13:28:51      41.136      141.857    69.7     HOKKAIDO, JAPAN REGION
MAP    4.6     2012/07/04 13:27:14      38.448      15.154    180.9     SICILY, ITALY
MAP    4.9     2012/07/04 13:01:04      11.300      126.056    40.4     PHILIPPINE ISLANDS REGION
MAP    2.7     2012/07/04 12:19:17      57.625     -152.946    35.8     KODIAK ISLAND REGION, ALASKA
MAP    4.8     2012/07/04 11:12:14      37.672      16.852    53.8     IONIAN SEA
MAP    4.9     2012/07/04 10:26:25      -5.821      147.478    99.4     EASTERN NEW GUINEA REG, PAPUA NEW GUINEA
MAP    2.9     2012/07/04 09:53:27      19.775     -155.573    17.2     ISLAND OF HAWAII, HAWAII
MAP    3.4     2012/07/04 09:04:44      33.378     -116.301    14.2     SOUTHERN CALIFORNIA
MAP    4.7     2012/07/04 08:33:04     -37.978      -72.709    9.7     ARAUCANIA, CHILE
MAP    2.5     2012/07/04 07:00:45      37.209     -104.826    4.5     COLORADO
MAP    2.5     2012/07/04 05:47:11      32.179     -115.297    10.0     BAJA CALIFORNIA, MEXICO
MAP    4.6     2012/07/04 05:38:53      -2.255      100.789    66.5     KEPULAUAN MENTAWAI REGION, INDONESIA
MAP    2.7     2012/07/04 05:13:12      37.571     -122.511    9.0     SAN FRANCISCO BAY AREA, CALIFORNIA
MAP    2.8     2012/07/04 04:13:46      65.994     -150.920    15.2     NORTHERN ALASKA
MAP    3.1     2012/07/04 04:00:06      48.648     -123.127    14.1     SAN JUAN ISLANDS REGION, WASHINGTON
MAP    4.8     2012/07/04 03:15:25      -4.144      152.741    31.9     NEW BRITAIN REGION, PAPUA NEW GUINEA
MAP    4.6     2012/07/04 02:37:47      43.837      146.349    74.8     KURIL ISLANDS
MAP    2.5     2012/07/04 02:15:45      37.562     -122.514    8.7     SAN FRANCISCO BAY AREA, CALIFORNIA
MAP    2.6     2012/07/04 02:09:57      37.568     -122.508    8.4     SAN FRANCISCO BAY AREA, CALIFORNIA
MAP    2.8     2012/07/04 02:06:22      37.562     -122.508    9.0     SAN FRANCISCO BAY AREA, CALIFORNIA
MAP    2.7     2012/07/04 01:51:49      33.118      -82.928    10.5     GEORGIA, USA
MAP    2.7     2012/07/04 01:34:03      57.873     -156.054    131.3     ALASKA PENINSULA
MAP    4.2     2012/07/04 00:29:46      51.678      176.546    55.5     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.8     2012/07/04 00:04:00     -59.126      148.972    10.3     WEST OF MACQUARIE ISLAND
     MAG    UTC DATE-TIME
MAP    2.5     2012/07/03 23:27:11      36.285      -89.447    4.7     TENNESSEE
MAP    4.4     2012/07/03 21:59:58      10.057      125.588    192.4     LEYTE, PHILIPPINES
MAP    3.0     2012/07/03 21:00:09      19.341      -65.681    14.0     PUERTO RICO REGION
MAP    2.6     2012/07/03 20:59:29      32.116     -115.209    10.0     BAJA CALIFORNIA, MEXICO
Most recent earthquakes are at the top of this list.
RE: Ice Age Model
« Reply #18, on August 19th, 2012, 07:56 PM »Last edited on October 6th, 2012, 03:09 PM by freethisone
this movie contain much of the data, and information i had used to deduce this effect, for the given cause, or charge. increasing potential of little b. the direction of gravity of  a sun.. there will also be a decreasing gravitational force to be documented down the road.
i hope you guys have learned as much as i did. i am always happy to share, i have learned a great deal from you..
:cool:
cheers peace..:shy:
https://www.youtube.com/watch?v=Oe7lk8bfvyY&feature=player_embedded
Absolutely the best pictures i have uncovered.  this movie shows the best supporting evidence of mass, and its movement to the starts.
https://www.youtube.com/watch?v=Zz2yilwoMqI
note these 2 pictures of the sun partially eclipsed. the one in the movie and its not by annual space station fly by  by.  lol really nasa???
Friday 14th September 2012
Eruptions of Fuego volcano in Guatemala have forced the evacuation of 33,000 people. The eruptions produced ash emissions which were visible in the capital Guatemala City, 75 km away. Pyroclastic flows travelled down the slopes of the volcano and heavy ashfall was reported in nearby villages. Fuego volcano is located 18 km SW of the city of Antigua. On the day of the eruption a magnitude 4.2 earthquake hit 47 km south of the volcano. The explosive phase of the eruption was preceded by emission of a 100 m long lava flow down the flank.
Monday 11th September 2012
San Cristobal Volcano, Nicaragua
Eruptions occurred at San Cristobal volcano, Nicaragua on 8th September 2012. Ash emissions reached 5000 m above the crater rim, and drifted 50 km west-north-west. Sulphur dioxide emissions were 3200 tons per day compare to a normal emission of 550-700 tons per day. On the northwest sector of the volcano incandescent material caused burns to six livestock.
More on San Cristobal volcano...
Volcanoes of Nicaragua...
Tuesday 4th September 2012
Krakatau Volcano, Indonesia
Activity has increased at Krakatau volcano, Indonesia. On 2nd September 2012 constant tremor was recorded at the volcano, accompanied by Strombolian eruptions to a height of 300 m above the crater. The explosions rattled windows on the west coast of Java, 50 km away. The alert status at Krakatau has been raised to level 3 (out of a maximum 4). A 1 km exclusion zone has been placed around the crater.:s
RE: Ice Age Model
« Reply #19, on October 6th, 2012, 03:08 PM »Last edited on October 6th, 2012, 06:03 PM by freethisone
these movies are absolutely incredible. I hope every one will get a chance to watch them all.
https://www.youtube.com/watch?v=w0HhFUHnfGU&feature=plcp
https://www.youtube.com/watch?v=pgQ6K8sTf8o&feature=plcp:-/
I found in a PDF file every one should read, amazing information.:heart:
eugene shoemaker
A fellow youtuber needs views:angel:..
Incredible. predictable.
peace all.:shy:
RE: Ice Age Model
« Reply #20, on December 8th, 2012, 06:17 PM »Last edited on December 10th, 2012, 06:36 PM by freethisone
Censor    5.6     2012/12/07 23:00:02      37.732      143.863    34.2     OFF THE EAST COAST OF HONSHU, JAPAN
MAP    5.6     2012/12/07 19:50:21      -7.633      146.963    118.9     EASTERN NEW GUINEA REG, PAPUA NEW GUINEA
MAP    6.3     2012/12/07 18:19:07     -38.321      176.086    166.8     NORTH ISLAND OF NEW ZEALAND
MAP    7.3     2012/12/07 08:18:24      37.889      144.090    36.1     OFF THE EAST COAST OF HONSHU, JAPAN
this large earthquake was predicted to within 8 day, of the original prediction of 3 to 8 days,  16 was the number of day after observations of the precession.
update.
picture 1 is the new nodes as of October 2012, post sandy.  called iron curtain.
this is very interesting noting the 2 circles or nodes on either end of the map.
pay close observation this is a  new scalar wave position enveloping Florida.  in 2010 to 2012 the predominant line has changed. 90 degrees from coast line mid atlantic.
compare pictures. one post sandy, and pic 2 pre sandy. Picture three is heating of that air mass in question.
:rolleyes:
RE: Ice Age Model
« Reply #21, on December 26th, 2012, 08:04 AM »Last edited on January 12th, 2013, 01:01 PM by freethisone
:heart:  Yes Doctor? reply.
The precession is continuity torquing.
It continues to follow the slipping top analogy.
Its simply spinning. Its simply stunning,
its simply continues to rotate,  I will exaggerate your observations. Its simply up to you to observe.
As it rotates earthquakes become time variable according to rotational speed.
The axis it i pointing,
Its following the spinning top..
its simply slipping. its simply a stunning effect.
There is a pressure of fluid within the core. Its simply splitting, its Humphrey Dummpie.
Its described, and self verifying. It simply continues.
Its bursting, of a water balloon. Its simply to soon.,
Its simply predictable. Its following its secondary oscillation. Beating like a drum.
The wave is in front. Its simply like a pointy boat or arrow.
Its simply caused by this star. There is, simply no way around.
