Air charge accumulator.
Re: Air charge accumulator.
« Reply #76, on September 13th, 2015, 05:29 AM »Last edited on September 13th, 2015, 05:37 AM
Quote from freethisone on August 5th, 2014, 12:07 AM
the forum community should be able to prove or disprove these claims.
my test set up suggestion for anyone willing to advance,
test setup. 1; a variable capacitor. 2; a charged surface. a ground wire.
guide line . test small surfaces by charging of a cap. use the lowest setting.  now increase the size of the reflector,   test the time of charge vs charging.voltages or density.  i claim as the surface area increases so do the charging times, and capacity of the variable capcitor
charge divided by radius.
sigma divided by surface area..  at 3 min  Walter lewin tells us we have a 5 times higher surface charge density. 5 times higher.  therfore i can use the earth as a source of equa potential. Ions are a dipole source with spin, and pressure. positive charge , variable Cap. charge times reduce as voltages go up on larger and larger euqa potential surfaces. without adding more current. In fact if we had done this with a very very high negative potential, infact we would have a air conditioner with energy being drawn from vast distances.
gain in electron volts. delta v delta x. cause of additional ions.
after years of a free energy claim no one here has tried to disprove my claims. i would think u would luv to bassh me down..
as a inventor with this lecture alone we can make generators based on charged electric fields. and the orientation in space with other charges.
a vast cold inflow of ions, the cooling of space, itself!!
i cant be live u call yourself vacume..
i give u another chance to come clean with this..  https://www.youtube.com/watch?v=Tid8AfqO87c
« Reply #79, on September 21st, 2015, 12:15 PM »Last edited on September 21st, 2015, 12:22 PM
incorporate in advancements.
this is great teaching,
https://www.youtube.com/watch?v=rk6z1vP4Eo8
i can work well on the electric fields, and i will add the new theory of our world.
the quasi sphere and the Gaussian surface explained.. or PILL BOX..
any thoughts related?
Polyhedrons
A polyhedron is a solid with flat faces
(from Greek poly- meaning "many" and -edron meaning "face").
Each face is a polygon (a flat shape with straight sides).
So: no curved surfaces!
« Reply #80, on October 8th, 2015, 04:39 AM »
Proof of concept
   This article possibly contains original research. Please improve it by verifying the claims made and adding inline citations. Statements consisting only of original research should be removed. (October 2013)
Two offshore skimmers tow an oil containment boom across the water during an oil spill and recovery "Proof of Concept" demonstration. An oil containment boom is a floating barrier, which is used to respond quickly and collect and recover offshore oil spills. The proof of concept demonstration focused on the ability of U.S. Navy and host nation assets to quickly react and respond to hazardous materials in the waterways
A proof of concept (POC) or a proof of principle is a realization of a certain method or idea to demonstrate its feasibility,[1] or a demonstration in principle, whose purpose is to verify that some concept or theory has the potential of being used. A proof of concept is usually small and may or may not be complete
The appearance of the terms in news archives suggests it might have been in common use as long ago as 1973.[2]
One of the early definitions of the term "proof of concept" was by Bruce Carsten in the context of a "proof of concept prototype" in the column "Carsten's Corner":
    Proof-of-Concept Prototype is a term that (I believe) I coined in 1984. It was used to designate a circuit constructed along lines similar to an engineering prototype, but one in which the intent was only to demonstrate the feasibility of a new circuit and/or a fabrication technique, and was not intended to be an early version of a production design.[3]
« Reply #81, on October 8th, 2015, 06:17 AM »Last edited on October 8th, 2015, 06:19 AM
There is a Secret
the first half of the movie is not informative at all.  but at the time i dropped the tube i got a shock, and also on that big metal nut at the end. very powerful oscillation or discharge.  the power took a path and that focused all that energy at that one point. when i bridged the gap.
what i say is the lateral movement of the flux path. the cylindrical difference in potential between the two objects, and how they are placed in relation to the negative charge that is over the entire conductor..
« Reply #82, on October 10th, 2015, 08:49 PM »
now i take a telsa coil.,  and i have static.
high voltage at negative dc only
 grounded to what is the earth or a water pipe.
the ground is now attracting the negative potential.
i suck it through a straw by including a gap, and a capacitor
what was now high voltage is stored, and acts a a oscillator  tuning is in fact part of the fun.
i now run this to my ac step down transformer, grounded on one end of the coil. i can now include a tesla inductor to increase capacity even further. these are the examples that i give..
how much of that energy can be manipulated by ozone, uv light rare air and so on? mili amps to high current.
that is your talk if you ever want proof of the coal car..
