LIFTER TECHNOLOGY
INVENTOR3
LIFTER TECHNOLOGY
« on August 2nd, 2011, 04:18 AM »
Hello.  I hve not posted here in a long time.
I will be attempting to make a small lifter.  I found a power supply on ebay here...
http://cgi.ebay.com/100kV-DC-high-voltage-power-supply-tesla-coil-/310335437454?pt=LH_DefaultDomain_0&hash=item48416efa8e
and im waiting for some high voltage, fast recovery diodes.
I hope this works.  I have not studied that far into lifters yet. I know little about them. How do they work??  I know they work with ion wind.  But does it just work off of Pulsed DC  or....? What are the main properties that i need to apply to make it lift?
RE: LIFTER TECHNOLOGY
« Reply #1, on August 2nd, 2011, 08:07 AM »
Quote from INVENTOR3 on August 2nd, 2011, 04:18 AM
From what I remember the ion wind wasn't the main source of propulsion.  Mythbusters tried to prove that it is ion wind by running a lifter in a vacuum, but who can trust Hollywood?
This is from page 367 of the book "Secrets of Antigravity Propulsion" by Paul A. LaViolette, Ph.D.:
"Although ions are important in producing the lifters thrust, its thrust is not due to ion wind effects, that is, forces arising from the recoil or impact of ions on the electrodes.  Such mechanical forces have been shown to fall short by several orders of magnitude in accounting for the observed lift." ....................... "Rather the thrust is most likely attributable to the unbalanced electrostatic forces."
I would recommend getting the book, it is very interesting.  I haven't finished reading it yet, but it covers pretty much every type of antigravity device out there.  The part about the Air Force's stealth bomber is really interesting.
INVENTOR3
« Reply #2, on August 3rd, 2011, 03:51 AM »
Quote from firepinto on August 2nd, 2011, 08:07 AM
Thanks for the book title, i will check it out.
i saw the myth buster video,,where it would not operate in a vacuum, but then i see an old video of NASA operating a lifter "in" a vacuum!
Unbalanced electrostatic forces between the electrodes,,,,would this be the Biefeld-Brown effect?
« Reply #3, on August 4th, 2011, 09:06 PM »
Quote from INVENTOR3 on August 3rd, 2011, 03:51 AM
That would be correct!  :cool:
« Reply #4, on September 3rd, 2011, 02:30 PM »Last edited on November 28th, 2011, 12:01 PM by freethisone
The writing on the wall has changed.  :blush:  :angel:  :cool:
Greetings inventor, and All.  I am happy to see many interested people. Paul I am so glad you made this post. It has been an interest to me for most of my life. Anti gravity, free energy. Today we are traveling so fast, time may have stood still at the crest just long enough for us to catch up to this opposition. This post takes old theory, brings it to light, and transforms it to a new understanding. A time variation, vulnerable to negative potentials. Electric charge, its natural essence, or function. A relation, cold electrical character. Superconductivity. This equilibrium between the long standing two aether field theory can be verified. I have take into account the teachings of Tomas Bearden, Nicola Tesla, and Dr Townsend brown the experimenter. We are held by account. I have found many off shoots of this technology. The ionic breeze machine by sharper image for one. This circuit was founded by Tesla himself. It was explained in his scientific research. very non intuitive.
What is the electric potential? What accounts for the medium? There is a positive, and negative co habitation of energy. The birth place of lifter technology, and anti gravity. The inevitable ability to travel through time..
I have two negative ion generators very low cost. The experiments with neg ION wind, or negative charges, are used to determine the cooling of empty space. In locality near the points of the emitters, it must be directly proportional, whereby the energy will fall off over distance. Inverse square rule.
After observing the effects of the ion wind on the surroundings, I come up with one interesting phenomena that i want to point out. This is the bi field brown effect vs. the ion wind. looking into the inner workings of this interesting effect, I found that neg ions seem to attract particles near, or around the source of ion emitters. These are 4 sharp points creating the negative energy. I had discovered the wall near these points sucked the smoke particles. Now that describes how Tesla's machine worked. By placing a metal conductor behind the emitters, you can cause the entire surface to attract particles.  Particles stick  near the emitters, and on the wall by the negative charge. That is how the breeze machine works. They are identical, and compared.
These sharp points be a negative potential, or charge. One half of the bifield described, or electric medium. Negativity attracts the positive potential.
like a static vacuum from the source, or a difference of the potential determined by how much charge is already present on any conductor..
The source of energy is the difference in potential. (type of charges) You create a negative type charge. This negative potential is desired. There is a high saturation of positive ions in the atmosphere.  This I have determined. (Positive electric field)
There is indeed Asymmetry, a variable changing relation. High, and low pressure is relativity.
I'm going in the direction, opposite to main stream determinations.  Clearly something is renaming, I test if this is true. Experiment. What if
the big bang with all that heat, some three degrees above absolute zero was not a result of some explosion? That heat may not  be result of the bang.
Has the mass cooled empty space? Does space continue to get colder? We know whenever a galaxy is formed, it must be either a positive, or negative potential in its relation to the electric field. As a whole the galaxy is a positive potential, but just like high, and low pressure were the clouds move in the direction of positive to negative. The negative attraction tends to cool local space, and possibly beyond.
 Check this to see if that's correct, This is only a prediction. May, or may not be true.
My ruff draft.  Tesla has clearly taken us to light speed, and you will have your lift off. Tongue
The first day of experiments, expanding on theory, and information provided.
I experimented with one of my neg. ion generator today. I discovered  a marvelous effect, and continue to observe.
First the emitter runs from non grounded 110 volt ac source. -7.5 kv.
Model no sw750 from electronic gold mine .com made by sea-wise ind ltd.
This is what I did. Plugged in the emitter. Placed the points well insulate from ground, so none of the static charge is dissipated to ground.
Now I introduce a variable. I place close to within about an inch or less the emitters. I  have a large stainless steel bowl. This was also well insulated from ground, to keep the negative static charge on the conductor..
You would think the bowl would act as a lay-den jar holding charge on its surface. This is true in my test setup. If I touch the bowl it has a strong spark.
About 10 to 15 kilo-volts. Same type of spark as if you had  run across a carpet. I could discharge at variable time periods, or  frequency.
Charging a capacitor would be easy work. I verified this to be correct.  Inside the bowl was also found to be charge.
Now for the second half of the experiment. I  take in hand a brass rod. It was about 8 inches long half inch diameter. Not important as this point, but will lead to more experiments with brass.
I bring the rod in-contact with the bowl, its sparks as expected, and I can cause a  high frequency of discharge.
wile working with time im trying to see if i could get a spark to jump about a centimeter from the rod with no luck.
I said perhaps after a long period of time it would be observed? For now I touch the brass rod, and there is another spark.
Energy clearly likes to flow to ground, so I acquired a higher frequency of discharge. A result of observation.
If i do not cause ground, there is no observable spark from bowl to brass rod. The rod is still  about one centimeter of gap.
If i shorten the gap a spark will jump from bowl to rod. As it stands now the rod is only close to the bowl, and well insulated from ground.
Of course these are well established principles in the electric field by all who have made conclusions. This an inductive force. Even glass is able to influence its nature, not well understood.(dielectrics)
Conclusion of first tests: a low powered emitter is capable of a continuous spark upon said objects that conduct. Within the influence of static source, electric field. Brass may be influenced to a higher degree. Special structure, copper zinc. The ability to conduct electricity, possibly to a higher degree the density of charge? More testing, more observation.
Some more interesting findings. first brass, it is a mixture of 30 percent zinc, 70 percent copper. There is a chemical type affiliation between the zinc and copper. You may make a voltaic pile. There is alot of information provided in the audio book I linked.
The audio book confirmed this through experiment, and research.
Since one bowl can take on a charge, so can a second, and a third. Any number of bowls placed near the main bowl will act like a conductor, of the same type charge described.. Energy is therefore multiplied, because each bowl now acts as a laden jar. Mass=Energy will the charge be the same on all the bowls? Yes its very close to equilibrium. The law of the inverse square rule applies here. The  energy will fall off at greater distance, no longer under the influence of the same.
Cheers everybody..
More later, I will need to fix all my mistakes.
« Reply #5, on September 6th, 2011, 06:30 PM »Last edited on November 29th, 2011, 11:11 AM by freethisone
scheduled for change, corrections are key..
:angel:
for better words,    Classic audio book.   :heart:
Special observation continued. Verifying factor experimental research.
I had the bowl, and the rod about one centimeter apart. Thinking charge would continue to increase. It would not, I was continuing to observe the emitter interaction with the brass rod, I made a startling discovery.
I was in the mood to open the windows and look out at the rain, I created a cross ventilation of outdoor air through the room. You wont believe this but it was found to be ionized in every way. The energy out put on the conductors did go up substantially in this case. Then again there was a spark of greater magnitude then before. The cross flow of ionized air had its effects. The out door air quickly caused the spark to quickly discharge. The discharge was continual. I could definitely smell ozone in the air. My conclusion: Free energy created by the presents of positively charged ions in the air. It was verifying, clear as day, there must be a substantial amount of ionization of our atmosphere. Radiations from Fucashima nuclear disaster, and the increase of radar energy devises have its roll. The amazing thing is that the amount of positive ions available is tremendous.
