Water Injector 3D Models
adys15
RE: Water Injector 3D Models
« Reply #126, on April 22nd, 2013, 03:45 PM »Last edited on April 23rd, 2013, 12:50 AM by ~Russ/Rwg42985
You can download the models below. If you would like a different model file, please post and I'll see what I can do.
Hy Brian,do you have the complete injector file?like in 3rd pic,thanks!
« Reply #127, on April 23rd, 2013, 12:47 AM »Last edited on April 23rd, 2013, 12:51 AM by ~Russ/Rwg42985
Quote from adys15 on April 22nd, 2013, 03:45 PM
there on the first post. ~Russ
adys15
« Reply #128, on April 23rd, 2013, 01:24 AM »
Quote from ~Russ/Rwg42985 on April 23rd, 2013, 12:47 AM
I saw those,but the parts are separated,i was refering to the whole injector in one file,thanks!
« Reply #129, on April 23rd, 2013, 02:14 AM »
Quote from adys15 on April 23rd, 2013, 01:24 AM
I saw those,but the parts are separated,i was referring to the whole injector in one file,thanks!
hummmm, you may be able to message bams5 and ask him. haven't seem him here in a while.
« Reply #130, on April 26th, 2013, 08:01 AM »Last edited on April 26th, 2013, 08:08 AM by securesupplies
Quote from ~Russ/Rwg42985 on April 23rd, 2013, 02:14 AM
Hey Russ Can you post the
3d printer files for the ceramic pc ,
you did in the last video for injector please.
it will be cool to get  people printing the pcs get them in
their hands to attemp making them with other materials.
Trival but worth while to post the 3d files,
3d Injector parts
Come to think of it,
Since we have the skills and many 3d printer firing up now,
Can we convert the all the injector parts to 3d printer files?????
ready to print global!!!
now thats worth doing.
I think it would be worth while and a fast way
to get it to come to life global, and not fade out again any time soon.
It means every one could be printing protypes and and use them
as models for machinists.
Very very cool ,
if only stan had this tool when he was alive.
RIP STAN .
Guys
PLease try to post all injector parts as printable
3d printer files I think we can speed up
replications and common knowledge
and familiarization, alot
by trying to plastic print
all parts on the 3d printer. if you have skill to do it please post it.
Imagine all the people printing
them very cool.
« Reply #131, on April 27th, 2013, 12:32 AM »
Quote from securesupplies on April 26th, 2013, 08:01 AM
3d Injector parts
Very very cool ,
RIP STAN .
Guys
them very cool.
http://open-source-energy.org/?tid=552
Tiffany_CMI
« Reply #132, on June 20th, 2013, 11:21 AM »Last edited on June 20th, 2013, 11:25 AM by Tiffany_CMI
Does anyone know if the probe is supposed to be a press-fit inside the ceramic insert?  And is the fitment between the ceramic insert and water inlet housing a press-fit?  The drawing dimensions are somewhat inaccurate.  I don't see how the probe with a 4-40 thread is going to fit through a .1094 dia hole in the ceramic insert.  The company I work for has asked me to build one of these and there seem to be a bunch of fitment issues.  Any info or suggestions would be greatly appreciated. Thanks
-Tiffany
Quote from BAM5 on May 29th, 2012, 01:04 AM
Hello!
This is my first post, and I hope it is a useful one.
I am making a 3D model of the complete injector assembly using Autodesk Inventor.
I've already made the plug housing (2-2) and the water inlet housing (2-3) exact to Stan's specifications. There is however some guesswork with the inlet threading and size. It would appear to me that the all the drawings throughout this design are inconsistent with each other and are not to scale with the measurements, however they do fit together.
I do have a few questions that I hope someone can help me clear up.
In figure 2-4, there is a label that says .110 DIA. STOP-SEAL SURFACE. What exactly is a "stop-seal surface," what does it imply?
In some of the measurements there are negative numbers in parentheses, usually very small on the scale of thousandths. What are these numbers for? Are they for fabrication accuracy?
And another question is about the functionality of the injector. Is the injector always supposed to be open? That is, there is no way to stop water from coming out the tip of the injector from the pressurized water inlet port?
One last thing that I've noticed is that no water can make it through the quenching circuits because of the way the ceramic sits inside the water inlet housing and the way both of those sit inside the injector housing. With one slight modification to how long the end of the ceramic insert is however, this problem can be fixed.
And now for why you came here. These models are my best interpretations of the drawings. These models do not have the fix stated above.
(Please note that the drawings may not be to size. )
Our 3D printer is +-.010 which would not help fitting these parts together since the tolerances seem to be much smaller.  What is the tolerance on your 3D printer?
