great book! thanks element 119!
it's a book that takes oyu right back to the basics. there are some really great experiments and a lot seems pretty parallel with a lot of ED's writings.
Edward Leedskalnin TPU
Today I watched Russ's video on his P.M.H. and I was inspired to build one myself. I found a 5/16 u bolt and welded 4 washers to it to wrap my coils between . I used telephone hookup wire, each coil has 189 wraps , both coils measure .8 ohms. I used a piece of old motor shaft key stock for the metal to bridge the gap in u bolt. After I figured out which end of either coil needed to be connected I charged the other 2 coil leads with a fresh 9v and it works great. I can't wait to run some tests.
The first thing I noticed was once charged and the metal is pulled off giving the coil the same polarity charge seems to result in a weaker hold as opposed to reversing the battery polarity every time I energize the coil. I plan on confirming this and running a few other tests. I made a trip to Ed's Coral Castle a few years back and I am fascinated at his work. Here is a pic of my build, later guys.
Just found this one today, pretty amazing!:
https://www.youtube.com/watch?v=v8TbqZa8li4&feature=related
this video is pretty need, and can work. It simple expands the magnetic field around the rock. like Ed said, everything is made of magnets. However, problem is, this has no effect on the weight. The rock would still be crazy heavy and his tripod would not pick the rock up ( i pretty sure anyways ). Also, moving the rock around into place would be difficult. One, because of the tripod in the way, and two, because the rock could easily break the field around it and fall if anything were to bump it. no evidence of any rock being broke.
i do like the video though. and glad to see people still working on this. Code144 forums is no longer up (although i did mirror the complete forum ) so i been looking for another active place to collectively consult. maybe this is a place to start. anyways, thats my 2 cents on the video.
freethisone
RE: Edward Leedskalnin TPU
« Reply #53, on December 13th, 2012, 08:00 PM »Last edited on December 14th, 2012, 08:03 AM by freethisone
Did he solve the problem of the PMH? I think he has the correct winding.:heart:
https://www.youtube.com/watch?v=gcfK0hfMKQI
https://www.youtube.com/watch?v=v2L7a1jMJNU
https://www.youtube.com/watch?v=NmYNi-k3-3U
Frank Grimes
« Reply #54, on December 13th, 2012, 09:39 PM »Last edited on December 13th, 2012, 09:41 PM by Frank Grimes
Can anyone tell me why I can't get the "Subscribe to this thread" function to work? I am getting the following message: Authorization code mismatch. Are you accessing this function correctly? Please go back and try again.:huh:
Quote from Frank Grimes on December 13th, 2012, 09:39 PM Well, now I seem to be subscribed.
freethisone
« Reply #55, on December 17th, 2012, 08:51 AM »Last edited on December 17th, 2012, 09:34 AM by freethisone
https://www.youtube.com/watch?v=ZdhibVRwmTghttps://www.youtub
https://www.youtube.com/watch?v=TlDGU05-nvk
you may need to sign in to youtube, or subscribe to see this link. His explanation is very good .we also saw this homo polar effect when magnaflipper posted the magnetic vortex effect of a permanent magnet..
looks like we have yet another secret reviled. Thanks MrAnguswangus you nailed it..
I had invited him to come to the forum.
He gives a good explanation, called a homo polar motor originally made by Faraday.
wooot GJ MrAnguswangus, :heart::cool:
I also include a link for you guys who are interested. https://www.google.com/search?q=faraday+homopolar+generator&hl=en&client=firefox-a&hs=sSf&sa=X&tbo=u&rls=org.mozilla:en-US:official&tbm=isch&source=univ&ei=0lDPUI_6LayB0QGSiICwBg&ved=
the cream the resistance, New patent using searl effect, called homo polar motor. wow.. I am not even sure professor Searl has any patents as of yet?
« Reply #56, on December 18th, 2012, 06:35 AM »Last edited on December 18th, 2012, 06:37 AM by Jeff Nading
This is cool freethisone, hope MrAnguswangus joins. Thanks for sharing.:cool::D:P
INSTEAD OF TRYING TO PULL OUT THE SECRET.
Ill just set you up with another link if any one is interested, the work on the corral castle has advanced many times over since i had tinkered with it.
http://www.conspiracy.co/forums/content/10-secret-egyptians-edward-leedskalnin-7129-610519
My one, and only contribution is related to his girl friend Agnes.
I think is girl was not real, i think it was only his labor of his work he had referred to.
Because she did not come to meet him at the alter he was disappointed.
sweet 16, valentine comet. Temple 1. so named by NASA. sweet 16.
Feb 16 equinox of 2010. I had confirmed this.
I think its best if you look for yourself what Ed had said.
"you will be seeing unusual accomplishment"
http://coralcastle.com/
For the most part, many secrets are ringing a bell of truth.:angel:
freethisone
« Reply #58, on December 20th, 2012, 07:18 PM »Last edited on December 20th, 2012, 07:22 PM by freethisone
something i want to add, has any one experimented with the Joseph Newman coils or motor?
if you have cool, but after i had saw this example of hit device i had said, wow look it has a connection to the center shaft. can you see it?
is this another homo polar motor developed by Faraday?
what do you think?
2 links for you. check it out for yourself.
Newman link Big Eureka - The Energy Machine of Joseph Newman.
https://www.youtube.com/watch?v=RMYo1QlvK5g
Homopolar Motor With Five Speed Manual Stick-Shift | Nikola Tesla
http://earthquake.usgs.gov/earthquakes/recenteqsww/Quakes/quakes_big.php
:angel::angel:
cheers.
what do you think?
