Thanks Dog, yes single feed ATM will fit more in/out ports and larger tubes and see how that works.
Post results later.
Post results later.
Did you try the 1 liter bottle fill time measurement yet?
Another test: Take your voltmeter and measure voltage across every pair of plates while it's running. That voltage should be nearly identical as you move across the cell.
Hole alignment: Those bottom fittings, are they inline with the bottom plate holes?
Yes, voltage across each pair is between 1.92 v and 1.97
Will be taking your advice and tearing cell down for a scrub up in the way you described. Thank you very much for detailed method and explaination of cause.
On a lighter note and some good news, this setup is definitely showing signs of OU. In a test run of generator done today I plugged a 500 W angle grinder into the AC output of the generator and was able to start cutting a piece of angle iron before balloon ran out :D. Using the calculator you posted with my cell info running at 35 A the cell would be using 419.90 W, and I'm 99% sure the engine is not setup to run correctly yet as it doesn't run long enough on one balloon full to mess with timing/fuel-air mix (I'm old-school and do most engine setups by ear), so should get even better.
Thanks again for all your help and support, hope I can repay in some way in the future.
Just found out some very useful information:
You will need plenty of air (Nitrogen) injected with the HHO and when the engine is running properly, the exhaust should smell of ammonia. You will also want to redirect some of this exhaust back to the intake for recirculation.
Link? to the info?Quote from Dog-One on March 6th, 2013, 03:43 PM Just found out some very useful information:
Nice work John. One quick note on your schematic: Don't double up (parallel) bipolar transistors--they don't work that way. One of them will get hot and the other one will do nothing unless they are both perfectly matched (which none are). You can do this with MOSFETs however, because of their temperature curves.
All-in-all, it's looking good though.
Bad news is I reassembled cell this evening and my last 10 days of work on it has made NO difference at all.
1. What amount of electrolyte should I be putting into de-ionized water ?
2. What sort of temperature would you think cell should run at ?
Sorry to say that but IMO Aaron´s information according to nitrogen and his $7 pdf is a scam. Of course most of ambient air consists of Nitrogen and so everyone can see that ambient air is in fact nitrogen plus oxygen plus some minor ingredients.
Everybody knows what happens if a human has to cope with a 100% oxygen atmoshpere. it doesn´t work at all. so everybody knows that nitrogen retards human oxygen consumption. nothing new so far ...
Quote:
"Air normally has no color, odor, or taste. It is a mixture of gases, primarily nitrogen, at about 78%, and oxygen, at about 21%, with the remaining 1% composed of carbon dioxide, methane, hydrogen, argon, and helium."
but what does that mean? at first you have to solve the problem for hydrogen production, for fuel supply and then next step you have to regulate for gasoline equivalence.
that´s no secret, that´s common sense published by stan meyer in his documents.
but is it the nitrogen that has to be ionized to get the process up and running or is it the oxygen?... that´s the question. AFAIK Stan says oxygen[/b].
Hi all, just a quick update on progress. Cell is now producing expected amount of gas (approximately 2LPM at 36 amps) Yippeee.:):):):). The problem was with my power supply, I did test with a car battery before and got the same results so believed that the problem was elsewhere but have now discovered that that battery is no good either. Latest test was done with a 120 amp car charger/starter borrowed from a garage. Have ordered parts to fix supply and will be doing more testing then.
Thanks for the info on Nitrogen Dog, I will test that out soon, have already tried with exhaust gasses and found engine ran smoother with it. My plan is to make a mixing chamber/manifold with 3 inputs for HHo, Air and exhaust gases all entering through adjustable flow valves so that I can alter the mixture ratio. Will post results soon.
Houston we have a problem.
This is the flashback arrestor I have been using for a long time with no problems at all, It's a water pipe repair fitting with end-caps drilled out to take a tube that is soldered in, it is filled with fine bronze wool and small stainless steel ball bearings (approx 1.5mm) about 1cm deep at each end and then stainless steel mesh to keep bearings in place. Last night while testing engine on balloon filled with gas it failed :(:(:(:( (glad I was testing with balloon though don't think flash would of gotten past bubbler and one way valve to cell). I rebuilt with new wool and tested by lighting gas coming out the end of a 6" long tube and all seemed well. Refitted and tried to start engine again. BOOOOOMMM !!!!!. Well I guess that didn't work to well then.
Here is the resulting damage to the bronze wool.
No idea why this should start happening all of a sudden, but think I need a new flashback arrestor. Any suggestions from you guys on what is the best to use would be appreciated.
John
Hi all, Ok have now managed to repair power supply and it's working better than ever :) so some progress this week. Still have to build new flashback arrestor and been scouring internet for ideas. Best design (IMO) that I have found so far is this:
https://www.youtube.com/watch?v=Wh9BwibvWSU
But I would like to hear your opinions on this design, or ideas for a better one, before I commit to building one, thanks in advance for any help on this.
I was also thinking of using Glass Beads (slightly smaller particles than sand) from my sandblaster instead of sand. Any thoughts on this ?
John
