Thanks Russ
Just 50 cents i have a little knowledge.
Something i misunderstand. i need all friend to suggest me.
i attend about electron work.i think electronic education teach wrong understanding to student like "battery positive side electric go to light and go to negative side of battery" (exam this video
https://www.youtube.com/watch?v=8gvJzrjwjds) this wrong cause free electron(from high negative ion) go to high positive ion / electron energize electricity. The right word is "negative side battery to positive side battery" positive ion is
atom like oxygen have 8 proton but have electron less than proton(
8) like 7 6 5 4 3 2 this positive ion. proton cant move because is big. only electron move(this exam about metal like copper iron).
Something like that make student misunderstand and misunderstand all about relation knowledge.
All explain things that go to one point to understand Electrical Polarization Process
if you have very very high positive side then you have very very high push away positive ion and very very high attach negative ion BUT very high negative side(high electron side) can't attach proton(proton very bigger than electron) just positive side is important
but positive side induction opposite side to have very very much electron act like negative side and attach positive ion from water bath. negative side can neutral by lose electron easily cause electron is smallest.
this knowledge conclude : to make very very high positive side why??
- upper reason
how???
- high voltage cause high positive atom which lose many electrons(high positive ion or high positive electrostatic) this stan use LC circuit to make infinity voltage
how restrict amps???cause high volt is high electron move very fast cause high Power consumption(Watts)
- i dont know???????
i know just...... to make high positive side
i think diode(why stan use diode very high amps (100+amps) cause front side of diode(between diode and secondary coil) have many electron try to back positive side(after diode to positive exciter)) is the key to stop electron back positive side cause after diode still have high positive atom(positive electrostatic)when gate time(power off) and next power on it can add very very high positive continue all the time(resonant=modulate 2+ waves) and after diode is very very very high positive by resonant and diode cause high positive electrostatic.This positive side is key to elongate far enough to break bond and hydrogen have unstable state and lose electron by to very high positive side.same the oxygen attach positive side lose electron to very high positive side after that oxygen go to neutral or positive then positive side push away oxygen out.
this way to know way use thin copper wire cause High Voltage. why low current???if same power like v=12 i=1 p=12w if 12w use 20000 volts amps=0.0006 amps it never require very big copper wire.why use ss430fr??? it hard to melt than copper.i think this just 50 cent . do u think?
exam about high volt low current and low volt high current u think like car and road
high volt like super fast car /low volt is slow car
the same rule is "transport 10 cars to destination vary number of lane .how to finish the same time?"
10 fast cars use 1 lane(low amps thin wire) exam this finish in 1 hour
10 slow car use 10 lane(high amps big wire)finish in 1 hour too
electron is a car then high volt ->electron fast use thin wire/low volt ->electron slow use big wire
sorry about language i'm from Thailand
thanks all friend
geenee
