Motor-Generator Self-Looped with Usable Energy Left Over
haiqu
Re: Motor-Generator Self-Looped with Usable Energy Left Over
« Reply #150, on March 10th, 2014, 11:14 PM »Last edited on March 10th, 2014, 11:18 PM
Of course, the good news is that an old guy called Chas Campbell already tried to patent a self-powering motor-generator here in Australia and failed, so it's open source. And with about 25 other people around the world claiming to having invented it, I think it will safely stay that way.
« Reply #151, on March 11th, 2014, 03:34 AM »
Quote from haiqu on March 10th, 2014, 11:14 PM
Do you have some documents or a link to it?
Thanks.
haiqu
« Reply #152, on March 11th, 2014, 05:25 AM »Last edited on March 11th, 2014, 05:27 AM
Chas Campbell's machine is easy to find with a Google search. Here's one link:
https://www.youtube.com/watch?v=QB2SLmy25K4#
The list of "inventors" for this technology is on PESwiki, see QMoGen.
http://peswiki.com/index.php/QMoGen
One patent was issued to Jesse McQueen in the USA but his unit has a gearbox, and he evidently proved mathematically that it was possible. Besides, the USPTO could hardly turn away a disabled black ex-vet. :cynical:
http://peswiki.com/index.php/Directory:McQueen_Machine
I believe Campbell was the first and the others are variations and/or replications. His PESwiki entry harks from 2007. The wayback machine is your friend for verification. My internet connection is rubbish so you'll have to research it further yourself. :)
« Reply #153, on March 11th, 2014, 11:48 AM »
Ok, thanks.
I remember seeing this a while ago and I guess I'm still wondering if it's up and running in a closed loop at all?
That would be one prereq for looking a little bit more into it, atleast for me.
haiqu
« Reply #154, on March 11th, 2014, 08:58 PM »Last edited on March 11th, 2014, 09:00 PM
Well, if you believe video evidence then it is a closed looped system with excess output available to do real work. I don't entirely understand how this works, but I'm certainly curious enough to try it.
BTW I don't regard closing the loop as any special evidence of a working over-unity system. My reasoning follows the comments made by Puthoff when he first announced the 1 watt challenge: sometimes the output energy is in an incompatible state. Closing the loop would remove all doubt but is only the cherry on the cake.
haiqu
« Reply #155, on March 11th, 2014, 10:51 PM »Last edited on March 11th, 2014, 11:17 PM
Just delved a little further down the rabbit hole on this device. It seems a Joseph Bitsadze (Tblisi, Georgia) made a patent application for something similar in 1998. I still haven't found it, but as I said my internet connection is rubbish. I did find this however:
http://contest.techbriefs.com/2011/entries/machinery-and-equipment/1653
His name is sometimes confusingly listed on the web as Joseph Byzehr but the "byzehr" is actually part of his email address.
Here's some theoretical stuff on superfluous energy of spinning masses:
http://technogeo.ucoz.com/load/the_latent_weight_result_of_a_spin_of_a_massive_body_and_a_sourse_of_superfluous_energy/1-1-0-1
I still have no idea how the systems that couple a motor directly to a generator work without the flywheel though.
geenee
« Reply #158, on March 12th, 2014, 12:17 AM »Last edited on March 12th, 2014, 12:28 AM
Quote from haiqu on March 11th, 2014, 10:51 PM
you 're right!!! FLYWHEEL!!! nothing more.
GOV WANT STOP FREE ENERGY!!!BANK WANT STOP FREE ENERGY!!!
https://www.youtube.com/watch?v=FmXBebQzMyQ#ws
« Reply #159, on March 12th, 2014, 06:49 AM »
Quote from geenee on March 12th, 2014, 12:17 AM
Better watch it again geenee.  The old guy is saying it doesn't work, will never loop and is asking the question why?
