Update 2: YouTube video with an explanation of the theory presented here: https://www.youtube.com/watch?v=tZf0yhe4B80
Update: A short overview of what is presented in this thread:
What Prof. Turtur did is that he showed that the electric field, which is emitted by charge carriers, is an energy source, because the charge carriers that emit the electric field convert energy from the vacuum into electric field energy.
It has been known for a very long time that the electric field propagates (travels) at the speed of light, which means it is not a "static" force. Normally, when you work with electricity, you do not really concern yourself with the behavior of the electric field you are working with. And because the law of conservation of energy is such a basic law, no one gives much thought about the fact that a "charged" object DOES radiate energy in the shape of what is called a "static" electric field. Until Prof. Turtur.
Now a dielectric is a material that can be polarized:
https://en.wikipedia.org/wiki/DielectricQuote So, a dielectric can be polarized using an electric field. This effect is used in capacitors, whereby a dielectric is placed in between metal plates. When you charge the plates, the dielectric gets polarized and when you discharge the capacitor, the polarization also is undone.
However, a dielectric *can* be kept in this polarization state for quite a long time. An interesting demonstration hereof is this YouTube video:
/watch?v=9ckpQW9sdUg
And besides that, when discharging a capacitor very fast, the dielectric cannot keep up de-polarizing and an effect known as "dielectric relaxation" occurs:
https://en.wikipedia.org/wiki/Dielectric#Dielectric_relaxation Quote When you charge any normal electrolytic capacitor to, say 10 V, and then briefly shortcut it, the capacitor will afterwards recharge itself to about 10% of the originally applied voltage due to this effect.
So what we got is a material that can be polarized and thus creates an electric field, and this effect can last a considerable time period under the right circumstances. It is possible to create materials which are permanently polarized, which are called electrets. These materials are a/o used in electret microphones:
http://en.wikipedia.org/wiki/ElectretQuote So, the electric field which is made available by an electret or polarized dielectric contains energy. Energy that must come from somewhere. Now what Prof. Turtur has shown is that this energy is being converted by the atoms/molecules in the dielectric from energy available in the vacuum / zero point field / aether / or whatever name you prefer.
In other words: a polarized dielectric (electret) IS an energy source from a practical point of view.
Now when you put a polarized dielectric in water, as is done in an electrolytic capacitor, the electric field created by the dielectric extends into the water. Now when you polarize the very thin dielectric layer in a electrolytic capacitor very strongly, it is possible to create such a strong electric field in a very tiny area around the dielectric that the field exceeds the dielectric breakdown strength of water, and you get "dielectric breakdown":
http://classes.yale.edu/fractals/panorama/physics/dla/DBM/DBM.html Quote So, what happens then is that because of the very strong electric field, electrons are ripped of their molecules and thus ionization occurs. This is what is called a "plasma", and you get tiny sparks in your dielectric, in this case water.
In this situation, the very same reactions that normally occur with "electrolysis" - requiring external power by means of an electric current - now also occur within the fluid, *but* they are powered by the electric field, without any external current being fed into the capacitor, although *some* current is needed to "charge" the capacitor in order to polarize the dielectric.
And the trick to create a much stronger polarized dielectric layer than normal is to "charge" the capacitor with sudden high voltage spikes. That creates momentarily a very strong electric field over the dielectric and thus polarizes it very strongly. That is the essence of what John Bedini's chargers do.
This way, we can produce H2 / O2 gas, a usable fuel, while we extract the energy for the production of the fuel out of the aether (the name I prefer). So, we extract a lot of energy from the aether, while we only have to invest a small amount of current in order to get that energy, namely the current needed to "charge" the capacitor and polarize the dielectric.
Now since the amount of energy we acquire that way in the shape of a usable fuel is much bigger than the amount of energy we have to spent in order to get that energy, we get a system with a COP > 1 (Coefficient Of Performance), the same principle as being used in a/o geothermal heatpumps:
http://en.wikipedia.org/wiki/Geothermal_heat_pump
YOU spend a small amount of energy in order to extract a large amount of energy for free from a known energy source.
