ok, outside rim of L1 is now grounded, L1 is bifilar
scr39 shows orange ringing of L3 scr41 is zoomed in to show half wave duration of 688nS (still the same)
scr40 shows impulse duration which now is 1078ns much longer than expected. (expected it to match L3)
the yellow impulse of L1 is measured at source (as are all other tests)
as can see, there now is barely any overshoot, and the last part of the impulse traveling up is prolonged.
This can be explained, by having the resonant side of L1 close coupled to L2.
while L3 has its resonant side facing loose coupled L2, instead of close coupled (but ungrounded) L4.
So I will check, which side is resonant at L1 and L3
edit, I checked, and both L1 and L3 resonant inside rims are facing air. So in theory should be the same.
L3 is faster. L3 might be faster due to LMD resonant mode.
I tuned to 90.8kc/s where ther ideal resonant mode was, without ripple.
note that with the faster impulse I needed to tune much higher to get rid of the ripple.
It seems the faster impulse creates a stronger shockwave ripple?
anyway... impulse now is to slow for L3. will need to revert to parallel shorted L1 (unifilar) and slow it down to L3 speed, by adding capacity parallel to L1. I could also loosen L3 from L2 to slow it down, but... the difference between the impulse and L3 is to much to solve it with coupling (frequency splitting)
maybe R is now to big, for a high Q impulse, since in series mode the wire is twice as long, and twice the R, with 0.75mm2 it might be "fatal" for proper impulse generation.
