Hello every one,
I'd like to post my current progress on the injector.
Attached is a picture of the insulator (not fully machined yet) made of Teflon and my probe that is lathed down to the 2.2~° point described in the prints. I have polished this with a cloth wheel and caulk. Very slick! Going on my own dimensions for the rest though, just for proof of concept. Going to use my ham radio that put out up to 100watts if necessary from anything between 0-30Mhz, this should provide some good results. Also I am going to try and do something with my neon transformer, rectified and perhaps try 240VAC? If I screw up my probe, I can build them by the dozens, but the housings not so much. I will probably experiment with just a simple spray nozzle like in another post that suggests paint sprayer. Get a gap that is sufficient that wont cause direct arcing but still electrolysis and yet potent enough to ignite the gases, pump enough water through to see if we can't make a torch.
Thought about using a direct injector from modern day cars as they have their own way of producing high pressures or regulating high pressures. Also for the steam or water vapor I've been bouncing ideas off of co-workers about using piezo-electric humidification.
[attachment=2060]
-Added later-
[attachment=2061]
[attachment=2062]