So, that is the essence. For practical application, quite a lot of details must be filled in, such as the choice of metal and electrolyte and the need for acoustic resonance in order to keep the fluid in sufficient movement. However, all that are practical considerations which are completely engineerable by a team of electrical engineers, mechanical engineers and chemists.
Hi all,
Agnar Kill said this to me on facebook:Quote Some time ago, I posted some ideas on the energetic forum about the electret effect, an observed effect that may very well be the key to understanding Meyer's technology.
There's a section on "the electret effect" in my article at PES, where there are links to the EF discussion, and at the bottom there is a link to a bedini video and some other material on what happens on the plates of the batteries:
http://peswiki.com/index.php/Article:Free_Electric_Energy_in_Theory_and_Practice#The_Electret_Effect
Bedini says something changes on his battery plates, and I think what happens is that a dielectric layer is grown, much like what happens in an electrolytic capacitor, especially the ones they made in the old days.
See: http://www.tuks.nl/Mirror/SparkBangBuzz/varelec-el.htm and http://www.tuks.nl/Mirror/SparkBangBuzz/borax-el.htm
I'm pretty sure this is the key to understanding Meyer's technology.
Will re-post some comments I made on the NPA_Dissidents Yahoo group on the matter.
NPA group extract 1:
Prof. Claus Turtur wrote an interesting piece, wherein he shows that the propagating electric (and magnetic) fields loose energy (to the vacuum), while apparently the particles (electrons, atom nuclieï, etc) that emit these fields draw energy from somewhere, since they don't loose mass. He came up with the idea that there is a circulation of energy between the vacuum and these particles and therefore you can in principle tap the energy emitted by particles in the shape of electro-magnetic fields:
http://www.wbabin.net/physics/turtur1e.pdf
When you accept the propagating EM fields to transport energy and you accept particles to somehow draw energy from the vacuum, which they emit in the shape of "static" electro-magnetic fields, then you have a foundation for building devices which draw their energy from the vacuum.
I believe Stan Meyer did this by creating a thin, semi-permanent polarized dielectric layer on his fuell cell tubes, which would be akin to an electret, just as happens in a normal electrolytic capacitor. Because these layers are very thin, it apparently is possible to induce a very strong electric field in a thin area inside the water around the dielectric, such that the field strength exceeds the dielectric breakdown fieldstrength of water, which then apparently splits into hydrogen and oxygen.
So, then you have a polarized dielectric which is, according to Turtur, capable of pulling in energy from the vacuum and convert that to electric field energy. And then this energy is converted into a usable fuel by having it split water into hydrogen and oxygen.
At least, that's my theory in a nutshell. :)
Extract 2:
> Stan Meyer . Was the energy output greater than the energy input without being clouded in smoke and mirrors . The input is water and the result of hydrogen / oxygen combustion is water . The writing in on the wall . The conservation of energy is a founding principle of physics that has stood the test of time . Mr Meyer seems to be a nice guy . I do not mean to be unkind however after watching his video I must conclude he is psychologically delusional believing god has given him a mission . It is sad to watch considering he has a bright mind and could have made fine contributions if life had dealt different cards.
> https://www.youtube.com/watch?v=Vd7QL1-NnlU
Yes, of course the conservation of energy is a founding principle of physics that cannot be overcome!
However, when you are capable of using an energy source that is already available, like for example light waves coming from the sun, then there is no breaking of energy conservation, while you still are able to get more energy out of the system than the energy you need to put in in order to get it. It is the exact same principle as using a solar-cell.
A better example is a Geothermal heat-pump.
https://en.wikipedia.org/wiki/Geothermal_heat_pump
"Like a refrigerator or air conditioner, these systems use a heat pump to force the transfer of heat from the ground. [...] The geothermal pump systems reach fairly high Coefficient of performance (CoP), 3-6, on the coldest of winter nights, compared to 1.75-2.5 for air-source heat pumps on cool days. Ground source heat pumps (GSHPs) are among the most energy efficient technologies for providing HVAC and water heating."
You need to spend a certain amount of energy to pump water down into the ground, etc., which is heated by the ground, an energy source that is available for free. The trick is that you spend less energy pumping the water down than the energy you obtain in the shape of heat which is extracted from the Earth, and thus you can obtain a COP > 1, meaning more energy out than in.
All right. Now the thesis of Prof. Turtur is that the "static" electric and magnetic field which are emitted by charge carriers contains/transports energy, energy which is somehow obtained by these charged particles from the environment whatever you may want to call it (zero-point energy, quantum fluctuations, Dirac Sea, whatever). In other words: particles extract energy from somewhere and make it available as a/o "static" electric field energy *without* breaking the law of energy conservation.
The question then becomes: how can we make use of this energy, just like we can use the wind to power a windmill or the sun's light to power a solar cell?
I believe one answer to that question is to use a polarized dielectric which creates a strong enough electric field that can break water into hydrogen and oxygen, whereby the dielectric transfers energy from the vacuum into the electric field it emits.
In other words: the idea is to use energy that is naturally extracted for free from the environment / vacuum / aether by a polarized dielectric in order to split water into hydrogen and oxygen, whereby you essentially convert some form of available energy into another, the latter being a useable fuel in the shape of hydrogen / ogygen gas.
For more details, see:
http://www.energeticforum.com/water-fuel/5590-basic-electrolysis-13.html#post102858
"Of course, this may not be the only phenomenon observed, but one thing is certain: Bedini's batteries do "cold boil" *after* the power has been shut of. In other words: there is at least one known way to split water into hydrogen and oxygen that can last long after any power has been fed into the system. The only way I see to explain that is that a (non permanent) electret layer has been formed on the plates inside the batteries, which is basically a polarised insulating layer."
Extract 3:
Let's first get one thing straight we agree on:
One cannot break the fundamental law of conservation of energy.
But, you can have "free energy" in the sense that you can extract energy out of some energy source you don't have to pay for in terms of dollars. There are numerous examples of this, like solar power, wind power, water power (Hoover's dam), Geothermal power, etc., etc. These are all accepted forms of free energy in my view which are commercially available and thus beyond the prototype stage already. I don't think there is any discussion about that either, so to me it is clear that you *can* have free energy without breaking the conservation of energy. It's just a matter of finding an energy source that is available for free.
Now of course the proof of the pudding is in the eating, but you can't make a good pudding without having a good recipe. So, if we want to build another kind of free energy devices, we will first have to identify a usable energy source and then figure out a way how to utilize it.
The first step towards that goal is the identification of a possible energy source and since it is well accepted that the static electric field stores/transports energy, it clearly is a candidate for such an energy source:
http://en.wikipedia.org/wiki/Electric_field#Energy_in_the_electric_field
"The electrostatic field stores energy. The energy density u (energy per unit volume) is given by ..."
Now since charged particles emit an electro"static" field, which propagates at the speed of light, it is clear that charged particles emit energy which is transported by the electric field into space.
Energy that must come from somewhere, because otherwise there would be a violation of conservation of energy. It is therefore obvious that charged particles are somehow extracting energy from their environment which they convert into "static" electric field energy. Prof. Turtur's thesis explains how this works, but the bottomline is that charged particles emit energy, energy that can (potentially) be utilized for free.
It's really just like wind or water power, just a matter of *conversion* of energy from one form into another. With wind or water power, one usually converts mechanical energy into electric energy using a generator. In this case, we need to convert electro-"static" energy into some usable form. So, all we need to do is find a way *how* to do this.
From this patent, it is clear that one can split water into hydrogen and oxygen using a sufficiently strong electric field:
http://www.tuks.nl/pdf/Patents/Eccles%20-%20Fracture%20Cell%20Apparatus%20-%20GB%202.324.307A.pdf
Now in this patent, they use like 25 kV over like 5 mm (or 5 MV/m) in order to induce a field with sufficient strength into the water. However, if you use an electrolytic capacitor whereby the ions inside your fluid form one of the capacitor plates, you have a very small plate distance:
http://en.wikipedia.org/wiki/Capacitor
"Electrolytic capacitors use an aluminum or tantalum plate with an oxide dielectric layer. The second electrode is a liquid electrolyte, connected to the circuit by another foil plate."
http://www.ami.ac.uk/courses/topics/0136_ec/
"A number of metals, such as tantalum, aluminium, niobium, zirconium and zinc, can be coated with an oxide film by electrochemical means.
By placing the metal in an appropriate solution and passing a current though the circuit, a thin layer of oxide forms on the anode. [...] What we have done is to produce an oxide that will ‘withstand’ the applied forming voltage, and will not grow and grow as rust does. This oxide film can be extremely thin1 (typically less than 1µm) as well as having a acceptably high dielectric constant. "
In other words, one can achieve the required field strength of about 5 MV/m inside a typical electrolytic capacitor by applying 5 MV * 1 µm = 5 V of potential across the terminals. And actually, unintended electrolysis is a well known problem with electrolytic capacitors, even today:
http://en.wikipedia.org/wiki/Capacitor_plague
"The situation of unimpeded formation of hydroxide (hydration) and associated *hydrogen* *gas* *production* occurred during "capacitor plague" or "bad capacitors" incidents involving the failure of large numbers of aluminum electrolytic capacitors. [...] Because it has been customary in electrolytic capacitors to *bind* the *excess* *hydrogen* with the help of reducing or depolarizing compounds to reduce the resulting pressure, the researchers then searched for compounds of this type."
So, therefore, I believe we have all the ingredients for our free energy pudding recipe right in front of our eyes.
To sum this up, what I am saying is:
1. I agree that the law of conservation of energy is a fundamental law which cannot be broken.
2. I disagree that you cannot make free energy devices, because one can utilize an energy source that is freely available, such as wind, water or sunlight.
3. Theoretically, any available energy source can be utilized.
4. It is well accepted that the electric field stores/contains energy.
5. It is well accepted that charge carriers emit electric fields and thus emit energy, which can thus in principle be utilized, all without violation of conservation of energy.
6. There is a patent which claims that a strong electric field can be utilized to split water into hydrogen and oxygen.
7. It is well known that electrolytic capacitors release hydrogen gas, which normally is unintended and creates a problem which takes quite a lot of effort to overcome.
Now you can argue that steps 5 - 7 is not what causes electrolytic capacitors to release hydrogen gas and that some other mechanism is responsible for that. I don't think so, but one cannot entirely rule out the possibility.
Other than that, I think this is a nice recipe for some kick-ass pudding, and I believe the prototype you were asking for has been built by Stanley Meyer and can thus be replicated using the principles stated just above. However, I do agree that the prove of the pudding is in the eating, so we will not know for sure before someone actually succeeds in building something like this.
I do intend to experiment with this stuff at some point in the future, wherein I intend to use this recipe for making DIY electrolytic capacitors:
However, at this moment I do not have the time to do so, because I amworking on another project:
http://www.energeticforum.com/renewable-energy/9727-who-performs-first-longitudinal-moon-bounce-history-6.html#post230353
A dielectric is an electrical insulator that can be polarized by an applied electric field. When a dielectric is placed in an electric field, electric charges do not flow through the material as they do in a conductor, but only slightly shift from their average equilibrium positions causing dielectric polarization.
Dielectric relaxation is the momentary delay (or lag) in the dielectric constant of a material. This is usually caused by the delay in molecular polarization[disambiguation needed] with respect to a changing electric field in a dielectric medium (e.g. inside capacitors or between two large conducting surfaces). Dielectric relaxation in changing electric fields could be considered analogous to hysteresis in changing magnetic fields (for inductors or transformers).
Electret (formed of elektr- from "electricity" and -et from "magnet") is a dielectric material that has a quasi-permanent electric charge or dipole polarisation. An electret generates internal and external electric fields, and is the electrostatic equivalent of a permanent magnet. Oliver Heaviside coined this term in 1885.
Dielectric breakdown refers to the formation of electrically conducting regions in an insulating material exposed to a strong electric field. For example, the intense electric fields during thunderstorms can produce a conducting path in the air along which many electrons flow (lightning).
Hi all,
hi Arend, read a comment you made at energetics forum, you said.. ''you could come up with a system that feeds "spikes" to the cap in order to maintain that non-permanent electret effect for a prolonged period of time, while only taking a minimal amount of energy to maintain the electret.'' this in a thread about Noelectrolysis water split..
Extract 2:
Extract 3:
