just some thoughts on stans wfc concentric tubes:
the inner and outer tubes have the resonant electrical frequency of the series inductor capacitor ( water) hitting them. So zero to max voltage on each tube ( positive on one tube/negative on the other). You want one tube to be hitting minimum voltage at same time as other tube is hitting max voltage....so synchronising the ringing inductors on each side of the wfc. So one inductor is variable to get the same resonant frequency on both sides of the wfc.....but....
Question: Is getting the same resonant frequency on both sides of the wfc enough to get the max/min voltages synchronised on each side of the tube at exact same time...?
Also just a thought : why stan had notches on some tubes:
Each inner and outer tube will have its own resonant vibrational frequency ( acoustic), hit each tube and it will ring acoustically with a certain note, like a guitar string.
The inner tube will have a different frequency to the outer tube. Stan might have been trying to give the inner and outer tubes the same acoustic resonant note.
What would be typical frequency of each tube? I have no idea...will it be in the khz range where stan had his electrical ringing frequency?
I doubt the vibrational ( acoustic ) resonant frequency has to match the electrical resonant frequency of the inductor/capacitor electrically ringing circuit. It doesn't seem to play any role in the injector wfc ( there doesn't appear to be any attempt to get the inner/outer cone shapes of the injector wfc to be matched acoustically).
I think it may have been more experimental in nature rather than something that proved to be important.
Is there any advantage , to match the acoustic resonant frequency of the wfc ( tube or injector) to the electrical resonant frequency?
My guess is its not important, if you could match those frequencies the wfc tubes should make quite a noise, the same should apply to the injectors also. Really I have no idea if its important or not, my guess is it the electrical frequencies that are important and the acoustic frequencies are irrelevant......I could be wrong.
Human hearing goes up to about 20khz which is certainly in the range where stan was pulsing, what sort of frequency do the stainless tubes of lengths stan used resonate at?
If its in the 10-20khz range then maybe there is some value in matching acoustic/electrical
frequencies?
frequencies?
