PLease update links to other doing HGG projects
Here is one I found very interesting
https://www.youtube.com/watch?v=E70RabnwOoI&feature=related
Thanks, Shainagua
so will Stan's system work with out the GHH??? i don't know. but we are on our way to finding out!
just remember that there is more to Stan's WFC than one supper efficient water breaker... the over all efficiency comes from all over the system... not from just one part of the system.
so, the answer i cant answer and haven't found any one that can answer it is...
What happens when you take at least 4 electrons away from oxygen, then try to burn it with hydrogen???
Hi Everyone
Iam new here and i would exchange my experience around Stans work witch others.
I think about LEDs we need to use in the Gas Processor. This is only correct wavelenght we can use to this proces.
Hydrogen absorbtion wavelenght is 4101,7 A = 410,17 nm and oxygen absorbtion wavelenght is 4105,0 A = 410,5 nm. We just need to set precisely voltage potencial on the LED with 410,5 nm (it will be different for different LED prodecent), and after set it in pulse frequency like Stan said. With this pulse we can get 410,17 nm too.
I dont understand whatfor the LEDs with for example 654 nm wavelenght are better if with 410 nm we have more energy transmitted by foton and for 410,5 - 3,013 eV/foton, for 410,17 - 3,016 eV/foton, where for 654 nm - 1,89 eV.
Sorry for my english, i hope your understand all :)
Greetings
Martin
Hey Russ,
First off just want to say that I have been watching your videos since day dot and I subscribe. I have always enjoyed your work. Keep it up! Just wondering if someone can explain in further detail the reason we are creating a corona. I understand the physics aspects of getting the gas to higher states using the LED's etc but how does the corona NOT ignite the HHO gas in the chamber?
i am very sad to see that the epg work had never been tested. i would have liked to see what a magnetic gas could do as far as circulation through the pump.
i have a link that is related, perhaps you would subscribe. , but they give you a short summery, link.
you gave him more then enough time and opportunity for him to complete his processor, Dave i think his name is? anyway, with the information provided in the article you can get a good understanding of the process Stan was experimenting with.
http://prl.aps.org/abstract/PRL/v106/i19/e193003:huh :
:idea:
this guy. grr https://www.youtube.com/watch?v=MW3GQ5jtVKo&feature=c4-overview&list=UUEGe7GasoADRNz6wfHM91sQ
cool Like the fb page,
We can do exact reproduction and advanced reproductions.
Can we post basic dimension of Stans the air intake ioniser and the gas gun?
Free, this video is the one I get upset about. In order to build a Cathode Ray Tube and focus the beam onto the correct phosphorus pixel spot, it would be impossible to not notice the helical magnetic field produce by the coils in the yoke. These would have to be compensated for to draw linear scan lines across the tube face. So somebody has known about this phenomena for quite some time now--known so well that millions of television circuits designed and manufactured worldwide have this twisting compensated for. Now that everything is flat panel, the new engineers of today probably have no clue about it.Quote from freethisone on December 12th, 2013, 01:55 AM
Don't know if this helps anyone but oxygen ionizes at 225nm found this searching online if it is wrong let me know seems legit.
http://m.iopscience.iop.org/0953-4075/26/19/006
