This thread is dedicated to Stan's steam resonator and replication progress.
Progress so far from YouTube user THEWATERENERGY1:
https://www.youtube.com/watch?v=fsmdSkYEp6M
The description of this video is paraphrased to be easily readable:Quote
Heat/Steam Resonator (element) Stan Meyer style circuit test @ 90VDC, 1A, 1.2 KHz
We are testing this element for the home heating boiler. Heating up 1 liter of water from 15 Celsius to 90 Celsius in 1 second is faster than a magnetron. The element used in this test is "3XXX 3#INCH". We are using a new circuit for this test.
What we are doing is testing a circuit at various frequencies and voltages at low amperage to find resonance and to quickly heat the water.
The reasons why you would need a "heat resonator" is, for example, to defrost the fuel tank, with water as fuel, in the winter if it is frozen. We would also use the "heat resonator" in a home heating boiler to heat up the water and pump it around the house to have a warm house in the winter. In Europe, we use a lot of propane in the wintertime to warm up our houses.
In the future, we will post more information about this system at work.
