I made it from two candle holders. 4cm diameter.
copper tape.
wire of the AC HV transformer through the middle.
Now the frequency has shifted up, which is ok.
to around 45kc/s
This is due to the parallel capacitor now being reduced in size, by this series capacitor.
one problem, is that somehow the AC HV transformer now starts hissing, and wont produce high voltages.
Another thing is that the low voltage side, now is 180 phase shifted.
But that is actually good. this will cause the field to increase voltage, demanding a charge current from the ambient.
like a vacuum, due to the sudden voltage increase.
sadly there also is a lot more ringing.
The voltage also cant get much higher.
At least I also found the probable anomaly cause. This happens when the signal delay on the edge of its capabilities.
I needed to retune the delay signal because the frequency is now so much higher.
Finally, I need to reduce the parallel capacity of the HC coil, to again match the new higher resonant frequency.
Since I have a dead line,
and this demands more engineering, I will stop the quest for now.
The ideas are always good, but again and again lead to more engineering challenges.
step by step I will get there.
I have come this far!
I will resume is time is available again
