Hello all,
Just a quick post to show what I have been doing this w/end.
[attachment=3313]
It's very crude ATM but it works.
Producing HHO ATM with very inefficient brute force flat plate electrolysis (unit can just about be seen in background of video) with not enough production to run engine direct from HHO generator(filling balloons and running from them for testing)
What I would like to ask you guys is, what you think would be the best route to take (easiest, cheapest and most efficient) to produce enough gas to run this engine, It's a 75cc Suffolk Colt lawn-mower engine and I think it should only need approx 3 LPM to run at around 1000 RPM ????????????. I will be borrowing a very accurate gas flow meter tomorrow evening from a friend that works for a gas equipment testing laboratory, so will have better idea of how much it does need to run then.
I was reading somewhere on here I think but maybe elsewhere on internet (I've read so much lately my eyes hurt) about one of Stan's early designs think it was 8XA circuit and matching VIC coil that was working quite well with flat plate systems and is relatively simple to build and get working, albeit not as efficient as his later designs that are not quite perfected yet (I believe that we will get there soon) but cannot find where I read it again. Would this be correct and would this be a good place to start ?. I have a sheet of 314 stainless steel aprox 1.5m x .75m .8mm thick ready to cut up to make new unit but am looking for some guidance before wasting this stuff on something that is no better than what i already have.
Not played around with dry-cell units before but am willing to built that type of unit if you guys feel that would be best.
I'm hoping that this build will help me get up to speed with you guys so that I maybe able to help this community to succeed in finishing off what Stan started as I am very impressed with what you are doing and how you all work together. So please point me in the direction that will help us all and I will do my best to help where I can.
Thanks
John
[attachment=3313]
Thanks
John
