OFFICIAL RELEASE OF RUSSTIC WFC FREQ GEN V7.0
Schematic V7.0:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/SCH/Russtic%20WFC%20Freq%20Gen%20SCH%20V7.0.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/SCH/Russtic WFC Freq Gen SCH V7.0.sch
PCB Board V7.0:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/PCB/Russtic%20WFC%20Freq%20Gen%20PCB%20V7.0.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/PCB/Russtic WFC Freq Gen PCB V7.0.pcb
Print out a sample of "Bottom Copper Layer" on a sheet of paper. Cut your Glossy photo paper to size and tape it to your sample print with scotch tape. Then Re-Print the "Bottom Copper Layer".
PCB Instructions:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/PCB/Express%20PCB%20Instructions.jpg
I have also added a Printer File to Print the PCB without using Express PCB. Be sure measure and make sure the print is 4.6" x 6" before you transfer:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/PCB/PCB print File.xps
Download Express PCB to use .PCB and .SCH file extentions (PC Only)
http://www.expresspcb.com/ExpressPCBHtm/Download.htm
Parts List:
See Below
Check your IC Chip Numbers to see if they have been tested:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Tested%20IC%20chips.txt
Find all Related Files and Pictures Here:
Old Version 4.0 PCB and SCH
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/SCH/Russtic WFC Freq Gen SCH V4.0.sch
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/PCB/Russtic WFC Freq Gen PCB V4.0.pcb
Version 4.0 Build Pictures Here:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/V4.0%20Pics/
PCB Board Transfer V7.0:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%201.jpg
Quicky Drill Press:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/drill_press.jpg
Installing Components V7.0:
Note: if you have some flux, give your board a quick wipe. It will make installation much easier.
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%202.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%203.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%204.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Signal%20Tester.jpg
If you do not own a scope and are having trouble troubleshooting. You could make a signal tester to help you out.
Mika and Insulators:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Indulators%20and%20Mika.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%206.jpg
After soldering the board you can apply a non-conductive grease or oil to the copper traces to prevent oxidization.
Building the Box V7.0:
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%205.jpg
If you are using a different type box, an alternative could be to rotate the board 180 Deg and place the Heat Sink on the outside of the box. There is a fan port behind the Heat Sink, but these Mosfets may get to hot for this box depending on what you plan on running threw them.
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%207.jpg
*Note: Resistors pots with low resistance can be added in series with R4 and R9 for fine tuning.
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%208.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%209.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2010.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2011.jpg
(All these Red wires are not in the Schematics, They are run threw switches so only 2 Meters can be used instead of 4)
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%20SP2T%20Switch%20Switch.jpg
I used this 4P2T switch (Rated 15A 125V AD/10A 250V AC) To Switch my amp meter between Sig 1 Out and Sig 2 out.
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2012.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2013.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2014.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2015.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2016.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2017.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2018.jpg
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/Russtic_FG_V7.0_Build%2019.jpg
___________________________________________________________________
Russtic 7.0 Boards, Parts & Kits
Circuit Board:
Etched Board - $50
Etched Drilled Board - $80
Parts:
The Parts are setup in a spreadsheet so that you may remove any parts you may already have and thus reduce the price
See .xlsx files
*Note Only one "Parts Picking" Price Will be Paid [$30] ,Also prices may vary as cheaper parts are recieved
Russtic 7.0 Necessary Board Parts [$57 + Parts Picking]
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/parts/Russtic%207.0%20Necessary%20Board%20Parts.jpg
(This is everything to solder to the board)
open-source-energy.org/rwg42985/russ/russtic_testfiles/parts/Russtic 7.0 Necessary Board Parts.xlsx
Russtic 7.0 Necessary External Board Parts [$20 + Parts Picking]
http://open-source-energy.org/rwg42985/russ/russtic_testfiles/parts/Russtic%207.0%20Necessary%20External%20Board%20Parts.jpg
(This is everything not soldered to the board, but still needed to get it working. Like the pots/switches/LED's) Look at the spread sheet
open-source-energy.org/rwg42985/russ/russtic_testfiles/parts/Russtic 7.0 Necessary External Board Parts.xlsx
Russtic 7.0 Extra Parts [Varies in Price] (Drill Bits / Meters / Switches...)
open-source-energy.org/rwg42985/russ/russtic_testfiles/parts/Russtic 7.0 Extra Parts.xlsx
Kits:
Etched Board and/or Parts - See Above for Prices
Complete Tested Board - $140 + $57 (Necessary Board Parts) + $20 (Necessary External Board Parts) + $30 (Parts Picking)= $247
Shipping:
Depending on Size and Location $3-$20
My Contact Info Can Be found at Enhanced Living .ca
Kevin Williamson
Schematic V7.0:
PCB Board V7.0:
PCB Instructions:
Parts List:
See Below
Quicky Drill Press:
Circuit Board:
Etched Board - $50
Parts:
See .xlsx files
Kits:
Shipping:
Kevin Williamson