The time frame was predictable. Its simply solar rotation. Its simply lunar precession
. At three  days of solar rotation, and according to speed it will split like a cord. Ripping the seams.
Its it was simply well known.
Its simply a des-cry. An utter dis-( By grace). I am simply sorry.
It simply was well known to be true. lighting up like a tree on Christmas day.
Its spilling on two sides. The start of the predictable out come is time variable.
It also follow along the net force inducing.
Its also bouncing, and skipping along. Bending space.
As the Earth spheroid preforms like an egg.
What is relativity? Its simply, Cause and effect.
.:):cool:;)
The extreme cold is well established.
It sits like a chair in a pocket of the same.
A change in equilibrium already  apparent.
Solar warming sets Earth core a flame.
Like a furnace expanding, breathing, smoking white ashes, the ice age.
Predictable outcome remains time variable.
Earth opens wide. a heated divide. The ice age.
Giant earthquakes, and powerful volcanic eruption..
The axis i pointing, slipping,  Earth bouncing, and skipping along.
Spurring  Great kingly tides.
 An Antarctic  breeze..   This ice age.
The water soon pools at its center, with Increasing momentum, causing this  sloshing about.
As the chilling rushing winds continue, each new storm mounting there attack against the north.
Like a perpetual winter breeze crossing the equator.
:dodgy::angel::-/
 To sustain my curiosity i keep on related. the following is a summery. of scientific information.
conclusions are inline with previous data, and the previous reports. For December, February. through the month of May 2013.
it appears volcanic eruption may be a major concern, as induction works with in the core. the next 4 months should be seriously look at for geo thermal events, and increasing natural gas sulfurdioxide, and methane releases.
core heating will go up substantially in the following months with many large volcanic eruptions. both on earth and the sun. Plasma filaments (solar flares (X and M factor.) due to spark gap position in the ISCM.) binary period of time relation. a ordinary electrical spark Gap trigger is assumed..
earthquakes for the previous cycle should be considered as time variable, and is a signal for the trigger of ice age model.
coastal flooding becomes a major concern. Flooding that has shown to be caused by external precession during the spring, fall, and winter equinox. all have shown them selves as significant.
the predicted time for precession is 6 to 7 years ,at this trigger point. that makes by the Feb 5 2010 solar cycle reversal.
data will be skewed from reporting agency with much of the important information left out.
air quality is a major concern and should be monitored.
winter storm warnings cyclones in effect as angular momentum increases even further in the following weeks, and months.
i hope this is sufficient to explain this angular, inductive, dynamic effect. eddy currents rise is due to axial shift, and resistance. gravity pushing force is in the direction, of increasing potential charge in space. equal, and opposite predicted. solar flare would be high, and Earth magnetosphere anomaly continue.
variables: :uv indexes high, x, and gamma ray mixed in : sea rise and fall. :continental shift, or drift during torque times delta T. king tides, :angular momentum variation (changing) : eddy current give rise to this dynamic effect: increasing potential: gravitational force direction. . time duration for increased core heating: amount of gaseous material, and crustal heating. 4 to 5 months.
RE: Ice Age Model
« Reply #22, on January 12th, 2013, 01:04 PM »Last edited on January 12th, 2013, 01:17 PM by freethisone
Quote from freethisone on December 26th, 2012, 08:04 AM
:heart:
.:):cool:;)
:dodgy::angel::-/
monitor, show graphs, and reactions. included observations, events and prediction.
time variable relation. cycles, 1 third  or 4 months. add volcanic eruption for January, February, March April May.
January 2013
25 years of volcano adventures
13 years on the internet - 2000-2013
New - see photos and video of John Seach flying Microlight aircraft.
Volcano adventure flying coming soon!
Tweets by @johnseach
Monday 7th January 2013
Seulawah Agam Volcano, Indonesia
Seulawah Agam volcano, Sumatra, Indonesia was raised to level 3 alert on 3rd January 2013, after an increase in seismic activity. A new solfatara was located near Heutsz crater which was the site of the last eruption in 1839.
More on Seulawah Agam Volcano...
Thursday 3rd January 2013
Today, 3 January 2013 marks the 30th anniversary of the beginning of the current eruption at Kilauea volcano, Hawaii. This is a remarkable eruption, and has been the longest eruption on the east rift zone in recorded history. The eruption has been continuous for so long that we have come to take it for granted. However the eruption will come to an end sometime. Currently the volcano is erupting at the summit and east rift zone. Lava continues to enter the ocean at several locations.
More on Kilauea Volcano...
Kizimen Volcano, Kamchatka, Russia
Kizimen volcano, Kamchatka, was raised to orange alert on 31 December 2012 after an increase in seismicity. In the previous 24 hours 357 earthquakes were recorded under the volcano. A crater glow was present and lava on the slopes.
More on Kizimen Volcano...
Volcanoes of Kamchatka...
Wednesday 2nd January 2013
Eruptions continue at two locations at Kilauea volcano, Hawaii. An active lava lake is located at the summit in Halemaumau crater. On the east rift zone lava is erupting from a location southeast of Pu'u O'o crater and flowing to the coast. On the pali and coast lava flow is about 1 km wide and enters the ocean at several locations.
Thursday 27th December 2012
Tolbachik Volcano, Kamchatka, Russia
Eruption continues at Tolbachik volcano, Kamchatka with strong seismic activity on 25 December 2012. Satellite images show a large area of thermal activity.
More on Tolbachik Volcano...
San Cristobal volcano, Nicaragua erupted on 25th December 2012, after increasing seismicity the previous day. Moderate explosions ejected ash and gas 2500 m above the crater. Light winds resulted in ashfall close to the volcano. Satellite images did not show a hotspot over the volcano. Ash emissions extended west to the Pacific Ocean.
More on San Cristobal Volcano...
Monday 25th December 2012
Copahue Volcano, Chile/Argentina
Satellite images show sulphur dioxide plume from Copahue eruption reached Tristan da Cunha in the south Atlantic Ocean 2700 km ENE of the volcano on 24th December 2012.
More on Copahue Volcano...
Volcanoes of Chile...
Monday 24th December 2012
Ambae Volcano, Vanuatu
Satellite images showed a sulphur dioxide plume over Ambae volcano, Vanuatu on 24th December 2012, extending NW towards Espiritu Santo Island.
More on Ambae Volcano...
Volcanoes of Vanuatu...
Strobolian eruptions to a height of 450 m are occurring at Copahue volcano. Crater glow is visible and eruption column was not higher than 1 km on 23 December 2012. An area of ash remains over the Atlantic Ocean. Aviation warning is RED.
Sunday 23rd December 2012
An eruption occurred at Copahue volcano on Chile/Argentina border on 22nd December 2012. Ash reached an altitude of 31,000 ft and extended 110 km southeast of the volcano.
Tuesday 18 December 2012
Tungurahua Volcano, Ecuador
Eruptions of Tungurahua volcano, Ecuador on 16th December created air waves which broke windows in nearby towns. Pyroclastic flows occurred on the upper flanks of the volcano. Ash emissions reached 3 km above the summit. The eruption was associated with new magma intrusion under the volcano.
More on Tungurahua Volcano...
Volcanoes of Ecuador...
Wednesday 12th December 2012
On 12th December 2012 the alert at White Island volcano, New Zealand was raised to level 2 after a 20-30 m wide spiny lava dome was observed in a small crater. Tour operators on the island had noticed the lava dome for about 2 weeks. The dome possibly started forming after the August 2012 ash eruption. This is the first time a lava dome has been observed at White Island volcano.
More on White Island Volcano...
Thursday 6th December 2012
Langila Volcano, Papua New Guinea
Volcanic ash emissions from Langila volcano, Papua New Guinea reached an altitude of 7000 ft and extended 60 nautical miles northwest on 6th December 2012, and satellite images showed a sulphur dioxide plume extending northwest. Langila is one of the most active volcanoes in the Bismarck arc. Volcanic activity at Langila typically consists of Strombolian-Vulcanian and Vulcanian eruptions and lava flows.
More on Langila Volcano...
Tuesday 4th December 2012
Seismic activity has declined but the eruption continues at Tolbachik volcano, Kamchatka. During the peak activity on 28-29 November 2012 the fissures spread over tens of kilometres, and the eruption was heard 60 kilometres away. The current eruption is similar to the Great Fissure eruption in 1975-76, but lower in intensity. A fissure 5 kilometres long has formed on the southern slope of the Plosky Tolbachik, in the same area as 36 years ago, but at a higher elevation – about two thousand metres above sea level. There are two active centres which are producing lava flows. A 10 kilometre long lava flow destroyed a monitoring station of the Institute of Volcanology and Seismology on Vodopadny creek, as well as the Leningradskaya station of the institute. A base of the Volcanoes of Kamchatka natural park has also been destroyed in the same area. Ashfall was reported 65 kilometres from the volcano up to a depth of 4 cm. Eruptions at the upper fissure have stopped, but the lower fissure continues to be active. Tolbachik volcano is 343 kilometres south west of Petropavlovsk-Kamchatsky.