:angel::angel:
cheers.
hi
these guys did something from this work
move a few magnets on the rotor and bam you have it
see here
http://www.zamandayolculuk.com
« Reply #60, on February 5th, 2013, 11:02 AM »Last edited on February 5th, 2013, 11:03 AM by Matt Watts
see here
http://www.zamandayolculuk.com/cetinbal/faradaydisk.htm
http://www.zamandayolculuk.com/cetinbal/Stardrive2.htm
« Reply #61, on February 6th, 2013, 03:35 AM »Last edited on February 6th, 2013, 04:33 AM by securesupplies
Sounds a lot like the N-Machine which I built years ago. I was told the voltage would be extremely low but the amperage would be very high requiring special brushes. The results of my experiment was that not only was the voltage very low, so was the amperage--far less than the power needed to turn the darn thing. I used a brass disc and whooper-sized neo magnets ($150 ea) too. Wrote the whole thing off as overblown hype. Surely I made some mistakes, but even still, I was orders of magnitude from the results I had hoped for. The basic prinicipals do seem correct, but the calculations for power output were seriously incorrect.Quote from securesupplies on February 5th, 2013, 06:22 AM these guys did something from this work
see here
dan
here is similar
'https://www.youtube.com/watch?feature=playe
http://www.johnsearlstory.com/
I haven't seen one like this before...
https://www.youtube.com/watch?v=eWSAcMoxITw
Something very powerful is holding those two pieces of metal together. Once you tear them apart and they no longer stick anymore, you have to ask yourself: Where on Earth did that energy go? If you took them apart inside a Faraday Cage, would that energy still be left inside the cage?Quote from firepinto on February 17th, 2013, 07:54 PM I haven't seen one like this before...
https://www.youtube.com/watch?v=SO3dXCsyBC4
So really these two bars in the first video have that double helix permanently flowing through it after the wire is shorted on the battery. What has my brain in a knot is, i imagined the original pmh had the double helix flowing through it following the path of the steel rod. With this one it dead ends on both ends and still works? Ed says the magnets flow faster through iron than air, so really a faraday cage would speed up this type of energy loss.
See. It is this kind of stuff that if we really understood it, we could build all sorts of really far out machines. It's just so hard to push all the other things out of the brain bucket and let some new things in. Another problem is we can't all sit in a classroom/laboratory with the likes of Ed Leedskalnin and learn it properly. So I guess we are stuck doing it the hard way--one experiment at a time.
Sterling posted a story about it here:
http://peswiki.com/index.php/Directory:Leedskalnin_%22Perpetual_Motion_Holder%22_%28PMH%29_Bond_Effect
He asked me to post my thoughts and review so he added my responce and videos in the story. Cool.
Any how, sweet idea I like it!!
https://www.youtube.com/watch?v=pIZx7WHBbl4
here is a guy who worked on Edd lee TPU.
but i liked this video, so i included it here.
it has more to do with electrical propagation speeds, but is very well made.
multiple flat top antenna.
cheers:dodgy:
hey russ. watch a lot of your videos, give a like when i remember too. very quietly intrigued though by all this sort of stuff.
does anyone know what happened with Mr Poole on youtube who overlaid the two of ed's book? so much for him having another video up soon haha
has anyone tried the way mr poole said and actually measured any current to find out if this overlay was a bit of a clue?
only just started reading up about ed today after hearing about coral castle a year or two ago. look forward to hearing more.
Brad
Brad
Brad
Published on Aug 30, 2013
https://www.youtube.com/watch?v=Ga4d0e0YGC8
freethisone
« Reply #72, on October 14th, 2013, 05:56 PM »Last edited on October 14th, 2013, 06:01 PM by freethisone
Bellow you will find R.L. Poole's latest video ...Quote from BradJJ on May 8th, 2013, 04:06 PM hey russ. watch a lot of your videos, give a like when i remember too. very quietly intrigued though by all this sort of stuff.
Brad
if a lotus flower has its peddles up and are pointed. would a coil wound in the shape of the flower and having its points of a flower as magnetic wire without a core. Plume waving( a generation of magnetic fields as a diffused flux)... Because only at these sharp points will there be an abundance of potential energy. Hmm i do like to theorize...:heart:
however when i see this overlay it reminds me of a harp string, it reminds me of the helix wound coil. dated back thousands of years.:idea:
freethisone
« Reply #73, on November 9th, 2013, 07:06 AM »Last edited on November 9th, 2013, 09:07 AM by freethisone
/watch?v=3x1_9HM28D8what did he do?
/watch?v=u0qWZRzprvw
:heart::heart:
our bud did make a new movie..:)
Spica
sPICa
hmm... /watch?v=Ga4d0e0YGC8
:heart::heart:
Spica
sPICa
freethisone
« Reply #74, on November 10th, 2013, 12:13 AM »Last edited on November 10th, 2013, 01:24 AM by freethisone
ground breaking stuff. sign up with this guy to get a private tutorial.
keep the forum informed.
https://www.youtube.com/watch?v=gMoWsgnbyd0:angel:
keep us posted .
simply spinning, simply stunning. he deserves all credit.
just look at the iron filings in the presents of a field magnet in motion. huge dipole alignments, and density..:P:P wow.
https://www.youtube.com/watch?v=Nm8SKwAEVDc
At 56 seconds, a magnetic wind effect..:cool: wow..
Quote from ~Russ/Rwg42985 on February 17th, 2013, 08:58 PM has anyone made a PMH, and use the wire technique rather then two coil technique like ed has done?:huh:
you need brute force separation of the pmh holder. a few good times to increase field strength.. like if i was to put the PMH holder between two truck bumpers and force them apart.
:cool:
you need to pull the bar off fast, several times. to get the magnetic current flowing in a field magnet, but this can be done with other types of field magnets also. advance..
the cover on eds flywheel is a shield also. and a means to short the inside of the flywheel.
keep us posted .
:cool:
