While helping Dan document the VIC board, I learned more about one of the Patches on Stan’s VIC board. I do not have that patch in my test systems as I build all my boards from schematics, so they are not an exact duplicated of Stan’s VIC.
I could see where the patch was connected but I wanted to see what it does to the signals. It turns it is pretty easy to install patch on by test setup as I used screw connectors and have easy access to multiple points on the board including the ones used in the patch.
The patch hooks up to the 4x switch position “1X” (which comes from pin 4 of the 4046 chip). This signal is the high frequency digital signal and contains the gate.
Patch runs from 1x to a 22K resistor connected to ground through 0.22uF capacitor, capacitor is on the same side as the input. The output of the resistor is connected, to PRI-S on the input side of the diode 1N5408, which places it between the Primary coil and diode.
In my test system I hooked up the capacitor and resistor with a couple of patch cords to do test so I could add it and remove it easily so I could see what changes.
Test setup. I have a baseline frequency and gate of 41.67hz which is also the baseline analog frequency. Gate is set to 50% duty cycle. The offset and gain is set to minimum levels that I have been using for most of testing. Frequency to the digital signal is set to 1khz and did not change any of these value during the tests.
For initial test I have scope probe inputs set to DC offset.
CH1- Yellow it the digital side of primary F+
CH2- Bule is the analog side of primary S-
Picture 1 show the input to the primary without the patch and is what I typical see for these settings. I have set levels to 1V for both sides so you can see the ramp on the analog channels.
Picture 2 is with the patch hooked up. No other changes I wanted to show ramp on analog signal is still there. (Hard to see on high scale setting on the scope).
Picture 3 is the same as picture 2 with scope scale set to 5V for both channels no other changes.
Picture 4 is the same as picture 2 but zoomed in
Picture 5 is the same as picture 2 but zoomed in even closer
Picture 6 I did not change setup but did put my differential Probe on CH2 scope probe is set to 100 but probe is 200 so reading off by a factor of 2. I want to show what signal to cell looks like. This is without patch. CH1 is still hooked to primary input and provide scope sync reference.
Picture 7 same setting as picture 6 but with patch installed. Notice that the signal across cell does not appear to change.
Picture 8 is the same as P7 but zoomed in.
One other thing I noticed is the lock light was now flickering when it was not before.