« Reply #83, on October 17th, 2015, 02:56 PM »Last edited on October 18th, 2015, 05:12 AM
amazing break through i can now incorporate a transformer c core, and without any capacitor create voltages in the windings with only a natural spark gap.
some secret sauce too.   a magnet...
DC directly from the 7.5 kv ion gen to AC  voltages in the coil win O:-)dings. . motionless gen. I thank you..
i am up to 50 feet of foil, and the results are stunning...
« Reply #84, on October 18th, 2015, 04:30 AM »Last edited on October 18th, 2015, 06:30 AM
thanks to a movie on pyramid magnets i solved a new puzzle. yes its true pyramidal delta at angle k,  has its minus vector delta also at angle J..
and has its gap to induce levitation..
2 angles very simple, delta deltoid..
vv cv ve core...
« Reply #85, on October 23rd, 2015, 01:17 PM »Last edited on October 23rd, 2015, 01:30 PM
i now state and conclude the tests i have done are in complete confidence as tesla describes below.
the work on a particle i claimed. the free ions as neutrino as tesla claimed. and the introduction of a cap to power a motor.
i now say for the record why has no one come forward to build these simple devices based on sound principles?
"All of my investigations seem to point to the conclusion that they are small particles, each carrying so small a charge that we are justified in calling them neutrons. They move with great velocity, exceeding that of light.
"More than 25 years ago I began my efforts to harness the cosmic rays and I can now state that I have succeeded in operating a motive device by means of them."
I was able to prevail upon Dr. Tesla to give me some idea of the principle upon which his cosmic ray motor works.
"I will tell you in the most general way," he said. "The cosmic ray ionizes the air, setting free many charges - ions and electrons. These charges are captured in a condenser which is made to discharge through the circuit of the motor.
this quote by tesla is a advance of the same principles. mechanical, stationary and rotating oscillators.I already Know how with the ed lee or ford motel T generator..
"I am just as sure that prize will be awarded to me as if I already had it in my pocket. They have got to do it. It means it will be possible to convey several thousand units of horsepower to other planets, regardless of the distance. This discovery of mine will be remembered when everything else I have done, is covered with dust."
« Reply #86, on October 23rd, 2015, 01:33 PM »
"It is of ideal simplicity," he said, "not subject to wear and can be operated at any potential, however high - even 100,000,000 volts - that can be produced. It will carry heavy currents, transform any amount of energy within practical limits and it permits easy control and regulation of the same.
"I expect that this invention, when it becomes known, will be universally adopted in preference to other form of tubes and that it will be the means of obtaining results undreamed of before.
"Among others, it will enable the production of cheap radium substitutes in any desired quantity and will be, in general, immediately more effective in the smashing of atoms and the transmutation of matter. However, this tube will not open up a way to utilize atomic or subatomic energy for power purposes."
« Reply #87, on October 23rd, 2015, 06:31 PM »
Last fact, if i go up in elevation the capacity will increase. according to Tesla in large structures building hint hint pyramids the capacity can increase as much as 50 percent per foot. ..I may as well add site work  too be completely candid.
The work to be revisited, and the means to acquire it.
known through my Belgian and British patents.
“In this system, I then explained, that, in estimating the wave-length of the electrical vibration in the transmitting and receiving circuits, due regard must be had to the velocity with which the vibration is propagated through each of the circuits, this velocity being given by the product of the wave-length and the number of vibrations per second. The rate of vibration being, however, as before stated, dependent on the capacity and inductance in each case, I obtained discordant values.
Continuing the investigation of this astonishing phenomenon I observed that the ca­pacity varied with the elevation of the conducting surface above the ground, and I soon ascertained the law of this variation. The capacity increased as the conduct­ing surface was elevated, in open space, from one-half to three-quarters of 1 per cent per foot of elevation. In buildings, however, or near large structures, this increase often amounted to 50 per cent per foot of elevation, and this alone will show to what extent many of the scientific experiments recorded in technical liter­ature are erroneous. In determining the length of the coils or conductors such as I employ in my system of wireless telegraphy, for instance, the rule which I have given is, in view of the above, important to observe.
« Reply #88, on October 29th, 2015, 12:44 PM »Last edited on October 29th, 2015, 01:03 PM
Tesla"According to the prevailing opinion, the virtue of the Franklin type of lightning rod is largely based on the property of points or sharp edges to give off electricity into the air. As shown by Coulomb, the quantity of electricity per unit area, designated by him “electrical density” increases as the radius of curvature of the surface is reduced. Subsequently it was proved, by mathematical analysis, that the accumulated charge created an outward normal force equal to to 2π times the square of the density, and experiment has demonstrated that when the latter exceeds approximately 20 C. G. S. units, a streamer or corona is formed.
