You guys may find this interesting reading:
http://kathodos.com/LeBonGustave.pdf
So, is Brown saying that electric field pressure and electromagnetic field pressure can be manifested into real thrust?
I once read an article about the amount of pressure that a dielectric is capable of and I've also read something about the sharp edge scenario in crystal - electro technology such as the piezo effect, when you read some of this stuff you begin to realise that we've just began to scratch the surface of electricity and its effects.
the forum community should be able to prove or disprove these claims.
my test set up suggestion for anyone willing to advance,
test setup. 1; a variable capacitor. 2; a charged surface. a ground wire.
guide line . test small surfaces by charging of a cap. use the lowest setting. now increase the size of the reflector, test the time of charge vs charging.voltages or density. i claim as the surface area increases so do the charging times, and capacity of the variable capcitor
charge divided by radius.
sigma divided by surface area.. at 3 min Walter lewin tells us we have a 5 times higher surface charge density. 5 times higher. therfore i can use the earth as a source of equa potential. Ions are a dipole source with spin, and pressure. positive charge , variable Cap. charge times reduce as voltages go up on larger and larger euqa potential surfaces. without adding more current. In fact if we had done this with a very very high negative potential, infact we would have a air conditioner with energy being drawn from vast distances.
gain in electron volts. delta v delta x. cause of additional ions.
the first real images of the free energy devise and the scientific principles that will follow.
i have another devise. and its even more spectacular from what you will see..
my ion accumulator dc transformer, has its secret in the foundation of spin. and duality...
after the principle of charging through a gap we have our capacitors that of a electric motor. these capacitor are the corner stone to unlocking what Tomas e, set forth to do. has done..
combine Tesla theory and much older writings of the same to unlocking the potential of the center of our universe..
a new wonder, plume waving, Maxwell...
the mist of the overcharged universe theory, produces in a little book... O:-)
https://www.youtube.com/watch?v=yblGWkT0RjM#
do you understand how mine works?
i am not German so i cant understand his words. :idea:
answer my question ? then we can chat about it... O:-).
if you cant answer then try to answer this..
how did the pide pipper pipe all the snakes out of Ireland?
Nope, not even sure it does work.
That would be Russian, not German.
What is your question?
First of all, it wasn't snakes, it was rats. And second, it wasn't Ireland, it was Hamelin, Germany.
And how?
Well, he used a magic pipe of course. Do you have a magic pipe? I'll bet you do, because with a magic pipe, anything is possible.
:heart:
well the whole point of me asking about the piper was to see if you can think for yourself..
i never seen any of your work.
mine is right here for 3 years. i gave the entire community that much time to disprove my claims..
i dont need to be good at ,math my bests friends both have masters in engineering.
he is helping me build the first corral castle replica. i have every missing part...
technically its already built i just need a few spare parts,
sure let me see this math stuff you have. that would be cool.
Okay, it is attached. Surely, your engineer friends would understand it.
I maybe could plow through it, but I'm not sure I would know how to use it. Item 7.4.1 seems to be the most valuable part of it.
what makes you think i don't understand it? i will pick out everything that is of importance. then prove it...
the results may surprise you.. cheers
Man, if you can read all those formulas like a book, more power to you. Maybe take a few minutes and highlight how we average folks can apply it.
