very dangerous radiant energy!!!who can tap and control it, will be like Tesla,Meyer,Puharich and Bob Boyce.
Now geenee, I want you to study what Bob says and think about this:
Bob initially was using a brute force electrolyzer cell powered by a standard three phase alternator, rectified down to DC. What he noticed is at a certain engine RPM, the performance of his boat went up noticeably. He later determined the anomaly to be a blown diode in the alternator's rectifier. This blown diode allowed AC current to mix with the DC current being feed to the cell. At a certain frequency of the mixed-in AC, the electrolyzer started to produce much more HHO than it ever did with straight DC. My point in repeating this is:
There are conditions that must be met and met in a particular order to produce the "Stan Meyer" effect above standard electrolysis. Think about it, the steps:
(FIRST) Bob's cell was already doing brute force.
(SECOND) An AC signal was being overlaid on top of the DC which began when the diode blew out.
(THIRD) When the AC frequency was increased (revving the engine), a particular resonance within the cell started the increased gas production.
I think in order for any of us to get a Stan Meyer water fuel cell to work, we have to follow those same steps. Start with brute force, overlay AC and adjust frequency until we find resonance. If we get that much to work, then and only then can we start backing off current, raising voltage and fine tuning the system. Also, I'm not convinced the cell having tubes is really necessary. Seems to me if we follow the process, regular plate cells should also have the same effect, just as it did for Bob Boyce.
My two cents. I'm completely happy to be proven wrong.