Friday 30th November 2012
Tolbachik volcano, Kamchatka has been raised to the highest aviation alert RED. The volcano poses a threat to aviation with plume reaching 33,000 ft altitude. The eruption has destroyed a scientific monitoring site. Satellite images show a large thermal signal indicating a fissure eruption.
Thursday 29th November 2012
Eruptions continue at Tolbachik volcano, Kamchatka. A 4-5 km fissure occurred at Tolbachinsky Dol with Strombolian eruptions at 4-5 vents. A 6-7 km fissure occurred at Plosky Tolbachik with Strombolian eruptions at 2-3 vents. Ashfall, booming noises and rattling windows were reported in nearby towns.
Wednesday 28th November 2012
The eruption of Tolbachik volcano was accompanied by 267 shallow earthquakes. Between 05:15 and 08:00 hr shallow earthquakes indicated possible ash explosions to 33,000 ft. From 08:00 to 24:00 hr volcanic tremor indicated possible lava flow. Lava intrusion occurred towards the summit caldera of Plosky Tolbachik, which was the location of the large fissure eruptions in 1975-76.
An explosive eruption began at Tolbachik volcano on 27th November 2012. Ash was reported to a height of 33,000 ft drifting north and northwest of the volcano. The height of ash emission was estimated from seismic records. Ashfall was reported at villages 35 km west of the volcano to a depth of 4 cm. The last eruption of Tolbachik volcano in 1975-76 produced a 28 km long fissure, and was the largest historical basaltic eruption in Kamchatka. The aviation colour code has been raised to ORANGE alert.
Friday 23rd November 2012
Taal Volcano, Philippines
There was a large increase in seismic activity at Taal volcano on 22-23 November 2012. In a 24 hour period 60 earthquakes were measured at the volcano. Two of the earthquakes were felt by residents of Calauit and Pira-piraso. The second felt earthquake at 7:23 pm on 22 November was felt with an intensity of III, and was accompanied by a rumbling sound. The earthquakes were located mostly under the north-eastern side of the volcano island. The Volcano Island is a Permanent Danger Zone. Level 1 alert remains at the volcano.
More on Taal volcano...
Volcanoes of Philippines...
Heard Island Volcano, Australia
A Heritage Expeditions cruise which departed Fremantle, Australia, reached Heard Island in the south Indian Ocean on 21st November 2012. A photo posted on the expedition's twitter page (@HeritageExp) showed the volcano under clear skies. There was no visible plume from the summit. Awaiting further observations. Satellite images showed a new period of activity commenced at the volcano around 21st September 2012. This expedition is the first to reach Heard Island in the current cycle of volcanic activity.
More on Heard Island volcano...
Volcanoes of Australia...
Thursday 22nd November 2012
A 1.8 km lava flow was reported at Fuego volcano, Guatemala on 21 November 2012. Incandescent avalanches produced ash which drifted 10 km south and southwest. 100 m high lava explosions were observed at the summit.
Wednesday 21st November 2012
An eruption occurred at Te Maari Craters, Tongariro volcano, New Zealand, at 1:25 pm on 21st November 2012. Volcanic ash was observed to an altitude of 21,000 ft. The eruption was preceded by increasing seismicity during the previous 4 hours. About 50 hikers were on the Tongariro Crossing at the time of the eruption. No injuries were reported. The Tongariro crossing is now closed. Ash fell on State Highway 46 and north-east towards Turangi. The eruption was seen from Taupo. An eruption of Tongariro volcano in August 2012 destroyed a National Park hut.
More on Tongariro Volcano...
Monday 19th November 2012
Ruapehu Volcano, New Zealand
The summit of Ruapehu volcano, New Zealand is off limits due to raised alert level. Climbers are advised to stay more than 2 km away from the crater, and not above Whakapapa ski area. Ruapehu has a history of explosive eruptions and lahars.
More on Ruapehu Volcano...
Friday 16th November 2012
Nevado del Ruiz Volcano, Colombia
An eruption was reported at Nevado del Ruiz volcano on 15th November 2012. The eruption was not directly seen due to clouds in the area. The eruption was detected by elevated seismic activity during the afternoon. The Washington Volcanic Ash Advisory Centre issued an alert. Winds were expected to change to the southeast during the day. Nevado del Ruiz volcano is located in central Colombia, 130 km WNW of Bogata. In 1985 an eruption of the volcano created history's fourth largest volcanic disaster, killing 25,000 people.
More on Nevado del Ruiz Volcano...
Volcanoes of Colombia...
Ruapehu volcano was increased to yellow alert on 16th November 2012 due to unrest under the crater lake. Ruapehu volcano is the highest mountain on the north island of New Zealand, and contains the largest ski fields in the country. The last eruption of Ruapehu volcano occurred in 2007 with ash emissions and lahars.
Tuesday 13th November 2012
Tinakula Volcano, Solomon Islands
Satellite images showed hotspots at Tinakula volcano, Solomon Islands, on 23 October 2012 indicating ongoing eruptions. Activity has been detected at the volcano throughout 2012. Tinakula is a very active, but rarely visited volcano.
More on Tinakula volcano...
Volcanoes of Solomon Islands...
Monday 12th November 2012
On 11th November 2012 a sulphur dioxide plume from Popocatepetl volocano, Mexico extended 600 km NE towards the border with Texas, USA.
Sunday 11th November 2012
Singu Volcano, Burma
A magnitude 6.6 Earthquake hit 36 km north of Singu volcano, Burma on 11th November 2012. Two magnitude 5.0 aftershocks occurred 8 and 13 km from the volcano two hours later. The last eruption at Singu volcano is unknown but probably occurred in the past 10,000 years, which makes it an active volcano on a geological timescale.
More on Singu volcano...
Volcanoes of Burma...
Thursday 8th November 2012
Raung Volcano, Indonesia
A large eruption occurred at Raung volcano, Indonesia on 8th November 2012. Pilots report ash emissions reached a height of 30,000 ft, but volcanologists report Strombolian eruptions 200 m above the crater. The volcano is on level 3 alert.
More on Raung volcano...
Guatemala Earthquake (Mag 7.4)
A magnitude 7.4 earthquake hit Guatemala, 84 km SSW of Santa Maria volcano on 7th November 2012. Initial reports indicate a tsunami was generated. Earthquakes of this magnitude can disrupt nearby volcanoes. Volcanoes in the area include Toliman, Fuego, Agua, and Pacaya. Santa Maria and Fuego are currently erupting.
Friday 2nd November 2012
Another Iceland Earthquake Swarm
An earthquake swarm was detected in NE Icleand along the Tjornes Fracture Zone on 1st November 2012. The swarm was located about 100 km east of the earthquake swarm which began on 21 October. This new swarm contained about 30 earthquakes with a maximum magnitude of 3. Tjörnes Fracture Zone contains a submarine volcano located 10 km off the north coast of Iceland. It is a transform fissure zone of the mid atlantic ridge. The last eruptions were in 1867-68.
More on Tjornes Fracture Zone...
Volcanoes of Iceland...
