This is my own invention. it is a working model with proof of concept.
I was lucky i have Mit lecture to back up my claims.
the cost to build this less then 50 buck.
Little investigation has come from the forum, so i must give you a chance to
disprove my claims, or confirm them as described. hope you can afford the 15 dollars for the neg ion Gen, by sea wise. 7.5 kv part from electronic gold mine.
the claim, this can electrify a conductor, and allows me to scoop off the charge to do work.
the devise works all day long, accumulation of specific figures are yet to be added.
the concept take energy from an overcharged air, to a undercharged conductor.
this works on the basis of equal potential in space, and is given experiments in the lifter thread.
you can find the movies made over a year ago. follow the link to the energy motion.
it is self organizing, self discharging, and self charging, no other work needs to be done after it is set up. except use the energy for work, you can
messure the output, and if not satisfied your money back.:P
http://open-source-energy.org/?tid=107&page=2
if you need more info, see these link s. This devise was inspired by Tesla, and he had confirmed results, as a cool inflow of electrical energy to his device. that device sits on a shelf, and is owned by sharper image as the ion generator they sell. It is A Tesla work, and is related to lifters, and radiant energy device. It is his creation, well hidden from the public eye, and masked as a simple air purifier. I did the work, i study hard. the secret i give to you. It it 100% true. pours out energy all day long. do not destroy the dipole obtained for work. do not ground fully or you kill the vacume. a gap is needed in most cases.
/watch?v=4ghy-5vozLw
/watch?v=dbu59vb6Wn4&feature=c4-overview&list=UUDqettIAukxMxdTeeurxpEQ
very easy to do.what are you waiting for? free energy vacume, by freethisone. Inspired by Tesla himself, and doctor Townsen Brown.
http://tesla3.com/free_websites/zpe_bearden_FS.html from link.
The Coal-Fired Locomotive
Rigorous Analogy of a Coal-Fired Locomotive. Now here's an exact analogy, to assist in understanding. Imagine a coal-fired train, and a fireman shoveling coal. He has an external load/scatterer of energy (the fire in the firebox under the boiler). He has a primary source of potential/energy (the coal car). No fireman in his right mind would ignite the coal in the chute of the coal bin, to try and get some heat energy into the firebox! [That is, he would not attempt to extract power from the source. Yet that's exactly what all we engineers are trained to do at present.] Instead, the fireman takes out (collects) a finite amount (a shovelful) of coal (trapped energy). Coal per se (the potential gradient) has a certain energy density per unit volume (trapped joules per unit volume of coal) and the shovel (collector) has a certain volume.
Accordingly, the shovelful of coal contains a certain amount of trapped joules of energy. In the fireman's shovel (the collector), the energy remains in totally trapped form, as coal not afire and without its trapped energy being dissipated as work. [He doesn't act like a fool and ignite the coal in the shovel either!] He then throws that shovel of coal (collected trapped energy) onto the fire (scatterer), completely separately from the coal bin/source. He continues to repeat his shoveling cycle, and each shovelful of coal added to the fire dissipates additional energy, powering the load.
The Free Energy Principle
All potential gradient (trapped excess energy density) is free for the taking.23 The potential is due to the violent VPF exchange between the vacuum and the separated bipolar charges furnishing the source potential gradient. The energy of the entire universe is flowing through that source potential. You can have as much of this internal VPF flux energy (potential) as you wish, as often as you wish, so long as you don't demand current (which is power, or the rate at which the energy is being freed and dissipated). It's really simple. You can have all the trapped energy you wish, from any source. You cannot connect to the source and start to dissipate the energy as power, however, without starting to close the "gate" from which your free trapped energy is coming.
In other words, here's the iron rule: If you draw current, you kill the bipolarity gate furnishing the potential gradient (source of energy density). In that case, you kill the source. If you do not draw current, you do not kill the bipolarity gate and you do not shut down the source. In that case, you can continue to "use" it and extract trapped EM energy from it forever.
/watch?v=w60SIHwOztk
This is what you get when you have a larger surface area. a higher density charge.
it is in self oscillation. if i now touch the foil i will get a bigger shock. adding more steam behind my engine.
:heart::cool:
i say i have done what Mr Bearden has told us to do, and proved it.
/watch?v=tE6VOYZN6jA
you may test for truth.:angel:
:heart::cool:
