That last statement, "When I'm done, you will know what I know.", sounds like a challenge to me. I'm pretty old, slow and there's a lot of calcification in my brain, but if you are up to the challenge, I'll try to learn.Quote from bussi04 on December 9th, 2013, 06:51 PM Russ has made another video at Boulder documenting Edward Mitchell´s Stan Meyer type setup putting high voltage into the water fuel capacitor
https://www.youtube.com/watch?v=jCnRdiKbINM
enjoy!
I still think there is something far different than just typical high voltage pulses going through that water, something we need to figure out. Scalar waves maybe? Yes, whatever it is, we need to understand it better, then we can really use it. And as for, "The scope doesn't lie.", I suspect the scope doesn't tell the whole story either--just reference guys like Tesla and Leedskalnin.
I told Russ just about all there was to tell so he now knows what I know, though I did make a mistake about the parallel connecting of the transformers as told in this post: http://aetherforce.com/inventors-diary-failing-to-learn-making-good-use-of-the-scientific-method/
As far as understanding the technology goes learn all you can about atoms and how they ionize as science doesn't tell the full story. When you look at how a leaf breaks down the water molecules you will learn that it traps the electrons so that the water molecules break apart. It uses sunlight, at the correct wavelengths, and potential difference with no current perfectly, and the spacing between it's potential zones are only a few molecules thick.
It really doesn't have anything to do with scalar waves, gas clusters, or anything like that, it's just simple ionization taking place in a new medium we are not use to dealing with. The use of the word medium is where the reaction takes place in referring to gas (air), liquid, or a solid medium. A lot of us know a little something about ionization in an air medium but know next to nothing about ionization in a liquid medium and most simply didn't know that it is possible too ionize atoms in a liquid medium. Meyer's technology is capable of ionizing the atoms even in a solid medium like ice breaking water in it's solid form directly into ionized hydrogen and oxygen gases. In the past you have heard me talking about this drawing:
This waveform is brought on by transformer action and yes it is some sort of an A/C waveform. But now think about ionization as this is where your mind should be. Air ionizes better in A/C than it does D/C correct? But now you have to get down to the what is actually being ionized so that you understand just what is taking place.
The oxygen molecules are being broken down into monatomic oxygen atoms when the electrons, by way of ionization, are free to move away from the atom. It is the electrons job to hold the molecules together and if something allows them to just take off the molecules simply falls apart.
When most people hear what I am saying about this they think I am coming out of left field and you know what? I am. As this technology is totally new in how it works and being so you can't pick up a book and learn much about it, thus you are forced to make use of the scientific method as I have been using for the past several years.
Now we want to ionized the oxygen atoms when they are making up the water molecules with hydrogen. And as a bonus hydrogen's ionization energy level is just about the same as oxygens. So, you need a potential difference of the proper voltage being applied to the atoms that make up the water molecules while restricting the flow of amps into the milliamp range. The waveform shown in figure 10-5 is sort of correct but you must now be able to understand the many different forms of drawings as this is what we in architecture call a block drawing and they are not blueprints as they can legally lie in most cases so look up what is a block drawing you can learn more about them. Now some of this is new to you but a lot of this is something you have heard before, right? Learn to toss out all the things leading you away from ionization and then it all becomes clear what you have to do.
There is a reason why this technology has not been solved since the death of Stanley A. Meyer and that reason is people lost sight of true scientific principles in favor of the quick and easy guess methodology. And given the time that has went by it should be clear by now that guessing didn't work out all that well for practically all that gave this technology a try. From reading drawings wrong to just plain making stuff up people have really made a mess of this technology bigtime to the point where no one knows which way to go anymore. All that are left working on this technology now are the most stubborn people left on this planet for he most part. The rest simply don't have the skills necessary to be able to reason this technology out. Without making use of the scientific method this technology is impossible to figure out as it is something totally new to us.
So, looking at figure 10-5 knowing we are now using a modified A/C wave to place a potential difference on the atoms in a liquid medium we can start to see how it all truly works. Get the atoms to go into a state of ionization and they all sort of quit their day jobs.
As can be seen I am putting 5.2 kv to the cell while at the same time restricting the flow of amps as in this shot the amps flowing through the cell are only around 25 ma. But the waveform isn't what it should be as I am not getting a strong enough negative step charging effect, so I too am not out of the woods totally even though I understand what needs to be done. Like everyone else I have to lean to build it all correctly the old fashion way through trial and error. But from what I have shown and told you it be clear by now that I am getting to the point of allowing voltage to take over while restricting the flow of amps just as Meyer said he was doing.
Why people don't follow my lead is a total mystery to me? Having heard Meyer's talk about putting high voltages to the water bath and then turning around a listening to someone telling you you don't need to do so is beyond my ability to comprehend. But looking at the replies to this thread and any other thread that someone has dared to post the interview of Gunther and I at the Global BEM has been a total rejection of this technology as if they have seen someone getting far better results with their efforts to allow voltage to take over while restricting the flow of amps.
Not only do I tell people to hook up their cells in series I show them and also show getting some high voltages to the exciter array and others come right behind me and tell people that's a total waste of time and everyone seems to listen to them for some crazy reason. They say, he's not really getting high voltages to his cells as the voltage he is showing has to be divided evenly to all of his cells, well, did you yourselves to the math on that one? Here let me show you as it's simple 5200/12= 433 volts per cell. Now who in here has seen voltages this high being place on a cell before without that someone cheating by coating the cells with some illegal substance Meyer never used and/or ever talked about using before?
Then there are my personal favorites that go around telling everyone that owe he isn't making any gas so therefore he must be doing it wrong as Meyer was making gas. These are the people that totally fail to understand how ionization actually works even with leading questions like the one I ask and answered in my last post here. If you don't reach the ionization threshold for the atoms then you simply don't get any gas production as you haven't paid the atoms enough to walk off of their jobs yet. They will only walk away from their jobs if you pay them the right amount of money or higher as they have their pride you know and will only lower their standards if you shine some pretty lights in their face but it too must be something they really like.
I know I can be hard on people as I simply will not accept information from any of these keyboard only lab technicians who's only real lab time is mostly spent dreaming about it in their heads. Nor will I accept anyone that tosses out the scientific method as from my point of view we really don't have anything to talk about. If your not someone that ever makes it to the lab so you can fail to learn I more than likely will simply ignore you as that is what I have to do in order to keep my notes clean of gute feelings and personal beliefs. Basically if you have an idea try it, observe the results, and figure out if those results did or did not answer the original question. Then you must share your results be it good or bad as then you will be able to learn from your mistakes and perhaps one day learn to walk.
Some perceive me as being arrogant or full of pride or something along those lines but really I just make use of the scientific method and can tell you have failed so many times I have lost count but each time I failed I learned something. And now it seems I am learning how to crawl perhaps one day soon I will learn how to walk and always remember I did it by failing to learn and never giving up.
If you want this you are going to have to be the one that makes it happen on your own or wait until something comes to market as these are your only two choices.
GodSpeed everyone,
Edward Mitchell
CEO and Owner
True Green Solutions