Seems as if the flywheel is completely useless and does nothing to help in the sense of mechanical advantage.  Gearing alone will not produce free energy.  So there is more to it obviously.  My instincts tell me it all has to do with impulses.  You strike a system with impulse X and nature has to apply energy equal to X + Y to get the system back into balance.  That's where you get your free energy.
« Reply #160, on March 12th, 2014, 07:43 AM »
Quote from haiqu on March 11th, 2014, 08:58 PM
If by closing the loop means that your machine, whatever it is, is working regardless of where you place it on this small planet, then that would be proof beyond any shadow of a doubt of a totally free energy producing system, with no strings attached whatsoever.
But that's just my 2C.
I'd be happy if it worked here.
« Reply #162, on March 12th, 2014, 03:44 PM »Last edited on March 12th, 2014, 04:12 PM
Quote from geenee on March 12th, 2014, 09:39 AM
his work is very exciting.but don't work because generator must run faster than prime mover 2x rpm when no load attacted.(reference from Chas Campbell)
example generator need 60hz=3600rpm,then he must run generator at 5000-7200rpm.
He has way more poles in his generator than he does in his motor so his generator doesn't need to spin nearly so fast to still get the proper AC frequency out.
On my setup though, it is exactly what you say, 2x.  My motor runs at 1800 rpm and the generator needs 3600 rpm.  To get this, I geared -up by a factor of two.  The problem I see though is that it takes quite a bit of torque just to overcome the exciter array in the generator and when you double that with gearing, the motor has to work really hard.  Too hard in my case.  The motor actually starts to get hot and is never able to fully turn the generator at 3600 rpm.
Everything that I was reading indicated that you actually want to run faster at the motor and slower (more poles) at the generator side, so that you have the mechanical advantage of the gearing.  If my setup was opposite to the way it is now, then my motor could run at 3600 rpm and gear down to the generator at 1800 rpm.  Then I think I could actually spin the generator without putting a really heavy load on the motor.
If you think of speed/velocity as voltage and torque as amperage, then the gearing acts like a step-up/step-down transformer, converting what you have into what you want.  Think of the term:  Lever.
« Reply #163, on March 12th, 2014, 04:01 PM »Last edited on March 12th, 2014, 04:04 PM
I think the statements made in your link are quite valid geenee.
There must be:
1. Continuous external input of Force/energy, which can be any suitable form: I.e.: electricity.
2. A Prime mover or movers capable of maintaining system Velocity.
3. Solid Matter being moved by Prime mover(s) and developing Kinetic energy exceeding the input energy per second,
4. A Mechanical method and means to extract, convert and transfer Kinetic energy between solid matter objects as high pressure Mechanical energy  pulses to develop/introduce non equilibrium into a system of inherent equilibrium,
5. A Mechanical means to split Time between Kinetic energy development, extraction and transfer of the high pressure Mechanical energy pulses,
6. A greater volume of matter in motion absorbing/receiving the Mechanical energy pulses at a Mechanical advantage, developing additional Kinetic energy and driving an electrical alternator/generator continuously.
7. And of course your ability to understand the one thing Generators/alternators require to function; continuous HORSEPOWER per second.
Notice the author mentions, "pulses" and "non-equilibrium".  Those are key--too much evidence exists to disprove it.  I use the terms:  Impulse and Asymmetry.  You develop a system with those two factors done correctly and you will have free energy.
haiqu
« Reply #164, on March 12th, 2014, 07:23 PM »Last edited on March 12th, 2014, 07:29 PM
Quote from Lynx on March 12th, 2014, 07:43 AM
Lynx,
"Closing the loop" refers to powering a device from its own output. I thought everyone knew that. Where it works geographically should never be an issue, as long as the input source is available.
