If you could please :D send me a link to the exact discussion you are referring to :D, my time is limited at this point in time, thanks.
I found the link that shows the coils.
http://peswiki.com/images/0/00/Jackson_wireless_power_transmitter_300.jpg
http://peswiki.com/index.php/OS:Tesla%2C_Meyl%2C_and_Jackson%27s_Wireless_Aetheric_Power_Transmission
RepRap 3d printer, Prusa Mendel
Very interesting, thanks freethisone, I will be looking into this as time permits.:cool::D:PQuote from freethisone on January 14th, 2012, 06:51 AM If you could please :D send me a link to the exact discussion you are referring to :D, my time is limited at this point in time, thanks.
RE: Free 3d printing
« Reply #77, on January 29th, 2012, 06:00 PM »Last edited on January 29th, 2012, 06:02 PM by Jeff Nading
Well, just another mod I did on my 3d printer and more to come.
https://www.youtube.com/watch?v=xz1soCwMwhU
« Reply #78, on February 18th, 2012, 02:46 PM »Last edited on February 18th, 2012, 04:05 PM by Jeff Nading
Ok, first photo, is an attempt to build the heated bed plate. It worked for pla but it would not reach temperature to cycle on and off for abs printing. So, I went back to the drawing board, as it were. Came up with a completely new design. I made my own heater elements for the aluminum print bed plate, they will be screwed on to the plate, so in the event that one would fail it could be changed out very easily. All of them will be powered and controlled through the Arduino board. From my calculations it should take 11 heater elements wired in parallel, this should give me about 100 watts, the plate should heat up quickly @ this rate. I might have to change the power supply to maintain this level of power, I will have to wait and see. I will run power though the elements with a separate power supply and a relay connected from the Arduino board, just for test purposes, this should allow me to test voltage and amperage. If all goes according to plan :huh: , I will connect it through a fuse then to the Arduino. :D See photos of the elements I built.
I just tried printing in ABS today. My heated bed got to temp but sure took longer than PLA. lol I still didn't get a good first layer, it all flaked off. I was using blue tape, I'm sure ill need kapton or that other tape with the ABS wash solution. I'm not sure if ill try it again, the smell is horrible.
The resistor blocks look great Jeff!Quote from Jeff Nading on February 18th, 2012, 02:46 PM Ok, first photo, is an attempt to build the heated bed plate. It worked for pla but it would not reach temperature to cycle on and off for abs printing. So, I went back to the drawing board, as it were. Came up with a completely new design. I made my own heater elements for the aluminum print bed plate, they will be screwed on to the plate, so in the event that one would fail it could be changed out very easily. All of them will be powered and controlled through the Arduino board. From my calculations it should take 11 heater elements wired in parallel, this should give me about 100 watts, the plate should heat up quickly @ this rate. I might have to change the power supply to maintain this level of power, I will have to wait and see. I will run power though the elements with a separate power supply and a relay connected from the Arduino board, just for test purposes, this should allow me to test voltage and amperage. If all goes according to plan :huh: , I will connect it through a fuse then to the Arduino. :D See photos of the elements I built.
Here is my 3d printer heated bed plate almost ready to install, see photo.
I was invited to show my 3D printer @ the Witte Museum today, along with the guy's from Hackerspace 10bitworks, for an annual event called build it day, there was a very good turn out, children and adults, got a real bang out of the printers shown. I also enjoyed showing off my work. Here is a video of the event. https://www.youtube.com/watch?v=-ezOKwrMm9w&feature=plcp&context=C3360e72UDOEgsToPDskIaJa3ULbQGIrmKOZ1pNQFV
Printing more parts, for mod's on my printer. Heated bed is working very well, reliably so, takes about 12 minutes to heat up, with the aluminum plate and double strength glass on top to print on.https://www.youtube.com/watch?v=6gOhH_U4Ijs&feature=plcp&context=C3360e72UDOEgsToPDskIaJa3ULbQGIrmKOZ1pNQFV
« Reply #84, on March 9th, 2012, 07:51 PM »Last edited on March 9th, 2012, 07:53 PM by Jeff Nading
Well I just did another upgrade on my Prusa, man it payed off. I finally figured out why the resolution wasn't just right, my hotend was moving within the extruder block, so I got rid of the pin setup that held the hotend supposedly in place. I made an aluminum plate with a slot cut in it, to slide around the neck of the hotend, it doesn't move at all now. Also went with the Wades hinged extruder with the larger gear, recalibrated the e drive. The wades extruder block is opposite of everyone else's :huh: , which I like much better. If you want to know how I did it just ask and I will tell you :blush:, Ha :P :cool: . I printed out a duel fan X carriage using the lm8uu linear bearings, like it much better as well, now I'm printing. Have allot of stuff to print out , and then bobbins, ya :P:D:cool:. I'll post a video soon.