In Fig. 2, 5 is a small sphere in contact so with a large one, 6, partly shown. It can be proved by the theory of electric images that when the two bodies are charged the mean density on the small one will be only π2/6 = 1.64493 times greater than that on the other, (See “Electricity and Magnetism” by Clerk Maxwell)
In Fig. 2, 5 is a small sphere in contact so with a large one, 6, partly shown. It can be proved by the theory of electric images that when the two bodies are charged the mean density on the small one will be only π2/6 = 1.64493 times greater than that on the other, (See “Electricity and Magnetism” by Clerk Maxwell). In Fig. 3, the two spheres 7 and 8 are placed some distance apart and connected through a thin wire 9. This system having been excited as before, the density on the small sphere is likely to be many time that on the large one. Since both are at the same potential it follows directly that the densities on them will be inversely as their radii of curvature. If the density of 7 be designated as d and the radius r, then the charge q = 4πr2d, the potential p = 4πrd and the outward force, normal to the surface, f = 2πd2. As before stated, when d surpasses 20 C. G. S. units, the force f becomes sufficiently intense to break down the dielectric and a streamer or corona appears. In this. case p = 80πr. Hence, with a sphere of one centimeter radius disruption would take place at a potential p = 80π=251.328 E. S. units, or 75,398.4 volts. In reality, the discharge occurs at a lower pressure as a consequence of uneven distribution on the small sphere, the density being greatest on the side turned away from the large one. "
i thought the pressure density is 5 times greater on the small conductor. but it needs to be converted in terms of proportionality. number of surfaces vs charge density, verse time change.
why is this so important, because the density can exceed 5 times by many multiples, include elevation.  he also has a thin wire.
i say it is true if i connect 1 mil volt potential to mass a and have a fine resistance at small mass b. the usable energy is massive by many times. enormous. difference in potential, this is considered an open surface, its not easy to understand, i add it simply because its true..
This relates to the building pyramidal structures with sharp points..
« Reply #89, on October 29th, 2015, 05:37 PM »
To all whom it may concern:
Be it known that I, NIKOLA TESLA, a citizen of the United States, residing at the borough of Manhattan, in the city, county, and State of New York, have invented certain new and useful Improvements in Apparatus for Transmitting Electrical Energy, of which the following is a specification, reference being had to the drawing accompanying and forming a part of the same.
In endeavoring to adapt currents or discharges of very high tension to various valuable uses, as the distribution of energy through wires from central plants to distant places of consumption, or the transmission of powerful disturbances to great distances, through the natural or non-artificial media. I have encountered difficulties in confining considerable amounts of electricity to the conductors and preventing its leakage over their supports, or its escape into the ambient air, which always takes place when the electric surface density reaches a certain value.
The intensity of the effect of a transmitting circuit with a free or elevated terminal is proportionate to the quantity of electricity displaced which is determined by the product of the capacity of the circuit, the pressure, and the frequency of the currents employed. To produce an electrical movement of the required magnitude it is desirable to charge the terminal as highly as possible, for while a great quantity of electricity may also be displaced by a large capacity charged to low pressure, there are disadvantages met with in many cases when the former is made too large. These are due to the fact that, an increase of the capacity entails a lowering of the frequency of the impulses or discharges and a diminution of the energy of vibration. This will be understood when it is borne in mind, that a circuit with a large capacity behaves us a slackspring, whereas one with a small capacity acts a stiff spring, vibrating more vigorously. Therefore, in order to attain the highest possible frequency, which for certain purposes is advantageous and, apart from that, to develop the greatest energy in such a transmitting circuit, I employ a terminal of relatively small capacity, which I charge to as high a pressure as practicable. To accomplish this result I have found it imperative to so construct the elevated conductor, that its outer surface, on which the electrical charge chiefly accumulates, has itself a large radius of curvature, or is composed of separate elements which, irrespective of their own radius of curvature, are arranged in close proximity to each so other and so, that the outside ideal surface enveloping them is of a large radius. Evidently, the smaller the radius of curvature the greater, for a given electric displacement, will be the surface-density and, consequently the lower the limiting pressure to which the terminal may he charged without electricity escaping into the air. Such a terminal secure to an insulating support entering more or less into its interior, and I likewise connect the circuit to it inside or, generally, at points where the electric density is small. This plan of constructing and supporting a highly charged conductor I have found to be of great practical importance, and it may be usefully applied in many ways.
