This was wrong.
nav
A Christmas present to you all
« on December 8th, 2015, 11:33 AM »Last edited on December 19th, 2015, 11:03 AM
....and here comes the clique. Bahahahaha
I really do not understand your aggression towards me........
That wasn't aggression, I was just joking. Don't take it so seriously.
Nav, your not stealing any thunder from me at all, I have given everyone a chance at the thunder and still will in the future. The floor is all yours to explain things the way you see it.
Ask stc, that is in this thread watching. He seems to be interested in whats been talked about in all the threads that has anything to do with Stan Meyers Tech. I've never been able to get him to say anything.
All I will say about this is, do you think the circuit that the feed back coil is feeding the information to that your talking about can handle that kind of coil voltage it will produce if they are the same ratio as the rest of the coils?
thanks for posting that info nav.
One way to confirm if your ideas match stans would be to compare the enamel capacitance of the injector vic coil to the capacitance of the injector voltage zone. Anyone got the values of those components at hand?
The PLL is only switched on during the zero voltage stage of 5Khz and its sniffing the core for flux leakage.
Sorry if it's the obvious question here, but if I understand you correctly, the PLL would then be honed in to a zero flux and if it sees any, through the pickup coil, then it initiates changes in frequency and/or pulse width in order to get back to and maintain zero flux during zero voltage of the 5 KHz pulsing, could that possibly be in the neckar of woods of what you're saying here?
i double checked the injector capacitance using this calculator
http://www.daycounter.com/Calculators/Plate-Capacitor-Calculator.phtml
( using 1 sq inch area, 0.01inch gap, 78 dielectric value)
gives injector capacitance of 1.7nf ( so 2nf is pretty close).
So to nav:
the vic coil that stan uses on the injector style water splitter, should have a capacitance of 1.7nf ( between coils/enamel) if your theory is correct. The injector vic is this one pictured below,
anyone know the capacitance between wires for that vic? it should give an idea if your theory is correct, you gave enamel value of between 3 and 5, but you need the capacitance of the injector vic to see if theory is correct....?
or russ has a copy of stans injector vic shown in this vid
https://www.youtube.com/watch?v=nWMmGxhu77s
Does that makes sense nav? it would confirm your theory?