 Magnitude 6.8 VANUATU December 21, 2012
Magnitude 7.1 BANDA SEA December 10, 2012
Magnitude 6.3 NORTH ISLAND OF NEW ZEALAND December 07, 2012
Magnitude 7.3 OFF THE EAST COAST OF HONSHU, JAPAN December 07, 2012
Magnitude 6.4 KURIL ISLANDS November 16, 2012
Magnitude 6.5 OFFSHORE GUATEMALA November 11, 2012
Magnitude 6.8 MYANMAR November 11, 2012
Magnitude 4.3 EASTERN KENTUCKY November 10, 2012
Magnitude 7.4 OFFSHORE GUATEMALA November 07, 2012
Magnitude 7.7 QUEEN CHARLOTTE ISLANDS REGION October 28, 2012
Magnitude 6.5 COSTA RICA October 24, 2012
Magnitude 5.3 CENTRAL CALIFORNIA October 21, 2012
Magnitude 6.2 VANUATU October 20, 2012
Magnitude 6.7 NEAR THE SOUTH COAST OF PAPUA, INDONESIA October 12, 2012
Magnitude 6.4 ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA September 26, 2012
Magnitude 5.6 SICHUAN-YUNNAN-GUIZHOU REGION, CHINA September 07, 2012
Magnitude 7.6 COSTA RICA September 05, 2012
Magnitude 7.6 PHILIPPINE ISLANDS REGION August 31, 2012
Magnitude 6.8 JAN MAYEN ISLAND REGION August 30, 2012
Magnitude 7.3 OFFSHORE EL SALVADOR August 27, 2012
Magnitude 6.6 MOLUCCA SEA August 26, 2012
Magnitude 6.3 SULAWESI, INDONESIA August 18, 2012
Magnitude 7.7 SEA OF OKHOTSK August 14, 2012
Magnitude 6.4 NORTHWESTERN IRAN August 11, 2012
Magnitude 6.5 NEW IRELAND REGION, PAPUA NEW GUINEA July 28, 2012
Magnitude 6.7 MAURITIUS - REUNION REGION July 26, 2012
Magnitude 6.5 SOLOMON ISLANDS July 25, 2012
Magnitude 6.4 SIMEULUE, INDONESIA July 25, 2012
Magnitude 5.2 OFFSHORE NORTHERN CALIFORNIA July 21, 2012
Magnitude 5.1 OFFSHORE NORTHERN CALIFORNIA July 21, 2012
Magnitude 5.7 HINDU KUSH REGION, AFGHANISTAN June 11, 2012
Magnitude 6.4 SOUTH OF PANAMA June 04, 2012
Magnitude 6.2 SOUTH OF PANAMA June 04, 2012
Magnitude 6.7 SANTIAGO DEL ESTERO, ARGENTINA May 28, 2012
Magnitude 5.6 BULGARIA May 22, 2012
Magnitude 6.7 TONGA April 28, 2012
Magnitude 6.6 NEAR THE NORTH COAST OF PAPUA, INDONESIA April 21, 2012
Magnitude 6.8 EASTERN NEW GUINEA REG, PAPUA NEW GUINEA April 17, 2012
Magnitude 6.7 OFFSHORE VALPARAISO, CHILE April 17, 2012
Magnitude 6.5 VANUATU April 14, 2012
Magnitude 6.9 GULF OF CALIFORNIA April 12, 2012
Magnitude 6.5 MICHOACAN, MEXICO April 11, 2012
Magnitude 5.9 OFF THE COAST OF OREGON April 11, 2012
Magnitude 8.2 OFF THE WEST COAST OF NORTHERN SUMATRA April 11, 2012
Magnitude 8.6 OFF THE WEST COAST OF NORTHERN SUMATRA April 11, 2012
Magnitude 7.1 MAULE, CHILE March 25, 2012
Magnitude 6.6 NEW GUINEA, PAPUA NEW GUINEA March 21, 2012
Magnitude 7.4 OAXACA, MEXICO March 20, 2012
Magnitude 6.9 OFF THE EAST COAST OF HONSHU, JAPAN March 14, 2012
Magnitude 6.7 VANUATU March 09, 2012
Magnitude 4.0 SAN FRANCISCO BAY AREA, CALIFORNIA March 05, 2012
Magnitude 6.6 SOUTHEAST OF THE LOYALTY ISLANDS March 03, 2012
Magnitude 6.7 SOUTHWESTERN SIBERIA, RUSSIA February 26, 2012
Magnitude 6.0 OFF THE COAST OF OREGON February 15, 2012
Magnitude 6.4 SOLOMON ISLANDS February 14, 2012
Magnitude 5.6 NORTHERN CALIFORNIA February 13, 2012
Magnitude 6.7 NEGROS - CEBU REGION, PHILIPPINES February 06, 2012
Magnitude 7.1 VANUATU February 02, 2012
Magnitude 6.3 NEAR THE COAST OF CENTRAL PERU January 30, 2012
Magnitude 6.6 SOUTH SHETLAND ISLANDS January 15, 2012
Magnitude 7.2 OFF THE WEST COAST OF NORTHERN SUMATRA January 10, 2012
Magnitude 6.6 SANTA CRUZ ISLANDS January 09, 2012
Magnitude 6.8 IZU ISLANDS, JAPAN REGION January 01, 2012
    MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    3.2     2013/01/12 19:22:24      52.938     -169.409    55.2     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    3.0     2013/01/12 18:42:52      61.698     -147.005    20.1     SOUTHERN ALASKA
MAP    5.3     2013/01/12 17:33:38      -2.991      129.808    7.3     SERAM, INDONESIA
MAP    3.4     2013/01/12 14:39:02      19.694      -64.260    42.0     VIRGIN ISLANDS REGION
MAP    5.1     2013/01/12 14:32:39     -53.114      -46.971    14.5     SOUTH ATLANTIC OCEAN
MAP    3.5     2013/01/12 14:24:06      19.171      -64.220    100.0     VIRGIN ISLANDS REGION
MAP    3.3     2013/01/12 14:22:54      19.605      -64.277    73.0     VIRGIN ISLANDS REGION
MAP    3.1     2013/01/12 14:13:33      19.116      -64.065    107.0     VIRGIN ISLANDS REGION
MAP    5.3     2013/01/12 13:37:23      47.400      153.439    35.0     KURIL ISLANDS
MAP    4.8     2013/01/12 12:34:17      23.984      122.345    28.0     TAIWAN REGION
MAP    2.7     2013/01/12 12:29:20      19.197      -64.233    97.0     VIRGIN ISLANDS REGION
MAP    3.2     2013/01/12 12:17:27      19.438      -64.219    96.0     VIRGIN ISLANDS REGION
MAP    4.6     2013/01/12 12:16:01      37.260      144.767    35.0     OFF THE EAST COAST OF HONSHU, JAPAN
MAP    3.4     2013/01/12 12:06:07      19.541      -64.300    79.0     VIRGIN ISLANDS REGION
MAP    2.9     2013/01/12 11:52:55      19.594      -64.544    62.0     VIRGIN ISLANDS REGION
MAP    2.6     2013/01/12 11:44:54      19.512      -64.352    62.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/12 11:37:17      19.531      -64.129    77.0     VIRGIN ISLANDS REGION
MAP    2.9     2013/01/12 11:34:50      19.496      -64.215    75.0     VIRGIN ISLANDS REGION
MAP    4.3     2013/01/12 11:19:51      43.631     -127.382    10.1     OFF THE COAST OF OREGON
MAP    3.2     2013/01/12 11:10:04      19.680      -64.483    19.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/12 10:28:26      19.462      -64.146    89.0     VIRGIN ISLANDS REGION
MAP    4.7     2013/01/12 10:22:08     -18.878      169.210    212.6     VANUATU
MAP    3.2     2013/01/12 10:17:14      19.339      -67.538    31.0     PUERTO RICO REGION
MAP    2.8     2013/01/12 09:49:12      19.691      -64.243    14.0     VIRGIN ISLANDS REGION
MAP    2.6     2013/01/12 09:46:23      19.634      -64.300    17.0     VIRGIN ISLANDS REGION
MAP    2.7     2013/01/12 09:18:05      19.595      -64.337    57.0     VIRGIN ISLANDS REGION
MAP    5.0     2013/01/12 09:15:14      -2.073      138.859    44.3     PAPUA, INDONESIA
MAP    3.4     2013/01/12 09:07:36      19.683      -64.251    43.0     VIRGIN ISLANDS REGION
MAP    3.0     2013/01/12 08:34:55      19.455      -64.183    71.0     VIRGIN ISLANDS REGION
MAP    2.7     2013/01/12 08:29:46      19.470      -64.303    66.0     VIRGIN ISLANDS REGION
MAP    2.7     2013/01/12 08:24:29      51.283     -178.439    23.2     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    3.0     2013/01/12 07:53:38      19.455      -64.257    76.0     VIRGIN ISLANDS REGION
MAP    2.6     2013/01/12 07:03:43      19.704      -64.255    24.0     VIRGIN ISLANDS REGION
MAP    3.0     2013/01/12 06:27:42      19.540      -64.299    55.0     VIRGIN ISLANDS REGION
MAP    3.0     2013/01/12 06:17:29      19.224      -64.178    91.0     VIRGIN ISLANDS REGION
MAP    3.2     2013/01/12 06:15:57      19.652      -64.429    27.0     VIRGIN ISLANDS REGION
MAP    3.4     2013/01/12 06:14:14      19.703      -64.253    51.0     VIRGIN ISLANDS REGION
MAP    2.9     2013/01/12 06:00:04      19.602      -64.273    60.0     VIRGIN ISLANDS REGION
MAP    3.9     2013/01/12 05:54:46      19.742      -64.255    29.0     VIRGIN ISLANDS REGION
MAP    4.5     2013/01/12 05:42:15      19.677      -64.442    33.0     VIRGIN ISLANDS REGION
MAP    5.4     2013/01/12 03:25:06      31.847      50.960    10.0     WESTERN IRAN
MAP    3.2     2013/01/12 02:24:05      19.498      -64.216    71.0     VIRGIN ISLANDS REGION
MAP    3.0     2013/01/12 00:42:59      19.184      -64.724    64.0     VIRGIN ISLANDS REGION
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    3.1     2013/01/11 23:19:13      19.720      -64.329    47.0     VIRGIN ISLANDS REGION
MAP    3.1     2013/01/11 22:46:33      19.118      -65.179    82.0     PUERTO RICO REGION
MAP    2.5     2013/01/11 22:20:31      49.386     -120.497    0.0     BRITISH COLUMBIA, CANADA
MAP    3.2     2013/01/11 21:45:11      19.054      -64.048    101.0     VIRGIN ISLANDS REGION
MAP    2.9     2013/01/11 21:11:26      51.656     -175.771    45.2     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    4.9     2013/01/11 20:32:53      15.502      -91.630    229.3     GUATEMALA
MAP    2.5     2013/01/11 19:32:37      19.291     -155.213    8.4     ISLAND OF HAWAII, HAWAII
MAP    2.9     2013/01/11 19:00:00      18.207      -67.832    11.0     MONA PASSAGE, PUERTO RICO
MAP    2.6     2013/01/11 18:19:16      59.682     -153.484    124.9     SOUTHERN ALASKA
MAP    3.5     2013/01/11 18:17:16      52.171     -170.804    28.3     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    2.9     2013/01/11 17:09:51      19.008      -65.172    81.0     PUERTO RICO REGION
MAP    5.1     2013/01/11 16:30:44      14.883      -92.611    90.4     OFFSHORE CHIAPAS, MEXICO
MAP    4.1     2013/01/11 14:59:54      62.501     -151.363    89.9     CENTRAL ALASKA
MAP    3.0     2013/01/11 13:43:30      19.448      -64.256    86.0     VIRGIN ISLANDS REGION
MAP    4.7     2013/01/11 12:38:23      -1.949      68.194    9.8     CARLSBERG RIDGE
MAP    3.3     2013/01/11 10:46:03      39.781     -123.567    9.3     NORTHERN CALIFORNIA
MAP    3.4     2013/01/11 10:30:25      55.548     -135.108    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.8     2013/01/11 09:47:23     -17.278     -177.385    388.5     FIJI REGION
MAP    3.3     2013/01/11 09:13:21      19.579      -64.436    7.0     VIRGIN ISLANDS REGION
MAP    5.0     2013/01/11 09:10:15      13.349      92.383    34.2     ANDAMAN ISLANDS, INDIA REGION
MAP    2.8     2013/01/11 09:04:36      32.231     -115.242    41.8     BAJA CALIFORNIA, MEXICO
MAP    2.5     2013/01/11 08:09:48      37.559     -118.460    10.1     CENTRAL CALIFORNIA
MAP    4.4     2013/01/11 07:47:46      -9.502      114.712    75.6     SOUTH OF BALI, INDONESIA
MAP    4.6     2013/01/11 05:35:57     -39.310      173.690    11.0     OFF WEST COAST OF THE NORTH ISLAND, N.Z.
MAP    2.9     2013/01/11 04:26:24      19.688      -64.355    51.0     VIRGIN ISLANDS REGION
MAP    2.7     2013/01/11 02:28:47      37.714      -88.897    16.0     ILLINOIS
MAP    3.4     2013/01/11 02:21:27      19.300      -64.420    79.0     VIRGIN ISLANDS REGION
MAP    3.2     2013/01/11 01:31:27      18.920      -64.884    11.0     VIRGIN ISLANDS REGION
MAP    4.3     2013/01/11 00:30:21      39.631      25.510    5.8     AEGEAN SEA
MAP    3.1     2013/01/11 00:26:36      19.242     -156.051    47.4     HAWAII REGION, HAWAII
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.2     2013/01/10 23:48:03      28.918      67.535    10.0     PAKISTAN
MAP    3.3     2013/01/10 23:42:48      19.654      -64.328    58.0     VIRGIN ISLANDS REGION
MAP    3.3     2013/01/10 23:35:08      18.356      -63.725    84.0     ANGUILLA REGION, LEEWARD ISLANDS
MAP    5.0     2013/01/10 21:57:20     -16.561      175.250    66.2     FIJI REGION
MAP    3.3     2013/01/10 21:56:32      19.524      -64.305    82.0     VIRGIN ISLANDS REGION
MAP    3.3     2013/01/10 21:27:34      19.646      -64.414    20.0     VIRGIN ISLANDS REGION
MAP    4.5     2013/01/10 21:26:21      37.345      143.674    34.5     OFF THE EAST COAST OF HONSHU, JAPAN
MAP    2.6     2013/01/10 21:17:52      61.221     -152.170    103.3     SOUTHERN ALASKA
MAP    3.1     2013/01/10 21:11:09      19.532      -64.410    10.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/10 20:35:11      19.512      -64.277    58.0     VIRGIN ISLANDS REGION
MAP    3.4     2013/01/10 20:27:56      19.491      -64.303    67.0     VIRGIN ISLANDS REGION
MAP    3.2     2013/01/10 19:57:16      67.207     -145.736    2.8     NORTHERN ALASKA
MAP    3.2     2013/01/10 19:14:43      19.488      -64.390    9.0     VIRGIN ISLANDS REGION
MAP    2.6     2013/01/10 19:10:23      19.356      -64.056    97.0     VIRGIN ISLANDS REGION
MAP    3.2     2013/01/10 19:03:08      19.740      -64.388    12.0     VIRGIN ISLANDS REGION
MAP    2.7     2013/01/10 18:12:52      19.335      -64.240    97.0     VIRGIN ISLANDS REGION
MAP    2.5     2013/01/10 18:09:28      62.546     -151.503    120.0     CENTRAL ALASKA
MAP    2.8     2013/01/10 18:08:10      18.933      -65.042    42.0     VIRGIN ISLANDS REGION
MAP    3.1     2013/01/10 17:30:27      19.638      -64.423    28.0     VIRGIN ISLANDS REGION
MAP    4.6     2013/01/10 17:21:01      52.230     -170.451    13.2     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    3.2     2013/01/10 16:51:25      19.416      -64.392    76.0     VIRGIN ISLANDS REGION
MAP    3.2     2013/01/10 16:41:30      19.472      -64.212    76.0     VIRGIN ISLANDS REGION
MAP    4.9     2013/01/10 16:33:37      19.671      -64.346    24.0     VIRGIN ISLANDS REGION
MAP    5.1     2013/01/10 16:26:27     -10.887      161.962    57.0     SOLOMON ISLANDS
MAP    2.8     2013/01/10 15:55:04      40.320     -123.749    22.7     NORTHERN CALIFORNIA
MAP    3.2     2013/01/10 15:53:05      18.988      -65.107    25.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/10 15:41:27      59.934     -140.155    8.7     SOUTHEASTERN ALASKA
MAP    3.3     2013/01/10 15:37:03      59.972     -140.096    6.5     SOUTHEASTERN ALASKA
MAP    4.5     2013/01/10 13:52:21      16.725      -85.949    35.9     OFFSHORE HONDURAS
MAP    2.9     2013/01/10 13:52:11      19.207      -67.919    12.0     DOMINICAN REPUBLIC REGION
MAP    3.1     2013/01/10 13:50:49      18.112      -68.341    124.0     MONA PASSAGE, DOMINICAN REPUBLIC
MAP    3.1     2013/01/10 13:48:02      19.069      -68.099    103.0     DOMINICAN REPUBLIC REGION
MAP    5.8     2013/01/10 13:47:04      4.754      95.133    35.1     NORTHERN SUMATRA, INDONESIA
MAP    2.5     2013/01/10 13:23:11      61.921     -151.598    84.7     SOUTHERN ALASKA
MAP    3.1     2013/01/10 13:18:04      58.420     -156.571    201.5     ALASKA PENINSULA
MAP    3.2     2013/01/10 12:52:24      52.239     -169.923    9.3     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.9     2013/01/10 12:48:22      37.561      141.269    53.3     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    2.5     2013/01/10 11:57:25      59.936     -153.465    121.2     SOUTHERN ALASKA
MAP    3.1     2013/01/10 10:36:59      49.691     -178.632    38.7     SOUTH OF THE ALEUTIAN ISLANDS
MAP    3.2     2013/01/10 10:09:49      19.974      -64.220    10.0     NORTH OF THE VIRGIN ISLANDS
MAP    3.5     2013/01/10 09:19:03      61.528     -147.806    18.3     SOUTHERN ALASKA
MAP    3.3     2013/01/10 07:43:31      19.251      -64.829    69.0     VIRGIN ISLANDS REGION
MAP    2.9     2013/01/10 06:47:14      59.769     -152.961    111.0     SOUTHERN ALASKA
MAP    2.5     2013/01/10 05:24:01      58.067     -151.471    47.4     KODIAK ISLAND REGION, ALASKA
MAP    5.1     2013/01/10 04:58:58      -4.954      152.711    53.8     NEW BRITAIN REGION, PAPUA NEW GUINEA
MAP    3.0     2013/01/10 04:57:03      19.136      -66.515    19.0     PUERTO RICO REGION
MAP    4.7     2013/01/10 04:28:44      32.364      141.600    53.6     IZU ISLANDS, JAPAN REGION
MAP    2.7     2013/01/10 03:10:28      17.979      -65.402    17.0     PUERTO RICO REGION
