I have been reading through your thread. I thought you guys should check out this comment about resonance from Peter Lindermann explanation:
"Transcription from MDG, for nov07 update:
..Now, the obvious problem with this situation is this, he is using the word resonant
here, like salt and pepper all the way through.
This is not a resonant circuit, this was part of the diversion about how to keep
people, how he protected the idea without actually leading people to understand what
was going on, and the proof that this is not a resonant circuit lyes in the bloking
diode ! huuuuuuu gushh
so what you can see here is what he is really doing is this, this system works without
electrolyte (MDG: Air being the dielectric layer to breakdown) ; so the purpose of it
is, he wants his water to have a fearly high resistance in it, and so, here is what he
is gona do, he got this chokes, this chokes are very important because when he puts
this inductive spikes on, here, ... with the diode, what he is doing is, he is charging
this capacitor, and the resonant chokes are specifically to damp the voltage spikes
that could prematurally set this thing off.
So what he is doing, he is making sure that he can charge this capacitor with kind
of soft pulses and pulse the thing up, so he can get this capacitor to charge to the
maximum degree before the dielectric material, in this case water, creates a
catastrophic dielectric failure in the capacitor
At which point, all the charge in the capacitor, all the voltage in the capacitor is
converted to amps as a shorts out internally, and orderly destroys the water it
moves through and creates massive quantities of hydrogen and oxygen.
(minute 3.00 of this video)
and as soon as it's out of the way, water rushes its back in, the dielectric constant is
again re-established, and this is what's happening, while this is happening, he waits,
and starts charging again.
(showing of patent page drawing progressive water molecule stretching under pulses
train)
again this types of drawing were made to confuse people, you know the idea of
drawing this things are that these were increasingly large resonant pulses and
everything, this is all a bunch of ... , all he is doing is just like any other voltage
multiplier that's used in pulsing, all you are looking up is a step ramp charger on a
capacitor until it reaches it's catastrophic failure, that is the method of the Stan
Meyer's system, and it does produce massive amounts of gas for a very small amount
of electricity."
For more details refer to this attached pdf file:
http://hodinfo.com/forum/topics/stanley-meyer-resonant#axzz1wxqbp3Rzdownload the attachment stanmeyers.pdf
Please let me know if anyone was successful in replicating stan meyers work with the schematics/ electronics developed here in this forum.
For those who need to replicate his work and dont want to spend much time building the WFC they can purchase it from this guy in australia. He also sells the stan meyers electronics but I doubt he includes the VIC with it. You can also use his schematics to build one and then add your own VIC or step up transformer. I think stan meyers idea is pretty simple. Use pulsed DC which is fed to VIC and the voltage does the job! please let me know if this analysis is wrong or not. I think resonance scanning is not needed here.
http://www.thehydrogenshop.com/index_shop.html