I quickly closed window, and door, the spark had quickly stopped. stopped. The interaction, and the difference in two static energy's together conduct, "as if a cloud finding its way to my laden jars of negative potential." Equal and opposite forces. Therefore by increasing the neg. potential I could get anti gravity, as described. The cloud is now giving a thrust. The positive potential is high, because the negative potential is also very high.
Wink
add initial theory..https://www.youtube.com/watch?v=0qEhm4llEpE
Dear Paul what does this mean? It means you can set your vandergraph generator as a negative potential.  Introduce conductors as to be charged as laden jars. Place the machine out doors if needed, and it will quickly multiply the out put of the generator, and the charge on all the laden jars. :D
I would discharge though a Tesla primary, and secondary coil setup. Even bifillar wound plus 2-4 pathways even better.
This is leading to more conclusive observations. I will continue to report on this success.  :cool:
« Reply #6, on September 8th, 2011, 01:12 PM »Last edited on November 29th, 2011, 10:15 PM by freethisone
:cool:from wiki solution = Ions in their gas-like state are highly reactive, and do not occur in large amounts on Earth, except in flames, lightning, electrical sparks, and other plasmas.Electronegativity
This electrostatic potential map shows how the oxygen atom has a more negative charge than the hydrogen atoms.
Electronegativity, symbol χ (the Greek letter chi), is a chemical property that describes the tendency of an atom or a functional group to attract electrons (or electron density) towards itself and thus the tendency to form negative ions.[1] An atom's electronegativity is affected by both its atomic number and the distance that its valence electrons reside from the charged nucleus. The higher the associated electronegativity number, the more an element or compound attracts electrons towards it. First proposed by Linus Pauling in 1932 as a development of valence bond theory,[2]
An anion (-) (pronounced /ˈæn.aɪ.ən/ an-eye-ən), from the Greek word ἄνω (ánō), meaning "up", is an ion with more electrons than protons, giving it a net negative charge (since electrons are negatively charged and protons are positively charged).
Conversely, a cation (+) (pronounced /ˈkæt.aɪ.ən/ kat-eye-ən), from the Greek word κατά (katá), meaning "down", is an ion with fewer electrons than protons, giving it a positive charge. Since the charge on a proton is equal in magnitude to the charge on an electron, the net charge on an ion is equal to the number of protons in the ion minus the number of electrons.
[edit] General
[edit] History and discovery
Etymologically the word ion is the Greek ιον (going), the present participle of ιεναι, ienai, "to go". This term was introduced by English physicist and chemist Michael Faraday in 1834 for the (then unknown) species that goes from one electrode to the other through an aqueous medium.[1][2] Faraday did not know the nature of these species, but he knew that since metals dissolved into and entered solution at one electrode, and new metal came forth from solution at the other electrode, that some kind of substance moved through the solution in a current, conveying matter from one place to the other.
Faraday also introduced the words anion for a negatively charged ion, and cation a for positively charged one. In Faraday's nomenclature, cations were named because they were attracted to the cathode in a galvanic device and anions were named due to their attraction to the anode.
[edit] Characteristics
Ions in their gas-like state are highly reactive, and do not occur in large amounts on Earth, except in flames, lightning, electrical sparks, and other plasmas. These gas-like ions rapidly interact with ions of opposite charge to give neutral molecules or ionic salts. Ions are also produced in the liquid or solid state when salts interact with solvents (for example, water) to produce "solvated ions," which are more stable, for reasons involving a combination of energy and entropy changes as the ions move away from each other to interact with the liquid. These stabilized species are more commonly found in the environment at low temperatures. A common example is the ions present in seawater, which are derived from the dissolved salts there.
All ions are charged, which means that like all charged objects they are:
    attracted to opposite electric charges (positive to negative, and vice versa),
    repelled by like charges, and
    when moving, travel in trajectories that are deflected by a magnetic field.
Electrons, due to their smaller mass and thus larger space-filling properties as matter waves, determine the size of atoms and molecules that possess any electrons at all. Thus, anions (negatively charged ions) are larger than the parent molecule or atom, as the excess electron(s) repel each other, and add to the physical size of the ion, because its size is determined by its electron cloud. Conversely, cations are generally smaller than the corresponding parent atom or molecule, for the same reason. One particular cation (that of hydrogen) contains no electrons, and thus is very much smaller than the parent hydrogen atom.
"h2opower Wrote:  This post is for the Gas Processor science in understanding how it works.
    Quote:Mechanism
    Negative coronas are more complex than positive coronas in construction. As with positive coronas, the establishing of a corona begins with an exogenous ionization event generating a primary electron, followed by an electron avalanche.
    Electrons ionized from the neutral gas are not useful in sustaining the negative corona process by generating secondary electrons for further avalanches, as the general movement of electrons in a negative corona is outward from the curved electrode. For negative corona, instead, the dominant process generating secondary electrons is the photoelectric effect, from the surface of the electrode itself. The work-function of the electrons (the energy required to liberate the electrons from the surface) is considerably lower than the ionization energy of air at standard temperatures and pressures, making it a more liberal source of secondary electrons under these conditions. Again, the source of energy for the electron-liberation is a high-energy photon from an atom within the plasma body relaxing after excitation from an earlier collision. The use of ionized neutral gas as a source of ionization is further diminished in a negative corona by the high-concentration of positive ions clustering around the curved electrode.
    Under other conditions, the collision of the positive species with the curved electrode can also cause electron liberation.
    The difference, then, between positive and negative coronas, in the matter of the generation of secondary electron avalanches, is that in a positive corona they are generated by the gas surrounding the plasma region, the new secondary electrons traveling inward, whereas in a negative corona they are generated by the curved electrode itself, the new secondary electrons traveling outward.
    A further feature of the structure of negative coronas is that as the electrons drift outwards, they encounter neutral molecules and, with electronegative molecules (such as oxygen and water vapor), combine to produce negative ions. These negative ions are then attracted to the positive uncurved electrode, completing the 'circuit'.A negative corona can be divided into three radial areas, around the sharp electrode. In the inner area, high-energy electrons inelastically collide with neutral atoms and cause avalanches, whilst outer electrons (usually of a lower energy) combine with neutral atoms to produce negative ions. In the intermediate region, electrons combine to form negative ions, but typically have insufficient energy to cause avalanche ionization, but remain part of a plasma owing to the different polarities of the species present, and the ability to partake in characteristic plasma reactions. In the outer region, only a flow of negative ions and, to a lesser and radially-decreasing extent, free electrons toward the positive electrode takes place. The inner two regions are known as the corona plasma. The inner region is an ionizing plasma, the middle a non-ionizing plasma. The outer region is known as the unipolar region.
Take care everyone,
h2opower"   thanks h2 good stuff.
« Reply #7, on September 9th, 2011, 10:33 PM »Last edited on September 9th, 2011, 10:36 PM by freethisone
wow, another interesting effect of the neg ion potential on the stainless steel bowl. it was found that if i light a lighter near the  bowl the flame would bend in the direction of the bowl, even if i tilt the lighter on its side, the flame also gets sucked into the negative potential. does heat from a flame contain positive ions too? at the lip of the bowl the effect is greatest. something err negative ions / electrons cause the flame to attract near the sharpest edge of the bowl. wow cool. :cool:
INVENTOR3
« Reply #8, on September 13th, 2011, 04:25 AM »
I will repond to this post very soon, sorry about the late reply
Quote from freethisone on September 9th, 2011, 10:33 PM
« Reply #9, on September 13th, 2011, 10:47 AM »Last edited on September 25th, 2011, 12:02 PM by freethisone
Quote from INVENTOR3 on September 13th, 2011, 04:25 AM
Dear Paul.
Big strides we made, the pieces all fit together.:cool: "plume waveing Maxwell"
Thanks to Faraday. Tesla, Brown, and so many more.Audio Book here.
enjoy the reading.
The Free Energy Principle by Tomas Bearden
All potential gradient (trapped excess energy density) is free for the taking.23 The potential is due to the violent VPF exchange between the vacuum and the separated bipolar charges furnishing the source potential gradient. The energy of the entire universe is flowing through that source potential. You can have as much of this internal VPF flux energy (potential) as you wish, as often as you wish, so long as you don't demand current (which is power, or the rate at which the energy is being freed and dissipated). It's really simple. You can have all the trapped energy you wish, from any source. You cannot connect to the source and start to dissipate the energy as power, however, without starting to close the "gate" from which your free trapped energy is coming.
In other words, here's the iron rule: If you draw current, you kill the bipolarity gate furnishing the potential gradient (source of energy density). In that case, you kill the source. If you do not draw current, you do not kill the bipolarity gate and you do not shut down the source. In that case, you can continue to "use" it and extract trapped EM energy from it forever.
Definitions Again
Definitions: I'll put down some simple equations, that may help to explain it more exactly. First we repeat some definitions.
Energy is any ordering imposed upon the virtual particle flux of vacuum. EM energy is any ordering imposed upon the virtual photon flux of vacuum. Static energy is an ordering (a template) which is stationary with respect to the external observer. Dynamic energy is an ordering (a template) which is not stationary with respect to the external observer.
Potential: Any ordering imposed upon the virtual particle flux of vacuum. Scalar potential is an ordering (template) that is not moving with respect to the external observer. Vector potential is an ordering (template) that is moving with respect to the external observer.
The scalar EM potential is any static (with respect to the external observer) ordering imposed upon the virtual photon flux of vacuum. Etc.
Note again that energy and potential have exactly the same definition. Potential is in fact trapped energy. Scalar EM potential is static EM energy (to the external observer) or trapped (collected) EM energy. In other words, if one takes off a differential of potential onto a fixed number of coulombs, one takes off a certain magnitude of trapped EM energy. In other words, one takes out a shovelful of coal from the coal car.
Importance of Separation of Charges
We Must Not Dispel the Separation of Charges In Our Source: The difference in our coal-fired train analogy and our electrical circuit is that, in the coal train, the coal in the coal car is not automatically and continually replenished. Also, the coal in the coal car has already been collected by the mass of the coal car, so it is not infinite. In the electrical circuit, the potential gradient in the primary source is continually replenished, automatically, and it is infinite (though it has a finite energy density). The reason is simple. EM potential (in the normal sense) is actually a virtual photon flux exchange between the vacuum (the entire vacuum, all over the universe) and a charged particle or collection of charged particles.24 Thus the potential (gradient) is a powerful energy flux, pumped by the vacuum and the entire universe, that continues automatically, so long as we do not allow the collected charges in our bipolarity source to be dissipated. In terms of a battery, we achieved separation of charges inside the battery by chemical action, and we paid for that initially. Once separated, the charges essentially stay separated (because of the chemistry) unless we foolishly do something to dissipate them, such as upsetting the chemistry, so they are no longer separated positive from negative. So if we don't do anything to these separated charges, they continue to be driven by their fierce exchange of virtual photon flux with the vacuum/universe. If we then simply extract some of that flux exchange, without moving the charges, we are directly "gating" trapped EM energy from the vacuum/charged particle VPF exchange.25
The Potential Is Infinite And So Is Its Energy Content
The formation of an ionic bond proceeds when the cation, whose ionization energy is low, releases some of its electrons to achieve a stable electron configuration. The anion, whose electron affinity is positive, then accepts the electrons, again to attain a stable electron configuration. Typically, the stable electron configuration is one of the noble gases for elements in the s-block and the p-block, and particular stable electron configurations for d-block and f-block elements. The electrostatic attraction between these two entities forms the ionic bond.
For example, common table salt is sodium chloride. When sodium (Na) and chlorine (Cl) are combined, the sodium atoms each lose an electron, forming cations (Na+), and the chlorine atoms each gain an electron to form anions (Cl−). These ions are then attracted to each other in a 1:1 ratio to form sodium chloride (NaCl).
    Na + Cl → Na+ + Cl− → NaCl
Representation of ionic bonding between lithium and fluorine to form lithium fluoride. Lithium has a low ionization energy and readily gives up its lone valence electron to the fluorine atom, which has a positive electron affinity and accepts the electron that was donated by the lithium atom. The end result is that lithium is isoelectronic with helium and fluorine is isoelectronic with neon. Electrostatic interaction between the two atoms forms an ionic bond.
The removal of electrons from the cation is endothermic, raising the system's overall energy. There may also be energy changes associated with breaking of existing bonds or the addition of more than one electron to form anions. However, the action of the anion accepting the cation's valence electrons and the subsequent attraction of the ions to each other releases energy and thus lowers the overall energy of the system.
Ionic bonding will occur only if the overall energy change for the reaction is favourable – when the reaction is exothermic. The larger the resulting energy change, the stronger the bond. The low electronegativity of metals and high electronegativity of non-metals means that the reaction is most favourable between a metal and a non-metal.
« Reply #10, on September 15th, 2011, 06:37 PM »Last edited on September 26th, 2011, 03:41 PM by freethisone
electron negativity Sharp points by you know who.. more supporting information a rare find. i will be makeing a tesla patent page because i can add all the text. no pictures sorry.
UNITED STATES PATENT OFFICE.
NIKOLA TESLA, OF NEW YORK, N. Y.
TESLA PATENT 1,266,175 LIGHTNING-PROTECTOR.
1,266,175.    Specification of Letters Patent.    Patented May 14, 1918.
Application filed May 6, 1916.   Serial No. 95,830.
To all whom it may concern:
Be it known that I, NIKOLA TESLA, a citizen of the United States, residing at New York, in the county and State of New York, have invented certain new and useful Improvements in Lightning-Protectors, of which the following is a full, clear, and exact description.
The object of the present invention is to provide lightning protectors of a novel and improved design strictly in conformity with the true character of the phenomenon, more efficient in action, and far more dependable in safe-guarding life and property, than those heretofore employed.
To an understanding of the nature of my invention and its basic distinction from the lightning rods of common use, it is necessary briefly to explain the principles upon which my protector is designed as contrasted with those underlying the now-prevailing type of lightning rod.
Since the introduction of the lightning rod by Benjamin Franklin in the latter part of the eighteenth century, its adoption as a means of protection against destructive atmospheric discharges has been practically universal. Its efficiency, to a certain degree, has been unquestionably established through statistical records but there is generally prevalent, nevertheless, a singular theoretical fallacy as to its operation, and its construction is radically defective in one feature, namely its typical pointed terminal. In my lightning protector I avoid points, and use an entirely different type of terminal.
According to the prevailing opinion, the virtue of the Franklin type of lightning rod is largely based on the property of points or sharp edges to give off electricity into the air. As shown by Coulomb, the quantity of electricity per unit area, designated by him “electrical density” increases as the radius of curvature of the surface is reduced. Subsequently it was proved, by mathematical analysis, that the accumulated charge created an outward normal force equal to to 2π times the square of the density, and experiment has demonstrated that when the latter exceeds approximately 20 C. G. S. units, a streamer or corona is formed. From these observations and deductions it is obvious that such may happen at a comparatively low pressure if the conductor is of extremely small radius, or pointed, and it is pursuant to a misapplication of these, and other, truths that the commercial lightning rod of today is made very slender and pointed. My invention, on the contrary, while taking cognizance of these truths, correctly applies them in the provision of a lightning protector that distinctively affords an elevated terminal having its outer conducting boundaries arranged on surfaces of large radii of curvature on two dimensions. The principles which underlie my invention and correct application of which dictate the form and manner of installation of my protector, I will now explain in contrast with the conventional pointed lightning rod.
In permitting leakage into the air, the needle-shaped lightning-rod is popularly believed to perform two functions: one to drain the ground of its negative electricity, the other to neutralize the positive of the clouds. To some degree it does both. But a systematic study of electrical disturbances in the earth has made it palpably evident that the action of Franklin's conductor, as so commonly interpreted, is chiefly illusionary. Actual measurement proves the quantity of electricity escaping even from many points, to be entirely insignificant when compared with that induced within a considerable terrestrial area, and of no moment whatever in the process of dissipation. But it is true that the negatively charged air in the vicinity of the rod, rendered conductive through the influence of the same, facilitates the passage of the bolt. Therefore it increases the probability of a lighting discharge in its vicinity. The fundamental facts underlying this type of lightning-rod are: First, it attracts lightning, so that it will be struck oftener than would be the building if it were not present; second, it renders harmless most, but not all, of the discharges which it receives; third, by rendering the air conductive, and for other reasons, it is sometimes the cause of damage to neighboring objects; and fourth, on the whole, its power of preventing injury predominates, more or less, over the hazards it invites.
My protector, by contrast, is founded on principles diametrically opposite. Its terminal has a large surface. It secures a very low density and preserves the insulating qualities of the ambient medium, thereby minimizing leakage, and in thus acting as a quasi-repellent to increase enormously the safety factor.
For the best and most economical installation of protective devices according to my invention, those factors and phenomena that dictate size, number of protectors and physical qualities of the apparatus must be grasped by the installing engineer, and preliminary, for full understanding of the principles of my invention, these should be briefly explained.
Economical installation, of course, demands that the protective capability of any given equipment be not needlessly greater than is required to meet the maximum expectancies under the conditions surrounding the particular building to be protected, and these depend, partially, as I shall show, upon the character of the landscape proximate to the building site.
In the drawings, Figures 1 to 4 inclusive, are diagrams requisite to illustration of the facts and conditions relevant to the determination of specific installations of my invention, and Figs. 5 to 8 illustrate construction and application of the protectors. Specifically:
Fig. 1 is a landscape suited for purpose of explanation; Figs. 2, 3 and 4 are theoretical diagrams; Figs. 5 and 6 illustrate forms of improved protectors; and Figs. 7 and 8 show buildings equipped with the same.
