In these type of reactor to imitate the convection condition of the earth outer core, which is in reality, is the
need for charge particle to be in motion in a metallic environment, the circulation of charged particle in the metallic
material can be easily achieved, by feed of charge particles from the plasma from the caroline core through special
borehole, that high energy protons is feed as the ingredient for the rotation of and heating of the material into the outer
core material.
[1026] Charge practical within this environment, where the energy of the protons is large enough to allow them to float
in the matter in this level. But they do not enough energy to cause ionisation or photon release. Thus for the choice of
the material for the outer core. This point has to be taken in to consideration. Therefore even inert gases which can
satisfy this criterion can be used in the outer core. Where the charged partials induced in to this core will maintain the
magnetic field and the current due to the convection of the gases on their own, where the gas in this level will become
a physical catalyst for the creation of magnetic field and not a chemical catalyst.
[1027] The proton balance in each core plus the speed of the rotation of the plasma will dictate the strength of the
magnetic field of the inner core..............................................if you have read it correctly ... plasma rotation is needed, do not confuse the word plasma Keshe attributed to the name of the entity.
