Just another note on Petkovs' experiment:
the generators output is 0-5v, this is very small voltage. On the oscilliscope you can see a few different voltages shown: left bottom of oscilliscope screen: ch1: 1.00v ( yellow)
middle bottom of osc. screen: 270mV Ch2? ( blue)
right top of oscilliscope screen: varies from 1 to 2v ( I think this is range setting?)
Anyhow if Ch1 ( yellow) is 1 volt, that a very tiny voltage, and ch.2 ( blue) I assume is voltage across resistor which gives indication of the current?
I've spent quite alot of time trying to find any information of low voltage pulses creating sound waves in water, I've not been able to find anything on it, so if sound is involved it would seem to be a new phenomenon not reported ( or not found by me). There are plenty of references to high voltage sound waves created in water, but are related to explosive gas release.
I'm just trying to make some sense out of Petkovs' results, and at the moment I cant find a relationship between the resonance points he found and sound waves in water.
It certainly doesn't help that i dont understand the oscilliscope results he shows, I'm hoping some others out there might be able to give some detailed synopsis of his experiment.
