Maybe this is a help to the people who want to carry out tests with a "dynamic plasma reactor" (Cola bottle reactor).
Excuse me for my poor English.
/watch?v=VDfrpku0P_E
just a fast draw out in solidworks.
http://imageshack.us/f/850/reactoranode.jpg/
i think i know what he means with getting into the plasma field.
if you create the plasma buble.
like you do in the plasma ball.
you just need to get two more components in.
one isolator.
and then a inox like rod wich will catch the ellektrons.
inside the plasma field.
do note that it needs a massa point wich you can regulate in distance toward the rod.
this would allow regulation of its output.
this catch rod is the middle one in the drawing.
then a ceramic isolator.
then the anode.
then again a ceramic isolator.
then you have the carige cage of the magnets holding also the cathodes.
if you do a mirror image of this system you will have a more powerfull extraction.
this is just a idea so please be kind with comments.
cheers :)
ps :btw geert am building a lil cnc mill.
if you need serten parts ill be able to make them soon.
even in titanium if needed.
and am from belgium so .
also i have a awesome idea for a beter seal but for that ill need my 4th cnc axis.
to spoil it a bit.
i could cut a inox ring in the right dimmentions.
then friction turn it to make it a 100% seal fit.
greetings
groetjes
Ok, I sent you a message. I would like to work together.Quote from spoocke on May 31st, 2013, 03:36 PM just a fast draw out in solidworks.
one isolator.
then the anode.
cheers :)
to spoil it a bit.
greetings
groetjes
Hey
This is another quick update about the building of the Keshe plasma reactor.
The polies and DC motor are mounted. This is just an outer core (single core) without central kolom.Met this concept is working to open a plasma. The core is already quite balanced but still needs to be updated a little. I have not been able to measure the speed but I think between 2500 and 3000 r / min. The core is placed under vacuum with ordinary air, so no added noble gases. This is an ordinary test to check the safety of the system.
enjoy
Geert
https://www.youtube.com/watch?v=Tq2nOchEEgo&feature=youtu.be
Last video update about the feedthrough problem of a spinning vacuum chamber.
Enjoy
Geert
System almost ready, test run.
https://www.youtube.com/watch?v=3gTBxzQlRRw
Hi Geert,
It is looking very nice and all, but i wonder how these rotating gases are supposed to be making a plasma. Is there some electric field also inside?
Can you elaborate a bit more on the theoretic side of this? Under what conditions is what supposed to be happening?
As i understand it now, you are rotating gases and also are maintaining a vacuum somewhere.
Thx for any more info
Hi guysQuote from FaradayEZ on December 2nd, 2013, 01:24 PM Hi Geert,
Here some explanation of what I'm trying to do.
It's just a rotary vacuum chamber where some types of gas are present in very small quantity. There is no electrical supply is present inside, only the gases. The gases have layers and they do as they spin in a vacuum environment (they react as a liquid). the ratio of different gases must now be tested. at some point certain layers begin to exchange electrones which give responses in the form of magnetic fields. When this lasts long enough in a particular circumstance, then open up a plasma (such Keshe calls it).
The coil around the sphere only serves as a detector of magnetic fields and not to drain Voltage as many suspect.
This is only the beginning and the concept still needs to be further developed.
Thus, the main purpose of these tests is the opening of a plasma, for the time being nothing else.
Best regards
Geert
Best regards
Geert