In Fig. 1, 1 represents Lord Kelvin's “reduced” area of the region, which is virtually part of the extended unruffled ocean-surface. (See “Papers on Electrostatics and Magnetism” by Sir William Thomson). Under ordinary weather conditions, when the sky is clear, the total amount of electricity distributed over the land is nearly the same as that which would be contained within its horizontal projection. But in times of storm, owing to the inductive action of the clouds, an immense charge may be accumulated in the locality, the density being greatest at the most elevated portions of the ground. Assuming this, under the conditions existing at any moment, let another spherical surface 2, concentric with the earth, be drawn—which may be called “electrical niveau”—such that the quantities stored over and under it are equal. In other words, their algebraic sum, taken relatively to the imaginary surface, in the positive and negative sense, is nil. Objects above the “niveau” are exposed to ever so much more risk than those below. Thus, a building at 3, on a site of excessive density, is apt to be so hit sooner or later, while one in a depression 4, where the charge per unit area is very small, is almost entirely safe. It follows that the one building 3 requires more extensive equipment than does the other. In both instances, however, the probability of being struck is decreased by the presence of my protector, whereas it would be increased by the presence of the Franklin rod, for reasons that I will now explain.
An understanding of but part of the truths relative to electrical discharges, and their misapplication due to the want of fuller appreciation has doubtless been responsible for the Franklin lightning rod taking its conventional pointed form, but theoretical considerations, and the important discoveries that have been made in the course of investigations with a wireless transmitter of great activity by which arcs of a volume and tension comparable to those occurring in nature were obtained (“Problems of Increasing Human Energy” Century Magazine June 1900 and Patents 645,576, 649,621, 787,412 and 1,119,732) at once establish the fallacy of the hitherto prevailing notion on which the Franklin type of rod is based, show the distinctive novelty of my lightning protector, and guide the constructor in the use of my invention.
In Fig. 2, 5 is a small sphere in contact so with a large one, 6, partly shown. It can be proved by the theory of electric images that when the two bodies are charged the mean density on the small one will be only π2/6 = 1.64493 times greater than that on the other, (See “Electricity and Magnetism” by Clerk Maxwell). In Fig. 3, the two spheres 7 and 8 are placed some distance apart and connected through a thin wire 9. This system having been excited as before, the density on the small sphere is likely to be many time that on the large one. Since both are at the same potential it follows directly that the densities on them will be inversely as their radii of curvature. If the density of 7 be designated as d and the radius r, then the charge q = 4πr2d, the potential p = 4πrd and the outward force, normal to the surface, f = 2πd2. As before stated, when d surpasses 20 C. G. S. units, the force f becomes sufficiently intense to break down the dielectric and a streamer or corona appears. In this. case p = 80πr. Hence, with a sphere of one centimeter radius disruption would take place at a potential p = 80π=251.328 E. S. units, or 75,398.4 volts. In reality, the discharge occurs at a lower pressure as a consequence of uneven distribution on the small sphere, the density being greatest on the side turned away from the large one. In this respect the behavior of a pointed conductor is just the reverse. Theoretically, it might erroneously be inferred from the preceding, that sharp projections would permit electricity to escape at the lowest potentials, but this does not follow. The reason will be clear from an inspection of Fig. 4, in which such a needle-shaped conductor 10, is illustrated, a minute portion of its tapering end being marked 11. Were this portion removed from the large part 10 and electrically connected with the same through an infinitely thin wire, the charge would be given off readily. But the presence of 10 has the effect of reducing the capacity of 11, so that a much higher pressure is required to raise the density to the critical value. The larger the body, the more pronounced is this influence, which is also dependent on configuration, and is maximum for a sphere. When the same is of considerable size it takes a much greater electromotive force than under ordinary circumstances to produce streamers from the point. To explain this apparent anomaly attention is called to Fig. 3. If the radii of the two spheres, 7 and 8, be designated r and R respectively, their charges q and Q and the distance between their centers D, the potential at 7, due to Q is Q/D. But 7, owing to the metallic connection 9, is at the potential Q/R = q/r. When D is comparable to R, the medium surrounding the small sphere will ordinarily be at a potential not much different from that of the latter and millions of volts may have to be applied before streamers issue, even from sharp protruding edges. It is important to bear this in mind, for the earth is but a vast conducting globe. It follows that a pointed lightning-rod must be run far above ground in order to operate at all, and from the foregoing it will be apparent that the pointing of the end, for supposed emissive effect, is in part neutralized by the increasing size below the extreme end, and the larger the rod, for reduction of electrode resistance, the more pronounced in this counter-influence. For these reasons it is important to bear in mind that sufficient thickness of the rod for very low electrode-resistance is rather incompatible with the high emissive capability sought in the needle-like Franklin-rod, but, as hereinafter set forth, it is wholly desirable in the use of my invention, wherein the terminal construction is intended for suppression of charge-emission rather than to foster it.
The notion that Franklin's device would be effective in dissipating terrestrial charges may be traced to early experiments with static frictional machines, when a needle was found capable of quickly draining an insulated electrified body. But the inapplicability of this fact to the conditions of lightning protection will be evident from examination of the simple theoretical principles involved, which at the same time substantiate the desirability of establishing protection by avoiding such drainage. The density at the pointed end f should be inversely as the radius of curvature of the surface, but such a condition is unrealizable. Suppose Fig. 4 to represent a conductor of radius 100 times that of the needle; then, although its surface per unit length is greater in the same radio, the capacity is only double. Thus, while twice the quantity of electricity is stored, the density on the rod is but one-fiftieth of that on the needle, from which it follows that the latter is far more efficient. But the emissive power of any such conductor is circumscribed. Imagine that the “pointed” (in reality blunt or rounded) end be continuously reduced in size so as to approximate the ideal more and more. During the process of reduction, the density will be increasing as the radius of curvature acts smaller, but in a proportion distinctly less than linear; on the other hand, the area of the extreme end, that is, the section through which the charge passes out into the air, will be diminishing as the square of the radius. This relation alone imposes a definite limit to the performance of a pointed conductor, and it should be noticed that the electrode resistance would be augmented at the same time. Furthermore, the efficacy of the rod is much impaired through potential due to the charge of the ground, as has been indicated with reference to Fig. 3. Practical estimates of the electrical quantities concerned in natural disturbances show, moreover, how absolutely impossible are the functions attributed to the pointed lightning conductor. A single cloud may contain 2 x 1012 C. G. S. units, or more, inducing in the earth an equivalent amount, which a number of lightning rods could not neutralize in many years. Particularly to instance conditions that may have to be met, reference is made to the Electrical World of March 5, 1904, wherein it appears that upon one occasion approximately 12,000 strokes occurred within two hours within a radius of less than 50 kilometers from the place of observation.
But although the pointed lightning-rod is quite ineffective in the one respect noted, it has the property of attracting lightning to a high degree, firstly on account of its shape and secondly because it ionizes and renders conductive the surrounding air. This has been unquestionably established in long continued tests with the wireless transmitter above-mentioned, and in this feature lies the chief disadvantage of the Franklin type of apparatus.
All of the foregoing serves to show that since it is utterly impracticable to effect an equalization of charges emissively through pointed lightning-rods under the conditions presented by the vast forces of nature great improvement lies in the attainment of a minimized probability of lightning stroke to the area to be protected coupled with adequate conductivity to render harmless those strokes that may, notwithstanding, occur.
Furthermore, a correct application of the truths that have thus been explained with reference to the familiar pointed type of lightning-rod not only substantiates the theoretical propriety of the form in which I develop my improved lightning protector, but will lead the installing engineer properly to take cognizance of those conditions due to location of the building, with respect to surrounding earth formations and other buildings, probabilities of maximum potential-differences and charge-densities to be expected under the prevailing atmospheric conditions of the site, and desirable electrode resistance and capacities of the protectors installed.
The improved protector, as above stated, behaves in a manner just opposite to the Franklin type and is incomparably safer for this reason. The result is secured by the use of a terminal or conducting surface of large radius of curvature and sufficient area to make the density very small and thereby prevent the leakage of the charge and the ionization of the air. The device may be greatly varied in size and shape but it is essential that all its outer conducting elements should be disposed along an ideal enveloping surface of large radius and that they should have a considerable total area.
In Fig. 5, Fig. 6, Fig. 7 and Fig. 8, different kinds of such terminals and arrangements of same are illustrated. In Fig. 5, 12 is a cast or spun metal shell of ellipsoidal outlines, having on its under side a sleeve with a bushing 13 of porcelain or other insulating material, adapted to be slipped tightly on a rod 14, which may be an ordinary lightning conductor. Fig. 6 shows a terminal 15 made up of rounded or flat metal bars radiating from a central hub, which is supported directly on a similar rod and in electrical contact with the same. The special object of this type is to reduce the wind resistance, but it is essential that the bars have a sufficient area to insure small density, and also that they are close enough to make the aggregate capacity nearly equal to that of a continuous shell of the same outside dimensions. In Fig. 7 a cupola-shaped and earthed roof is carried by a chimney, serving in this way the twofold practical purpose of hood and protector. Any kind of metal may be used in its construction but it is indispensable that its outer surface should be free of sharp edges and projections from which streamers might emanate. In like manner mufflers, funnels and vents may be transformed into effective lightning protectors if equipped with suitable devices or designed in conformity with this invention. Still another modification is illustrated in Fig. 8 in which, instead of one, four grounded bars are provided with as many spun shells or attachments 18, with the obvious object of reducing the risk.
From the foregoing it will be clear that in all cases the terminal prevents leakage of electricity and attendant ionization of the air. It is immaterial to this end whether it is insulated or not. Should it be struck the current will pass readily to the ground either directly or, as in Fig. 5, through a small air-gap between 12 and 14. But such an accident is rendered extremely improbable owing to the fact that there are everywhere points and projections on which the terrestrial charge attains a high density and where the air is ionized. Thus the action of the improved protector is equivalent to a repellent force. This being so, it is not necessary to support it at a great height, but the ground connection should be made with the usual care and the conductor leading to it must be of as small a self-induction and resistance as practicable.
I claim as my invention:
1. A lightning protector consisting of an elevated terminal, having its outer conducting boundaries arranged on surfaces of large radii of curvature in both dimensions, and a grounded conductor of small self-induction, as set forth.
2. A lightning protector composed of a metallic shell of large radius of curvature, and a grounded conductor of small self-induction, as described.
3. Apparatus for protection against atmospheric discharges comprising an earth connection of small resistance, a conductor of small self-induction and a terminal carried by the same and having a large radius of curvature in two dimensions as, and for the purpose set forth.
4. In apparatus for protection against atmospheric discharges an insulated metallic shell of large radius of curvature supported by a grounded conductor and separated from the same through a small air-gap as, and for the purpose described.
5. A lightning protector comprising, in combination, an elevated terminal of large area and radius of curvature in two dimensions, and a grounded conductor of small self-induction, as set forth.
6. In apparatus for protection against lightning discharges, the combination of an elevated metallic roof of large area and radius of curvature in two dimensions, and a grounded conductor of small self-induction and resistance, as described.
7. As an article of manufacture a metallic shell of large radius of curvature provided with a sleeve adapted for attachment to a lightning rod as, and for the purpose set forth.
8. A lightning protector comprising an ellipsoidal metallic shell and a grounded conductor of small self-induction, as set forth.
9. In apparatus for protection against atmospheric discharges a cupola-shaped metallic terminal of smooth outer surface, in combination with a grounded conductor of small self-induction and resistance, as described.
In testimony whereof I affix my signature.
NIKOLA TESLA.
« Reply #11, on October 1st, 2011, 11:36 AM »Last edited on February 15th, 2012, 01:03 PM by freethisone
[attachment=314]Greetings all, were are you Paul?
Dr. Townsend Brown called this effect the ELECTROKINETIC effect. Brown had  found that a capacitor charged to a certain potential would cause the capacitor to loose weight.
Tom Bearden teaches us that if we used asymmetry in our circuits then we can fully furnish the dipole from a vacuum.
Today i was thinking about this effect harder then i did before. My question was why does browns saucer not resemble a capacitor? To postulate, I am still unclear to what this force it attributed to. Could on the other hand the saucer shaped craft be acting in a manner that utilizes other less known effects of a physical nature on a smaller scale?
first i add the asymmetrical  permanent magnet , that can, because of its magnetic vorticity have an action upon a coil of wire that will induce a  charge without adding an external spin to the system, or need of a rotary devise to cause the changing magnetic field..
I will edit, and add some finger paintings to describe further the effect i am considering, that also must have its action, by means of effect  less understood on the magnetic field produced by this type  saucer shaped  craft.  Is it really a capacitor, or  does the effect manifest by acting on the 2 electric field relations.
In addition to the explanations given by Brown.
In the first picture, I see a magnetic field produced by this devise resembling that of the earths magnetic field.  A great discovery all by itself. I'm interested in #21 in the description.
From the patent elektokinetic devise,
"While the phenomenon just described has been observed and its existence confirmed by repeated experiment, the principles involved are not completely understood. It has been determined that the greatest forces are developed when the leading electrode is made positive with respect to the body 20, and it is accordingly thought that in the immediate vicinity of the electrode 21 where the potential gradient is very high, free electrons are stripped off of the atoms and molecules of the surrounding medium. These electrons migrate to the •positive electrode 21 where they are collected. This removal of free electrons leaves the respective atoms and molecules positively charged and such charged atoms and molecules are accordingly repelled from the positive electrode 21 and attracted toward the negative electrode 20. The paths of movement of these positively charged particles appear to be of the nature represented by the lines  27 in figure 2"
PDF files describe more detail, and i included a few of them below. Picture 2  does not resemble  Only a capacitor,  but also a primary coil, and secondary coil. The large saucer being the primary conductor, and the fine wire the secondary. The later having a high resistance compared to the saucer shape having a low resistance.
like Tesla design, biffilar wound coils use the lateral force of inductance in the preceding coil winding, and so on. The vacuum field of energy thereby a lateral flow  with respect to the coil windings when the coil becomes energized. Tesla found that by this orientation of coil winding that the voltage in the next winding will increase.
With this in mind  multiplying the density of the electrons flowing over the plate. causing the plate to vibrate over longer intervals. Even when it becomes superconducting. The bleeding off value is lowered, because i look at two separate functions, both leading to the electric field of perspective. (Negative, and positive voltages.)  The energy output of the craft increased, by  increasing the density of the free electrons that may migrate to the larger plate.   What function? lowering
reducing the pressure on that plate. allowing for migration from the vacuum field.
the  same principle based on a bifilar coil,instead now we are lowering the resistance in the nearby plate , or coil winding..
I add a second,  3rd, and fourth path way to ionize the surrounding air. More so lowering the potential on the nearby plate , and increasing its action in combination with the vacuum field. The bi-field has its pressure asymmetrical in relation to the nearby fine wire of higher resistance.
Add pictures.
 If i reduce the resistance in a plate what have i really done? i have lowered the pressure density  on the plate.  It now has a higher permeability in relation to zero  vacuum field. I create a void ,and the vacuum is drawn in that direction. Equal , and opposite reactions again. by increasing the permeability even further, i super cool the primary plate. A  change in vacuum pressure should be measured. These fields are electrical, and its negative component dictated the positive mensurable pressure in the surround field of the craft.
That very simple?
You may record this is a lowering of pressure  on the larger plate, thus giving the positive lift to the craft.  A zero point of pressure would mean bringing the conduction to the same pressure as the reacting force of  the electric fields mentioned.  Test.
The electric magnetic field equalizing the vacuum, by way of its natural action upon the bi ethereal medium.. see pdf electric field machine.
IN DR. Browns words "the direct production of force and motion.
Since any conversion of energy from one form to another is accompanied by losses due to friction, radiation or conduction of heat, hysteresis, and the like, as well as serious reductions in the availability of the energy by ?increases in the entropy of the system, it is apparent that great increases in efficiency may be achieved through the use of the direct production of electrical energy and force and motion made possible by my invention. Likewise, the elimination of the machinery for the intermediate conversions results in great savings in first costs, maintenance, weight and space, the latter two being of great importance in self-propelled vehicles including mobile vehicles such as aircraft and space craft.
It is therefore an object of my invention to provide an apparatus for converting the energy of an electrical potential directly into a mechanical force suitable for causing relative motion between a structure and the surrounding medium."
It is another object of this invention to provide a novel apparatus for converting an electrical potential directly to usable kinetic energy.
It is another object of this invention to provide a novel apparatus for converting electrostatic energy directly into kinetic energy.
It is another object of this invention to provide a vehicle motivated by electrostatic energy without the use of moving parts.
It is still another object of this invention to provide a 'self-propelled vehicle without moving parts.
It is a feature of my invention to provide an apparatus
for producing relative motion between a structure and the surrounding medium which apparatus includes a pair of electrodes of appropriate form held in fixed spaced relation to each other and immersed in a dielectric me6 dium and oppositely charged.
research: references wiki on Thermionic emission is the heat-induced flow of charge carriers from a surface or over a potential-energy barrier. This occurs because the thermal energy given to the carrier overcomes the binding potential, also known as work function of the metal. The charge carriers can be electrons or ions, and in older literature are sometimes referred to as "thermions". After emission, a charge will initially be left behind in the emitting region that is equal in magnitude and opposite in sign to the total charge emitted. But if the emitter is connected to a battery, then this charge left behind will be neutralized by charge supplied by the battery, as the emitted charge carriers move away from the emitter, and finally the emitter will be in the same state as it was before emission. The thermionic emission of electrons is also known as thermal electron emission.
In the solid-state physics field of semiconductors and insulators, the conduction band is the range of electron energies, higher than that of the valence band, sufficient to free an electron from binding with its individual atom and allow it to move freely within the atomic lattice of the material. Electrons within the conduction band are mobile charge carriers in solids, responsible for conduction of electric currents in metals and other good electrical conductors.
Photoelectric work function
The work function is the minimum energy that must be given to an electron to liberate it from the surface of a particular substance. In the photoelectric effect, electron excitation is achieved by absorption of a photon. If the photon's energy is greater than the substance's work function, photoelectric emission occurs and the electron is liberated from the surface. (Excess photon energy results in a liberated electron with non-zero kinetic energy.)
The photoelectric work function is
    \phi=hf_0 \,
where h\, is Planck's constant and f_0\, is the minimum (threshold) frequency of the photon required to produce photoelectric emission.
[edit] Thermionic work function
The work function is also important in the theory of thermionic emission. Here the electron gains its energy from heat rather than photons. According to the Richardson-Dushman equation the emitted electron current density, J (A/m2), is related to the absolute temperature T by the equation:
    J = A T^2 e^{-W \over k T}
where W is the work function of the metal, k is the Boltzmann constant and the proportionality constant A, known as Richardson's constant, is given by
    A = {4 \pi m k^2 e \over h^3} = 1.20173 \times 10^6 \; \mathrm{A m^{-2}K^{-2}}
where m and -e are the mass and charge of an electron, and h is Planck's constant.
Thermionic emission—electrons escaping from the heated negatively-charged filament (hot cathode)—is important in the operation of vacuum tubes. Tungsten, the common choice for vacuum tube filaments, has a work function of approximately 4.5 eV. various oxide coatings can substantially reduce this.
[edit] Free Electron Gas Model
In the free electron model non-interacting electrons bounce around inside a potential well of depth U. The Fermi Level is the highest energy level that is occupied by electrons. Here EF is defined relative to the bottom of the potential well, and the work function W is the energy required to eject the electron in the Fermi Level.
In the free electron model the valence electrons roam freely (zero force) inside the metal but find a confining potential step U at the boundary of the metal. In the system's ground state, states with energy less than the Fermi Level are occupied, and states above the Fermi Level are not occupied. The energy required to liberate an electron in the Fermi Level is the work function. If, as in the diagram right, we define the Fermi Energy EF from the bottom of the well, the results reported in the Wiki page Fermi Energy are applicable. However, usually the Fermi Energy is referenced to energy zero: that of the lowest energy electron free of the metal. In that case the Fermi Energy would have a negative value (i.e., the Fermi Level lies below those of escaped electrons) E_F\approx -W (but see below).
[edit] Work Function Trends
The thermionic work function depends on the orientation of the crystal and will tend to be smaller for metals with an open lattice, larger for metals in which the atoms are closely packed. The range is about 1.5–6 eV. It is somewhat higher on dense crystal faces than open ones. The magnitude of the work function is usually about a half of the ionization energy of a free atom of the metal. For example, caesium has ionization energy 3.9 eV and work function 2.14 eV.
[edit] Work Function and Surface Effect
  Lothar Wolfgang Nordheim (November 7, 1899, München - October 5, 1985, La Jolla, California, USA) was a German-born Jewish theoretical physicist. He taught at Duke University.
His name is sometimes misspelled as Lother.
An important contribution, with the British physicist Fowler in 1928, was to establish the correct physical explanation of the physical phenomenon now called field electron emission (FE). They established that electron emission occurred by a form of wave-mechanical tunneling now called Fowler-Nordheim (FN) tunnelling), and – with the help of the assumption that electrons in metals obeyed Fermi-Dirac statistics – derived an (approximate) emission equation. Over time, this equation has been developed into a family of approximate equations (offering different degrees of approximation to reality, when describing FE from bulk metals), known as Fowler-Nordheim-type equations.
FN tunneling was the first effect in physics to be firmly identified as due to wave-mechanical tunneling, in the early days of quantum mechanics. The original FN-type equation was one of the first to use Fermi-Dirac statistics to explain an experimental phenomenon involving electrons in metals, and its success greatly helped to establish modern electron band theory.
Although four specific embodiments of the present invention have been shown and described, it should be understood that the shape and configuration of the sub- 25 strates and charge holding elements carried thereby could take a variety of forms. The common feature of all of these embodiments is the utilization of a plurality of small scale charge carrying elements interleaved in close proximity to one another. The elements either 30 carry a charge or are periodically charged and discharged to produce electric force fields which interact to cause movement of some of the elements relative to the others. Because of the small scale, the elements can be placed in close proximity to utilize the increased 35 electric field forces resulting from the close proximity. A function of band theory reference "http://www.allaboutcircuits.com/vol_3/chpt_2/4.html
RE: LIFTER TECHNOLOGY
« Reply #12, on October 10th, 2011, 08:39 AM »Last edited on October 10th, 2011, 08:45 AM by freethisone
Quote from Rwg42985 on October 8th, 2011, 07:30 AM
Quote from freethisone on October 1st, 2011, 01:34 PM
Very similar concept By DR Townsend Brown, The first epg?
extremely interesting. very nice find! ~Russ
I didn't know this to be a fact until i had read it in the audio book provided.
Audio book
A experiment to try.
Take a spark gap, make the distance close, were the spark will fly  but not touching. How much energy does it take to cause a spark to cross that gap? I think its about 10 to 15 kilo-volts. If you make the gap wider then you need more energy therefore a greater charge to get the spark to fly.. do you agree?
If i now increase the gap, and introduce a strong UV light  were the spark will  cross the gap what will happen? you may say nothing, and all will be as before, but it is well known that this UV light will allow the spark to cross a greater distance then without it. ( I didn't know that, did you?)
now i increase the gap, and this time i add no more energy then the 10 to 15 kilo volts i had before. What will happen?
The spark will fly a greater distance, therefore there must be an increase in energy in the spark then there was when the gap was very small. do you agree?
that 10 to 15 kilo-volts must be greater, the spark traveled a greater distance even though the gap was increased..  one the medium becomes more conductive. two the energy traveled a greater distance. three in order to achieve this under normal conditions you will need to add more energy to get the spark to pass the air gap.
Was the charge furnished from an external source?   If some one could try this experiment it would be appreciated. A uv laser should do the trick.
A spark passed through the air gap, the air is ionized. because of the UV light source, what really happened to the ionized air?
Could it be that the UV source adds energy to the ionized air by the same principles as the HHO GUN?  by adding energy to the free electrons, or by absorption/induction of the ionized gas?
In my experiment I shewed an increase of energy in spark gap. Concluded that the increase was caused by an external source. Ozone. It was the positive inflow of ions of the opposite charge. caused by the electron negativity of the negative ion source.
There was no UV light source present after i made these findings, only the strong smell of ozone in the air.
« Reply #13, on October 12th, 2011, 08:58 AM »Last edited on October 12th, 2011, 08:12 PM by freethisone
beyond the light rays byMoray:cool:    I :heart: bands
adding and expanding, advancements epg  vortex magnetic fields etc.
Expanding on the perpetual motion holder, expanding on superconducting metal plates.  effects,  electron negativity. chemical components oxygen, plasma state electron liberation.
electrostatic electricity.
band theory
ARTICLE
from the
Encyclopædia Britannic
band theory, in solid-state physics, theoretical model describing the states of electrons, in solid materials, that can have values of energy only within certain specific ranges. The behaviour of an electron in a solid (and hence its energy) is related to the behaviour of all other particles around it. This is in direct contrast to the behaviour of an electron in free space where it may have any specified energy. The ranges of allowed energies of electrons in a solid are called allowed bands. Certain ranges of energies between two such allowed bands are called forbidden bands—i.e., electrons within the solid may not possess these energies. The band theory accounts for many of the electrical and thermal properties of solids and forms the basis of the technology of solid-state electronics.
The band of energies permitted in a solid is related to the discrete allowed energies—the energy levels—of single, isolated atoms. When the atoms are brought together to form a solid, these discrete energy levels become perturbed through quantum mechanical effects, and the many electrons in the collection of individual atoms occupy a band of levels in the solid called the valence band. Empty states in each single atom also broaden into a band of levels that is normally empty, called the conduction band. Just as electrons at one energy level in an individual atom may transfer to another empty energy level, so electrons in the solid may transfer from one energy level in a given band to another in the same band or in another band, often crossing an intervening gap of forbidden energies. Studies of such changes of energy in solids interacting with photons of light, energetic electrons, X-rays, and the like confirm the general validity of the band theory and provide detailed information about allowed and forbidden energies.
A variety of ranges of allowed and forbidden bands is found in pure elements, alloys, and compounds. Three distinct groups are usually described: metals, insulators, and semiconductors. In metals, forbidden bands do not occur in the energy range of the most energetic (outermost) electrons. Accordingly, metals are good electrical conductors. Insulators have wide forbidden energy gaps that can be crossed only by an electron having an energy of several electron volts. Because electrons cannot move freely in the presence of an applied voltage, insulators are poor conductors. Semiconductors have relatively narrow forbidden gaps—which can be crossed by an electron having an energy of roughly one electron volt—and so are intermediate conductors.
LINKS
Related Articles
Aspects of the topic band theory are discussed in the following places at Britannica.
Assorted References
    chemical bonding in metals  (in  chemical bonding (chemistry): Metals)
    ...is very large, it follows that the energy separation between neighbouring molecular orbitals is very small and approaches zero as n approaches infinity. The molecular orbitals then form a band of energies. Another similar band can be formed by the overlap of the 3p orbitals of the atoms, but there is a substantial band gap—i.e., a region of energy in which there...
    colour  (in  colour (optics): Metals)
    ...piece of a metal. These delocalized electrons are thus able to move over the whole piece of metal and provide the metallic lustre and good electrical and thermal conductivities of metals and alloys. Band theory explains that in such a system individual energy levels are replaced by a continuous region called a band, as in the density-of-states diagram for copper metal shown in the...
    electrical conduction  (in  electricity (physics): Conductors, insulators, and semiconductors)
    ...of levels is extremely large; most of the higher energy levels overlap in a continuous fashion except for certain energies in which there are no levels at all. Energy regions with levels are called energy bands, and regions that have no levels are referred to as band gaps.
    Fermi surface  (in  Fermi surface (physics))
    ...magnetic, and optical properties of crystalline metals and semiconductors. They are closely related to the atomic lattice, which is the underlying feature of all crystalline solids, and to energy band theory, which describes how electrons are distributed in such materials.
    hole  (in  hole (solid-state physics))
    According to the band theory of solids, electrons within a solid have energies only at certain discrete levels that combine into groups or bands. The valence band contains electrons that are bound into the atomic structure of the material (see valence electron), whereas the conduction band contains electrons at higher energies that are free to move.
    semiconductors  (in  semiconductor (electronics): Electronic properties;
    ...have only discrete energy levels. However, when a large number of atoms are brought together to form a crystal, the interaction between the atoms causes the discrete energy levels to spread out into energy bands. When there is no thermal vibration (i.e., at low temperature), the electrons in an insulator or semiconductor crystal will completely fill a number of energy bands, leaving the rest of...
    in  radiation measurement (technology): Semiconductor detectors;
    The electronic structure of semiconductors is such that, at ordinary temperatures, nearly all electrons are tied to specific sites in the crystalline lattice and are said to have an energy in the valence band. At any given time, a few electrons will have gained sufficient thermal energy to have broken loose from localized sites and are called conduction electrons; their energy lies in a higher...
    in  semiconductor device (electronics): Electronic properties )
    ...atom can have only discrete energy levels. When a large number of atoms are brought together to form a crystal, the interaction between the atoms causes the discrete energy levels to spread out into energy bands. When there is no thermal vibration (i.e., at low temperature), the electrons in a semiconductor will completely fill a number of energy bands, leaving the rest of the energy...
Other
The following is a selection of items (artistic styles or groups, constructions, events, fictional characters, organizations, publications) associated with "band theory"
    band theory (physics)
    Fermi level (physics)
Citations
MLA Style:
"band theory." Encyclopædia Britannica. Encyclopædia Britannica Online. Encyclopædia Britannica, 2011. Web. 12 Oct. 2011. .
APA Style:
band theory. (2011). In Encyclopædia Britannica. Retrieved from http://www.britannica.com/EBchecked/topic/51430/band-theory
This feature allows you to export a Britannica citation in the RIS format used by many citation management software programs.
« Reply #14, on October 12th, 2011, 08:58 PM »Last edited on October 17th, 2011, 01:46 PM by freethisone
:cool:ion structure
beyond the light rays byMoray ::heart:
Highlights Moray
This, then, is the electromagnetic theory of the luminous vibration. In the older or elastic-solid theory, the light vibrations were supposed to be actual oscillation of the elements of molecules of the ether about their positions of rest, such as takes place when waves of (transverse) disturbance are propagated through an elastic solid. Such a limitation is, however, unwarranted. All we know is that the change, disturbance, vibration, polarization, or whatever we wish to term it, is periodic and transverse to the direction of propagation. The electromagnetic theiry teaches us nothing further as to its nature, but rather asserts that whatever the change may be, it is the same in kind as that which occurs in the ether when the charge of an electrified body is altered or reversed. It reduces light and heat waves to the same category as waves of electric polarization; the only quality of the latter required to constitute the former is sufficient rapidity of alternation. These speculations have received the strongest confirmation by the important experiments of Professor Hertz. Before describing them we shall consider the mode of discharge of a condenser. The theoretical investigation was given by Sir William Thomson  (Lord Kelvin) as early as 1853 (Phil. Mag. June, 1853).
classic books sieries.  :heart:
Hennery Cavendish on elastic fluid :heart:
Aether and Gravitation :heart:
« Reply #15, on October 18th, 2011, 11:39 AM »Last edited on November 3rd, 2011, 10:43 AM by freethisone
i have another wonderful effect i had discovered by modifying my neg ion generator, i achieved the most delightful shock . i  want to create the greatest electrification, and potential spark, or magnetic pressure, between the conductors.
I have, on the outside of the jar wrapped the tin foil, as in a manner at to have a small gap from the rim..
in the inner portion of the jar i used a salt water solution. I also used as a conductor, i placed inside the jar a metal tube, were i could connect the neg ion emitter of specific negative charge. there does not appear the need for this tube at all, as the energy is transferred to the outer tin foil coating by only bringing the negative wire in contact with the glass jar. the ground short is external. therefore there is no need for a inner tinfoil coating. it is essentially a broken conductor, and its gap upon itself, this negative electrification, becomes both positive , and negative charges.
i operated the devise as before were the neg ion emitter is used to charge conducting material by use of free electrons, to also determine the negative energy, and then the negative electrification of the movement of the electric fields that are opposite. Is it moving in that direction, proportional to well known laws? having a radial force proportional to the distance from that source charge. the electric field is greater the closer to the source vibration.  I don't think the salt water helped the glass to become electrified. These are static charges.
by adding a resistor of high capacity, or High resistance may be key, inorder to use this charge.
what i have discovered is that one of the effects that glass has when it becomes charged in this manner, it is significant that it has a greater vibration, and also a greater electrification, or pressure. On the jars outer surface there is a electrification, an vibration.. For charging capacitors, and such to create a lift.
I have creating a divination in a string of magnetic dipoles, it acts like it is reaching out finding the path for the electric fluid to travel. at each break in a conductor the force is north south north south pole. the vacuum energy rushes in, and equalizes tthe negative charge. A repellent, and attracting force.
add more draw pics.. don't laugh at my primitive drawings. TongueAngel
in the diagram i made, i show that the entire body will become electrified with two unlike charges, and the energy flows over the conductor in that way. North south separated magnetic pressures.
a powerful shock will be felt if you were to touch the tinfoil coating, and a conducting body if you arrange the charges correctly.
« Reply #16, on October 21st, 2011, 11:34 AM »Last edited on December 1st, 2011, 09:08 AM by freethisone
Quote from freethisone on September 6th, 2011, 06:30 PM
for better words,:heart:
special observation. wile i was continuing to observe the  emitter interaction with the brass rod, i made a startling discovery. the rod discharge all together stopped and the gap was slightly increased. wile i was in the mood to open the windows and look out at the rain, i created a cross ventilation of outdoor air through the room. you wont believe this but it was found to be ionized in every way. the energy out put of the conductors went up substantial, and when again there was a spark of greater magnitude then before. the cross wind had its effects, the out door rain and humidity caused the spark to go up in this case. and i could smell ozone in the air. my conclusion is free energy created by the presents of charged ions in the air. in this case its clear there must be a substantial amount of ionization of our atmosphere. radiations from fucashima, and the increase of radar energy devises have its roll. the amazing thing is that the amount of positive ions available is tremendous.  definition assume respiratory conditions are increasing.
For me, I have noticed the atmosphere is producing copious amounts of ozone, several less well know causes can be accounted for.
Lets face it, the nuclear disaster in japan is a main contributor. Radioactive material drifting around the entire world.
What does radio active mean? It means it is releasing energy.
The interaction in our atmosphere, causes a response.
water vapor in the form of cloud cover gets heated, heat causes it to evaporate quickly, leading to less cloud cover were the heating is very high.
Perhaps the drought in Texas is related to that, the radiation transforms the atmosphere leading to a huge spike in low level ozone, you may not like this answer, but it is scientifically sound.
Other causes an increase in natural gas, and methane bubbling up from pockets under ground that have reached the surface. an earth quake, or drilling in search of fuel may release the trapped pockets of gas.
This gets even more dangerous, as it is also exposed to solar rays, and even the radiation coming from nuclear plants that fail, nuclear testing, under ground testing etc.
This is not per-say the (only factors) to respiratory problems on a global scale, but is becoming evident, a main contributor. Independent study, and sampling of the air you breathe and the drinking water being consumed
Is necessary for determining cause. The amount of tolerances a body can handle is determined not by the individual, but by the quantity a species can safely tolerate.
If the quantity of these very dangerous by products find its way hovering above your home, you can be sure the clean breathable oxygen is reduced. It may even lead to brain damage, or permanent damage to the respiratory system.
My own researches verify that.
