This is neat guy's. Check it out.:cool::D
https://www.youtube.com/watch?v=E97CYWlALEs&feature=related
This is used in the track system of high-speed lev trains. Aluminum instead of copper, and electromagnets instead of neos.
interesting, dØ/dt - possibly this works because the parameters are about right, enough flux, enough weight.
Here's the question, where is the reaction force coming from? OK it's magnetism but where is THAT coming from? :huh:
eddy currents...
its why we cant find a good way to generate power with out drag on a system...
you want to see something neat... check this out 45tesla Magnet...
watch the hole thing but look at 6 min in... takes a 2Kg aluminum chunk 2.5min to fall 12 feet... :)
https://www.youtube.com/watch?v=QGytW_C6hR8&feature=youtube_gdata_player
I tried dropping two magnets glued together (north to north) things really got slowed down going down copper pipe. You should check out anti-gravity-in a inter-view with Boyd Bushman that worked for Lockheed Martin-senior reseach scientist. It would be better for you to hear him tell of his reseach on magnets and gravity. enjoy fgunsmokeQuote from Jeff Nading on May 22nd, 2012, 02:44 PM This is neat guy's. Check it out.:cool::D
Hi All,
In nijmegen, holland they did research with magnetic fields
here they float a strawberry, they also did pieces of pizza and a frog (did no harm)
they locked in the frequency to water to levitate these items
So eBay really does have "everything" even things that don't exist. hehe :DQuote from Lynx on September 14th, 2012, 02:15 AM
Looks real to me. Anyone else wanna take a guess?
https://www.youtube.com/watch?v=RkLfpXpO5sQ&feature=player_embedded#!
Jeff-Have you checked out Boyd Bushman-retired senior research scientist of Lockheed Martin and what he did as a experiment with two magnets bolted together north to north?. It is on you-tube. Have you tried to glue two cheap magnet together and dropping them in copper tube? NORTH to North - or south to south? I don`t know if Russ has tried this but on his Leedskalnin TPU I built one like the small one he first did and it worked great. For the top bar -I used a soft iron bar out of a transformer. I then reversed the wiring on LED. The Led didn`t light when i jerk the bar off the bolt but it did light each time I put the bolt on with a tap. It didn`t need charged with a battery unless you wanted to lock the bar on- plus you would need to reverse the LED. You need to use a quick tap like the quick jerk when taking the bar off. this seem like a spike and doesn`t dim with use. I told someone on here about getting water to burn for me but that is the big thing I need to work on. Having a hard time moving around in here and finding my way back to the same place. fgunsmokeQuote from Jeff Nading on May 22nd, 2012, 02:44 PM This is neat guy's. Check it out.:cool::D
Do you have a link for that, thanks.:DQuote from fgunsmoke on September 28th, 2012, 03:23 PM I tried dropping two magnets glued together (north to north) things really got slowed down going down copper pipe. You should check out anti-gravity-in a inter-view with Boyd Bushman that worked for Lockheed Martin-senior reseach scientist. It would be better for you to hear him tell of his reseach on magnets and gravity. enjoy fgunsmokeQuote from Jeff Nading on May 22nd, 2012, 02:44 PM This is neat guy's. Check it out.:cool::D
Yes that's the same video.:D
