Hi all.
now i think to calculate lpm requirement for engine.
pakistan inventor run a car(1200cc) use 20 lpm of hho gas.this is from my old thread.
meyer first run a car from water by 9 tubes alternator wfc version(about 3 lpm produce,15 psi meter).on idle,1600cc dune buggy, idle run 500-1000 rpm.
(1)if 1600cc run 80-100 km/h ,use about 6000 rpm.but drain gas 3000 rpm,for 4 stroke engine.
-that mean drain gas 1.6lites*3000 = 4800 LPM,if use hho 1% of that(4800LPM) = 48 LPM ,if use 0.5% =24 LPM.
(2)from idle run(1600cc),if idle at 1000 rpm,but drain gas 500 rpm,for 4 stroke engine.
-that mean drain gas 1.6lites*500 = 800 LPM,if use hho 1% of that = 8 LPM ,if use 0.5% =4 LPM.
(3)from idle run(1600cc),if idle at 500 rpm,but drain gas 250 rpm,for 4 stroke engine.
-that mean drain gas 1.6lites*500 = 400 LPM,if use hho 1% of that = 4 LPM ,if use 0.5% =2 LPM.
from (2)-(3) observed,if dune buggy run idle about 500-1000 rpm.that need hho about 2-4 LPM,this is reasonable for run a car from 3 lpm(9 tubes alternator wfc) on idle.
Do you think like me?Maybe i'm wrong?
thanks
geenee
thanks
geenee