Sincerely
I quickly closed window and door, and then again the spark had quickly stopped. stopped. Its clear the interaction, and the difference in two static energy's together conduct, "as if a cloud finding its way to my laden jars of negative potential." equal and opposite forces, in this case by increasing the neg. potential i could get anti gravity. the cloud is now giving a thrust. its positive potential is high, because the negative potential is also very high.
add initial theory.https://www.youtube.com/watch?v=0qEhm4llEpE
Dear Paul what does this mean? It means you can set your vandegraph generator as a negative potential.  introduce conductors as to be charged as laden jars. place the machine out doors, and it will quickly multiply the out put of the generator, and the charge of all the laden jars. :D
I would discharge though a tesla primary, and secondary coil setup. Even bifillar plus 2-4 pathways even better.
https://www.youtube.com/watch?v=PxKNy-hweMw
if any one knows what is going on in the movie, as to why the energy increased please let me know.  thank you.
« Reply #17, on October 22nd, 2011, 10:41 AM »Last edited on November 3rd, 2011, 10:49 AM by freethisone
magnetic pressure is what i want to compare. Magnetic pressure is not the same as, the pressure charge density of electric effluvia. Pressure charge density is the negative component to the positive pressure of the opposing electric fluid.
The positive fluid always in proportion to the change in negativity, in relation to, any near by secondary charge.
The vacuum energy is proportional to itself. A negative Fluid that Gives Positive energy. therefore There must always be a negative fluid, and is what we call the medium.
charge density is relative to both the physical conductors charge density, and the negative pressure of the medium, one always being more negative then the other.
What is Super conducting? is it the resistance between any two charges?
the faster the charge is moved, the greater the magnetic commponent? ohms law.
A marvelous effect.
« Reply #18, on October 22nd, 2011, 01:40 PM »Last edited on November 6th, 2011, 10:44 AM by freethisone
What is the vacuum energy? a directional pressure change in the natural fluid,  in relation to the negative density of that fluid that is aether.
I think for the most part, its only in relation, to a physical ability to see, only the charge on the conductors.(plume waving) Maxwell.Cool
Any secondary charge, that are still slightly more negative then the other, a change in constant pressure, or spin of the neg field that has its pressure in nature.
experiment on your own.
my objective is to lower, or increase the resistance even further, between the two conductors. by adding different alloys in connection to the gap. This is were i would add my superconductor, by lowering, or increasing resistance, acting on the medium itself, or perhaps by a change in the barometer of that medium.
 A path for the energy to ground, or be held in constant vibration. (current) A constant difference of potential to the natural medium, by way of insulating property's. By isolating the devise form all other secondary conductors.
I would like to  try a good earth ground used with the super conducting body. All the energy may either drain away to earth, or allow earth to help furnish a charge, Angel
After more experimentation, I would like to learn how to operate this as a speaker. like Dr. Townsend Brown, Tesla, and Rodan With the magnetic components in plain sight. The white wire is waving its plume.
yahoo.
Add pictures. make a zero point device. quantum leaps, and atomic spin.
This should not be called ion wind, it is the directional flow of the electric aether. That direction is toward the sharp points, or white wire. The cooling effect is a cause for the interstellar medium. that is cold space. Rolleyes
Hennery Cavendish charge separation
ZPM:shy:
« Reply #19, on November 28th, 2011, 01:32 PM »Last edited on November 29th, 2011, 02:32 PM by freethisone
Greetings all, I have scheduled all information for correction.  :angel: working on chalk board also. It is  also looking better. more clear.
Final conclusions, and further information section will follow.
My first post has already been corrected.
My problem, a huge inflow of information. Getting it down on paper was my main concern.  Scientific method of course.
cheers all.  Stay tuned for the English version, not the mad scientist view.  lol at Russ,   hah-ha.:D
Classic books
:P peace.
« Reply #20, on November 29th, 2011, 02:09 PM »Last edited on November 29th, 2011, 02:11 PM by freethisone
Notes, sources other interesting facts.
city
The audio book provided: A history of the theories of aether, and electricity.
From the age of Descartes to the close of the nineteenth century. by E.T. Whittaker.
Published 1910 by Longmans,Green in London,New york.
This classic book has been much evidence to light. I will refer to some specific information for your research purposes.
Page 41, paragraph 4.
Professor in 1745 Pieter van Musschenbroek at leyden  quote:
"Attempted to find a method of preserving electric charges from the decay which was observed when the charged bodies were surrounded by air.  With this purpose he tried the effect of surrounding a charged mass of water by an envelope of some non-conductor, eg Glass (dielectric) In one of  his experiments, a phial of water was suspended
from a gun barrel by a wire let down a few inches into the water through the cork; and the gun barrel suspended on silk line, was applied so near an exited glass globe that some metallic fringes inserted into the gun barrel touched the globe in motion. Under these circumstances a friend named Cunaeseus, who happened to grasp the phial with one hand, and touch the gun barrel with the other, received a violent shock; and it became evident that a method of accumulating, or intensifying the electric power had been discovered."
WOW!    .:dodgy::angel:
Add more notes:
Cheers all, peace.  :heart::heart:
« Reply #21, on November 30th, 2011, 10:12 AM »Last edited on November 30th, 2011, 01:03 PM by freethisone
Boy George I have it!  Calm down.
Disclaimer, you may use the application only for your own needs. If you try and sell it, i would like a small 15%. Un-patenable.
If it is patentable, I will list any one as a beneficiary 50% 50% of profits.
Tom Bearden said it best.  Locate in thread #10  You need only a shovel full. Do not kill dipole source. Are you ready?
Can you handle it? I am ecstatic.  Calm down...  I will draw the circuit shortly. input upload complete...
Coal car analogy.   How I did it.  See movie..
It is not  how I did it, It was already there, the whole time in front of us all. I finally understood It.  You may have also.
I  think a ground may be needed on secondary plate. In order to discharge as both pos. neg energy. For use with electrolytic caps.
The only technicality i have not stipulated is, you will need to isolate completley the secondary conductor from the primary. Each discharge to the secondary will require a small gap. After the self discharging primary caps are loaded. The path taken to the secondary coal car, will need to include a very small gap for the discharge to reach the coal car. Not interfering at all with the primary vacuum state dipole. (primary conductor.) Very non intuitive. easy peezy..
A good ground on the secondary will cause the furnished charge to  become a positive, in comparison. The negative potential, will act like a positive.
oh my.  :angel::sleepy::P
https://www.youtube.com/watch?v=qwF5n67yjx8
You will see within moments:  Thank You sincerely, credits to Nikola Tesla, Tomas Bearden, Townsend Brown.  :heart: :cool:
https://www.youtube.com/watch?v=U24Lf6jQI9w :heart::dodgy:
Advance, make viral.... Woot!
« Reply #22, on November 30th, 2011, 02:38 PM »Last edited on December 1st, 2011, 09:37 AM by freethisone
The concept is very close to holding up.   So so far, i think there still remains 2 clearly different charges.
The ground is giving direction only as far as I can tell.  In my last movie I said one is  more positive to the negative. They remain negative charges.
Other configurations. I have also demonstrated a 2 ground set up. I was able to get a clear crooks type discharge repeatedly.
A magnificent green continual crooks type discharge, after more configurations were tested..
So now there is possible 2 kinds of charges, 1 green, 1 blue. Also a steady stream. without the caps this was not possible.
The green spark will be tested more. Along with more crude experiments including the shock I got.
I will post the other configurations later date. Also I had separated the secondary far enough, so no charge is on it at all. acts as second ground.
2 discharges one small cap, one large..  The set Gap is important for also. I  have tried 2 separate ground configuration too.
Stay tuned, I will be testing, and redetermining, conclusions over the next few days.  It is Looking pretty good from here, very promising.
 even with my primitive set up.
https://www.youtube.com/watch?v=89o8rx-jHRE  :sleepy:
peace.
schedule for changes.
« Reply #23, on December 1st, 2011, 02:59 AM »
Quote from freethisone on November 30th, 2011, 02:38 PM
https://www.youtube.com/watch?v=6C3DYcusv6s  :sleepy:
peace.
nice work my friend! nice wok! i wish you the best with your upcoming tests!
please be safe!
« Reply #24, on December 1st, 2011, 10:12 AM »Last edited on December 8th, 2011, 05:38 AM by freethisone
 Many Other configurations, open asymmetry.
You may try a series  Of capacitors. you can try parallel.
You may use single ground wires, double, or triple. You may try any  number of configuration.  Series, and parallel combined.
You may use as many capacitors as wanted. You may use for oscillation circuits. You may use as storage system of energy. You may advance in any number of ways.
Fully furnished if you only take a shovel Full. Special thanks to all have been mentioned. Including Russ, rwg.
  All who have came before us, including a Thank you to Tomas Bearden. Nikola Tesla indeed.
I have tried many configurations. The Green discharge is incredibly interesting. Feel free to upload, download viral. Anti Gravity, equal, and opposite inertial forces.
https://www.youtube.com/watch?v=So7mYlAIAyI&feature=channel_video_title
https://www.youtube.com/watch?v=ySiq-Dqzri4
Even a Linier magnetic component. Heavy poynting energy..
The Free Circuit, Dipole, Automatic.
Freely Furnished, Shoveled Coal Car .
Poynting, Kinetic, Negative Static green energy configurations. The FreeThis circuit.
Cheers, All.    :cool:
