LIFTER TECHNOLOGY
RE: LIFTER TECHNOLOGY
« Reply #25, on December 2nd, 2011, 04:19 AM »Last edited on December 8th, 2011, 08:45 PM by freethisone
nice work my friend! nice wok! i wish you the best with your upcoming tests!
please be safe!
Thank you very much Russ, hard work payed off.
Here is the new Youtube channel, waiting for your approval.:)
https://www.youtube.com/watch?v=sS0oy1QRIl8&feature=channel_video_title
Energy in motion. "Free this circuit"
Sincerely Free
:angel:    Best I can do in finger paint, any one is welcome to draw, and add real circuit diagrams. Thanks..
Now included original coal loading. 'The free energy circuit'. :cool:  More to follow.. peace. Wireless config, fall off at distance.
Movie I found on youtube, brings in many new concepts perhaps solid state configurations, I will try.
https://www.youtube.com/watch?v=So7mYlAIAyI&feature=relmfu
INVENTOR3
These are deduced. >function force bi ether medium. Two fluids. one at greater pressure opposed to the later bi field electric fluid. As explained by philosophers of old. Neg pressure, results in flux of secondary primary fluid. that is the electric field.
please share.
Take care
« Reply #26, on December 5th, 2011, 11:55 AM »Last edited on December 8th, 2011, 08:42 PM by freethisone
Advancements, concept.
I would seemly make a large table top capacitor.
several layers. 2 ft diameter. finally submerged in oil. separated by sheet mica.
charge one end of table neg. ground bottom plate.
optic is triple refraction. we get virtual photon editions, re emit.  If  Refract. one or two times. this is the assumption. photon train. :rolleyes:
Clerk Maxwell has also, opened our eyes to classic mechanics, charge separation. move a charge, EMF
Walter Lewin  great inspiration. :D:P
https://www.youtube.com/watch?v=7WaQ3KeHQXM&feature=channel_video_title:cool:
https://www.youtube.com/watch?v=5M6uI9uZARA&feature=channel_video_title
The Energy Motion channel down loads
https://www.youtube.com/watch?v=-2HkKCoNGgg&feature=channel_video_title:heart::cool:
« Reply #27, on December 14th, 2011, 10:48 AM »Last edited on January 1st, 2012, 06:29 PM by freethisone
I have a couple fun setups to share. One setup  uses 2 large diodes, along with a secondary conductor. Allowing for  Very fast charge, discharge rates. One large single ceramic cap is used. It is difficult to smooth out the energy vacuum. It remains a negative static potential.  Directing the energy flow is very simple. Positive to negative electric  flow.
https://www.youtube.com/watch?v=y4GdXsofyF4
The second movie I am charging 6 small caps in a Lord of the silver rings setup, the tube is the common ground. All the spark gaps are small enough to allow for a impressive discharging  effect. High frequency discharges.
https://www.youtube.com/watch?v=TxL6F-7q0kA&feature=channel_video_title
This last movie has one more added feature. A 200 SA green ceramic cap connected to the center ground tube. Observe the powerful discharges as I bring into contact a secondary ground wire..   :cool:
https://www.youtube.com/watch?v=dbu59vb6Wn4
:shy::shy::) Cheers all.
OtisTCarrTeslaSaucers
http://www.archive.org/stream/OtisT.CarrAndTheTeslaSaucersbyDougYurchey/OtisTCarrTeslaSaucers#page/n5/mode/2up
« Reply #28, on January 19th, 2012, 10:55 AM »Last edited on January 21st, 2012, 09:12 AM by freethisone
Tesla and his radiant energy device.
After review of the 3 files  below, Light is being shed on the fundamental properties of electricity.
I am drawing closer, and closer to the description of the Tesla device.  the same electrification, and charging of the positive plate with negative energy gives the desired effect. for lifter, and for radiant energy.
This post will be expanded on, advanced as soon as time permits.
I thought it would be good to include these files for your review. I  am to a higher degree more interested in the Tesla description, and the function of the radiant energy device in the file labeled chapter 7.
The operation is in close accordance with my experimentation, and the function of the separation, and charging of capacitors. For the most part I believe the experiments i have done are the rebirth of the descriptions Tesla has used to explain the same phenomena in the radiant energy device, and its operation.
cheers, rainbow in the sky lalala...:angel:
Classic book series, download PDF lodge, or listen to the  modern view in audio.
 There are many books by this author sir Oliver lodge..
modern views of electricity   sir Oliver lodge..
Electrons, negative energy    sir Oliver lodge..
« Reply #29, on January 21st, 2012, 01:26 PM »Last edited on January 21st, 2012, 01:51 PM by freethisone
battery operated neg ion gen.  <<<< link.
see this link for the circuit design.
circuit design ion gen.  <<<< link
Russ has been kind enough to help me purchase  a battery operated neg ion generator.
My proposal,  it should be easy to test output vs input. the time the battery drains vs. how much energy can be stored in a capacitor, or used as work.
Time vs energy drain. time vs stored energy. adding all the numbers will prove beyond a doubt the possible uses for such a device.
here is a simple way to do a test.
1. charge battery to 12 v, use ion gen for a time long enough to drain 2 volts energy from the battery.
2. now you have a time energy is dissipating 2 volts.
3. hook up a primary and secondary conductor like i have done.
4. test drain time of 2 volts using a primary conducting plate.
5. we now have comparison to work with.
6. add capacitors to obtain the 2 volts drained from the battery, and take the time again for the drain to occur of 2 volts.
7. this will enable you to make real world testing, and real world calculations of charge, vs discharge, vs stored energy, vs time.
Any thoughts?  :idea:  i WOULD PREFER A NON GROUNDED BATTERY OPERATED NEG ION GEN TO CONDUCT MORE EXPERIMENTS. This could work even though it is grounded, but may cause the battery to drain off to quickly. I will add a secondary ground wire off the primary ground as shown in my finger painting.
Tesla modified version, as seen PDF file radiant energy.  chapter 7 below.  This would almost be precisely as described.
« Reply #30, on January 21st, 2012, 02:41 PM »Last edited on January 21st, 2012, 02:55 PM by ~Russ/Rwg42985
Quote from freethisone on January 21st, 2012, 01:26 PM
you will have separate ground... but i dont know if the internally grounded? you can check when you get it.
its not the one on that site.its this one: http://www.etp-inc.com/90-900014-901.PDF
 Be Blessed and Bless... Help And Be Helped, Dont just talk the talk... Walk the walk!!!
God Bless,
« Reply #31, on February 15th, 2012, 12:25 PM »Last edited on March 20th, 2012, 10:02 AM by freethisone
Thanks Russ, I did some experiments with the new DC units.
The effects are not at all the same, as with the Neg AC units.
The vibration from the dc unit is a bit High, and the electrical density a bit low to get the desired effects.
I will have to be a more creative if i want the desired effects.
At this point The AC unit works best, and is in close accord to Tesla Radiant energy device.
I really Just wanted to Say Thanks for helping me out, and also to Bruce. Thanks again for your help, and the DC units.
« Reply #33, on April 24th, 2012, 03:08 AM »Last edited on April 24th, 2012, 03:09 AM by ~Russ/Rwg42985
Quote from freethisone on April 23rd, 2012, 07:58 AM
interesting patents, related. UFO airfoils.
advancement physics. lifters. ion skin effect, airplanes UFO submarine..
https://www.youtube.com/watch?v=uF8otSSPgdA
i did not read it but just looked at photos!
and...
hahahahaah! that is to crazy! that's a cool concept!!!
so this works on ionized gas... ( ambient air gas) so what happens to this craft when it gets close to the outer atmosphere or even space?
too cool. that's some crazy work there!