As an instance of what I was talking about back up the thread, a device might use magnetic fields to produce heat. Well, you can't close that loop easily, and yet it could still be OU. But if there's no magnetic field it won't work. Got it?
geenee
« Reply #165, on March 12th, 2014, 07:41 PM »Last edited on March 12th, 2014, 07:47 PM
from the link i posted,i get it from comments of the old guy(youtube, very big flywheel).Matt Watts,i don't think all information is correct but maybe have somethings useful.he said generator need enough Horse Power to run a generator.by adding fly wheel that can make more HP but speed will be slower,this way that need pulleys or gear to speed up to enough rpm(generator need) or above rpm.HP is Force per Second,when fly wheel run at high speed that mean more HP.
modified race motor bike in Thailand use this concept to improve HP,by adding weight to flywheel and change gear ratio.speed will be greater without changing about engine.
about you thought that maybe possible too, make asymmetry.like pulse motor that has very low power consumption,ex Kepp motor.
haiqu
« Reply #167, on March 12th, 2014, 08:22 PM »
Quote from Matt Watts on February 12th, 2014, 09:49 PM
More info on the BlackBox Power Station:
They are naming this particular unit the BlackBox Dominator.  Supposedly the motor/generator combination allows for faster charging, but again, it is not close-looped.  So...  Back to the drawing board everyone, doesn't look like Doug Myers has what we originally thought.  I'm sure the free advertising helped his sales some though, that's what counts right?  Somebody making a buck instead of changing the world.
You get that a lot in the alternative energy field. Initial claims of over unity, then the product comes out and it's just a marginal improvement over previous methods.
The PESwiki QMoGen list is supposed to be full of self-looping over unity devices. There's even some guy in Nigeria who claims to have done it. How hard could it be to replicate?
If the flywheel is necessary at all, it will be to store energy that's provided to the motor, to pulse the generator past its next step of physical resistance. That's mad. Bedini has proven for years you don't need physical resistance to create electricity. It's using a dinosaur (standard generator) to do a job that can be done much more elegantly with something more modern.
If it works then one has to wonder why the electrical supply authorities don't utilize it already.
As you rightly pointed out, no amount of belts or gearing will create more power. More momentum or torque, yes. But lossess from mechanical friction are just being added along the way here. And if it could work through some mechanism undiscovered then there are much better ways of utilizing whatever effect is causing it.
« Reply #168, on March 13th, 2014, 03:06 AM »
Quote from haiqu on March 12th, 2014, 07:23 PM
Lynx,
I know what closing the loop means.
If the magnetic device you're referring to is impossible to loop then it's not much of a working device, is it?
haiqu
« Reply #169, on March 13th, 2014, 07:26 AM »Last edited on March 13th, 2014, 07:51 AM
Quote from Lynx on March 13th, 2014, 03:06 AM
I can't believe I'm reading this from a Moderator.
Closing the loop is not the only proof of over unity. That's a skeptic's argument, and it's patently false. In the example I gave, if heat is the desired output then the device is useful. But converting heat back to a magnetic field isn't something I've seen anywhere. It may be possible, I just don't know about it. But I also grant that it's not a great example, since flux density and temperature are incompatible units anyhow. It would be difficult to evaluate whether over unity is present.
Let's take the work of Bedini as a better example. He can charge batteries with pulses, and those batteries can observably provide real power, enough to light large banks of lamps. And yet the pulses can't be directed back to the battery used to run the device as it's operating, because that stops it from working. He can, however, swap the device's battery for one that has been charged and continue to run the device.
So, he uses one battery for several hours to charge many others. That's over unity. There's a net gain in the number of charged batteries. It is also geographically portable, fulfilling your requirement. The power gained can be measured as the number of usable amp-hours gained in the charged batteries, less the amp-hours provided by the machine's battery to charge them.
This is really basic stuff. If you don't understand that I have to wonder what you're doing here.
Now, as to why we consider Bedini's battery charger over unity. Conventional electrical engineering regards the charging process as inherently lossy. They say we have to pump electrons back into the battery by force in order to recharge them, and that this process is less than 100% efficient (typically more like 80%). So, maybe Bedini has just invented a more efficient way to charge a battery, but it's still better than the currently acceptable method  by a large margin.
