Hi Guys
Man have i missed some stuff here.Been flat out with the pulse motor build of-along with Russ.
Anyway i have some questions-or a question
Why are people so intent on reduceing the cell temp?
First up,the hotter the water,the less amp's it takes to disasociate the hydrogen and oxygen atoms.
The reason you see an amp draw gain as the water gets hotter is because the higher the temp of the water-the better it conducts current.
So why not reduce the electrolite or remove it altogether,and lift the temp of the water?
The other thing is-why are people concerned with steam passing through into the engine with the HHO.
Steam is a good thing when running on HHO-it reduces pinging and the timeing dosnt have to be retarded as much.
It also increases the burn time of the HHO.
On another note-why dose everyone insist on useing DC ? why not use AC insted
It makes more sence to me to rock the voltage back and forth within the cell,rather than trying to push it in one direction.
Now that the pulse motor build off is near finished,i will be returning back to work on my motor generator setup.
I have an idea for an AC duel phase water capacitor that would also produce HHO.
The way this setup works,it wouldnt draw any more current or power from the prime mover that is driveing the generator.
I will keep you guys up to speed on how this turns out,and if its a win-then we can go from there.
If it's a dud,then we have learnt how not to do it lol.
Cheers guys
Glad you are liking my own little build-off - electronics never was my speciality but mechanics and electrical engineering were so I decided to go for the car instead. :)
The current challenge with heating is that the way I was doing it initially was already pulling 400+ Amps on 300 Amp rated cables so the hotter the cell got the more current it drew and so the hotter everything else became as well.
So I've had to opt to up the voltage to get the current draw down to something much more realistic so on the next setup it heating up may be a benefit as you say and I agree steam in there as well will be all beneficial; in fact we were discussing earlier about using a kettle or something like that to then introduce steam into the equation as well as some non-combustible exhaust gasses.
I'm using DC as Tom over at Punch HHO where I got the cells says in his information:
http://www.punchhho.com/about.php
Regardless of how you decide to drive your cell, you will obviously require DC voltage! Do not attempt to apply AC voltage to the cell, the results will be catastrophic.
So I'll ask him what happens if you put A/C across the cell...
Further on he also mentions it is important to iron out any A/C ripple from the supply as well:
Power supply filtering:
In rectified DC, you have what is called AC ripple. In fact using a full wave bridge rectifier you will see up to 45% AC ripple. AC ripple does us NO GOOD! AC ripple is just wasted energy that dissipates in the cell as heat energy. You can cut down on the amount of AC ripple by filtering in one of two ways. You can use a choke or more commonly an electrolytic capacitor. The purer your DC is, the higher your efficiency will be! Keep in mind, if you do decide to filter your output with a capacitor, you will increase your DC voltage by approximately 15%. So, if you are using the cell without a controller and just want to rectify your AC line voltage from your house, you would start with 120v and end up with about 138 volts! That's 2.5 volts per plate!
Good luck with your pulse motor and I look forward to seeing the finished one...
All the very best
ethospete...