INVENTOR3
« Reply #35, on May 11th, 2012, 04:33 AM »
Quote from KevinW-dirtwill on April 27th, 2012, 07:18 AM
Neat stuff guys.
What do you think of this video?
https://www.youtube.com/watch?v=IkpPbro-EAk
Ohhh, beautiful video!!,,,i only had time to watch half of it so far,,,i will have to continue watching it later, time for work now.  Wow, finaly, someone got their head out of their ass.  Yes, yes!!  This is reality! Great video. I like what was said at 6:00-6:30.
We all have our own time!  Time has to be relative to mass!!
Wow, there is someone else in this world that agrees with me! :-)  Maybe im not as crazy as i thought, hehehehee.
I will comment more after watching the rest,,,I LOVE IT! :-)  Thanks for posting!
cncjoe
« Reply #36, on May 11th, 2012, 10:01 PM »
Please forgive me for being dumb but could anyone tell me how to replicate freethisone's experiment? I don't even get what is happening there...:huh:
« Reply #37, on May 12th, 2012, 06:38 AM »
Quote from cncjoe on May 11th, 2012, 10:01 PM
Hi Joe, I have a request out to post a complete schematic for this technology, hopfuly we will see something soon, Jeff.:D
KevinW_EnhancedLiving
« Reply #38, on May 12th, 2012, 05:31 PM »
Quote from INVENTOR3 on May 11th, 2012, 04:33 AM
Neat stuff guys.
I haven't made it all the way threw yet either. It is  alot to take in, might take a couple of watches.
« Reply #39, on May 18th, 2012, 03:40 PM »Last edited on July 16th, 2013, 04:21 AM by freethisone
Quote from Jeff Nading on May 12th, 2012, 06:38 AM
https://www.youtube.com/watch?v=ivewO2BVZHo&feature=related
Great movie Thanks for the link. will do Jeff.
:cool:
« Reply #40, on May 18th, 2012, 04:29 PM »
Quote from freethisone on May 18th, 2012, 03:40 PM
:cool:
Thanks freethisone.:cool::D
« Reply #41, on May 19th, 2012, 04:49 PM »Last edited on May 19th, 2012, 05:00 PM by freethisone
"cncjoe Wrote:  Please forgive me for being dumb but could anyone tell me how to replicate freethisone's experiment? I don't even get what is happening there...Huh"
Hi  there. what part are you interested in? charging capacitors? This is what i had planned. Pulling energy from an over charged air, to an under charged conductor? I think this is how he explains it.
It is getting very Interesting. I have a book mark below, its an audio book.
learning about electricity should listen to a few pages.
Any one interested in understanding some of my experiments as  well, the classic book will open up a few doors by listening to some of the experiments.
I have some really good ideas for advancing these lifters. download moving fluids, the last PDF file posted.  This is a great file. It gave allot of information, and was unaware it had existed.
Thanks guys keep it going..
Electrical researches of Hennry C.
cncjoe
« Reply #42, on May 19th, 2012, 05:50 PM »
Quote from freethisone on May 19th, 2012, 04:49 PM
Hey, thanks for responding bud. Yeah, pulling energy from overcharged air into an undercharged conductor sounds like a GREAT start! So, it seems to me like what you are doing is running an ionic breeze across a conductor (what does that accomplish?) then harvesting it. You seemed really excited by it but I never understood the significance of it. I'll try listening to and understanding the audio book you posted (thanks for that by the way) to try to get up to speed with this but I fear that I might not have the ??? to grasp it. Thanks again!
joe
« Reply #43, on May 19th, 2012, 06:00 PM »
Thanks freethisone, I'll look at it, Jeff.:D
« Reply #44, on May 20th, 2012, 02:36 PM »Last edited on May 20th, 2012, 02:46 PM by freethisone
Hi Jeff , thanks for asking. I will add some files to this in the future.
In my mind i see an incompressible fluid, and a way in which to act on it.
The information Tesla had provided on the radiant energy device in my mind, teaches us how to move charges and the negative energy being significant. See Tomas Bearden for additional information. I will add the Tesla PDF also..
