That's just awesome Nav, thank you very much for the answer and the schematics :thumbsup:
As it is right now I've stopped my Meyer WFC tinkering quite a while ago and I don't think I'll take it up any time soon TBH, but it's very interesting to see your line of thinking here with regards to how the signal from the pickup coil can be recognized and made to scan for optimum performance given that it looks for zero voltage/zero flux, as opposed to max voltage when conditions are ripe for the Meyer goodness in the fuel cell, which is, up to now anyway, what I had in mind for how the signal from the pickup coil should be interpreted and put in good use in the PLL circuit of it all.
OTOH, I've actually started building a Faradic brute force electrolyser based on what I found here and I am kinda confident that it will work as advertised, that I'd be able to loop say a lawnmower or genset or the likes and to me that would be almost as good as a Meyer WFC because if there's 2 things that which we got a s#itload of on this small planet it's water and dirt, so it's well worth pursuing.
But that's as maybe, back to topic ;-)
