just going back to davy oneness mentioning russ testing coil in hotel room, I believe that coil is the one that is thought to go with the water injector of stan ( not the water heating).
The link of davy on cold fusion at low temps, is an interesting read, though its dealing in large part on theoretical considerations on a wide range of topics in a short synopsis. It may well be directly relevant to the workings of stans system, but very difficult to use that in a meaningful practical manner to the problem of efficient water heating method that meyer has patented.
Once again ( as with stans work on the wfc) there is a lack of published research data by Stan showing the measured efficiencies of the water heating process. Stan also seems to have neglected to publish detailed results on the efficiencies of the wfc system ( he gives data on gas produced but only as statements not in the way of detailed research articles/papers).
Its always been a problem for me to accept this oversight by meyer. If you had developed a high efficiency water splitting and also water heating system, apart from patenting the systems, you would want to make sure you had irrefutable data/research showing how these ground breaking efficiencies were measured............in great detail.
I would also think this is an area of priority for anyone trying to replicate stans patents/experiments. Its a long journey from finding out about water splitting technology ( puharich/meyer), then understanding it at least in part, then to actually try replicate the work.
We are all at different levels in that journey, it would be truly remarkable to see a replication of meyers injector or water heating device, with some actual data on efficiency.
I think davy oneness contribution to the circuit reverse engineering is excellent contribution, but it will take time to build the circuit and test it
