Engine Builds
Engine Builds
« on September 4th, 2019, 07:25 AM »Last edited on September 4th, 2019, 07:30 AM
New Thread for Engine Builds
Sharing ideas for engine builds
This one is  Cummins 6 cylinder  50 kw unit engine over spec for power
Re: Engine Builds
« Reply #1, on September 4th, 2019, 07:34 AM »
i post  so people with engine know how can see the  basic method
rail is from  1 bar to 5 bar
ecu is custom
injectors high flow custom
turbo egr and erg cooler custom
positive earthed  block
ionzed intake with  air gate check valve
crank crank case , manifolds and rocker covers with  blow off valves
lan wifi and gps system by siemens
swagelok fittings and fueling custom
flash arrestors germany with filters all NPT - f thread
fuel line  3/8  tube alloy non magnetic
Distributor ( dizzy)  led
the alternator is positive earth ground modified in uk
the oil system and coolign is basic standard
performance will be 120% over gasoline using h2 from tanks or from on demand
Re: Engine Builds
« Reply #2, on September 5th, 2019, 08:47 AM »Last edited on September 5th, 2019, 10:20 AM
EGR Plans  we scale op egr cooler and the  tube sizes to mix with h2
Re: Engine Builds
« Reply #3, on September 14th, 2019, 09:40 PM »Last edited on September 14th, 2019, 09:42 PM
Designing the Water Loop EGR
Yes we  can Tesla quantified the effectiveness of the device by calculating the ratio of resistance in one direction compared to the other. He made the bold claim that “The resistance in the reverse may be 200 times that in the normal direction […] so that the device acts as a slightly leaking valve.”
We have option to put a More Advanced Reverse EGR Cooler Box Also
I am making ans Selling such exhaust water catch Boxes at this time