Thanks guys for the interest...:cool:
What happens at a sharp point? Even though according to MIT lecturer Walter lewin, the conductor is said to be in equilibrium. If it is charged with the same potential.  The density of that charge is greater at these sharp points.. We then may say no matter how we act on that conductor it will always remain in equilibrium. I add a sail to catch the wind, according to Tomas Bearden.
Fascinating...
« Reply #45, on May 20th, 2012, 02:57 PM »
Quote from freethisone on May 20th, 2012, 02:36 PM
Fascinating...
Thanks freethisone.:D
cncjoe
« Reply #46, on May 20th, 2012, 07:56 PM »Last edited on May 20th, 2012, 08:09 PM by cncjoe
So where can be found patent #577,671? never mind... Googled it. Sorry!
« Reply #47, on June 1st, 2012, 02:15 PM »Last edited on June 1st, 2012, 02:18 PM by freethisone
Below is two quick drawings i made, incorporating other configurations, and concepts.
The classic lifter uses one wire only, insulated from the body arranged to have  a gap about 1 centimeter, or so from the main negatively charged body.
If using DC the body was charged negatively for best results.. TESLA AC current is best for all his flying crafts. Cigar shaped...
My ideas take the new PDF file labeled moving fluids, and incorporates a circuit to get the desired pulse train.  A Lot can be learned from a few experiments.
Take a look at my finger paints. I incorporated a second, third, or even a fourth wire.:blush:
Now from there we would pulse the voltage farthest to closest, increasing voltages by double? read PDF...
we could try a steady negative charge on the  main body  100,000 volts, or not charge it at all.  I could even incorporate sharp points.
This is only in the experimental stages, and would require more equipment than i have to produce the results. My plans would be to try different configurations. styro foam balls with aluminum foil. etc you can be creative as you learn.
Peace all..
« Reply #48, on June 18th, 2012, 12:53 PM »Last edited on June 18th, 2012, 01:02 PM by freethisone
[/quote]Hey, thanks for responding bud. Yeah, pulling energy from overcharged air into an undercharged conductor sounds like a GREAT start! So, it seems to me like what you are doing is running an ionic breeze across a conductor
 You seemed really excited by it but I never understood the significance of it.  Thanks again!
joe[/quote]Yes harvesting it. What is significant, not many may know this, but this effect of the ionic breeze was discovered by Tesla. It may have also funneled down to DR. Townsend brown also.
the energy was observed in my first few experiments. That was when i had opened the door, and i could smell ozone in the air. Energy from the spark gap had greatly increased. This may also be accomplished with UV lights according to one of the papers i had read.
The experiment by Tesla, the one in witch he drew smoke from a very far distance to one of his devises.  Tesla had a generator type machine that draws in cold electricity from the vacuum. this was the device in question.  Higher mass, and a greater potential is needed if you want to pretend to be Tesla. LOL
yes im very exited, but this is lost secrets. rediscover them is what we will have to do.
mass of an object interacting with charge, or surface area. The higher the furnished charge, the greater will be the energy you may capture from a sailing ship.
Cheers:cool::cool::cool:
Also this can be adopted it is also a off shoot of the speaker that was a wash board, Brown had demonstrated this device. look them up if you have time.. it had created very clean sound. Just like the  Michel Rodan coil can produce.
INVENTOR3
« Reply #49, on June 21st, 2012, 03:57 AM »
Many will say that the Lifter can Not work in a vacuum, and they even showed this on Myth Busters.    But here is old video of lifter, by NASA, working in a vacuum!!
https://www.youtube.com/watch?v=xYMUv1VJ3VQ&list=FL4veaoZVOJwJ4LdYGAjclwg&index=51&feature=plpp_video
Any comments?
Do we "really" know what effect is taking place here.  If this is working in a vacuum, can we really say this is an "Ion" effect?
FreeThisOne:  i like your designs/concepts.