My makergear hotend came with a laser cut wood piece that does the same. It works well, even aftera few stupid mistakes causing impact on my part. :). Did you get the x ends to work out?Quote from Jeff Nading on March 9th, 2012, 07:51 PM Well I just did another upgrade on my Prusa, man it payed off. I finally figured out why the resolution wasn't just right, my hotend was moving within the extruder block, so I got rid of the pin setup that held the hotend supposedly in place. I made an aluminum plate with a slot cut in it, to slide around the neck of the hotend, it doesn't move at all now. Also went with the Wades hinged extruder with the larger gear, recalibrated the e drive. The wades extruder block is opposite of everyone else's :huh: , which I like much better. If you want to know how I did it just ask and I will tell you :blush:, Ha :P :cool: . I printed out a duel fan X carriage using the lm8uu linear bearings, like it much better as well, now I'm printing. Have allot of stuff to print out , and then bobbins, ya :P:D:cool:. I'll post a video soon.
Found a good deal on Arduino's, the mega for $32.00 @
http://s.dealextreme.com/search/arduino
« Reply #89, on March 22nd, 2012, 04:37 AM »Last edited on March 22nd, 2012, 04:43 AM by Jeff Nading
Well I'm printing again. Printed out a perfect gear and Nate's X motor end. Just finished another mod, the printed Y carriage, it has 4 linear bearings, instead of the 3 linear bearings, like I had on my old aluminum cast carriage which was only a month old. I found that using just 3 bearings, the carriage would wobble, then cause problems with a print. I think to, the weight is a concern, the little Y stepper motor can't move much weight. If there's to much weight it will lose steps or resolution will be off. Here's another video of my print, sorry, the first part is a little out of focus.https://www.youtube.com/watch?v=nQhBaDjDmAQ
My videos are always out of focus lol. I need a better mic on my camera, but I can't plug one in. I should of spent more $
Should I post stls on thingiverse? I think if they are only available here it will attract more people to energy research. To me thingiverse is becoming a place to go if you want to find a print to turn your iphone into a door stop.
I kind of wish I did 4 bearings too. Also my rods must be a soft steel, because grooves are wearing in from the bearings. The great thing is we can learn as we go and make improvents. Imagine if we had proprietary printers and was stuck with what we have. LolQuote from Jeff Nading on March 22nd, 2012, 04:37 AM Well I'm printing again. Printed out a perfect gear and Nate's X motor end. Just finished another mod, the printed Y carriage, it has 4 linear bearings, instead of the 3 linear bearings, like I had on my old aluminum cast carriage which was only a month old. I found that using just 3 bearings, the carriage would wobble, then cause problems with a print. I think to, the weight is a concern, the little Y stepper motor can't move much weight. If there's to much weight it will lose steps or resolution will be off. Here's another video of my print, sorry, the first part is a little out of focus.https://www.youtube.com/watch?v=nQhBaDjDmAQ
I would say Nate, it's a good thing that people have to come to this forum to download stl's :cool::D . Really, all one has to do is type in a key word like reprap on a Google search and there we are. To, what you and I have learned, the experience we have gained from building the Prusa 3d printers, this is valuable information that you and I have posted :cool: , it will help others not make the same mistakes we have made [ you less than I] :P . So, this knowledge base here is worth the effort for people to visit our forum, then see what we are about and trying to accomplish then join in, good for everyone :P:D:cool: .Quote from firepinto on March 22nd, 2012, 05:11 AM I kind of wish I did 4 bearings too. Also my rods must be a soft steel, because grooves are wearing in from the bearings. The great thing is we can learn as we go and make improvents. Imagine if we had proprietary printers and was stuck with what we have. LolQuote from Jeff Nading on March 22nd, 2012, 04:37 AM Well I'm printing again. Printed out a perfect gear and Nate's X motor end. Just finished another mod, the printed Y carriage, it has 4 linear bearings, instead of the 3 linear bearings, like I had on my old aluminum cast carriage which was only a month old. I found that using just 3 bearings, the carriage would wobble, then cause problems with a print. I think to, the weight is a concern, the little Y stepper motor can't move much weight. If there's to much weight it will lose steps or resolution will be off. Here's another video of my print, sorry, the first part is a little out of focus.https://www.youtube.com/watch?v=nQhBaDjDmAQ