"Any sufficiently advanced technology is indistinguishable from magic." - Arthur C. Clarke
« Reply #170, on March 13th, 2014, 07:38 AM »
Quote from haiqu on March 13th, 2014, 07:26 AM
I really don't care how ever much you try to disregard the fact of closing the loop on just about any build is necessary in order for it to become self sustainable, anything else is just not working as advertised unless you can put portions of the energy back to the original power source and thereby have the build at hand powering itself in a closed loop, with no outer strings attached whatsoever, while leaving useful energy over to do work elsewhere, whatever you have it.
Btw, me being a moderator here doesn't have anything to do with me being able to express my personal opinion here, they're my opinions and they don't reflect the mindset of the rest of the staff.
haiqu
« Reply #171, on March 13th, 2014, 08:01 AM »Last edited on March 13th, 2014, 08:04 AM
Quote from Lynx on March 13th, 2014, 07:38 AM
Sorry Lynx, that's patent BS. I just gave you a perfect example of a self-sustained system. The only difference is that it isn't instantaneous, which is what you seem to be demanding.
By your definition a hydroelectric scheme isn't self-sustained either.
It does, however, reflect on their judgement.
« Reply #172, on March 13th, 2014, 08:02 AM »
Quote from haiqu on March 13th, 2014, 08:01 AM
By your definition a hydroelectric shceme isn't self-sustained either.
Whatever, you got your opinion, I got mine.
What do you mean?
« Reply #173, on April 1st, 2014, 07:18 PM »
So here it is if you believe it:
Quote from Energy Times Newsletter
Paul Babcock and Jim Murray are going to be presenting the concepts of using reactive power as energy. If you're not sure what that means, imagine drawing a load from an AC generator without the generator seeing a load! That is oversimplified, but it is one of the most guarded secrets and is something Tesla talked about but almost nobody has ever understood it. If this was the one and only presentation at the conference, it would be worth coming just to learn about this.
Seats are still available:
http://energyscienceconference.com/
« Reply #174, on May 5th, 2014, 05:15 PM »Last edited on May 5th, 2014, 07:18 PM
Did I just not look far enough?
https://www.youtube.com/watch?v=aDjWwoD83Rk#
Jim demos his electronic unit, but states at the beginning that timing can also be controlled mechanically with what appears to be a QoMoGen device sitting on the other table.
Many years ago I knew an old guy that was always saying, "Timing is everything."  I suspect the old guy was right, but I have to wonder how we could swap between voltage and amperage at the correct intervals to utilize reactive power.  To me it seems like there should be a straightforward way to borrow voltage when the amperage is high to produce wattage, then again borrow amperage when the voltage is high to also produce wattage.  Maybe only one or the other is possible, but the idea all revolves around timing--you shift in what you need at times when you wouldn't normally have it and in doing so, you create power that can do useful work.  Conceptually, it just doesn't seem that difficult.  Think about this...
We can charge a capacitor very fast with high amperage, but at the time we have high amperage, we have low voltage.  So lets charge the caps in parallel when voltage is low and current is high, then cross connect the capacitors all in series to create fairly high current potential as well as increase the voltage potential.
How about the other side?  We can make a strong magnetic field in an inductor when the voltage is high and the amperage is low.  So here lets do the same as we did with the capacitors.  Lets "charge" them in parallel when voltage is high and amperage is low, then switch them from being in parallel to series to drive our load.
Now remember here, our source power is reactive--voltage and amperage are 90 degrees out of phase.  So at each quadrant of the AC power source, we have two angles to charge inductors and two other angles to charge capacitors.  And when these devices are not charging, they are discharging into our load.
Now I'm sure I don't have this 100% correct or any of the engineering details described, but is the concept sound?  Could this work?
