(This post was edited from is original content.)
Thank you for all you have done so far, and I know you haven't stopped yet.
The point I was trying to make is - every atomic structure has it's own photon emission spectra. That is why a mass spectrometer works. By reading the emission spectra of a substance you can tell what it's made up of. Bill Williams can more than verify this. He can show you his own mass spectrometer.
So, depending on what you are using in your MEG or gas-gun determines what part of the spectrum you need to use.
I fully understand the how's and whys of photon to atom energy transference and am here to help - just like you.
:D
So, if anyone here needs to know exactly what wavelength of photon's to use in their device, all you need to do is tell me what gas and doping agent's you are using and I will tell you the parts of the spectrum you need - and do my best to hunt down the LED's or laser's for you.
The purpose of the electron extraction device is to extract electron from ionized atoms. The lower parts of the light spectrum will not ionize an atom. Only the upper parts of the spectrum will do that.
Case in point - with hydrogen in it's lowest energy state, infrared will move the electron within the shell but wont kick it out. Deep UV will kick out the electron. 91nm will instantly ionize the hydrogen proton when it's in it's lowest energy state, but getting a 91nm laser or LED is impossible unless I make the laser for you.
But, if you use the IR to move the H atom into a higher energy level, a 405nm will ionize the proton - so a 91nm laser isn't needed.
Once again - thank you for posting the links and for all you are doing.
Peace and light.
Mike.
I know that as a group working together - We Will Get This Done..
:D
Peace and light.
Mike.