That's pretty much what I'm thinking. It would be nice if we could upload stls in unzipped form, i think we could have nice 3d views right in the thread. I might start thread to test that.Quote from Jeff Nading on March 22nd, 2012, 05:38 AM I would say Nate, it's a good thing that people have to come to this forum to download stl's :cool::D . Really, all one has to do is type in a key word like reprap on a Google search and there we are. To, what you and I have learned, the experience we have gained from building the Prusa 3d printers, this is valuable information that you and I have posted :cool: , it will help others not make the same mistakes we have made [ you less than I] :P . So, this knowledge base here is worth the effort for people to visit our forum, then see what we are about and trying to accomplish then join in, good for everyone :P:D:cool: .Quote from firepinto on March 22nd, 2012, 05:11 AM I kind of wish I did 4 bearings too. Also my rods must be a soft steel, because grooves are wearing in from the bearings. The great thing is we can learn as we go and make improvents. Imagine if we had proprietary printers and was stuck with what we have. LolQuote from Jeff Nading on March 22nd, 2012, 04:37 AM Well I'm printing again. Printed out a perfect gear and Nate's X motor end. Just finished another mod, the printed Y carriage, it has 4 linear bearings, instead of the 3 linear bearings, like I had on my old aluminum cast carriage which was only a month old. I found that using just 3 bearings, the carriage would wobble, then cause problems with a print. I think to, the weight is a concern, the little Y stepper motor can't move much weight. If there's to much weight it will lose steps or resolution will be off. Here's another video of my print, sorry, the first part is a little out of focus.https://www.youtube.com/watch?v=nQhBaDjDmAQ
Are you printing a set of X ends for spares?Quote from Jeff Nading on March 25th, 2012, 04:58 AM
Yes, the X ends are for another printer I want to build, want to try wax extrusion.Quote from firepinto on March 25th, 2012, 08:23 AM Are you printing a set of X ends for spares?Quote from Jeff Nading on March 25th, 2012, 04:58 AM
Ohh cool.. is that for casting metals?Quote from Jeff Nading on March 25th, 2012, 12:19 PM Yes, the X ends are for another printer I want to build, want to try wax extrusion.Quote from firepinto on March 25th, 2012, 08:23 AM Are you printing a set of X ends for spares?Quote from Jeff Nading on March 25th, 2012, 04:58 AM
Yes, eventually I want to build a printer out of aluminum, all parts cast. I'm also going to make the heated bed stationary, have two steppers move the Y axis and one move the Z axis.Quote from firepinto on March 25th, 2012, 02:34 PM Ohh cool.. is that for casting metals?Quote from Jeff Nading on March 25th, 2012, 12:19 PM Yes, the X ends are for another printer I want to build, want to try wax extrusion.Quote from firepinto on March 25th, 2012, 08:23 AM Are you printing a set of X ends for spares?Quote from Jeff Nading on March 25th, 2012, 04:58 AM
I just battled with my first prusa tonight. I had a Z motor coupler break, so I had replaced them with the newer print design. Well stuff started printing uneven. So while messing with it I found out the couplers were slipping, then they fell.:@ Then getting the Z and bed all matched up again.. what a pain. I can't wait to redo this printer, or better yet use my new printer! lol Z home position is the worst thing to set up on my printer. I need those adjustable magnetic endstops soon!
I'm printing the latest of my RAMPS box now. I'll try to get files out tonight for it.