MAP    4.9     2013/01/10 02:54:26      -5.434      151.712    60.1     NEW BRITAIN REGION, PAPUA NEW GUINEA
MAP    3.1     2013/01/10 02:17:36      19.120      -66.498    32.0     PUERTO RICO REGION
MAP    3.1     2013/01/10 02:16:31      19.103      -66.483    32.0     PUERTO RICO REGION
MAP    2.8     2013/01/10 01:07:28      19.130      -66.505    29.0     PUERTO RICO REGION
MAP    2.9     2013/01/10 00:45:44      19.126      -66.509    34.0     PUERTO RICO REGION
MAP    2.9     2013/01/10 00:14:19      19.145      -66.516    23.0     PUERTO RICO REGION
MAP    3.0     2013/01/10 00:06:30      19.118      -66.489    44.0     PUERTO RICO REGION
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    2.6     2013/01/09 23:59:45      40.292     -124.568    18.9     OFFSHORE NORTHERN CALIFORNIA
MAP    3.4     2013/01/09 23:44:45      19.962      -64.235    32.0     NORTH OF THE VIRGIN ISLANDS
MAP    3.5     2013/01/09 23:27:31      37.492      -3.746    21.0     SPAIN
MAP    3.0     2013/01/09 23:16:03      55.132     -134.657    20.0     SOUTHEASTERN ALASKA
MAP    4.1     2013/01/09 22:05:06      60.744     -150.173    49.7     KENAI PENINSULA, ALASKA
MAP    5.6     2013/01/09 21:46:03     -57.058     -141.451    13.7     PACIFIC-ANTARCTIC RIDGE
MAP    4.8     2013/01/09 21:20:08      -1.907      68.058    10.0     CARLSBERG RIDGE
MAP    5.0     2013/01/09 21:05:02      0.758      92.727    14.9     OFF THE WEST COAST OF NORTHERN SUMATRA
MAP    3.3     2013/01/09 20:17:24      55.620     -135.005    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    5.0     2013/01/09 18:38:41     -17.882      -69.422    78.9     TARAPACA, CHILE
MAP    3.5     2013/01/09 17:50:49      51.377      177.246    4.8     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.5     2013/01/09 16:30:58      -7.226      144.072    35.0     NEAR SOUTH COAST OF NEW GUINEA, P.N.G.
MAP    2.8     2013/01/09 16:02:45      50.865     -179.310    4.9     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    4.4     2013/01/09 15:41:33      39.711      25.630    9.0     AEGEAN SEA
MAP    3.9     2013/01/09 14:47:32      55.355     -134.781    20.0     SOUTHEASTERN ALASKA
MAP    2.9     2013/01/09 13:54:36      51.820      176.359    25.3     RAT ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    3.0     2013/01/09 13:50:48      37.273     -114.363    5.8     NEVADA
MAP    5.1     2013/01/09 11:21:19     -24.268      -69.522    115.3     ANTOFAGASTA, CHILE
MAP    2.5     2013/01/09 11:14:48      55.762     -135.093    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    3.4     2013/01/09 11:06:49      19.852      -65.287    18.0     PUERTO RICO REGION
MAP    4.9     2013/01/09 10:51:30      -1.953      67.960    10.0     CARLSBERG RIDGE
MAP    4.6     2013/01/09 10:35:52      -1.935      67.946    10.0     CARLSBERG RIDGE
MAP    4.7     2013/01/09 10:27:47      -1.912      67.854    10.0     CARLSBERG RIDGE
MAP    4.7     2013/01/09 10:08:45      -1.915      67.740    10.0     CARLSBERG RIDGE
MAP    4.7     2013/01/09 09:40:52      -1.851      67.906    10.0     CARLSBERG RIDGE
MAP    4.7     2013/01/09 09:02:39      -1.952      67.857    10.2     CARLSBERG RIDGE
MAP    2.9     2013/01/09 08:49:43      55.436     -134.793    20.0     SOUTHEASTERN ALASKA
MAP    4.1     2013/01/09 08:39:44     -33.082      -71.209    66.1     VALPARAISO, CHILE
MAP    4.4     2013/01/09 08:29:40      52.304     -170.518    45.3     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    2.5     2013/01/09 08:03:18      61.578     -151.986    99.3     SOUTHERN ALASKA
MAP    5.0     2013/01/09 07:44:20      29.753      81.735    34.2     NEPAL
MAP    3.0     2013/01/09 06:57:08      18.984      -65.227    28.0     PUERTO RICO REGION
MAP    4.8     2013/01/09 06:50:39      -1.915      68.001    10.0     CARLSBERG RIDGE
MAP    4.9     2013/01/09 06:21:57      -1.928      68.031    10.0     CARLSBERG RIDGE
MAP    5.0     2013/01/09 05:27:05      -1.937      68.031    10.0     CARLSBERG RIDGE
MAP    4.9     2013/01/09 04:46:30      -1.860      67.884    10.0     CARLSBERG RIDGE
MAP    4.7     2013/01/09 04:12:48      55.334     -134.948    10.0     SOUTHEASTERN ALASKA
MAP    2.5     2013/01/09 03:37:01      55.618     -134.941    20.0     SOUTHEASTERN ALASKA
MAP    2.7     2013/01/09 02:44:02      67.108     -142.504    4.0     NORTHERN ALASKA
MAP    5.8     2013/01/09 01:41:53      25.322      95.021    90.5     MYANMAR
MAP    2.8     2013/01/09 00:31:34      38.951     -122.759    2.4     NORTHERN CALIFORNIA
MAP    4.6     2013/01/09 00:17:53      46.805      152.515    54.3     KURIL ISLANDS
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.6     2013/01/08 23:42:58      -2.258      68.030    10.0     CARLSBERG RIDGE
MAP    4.8     2013/01/08 23:38:43      -2.063      67.984    10.0     CARLSBERG RIDGE
MAP    4.7     2013/01/08 23:31:49      -1.977      68.012    10.1     CARLSBERG RIDGE
MAP    2.6     2013/01/08 23:18:37      35.515      -97.371    5.3     OKLAHOMA CITY URBAN AREA, OKLAHOMA
MAP    5.4     2013/01/08 21:26:55     -34.429      179.170    8.4     SOUTH OF THE KERMADEC ISLANDS
MAP    5.2     2013/01/08 20:15:05     -10.293      161.666    87.4     SOLOMON ISLANDS
MAP    2.8     2013/01/08 19:40:27      18.804      -67.244    10.0     PUERTO RICO REGION
MAP    5.0     2013/01/08 19:04:01     -32.382      -14.178    9.8     SOUTHERN MID-ATLANTIC RIDGE
MAP    5.0     2013/01/08 18:55:40      52.405     -170.630    52.7     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.6     2013/01/08 18:45:03      55.386     -134.944    9.1     SOUTHEASTERN ALASKA
MAP    2.7     2013/01/08 18:36:32      38.953     -122.757    2.5     NORTHERN CALIFORNIA
MAP    2.5     2013/01/08 18:32:23      38.955     -122.754    3.0     NORTHERN CALIFORNIA
MAP    2.5     2013/01/08 18:18:36      49.446     -120.488    0.0     BRITISH COLUMBIA, CANADA
MAP    2.6     2013/01/08 18:16:26      37.417     -118.321    8.1     CENTRAL CALIFORNIA
MAP    3.2     2013/01/08 17:43:19      37.423     -118.330    7.6     CENTRAL CALIFORNIA
MAP    2.8     2013/01/08 17:14:26      51.602     -178.363    2.9     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.7     2013/01/08 16:55:38      59.986     -140.586    5.7     SOUTHEASTERN ALASKA
MAP    4.3     2013/01/08 15:50:11      15.405     -104.986    40.0     OFF THE COAST OF MICHOACAN, MEXICO
MAP    3.0     2013/01/08 15:22:12      38.760     -122.724    1.6     NORTHERN CALIFORNIA
MAP    4.0     2013/01/08 14:46:33      56.008     -135.454    10.0     SOUTHEASTERN ALASKA
MAP    5.7     2013/01/08 14:16:09      39.658      25.543    10.3     AEGEAN SEA
MAP    2.9     2013/01/08 13:39:21      48.533     -119.893    1.0     WASHINGTON
MAP    2.5     2013/01/08 12:15:18      59.785     -153.533    138.2     SOUTHERN ALASKA
MAP    4.4     2013/01/08 11:26:49     -10.428      120.163    38.7     SUMBA REGION, INDONESIA
MAP    4.7     2013/01/08 10:47:41      39.491      71.740    10.0     KYRGYZSTAN
MAP    2.9     2013/01/08 10:46:35      40.301     -123.903    27.9     NORTHERN CALIFORNIA
MAP    4.3     2013/01/08 09:08:32      22.883      123.064    19.1     SOUTHEAST OF TAIWAN
MAP    2.6     2013/01/08 09:02:47      18.077      -66.984    21.0     PUERTO RICO
MAP    4.7     2013/01/08 08:29:43      -4.295      141.985    119.2     NEW GUINEA, PAPUA NEW GUINEA
MAP    5.4     2013/01/08 07:51:32      40.208      142.203    38.6     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    3.2     2013/01/08 06:55:41      19.238      -67.856    31.0     DOMINICAN REPUBLIC REGION
MAP    4.3     2013/01/08 06:15:06      37.682      37.986    10.1     CENTRAL TURKEY
MAP    4.5     2013/01/08 06:05:09      37.810      37.952    10.0     CENTRAL TURKEY
MAP    2.5     2013/01/08 05:02:47      60.546     -145.503    19.1     SOUTHERN ALASKA
MAP    4.5     2013/01/08 02:51:45      19.221      121.257    10.0     BABUYAN ISLANDS REGION, PHILIPPINES
MAP    2.6     2013/01/08 01:46:37      52.360     -174.598    198.6     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    3.3     2013/01/08 00:49:54      31.345     -116.218    10.0     BAJA CALIFORNIA, MEXICO
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    4.6     2013/01/07 23:55:22      35.121      141.663    19.7     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    2.6     2013/01/07 22:24:42      55.289     -134.676    20.0     SOUTHEASTERN ALASKA
MAP    3.1     2013/01/07 21:52:40      67.184     -142.590    45.0     NORTHERN ALASKA
MAP    2.5     2013/01/07 20:14:19      51.245     -177.916    23.3     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.8     2013/01/07 19:55:13      36.645     -121.101    12.4     CENTRAL CALIFORNIA
MAP    2.7     2013/01/07 19:33:57      51.240     -177.916    25.6     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.6     2013/01/07 18:29:13      36.224      -89.436    6.3     TENNESSEE
MAP    2.9     2013/01/07 18:25:42      60.120     -153.393    160.5     SOUTHERN ALASKA
MAP    3.6     2013/01/07 18:22:58      19.212      -65.220    5.0     PUERTO RICO REGION
MAP    2.9     2013/01/07 16:04:35      52.805     -173.729    176.6     ANDREANOF ISLANDS, ALEUTIAN IS., ALASKA
MAP    2.7     2013/01/07 15:57:12      59.797     -153.178    115.9     SOUTHERN ALASKA
MAP    3.1     2013/01/07 15:36:43      36.838     -111.856    6.4     ARIZONA
MAP    4.0     2013/01/07 15:07:35      55.382     -134.807    20.0     SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 14:21:38      18.668      -66.512    30.0     PUERTO RICO REGION
MAP    4.9     2013/01/07 13:53:50      37.817      142.356    48.3     OFF THE EAST COAST OF HONSHU, JAPAN
MAP    3.4     2013/01/07 11:31:46      19.465      -68.393    9.0     DOMINICAN REPUBLIC REGION
MAP    2.9     2013/01/07 11:04:19      55.416     -135.750    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 10:58:10      55.422     -135.757    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 10:34:53      53.817     -164.652    58.0     UNIMAK ISLAND REGION, ALASKA
MAP    2.5     2013/01/07 08:05:19      56.035     -135.251    20.0     SOUTHEASTERN ALASKA
MAP    3.0     2013/01/07 07:44:34      55.678     -134.883    20.0     SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 07:31:59      18.983     -155.444    37.2     HAWAII REGION, HAWAII
MAP    2.9     2013/01/07 06:50:50      40.599     -123.355    33.3     NORTHERN CALIFORNIA
MAP    5.2     2013/01/07 06:49:07      24.535      122.913    73.3     TAIWAN REGION
MAP    2.5     2013/01/07 05:56:01      18.110      -64.021    16.0     VIRGIN ISLANDS REGION
MAP    4.2     2013/01/07 05:32:45      28.325      94.309    18.1     ARUNACHAL PRADESH, INDIA
MAP    3.1     2013/01/07 05:24:48      55.255     -134.692    20.0     SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 05:07:07      55.612     -135.028    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 03:34:32      37.515     -118.874    7.2     CENTRAL CALIFORNIA
MAP    4.4     2013/01/07 03:33:23      49.035     -128.715    10.0     VANCOUVER ISLAND, CANADA REGION
MAP    2.7     2013/01/07 02:45:19      55.963     -135.347    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/07 01:42:34      40.215     -124.114    13.4     NORTHERN CALIFORNIA
MAP    2.5     2013/01/07 01:31:24      62.127     -145.668    19.3     CENTRAL ALASKA
MAP    2.5     2013/01/07 00:51:47      37.057     -104.644    5.4     COLORADO
MAP    4.3     2013/01/07 00:41:57      26.839      56.184    10.0     STRAIT OF HORMUZ
MAP    2.9     2013/01/07 00:33:13      55.405     -134.795    20.0     SOUTHEASTERN ALASKA
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    2.7     2013/01/06 23:35:27      53.460     -167.967    149.5     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    4.3     2013/01/06 23:22:32      40.153      21.819    11.8     GREECE
MAP    3.4     2013/01/06 23:17:17      54.679     -159.827    13.2     SOUTH OF ALASKA
MAP    2.5     2013/01/06 21:46:39      55.235     -134.647    20.0     SOUTHEASTERN ALASKA
MAP    3.1     2013/01/06 21:20:02      40.846     -125.372    21.5     OFFSHORE NORTHERN CALIFORNIA
MAP    2.8     2013/01/06 20:32:21      55.254     -134.714    20.0     SOUTHEASTERN ALASKA
MAP    3.0     2013/01/06 19:43:51      55.625     -135.289    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.9     2013/01/06 19:39:03      45.676      154.077    27.2     EAST OF THE KURIL ISLANDS
MAP    5.1     2013/01/06 18:24:45      17.135      -94.994    65.3     OAXACA, MEXICO
MAP    4.9     2013/01/06 18:17:31     -22.875      -66.102    252.6     JUJUY, ARGENTINA
MAP    2.5     2013/01/06 18:15:16      55.443     -135.002    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.5     2013/01/06 17:48:25      55.677     -135.186    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.7     2013/01/06 17:35:09      55.707     -135.108    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    5.1     2013/01/06 16:28:19     -26.266      178.394    634.0     SOUTH OF THE FIJI ISLANDS
MAP    2.6     2013/01/06 16:09:16      37.423     -121.768    6.6     SAN FRANCISCO BAY AREA, CALIFORNIA
MAP    2.6     2013/01/06 15:40:37      55.383     -134.884    20.0     SOUTHEASTERN ALASKA
MAP    4.1     2013/01/06 15:24:14      29.963      57.605    10.0     SOUTHERN IRAN
MAP    4.7     2013/01/06 14:34:58     -17.751      -72.109    87.9     NEAR THE COAST OF SOUTHERN PERU
MAP    3.3     2013/01/06 13:49:45      55.480     -134.943    20.0     SOUTHEASTERN ALASKA
MAP    2.6     2013/01/06 13:39:27      55.352     -134.593    20.0     SOUTHEASTERN ALASKA
MAP    2.7     2013/01/06 13:23:12      18.054      -64.042    28.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/06 13:17:49      18.340      -64.062    52.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/06 13:16:33      55.518     -135.066    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    3.8     2013/01/06 12:14:33      55.449     -135.328    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.3     2013/01/06 11:48:01     -24.287      -67.047    184.5     SALTA, ARGENTINA
MAP    2.9     2013/01/06 11:44:06      55.554     -135.132    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.5     2013/01/06 11:35:49      55.483     -135.394    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/06 11:18:41      60.062     -153.318    144.3     SOUTHERN ALASKA
MAP    5.4     2013/01/06 11:08:33      1.096      127.482    149.9     HALMAHERA, INDONESIA
MAP    3.1     2013/01/06 10:29:06      55.574     -135.040    19.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.8     2013/01/06 10:25:09      1.863      89.663    13.7     NORTH INDIAN OCEAN
MAP    4.6     2013/01/06 10:20:42     -17.191     -174.157    100.8     TONGA
MAP    2.6     2013/01/06 10:14:20      59.863     -152.889    100.6     SOUTHERN ALASKA
MAP    2.5     2013/01/06 10:05:12      18.522      -64.257    12.0     VIRGIN ISLANDS REGION
MAP    2.8     2013/01/06 10:04:03      55.461     -134.922    20.0     SOUTHEASTERN ALASKA
MAP    2.7     2013/01/06 09:43:46      55.285     -134.586    20.0     SOUTHEASTERN ALASKA
MAP    2.9     2013/01/06 09:40:52      56.019     -135.343    20.0     SOUTHEASTERN ALASKA
MAP    2.5     2013/01/06 09:33:39      52.589     -169.200    18.2     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    3.4     2013/01/06 08:43:53      18.372      -68.368    97.0     MONA PASSAGE, DOMINICAN REPUBLIC
MAP    4.5     2013/01/06 08:37:30      55.810     -135.090    10.1     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.8     2013/01/06 08:19:38      33.242     -116.344    14.1     SOUTHERN CALIFORNIA
MAP    4.7     2013/01/06 08:11:27      37.599      142.077    35.0     OFF THE EAST COAST OF HONSHU, JAPAN
MAP    2.5     2013/01/06 07:58:52      19.365     -155.411    10.8     ISLAND OF HAWAII, HAWAII
MAP    2.6     2013/01/06 07:36:35      55.382     -135.067    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.9     2013/01/06 07:21:38      55.600     -134.967    20.0     SOUTHEASTERN ALASKA
MAP    2.7     2013/01/06 07:07:26      55.643     -134.991    20.0     SOUTHEASTERN ALASKA
MAP    2.8     2013/01/06 06:27:48      55.630     -134.948    20.0     SOUTHEASTERN ALASKA
MAP    3.5     2013/01/06 06:22:53      55.457     -135.106    10.5     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    3.0     2013/01/06 06:04:08      55.999     -135.152    17.6     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/06 05:51:42      56.058     -135.406    20.0     SOUTHEASTERN ALASKA
MAP    2.7     2013/01/06 05:40:01      55.596     -135.344    19.5     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.6     2013/01/06 04:43:11      19.434     -155.259    1.6     ISLAND OF HAWAII, HAWAII
MAP    3.2     2013/01/06 04:21:56      55.758     -134.975    20.0     SOUTHEASTERN ALASKA
MAP    2.5     2013/01/06 04:03:27      55.475     -135.168    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    3.0     2013/01/06 03:58:45      52.503     -167.499    5.1     FOX ISLANDS, ALEUTIAN ISLANDS, ALASKA
MAP    2.7     2013/01/06 03:46:22      55.577     -134.770    4.5     SOUTHEASTERN ALASKA
MAP    2.8     2013/01/06 03:14:29      55.576     -135.176    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.3     2013/01/06 02:32:33      35.261      141.124    26.6     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    2.8     2013/01/06 02:16:56      59.100     -153.584    105.6     SOUTHERN ALASKA
MAP    2.9     2013/01/06 02:16:26      55.478     -135.034    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    3.2     2013/01/06 02:06:56      55.639     -135.043    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    2.7     2013/01/06 01:26:36      55.334     -134.647    14.4     SOUTHEASTERN ALASKA
MAP    3.1     2013/01/06 00:55:30      55.537     -134.751    20.0     SOUTHEASTERN ALASKA
MAP    2.6     2013/01/06 00:14:34      55.657     -134.980    20.0     SOUTHEASTERN ALASKA
MAP    3.0     2013/01/06 00:08:17      54.467     -161.691    17.0     ALASKA PENINSULA
MAP    3.2     2013/01/06 00:02:21      55.400     -134.940    20.0     SOUTHEASTERN ALASKA
     MAG    UTC DATE-TIME
y/m/d h:m:s    LAT
deg    LON
deg    DEPTH
km     Region
MAP    2.7     2013/01/05 23:41:04      55.433     -134.940    20.0     SOUTHEASTERN ALASKA
MAP    2.9     2013/01/05 23:14:16      55.564     -134.940    20.0     SOUTHEASTERN ALASKA
MAP    2.5     2013/01/05 22:50:56      55.602     -134.931    20.0     SOUTHEASTERN ALASKA
MAP    4.6     2013/01/05 22:04:38      44.101      146.849    102.4     KURIL ISLANDS
MAP    3.2     2013/01/05 21:56:03      55.588     -135.055    20.0     OFF THE COAST OF SOUTHEASTERN ALASKA
MAP    4.0     2013/01/05 21:26:56      55.312     -134.728    9.9     SOUTHEASTERN ALASKA
RE: Ice Age Model
« Reply #23, on January 31st, 2013, 05:34 PM »Last edited on February 1st, 2013, 02:51 PM by freethisone
To add to this, this increasing potential is slipping quickly through the gap.
in a few month we should see this change occur. and in 6 to 9 month increased resistance, and thermal events.
it is assumed  a slip stream, and therefore a short time will pass with generally lower inductive readings., and flux.
as the changing magnetic field cuts lines of force the solar energy will go up. the form of plume waving with higher mass ejections of plasma.
add movie.  these observations will be as follow. 20 day periods. 40 days 60 days 80 days.
I will update this with observable data to make  final conclusions for predictable outcome.
this may well turn out to be a 13 year observation with 6, and 7 being the center of this relation. time, distance ,radius ,speed. and position..
magnetic field, charge, mass. eruption, axial shift, tidal surge, atmosphere circulation changes during torque times delta t.
angular momentum. lunar observations, solar observation. and the new observation of brilliant lights called comets or stars.
:angel:
MAP    6.7     2013/02/01 22:16:38     -10.997      165.403    34.2     SANTA CRUZ ISLANDS
MAP    6.0     2013/02/01 05:36:41     -11.090      165.538    9.4     SANTA CRUZ ISLANDS
MAP    5.9     2013/02/01 02:17:27      -6.951      147.667    34.8     EASTERN NEW GUINEA REG, PAPUA NEW GUINEA
MAP    5.1     2013/02/01 00:18:08     -11.034      165.334    10.7     SANTA CRUZ ISLANDS
MAP    6.0     2013/01/31 09:53:44      55.584     -134.745    9.7     SOUTHEASTERN ALASKA
MAP    5.1     2013/01/31 06:42:11     -10.713      166.386    35.2     SANTA CRUZ ISLANDS
MAP    5.4     2013/01/31 05:18:15     -10.567      166.446    45.7     SANTA CRUZ ISLANDS
MAP    5.0     2013/01/31 05:16:58     -10.502      166.201    25.0     SANTA CRUZ ISLANDS
MAP    5.6     2013/01/31 04:31:33     -10.934      165.418    32.9     SANTA CRUZ ISLANDS
MAP    5.0     2013/01/31 04:10:46      -4.613      102.515    51.7     SOUTHERN SUMATRA, INDONESIA
MAP    5.6     2013/01/31 03:58:00     -10.680      166.391    35.1     SANTA CRUZ ISLANDS
MAP    6.2     2013/01/31 03:33:44     -10.628      166.382    9.2     SANTA CRUZ ISLANDS
MAP    6.0     2013/01/30 23:03:45     -10.518      166.486    10.0     SANTA CRUZ ISLANDS
MAP    6.8     2013/01/30 20:15:43     -28.180      -70.784    42.7     ATACAMA, CHILE
MAP    5.0     2013/01/30 12:57:51      10.422      126.922    35.0     PHILIPPINE ISLANDS REGION
MAP    5.2     2013/01/30 09:27:06      32.847      94.706    37.1     XIZANG-QINGHAI BORDER REGION
MAP    5.3     2013/01/30 03:14:28      43.566     -127.598    10.2     OFF THE COAST OF OREGON
MAP    5.4     2013/01/30 02:32:20      10.558      126.684    46.0     PHILIPPINE ISLANDS REGION
MAP    5.1     2013/01/29 19:30:33     -11.206      165.355    24.7     SANTA CRUZ ISLANDS
MAP    6.0     2013/01/28 16:38:54      42.598      79.699    15.0     EASTERN KAZAKHSTAN
MAP    5.2     2013/01/27 20:57:35      27.214      128.362    57.9     RYUKYU ISLANDS, JAPAN
MAP    5.2     2013/01/27 19:32:41     -34.733     -108.974    14.8     SOUTHERN EAST PACIFIC RISE
MAP    5.1     2013/01/27 18:41:49      36.526      140.534    70.9     NEAR THE EAST COAST OF HONSHU, JAPAN
MAP    5.1     2013/01/27 13:50:37     -35.163     -108.522    10.0     SOUTHERN EAST PACIFIC RISE
MAP    5.7     2013/01/27 09:59:27     -16.105     -173.240    8.6     TONGA
MAP    5.0     2013/01/27 04:05:42      -5.170      102.940    58.1     SOUTHERN SUMATRA, INDONESIA
